I want to use the TPS3808G01 model in simulation, but the model has no GND pin. How to use it?
Hi, thanks for your reply. I got it running in a simple simulation only using the TPS3808 but in combination with other parts I have troubles with unexpected results.
The solution was to remove nom_pspti.lib from the library configuration and add only the required libraries.
After that the simulation successfully run ant that much faster. So I think there are more conflicts with internal models and the nom_pspti.lib
Hi Andreas,
Thank you for providing feedback regarding the models. This particular model was developed some time ago and with the new PSPICE for TI program, the transition may have gone through some difficulties.
I am glad to hear that you are up and running now.
Ben
