I am trying to install PSpice for TI design and simulation tool. While installing, I got the below error. Can I please be helped to install the software?
Could you please show me your installation log? It is located at %APPDATA%/Roaming/Cadence/PSpiceTIInstall/cdsPspiceTIlog.txt
Could you also please check what text is shown on this page: https://cdsplicwc.cadence.com/chws/test/connection.html
If it says "successful connection," then your network connection is not the issue. If it displays other text, please let me know.
Thank you,
Jackie
Hi Jackie,
Thank you for the quick response.
11:06:55 09 March 2021 : Response Content length = 1724 11:06:55 09 March 2021 : C:\Users\kzk\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:06:55 09 March 2021 : Reading Json URL File 11:06:55 09 March 2021 : Setting TI Library URL from Json URL File 11:06:55 09 March 2021 : Reading Json URL File 11:06:55 09 March 2021 : setting media download server URL from Json File 11:06:55 09 March 2021 : Reading Json URL File 11:06:55 09 March 2021 : setting Dll path from Json File 11:06:55 09 March 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:06:55 09 March 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:06:55 09 March 2021 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip 11:06:56 09 March 2021 : parameter count = 1 11:06:56 09 March 2021 : -wrapper 11:06:57 09 March 2021 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system: 11:07:28 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:07:28 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:08:22 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:08:22 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:08:26 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:08:26 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:10:33 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:10:33 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:10:35 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:10:35 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:10:37 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:10:37 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:10:38 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:10:38 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:11:07 09 March 2021 : Deleting file : C:\Users\kzk\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 11:11:07 09 March 2021 : Response Content length = 1724 11:11:07 09 March 2021 : C:\Users\kzk\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:11:07 09 March 2021 : Reading Json URL File 11:11:07 09 March 2021 : Setting TI Library URL from Json URL File 11:11:07 09 March 2021 : Reading Json URL File 11:11:07 09 March 2021 : setting media download server URL from Json File 11:11:07 09 March 2021 : Reading Json URL File 11:11:07 09 March 2021 : setting Dll path from Json File 11:11:07 09 March 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:11:07 09 March 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:11:07 09 March 2021 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip 11:11:08 09 March 2021 : parameter count = 1 11:11:08 09 March 2021 : -wrapper 11:11:09 09 March 2021 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system: 11:13:37 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:13:37 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1) 11:56:37 09 March 2021 : error_code cdsVblRegisterInstallation: VblInternalError 11:56:37 09 March 2021 : strErrorMsgDesc: An Internal error occurred. Please go to http://e2e.ti.com for further assistance. (-1)
Please find attached installation log.
I have got the "connection successful" message on the link you sent.
Keerthi
Hi Keerthi,
Thanks for the file. we'll review this and get back to you.
JC
Hello Keerthi,
Unfortunately, we have not yet received further information from Cadence. We will contact you when we do.
Thank you,
Jackie
Hello Keerthi,
We have further information from Cadence. I have attempted to contact you privately through this forum.
Thank you,
Jackie
Hi Jackie,
Thanks a lot for the effort taken. I tried to follow the download link couple of times, it finally got installed the third time.
Keerthi
Thank you for letting me know. I'm glad you were able to install PSpice for TI. Did you change any settings or your network connection? It is odd that it didn't work for you every time. Thank you again,
Jackie
Hi Jackie,
I tried to install from office Wifi, I personally didn't do any change. I tried to follow all the instructions again after 3 days. It worked.
Keerthi
