Hi team,
My PSpice-for-TI always shutdown unexpectedly if I start run simulation.
Please check attached project and crashdump.dmp in "capture28559062" folder.
regards,
Hi team,
regards,
HI Fujihara-san,
Does the crash happen consistently? If so, would you please zip up the "capture???" folder (the name changes) next time it happens? As it is in the windows TEMP directory, it may have been deleted by Windows already.
JC
Hi team,
I uninstalled old version and re-installed 17.4-2020 S004, now I found another issue.
When I try to open or create simulation profile, the empty dialog always pop-up, and I can't edit it.
It happens regardless with type of project, so I suppose it's something to do with tool itself.
Could you support to solve this?
Hi JC-san,
I tried the project, but I see same result.
I couldn't open simulation setup window (empty dialog only).
This error happens regardless project.
Could you show how to try S003 instead of S004?
best regards,
Thanks JC-san,
I could successfully run simulation by taking below steps before re-install TI-PSPICE.
Use control panel to delete your PSpice for TI.
a. %HOME%\cdssetup\OrCAD_CaptureTIPSpice_Install
b .%HOME%\cdssetup\OrCAD_PSpiceTIPSpice_Install
c.%HOME%\cdssetup\pspTILibDir
Nobuo
