Other Parts Discussed in Thread: BQ76940, BQ78350-R1, BQ76930, BQ76200
Hi Kanidu,
An external Micro-controller is not required. The BQ76940 battery monitor IC does require a controller, but the BQ78350-R1 device is used for this purpose on TIDA-00792.
If you want to use 6 cells in series, I recommend using the same TI design, but use the BQ76930 (10S) instead of the BQ76940 (15S).
The continuous current is determined by the sense resistor and FET selection. Many applications use multiple FETs in parallel to handle higher currents. There is an app note on the BQ76200 that shows many examples. https://www.ti.com/lit/pdf/slva729
The datasheet for the BQ76940 has a section on how to connect the unused cell inputs. See section 11.1 of the datasheet.
This video might be helpful: https://training.ti.com/how-create-schematic-bq76920-bq76930-and-bq76940
Matt
