PSPICE-FOR-TI: PSPICE Crashes On Open
Part Number: PSPICE-FOR-TI
I'm trying to run PSPICE for TI, but I am not able to open the program. I've tried a couple times from fresh installs, and every time I install the program and go to open it, I get the following error message:
How can I fix this? I don't have an archived project to submit, as the prompt suggests, because I've never been able to open the software.
  • Hello Matthew,
    Can you please share the installation log? It can be found at %appdata%\Cadence\PSpiceTIInstall\cdsPspiceTIlog.txt. %appdata% is a system variable which you can just type into the file manager.
    Are you connected to the internet while opening PSpice for TI?
    Thank you,
    Jackie
  • Hi Jackie,
    Yes, I am connected to the internet during the installation and while opening Spice.
    Attached is the log file you requested.
    Thank you.
    6545.cdsPspiceTIlog.txt
    10:36:08 AM Tuesday, March 30, 2021 : Response Content length = 1724
    10:36:08 AM Tuesday, March 30, 2021 : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
    10:36:08 AM Tuesday, March 30, 2021 : Reading Json URL File
    10:36:08 AM Tuesday, March 30, 2021 : Setting TI Library URL from Json URL File
    10:36:08 AM Tuesday, March 30, 2021 : setting media download server URL from Json File
    10:36:08 AM Tuesday, March 30, 2021 : setting Dll path from Json File
    10:36:08 AM Tuesday, March 30, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    10:36:08 AM Tuesday, March 30, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    10:36:08 AM Tuesday, March 30, 2021 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip
    10:36:09 AM Tuesday, March 30, 2021 : parameter count = 1
    10:36:09 AM Tuesday, March 30, 2021 : -wrapper
    10:36:09 AM Tuesday, March 30, 2021 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system:
    10:36:54 AM Tuesday, March 30, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
    10:36:54 AM Tuesday, March 30, 2021 : error_code cdsVblRequestLicense: VblSuccess
    10:36:58 AM Tuesday, March 30, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
    10:36:58 AM Tuesday, March 30, 2021 : Setting default working directory : C:\SPB_Data
    10:37:01 AM Tuesday, March 30, 2021 : Checking for memory space
    10:37:01 AM Tuesday, March 30, 2021 : Memory space available
    10:37:01 AM Tuesday, March 30, 2021 : Target Dir: C:\Cadence\PSpiceTI
    10:37:01 AM Tuesday, March 30, 2021 : Working Dir: C:\SPB_Data
    10:37:04 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
    10:37:04 AM Tuesday, March 30, 2021 : Starting download of setup.inx   Attempt no 1 DataSize is 558491
    10:37:04 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
    10:37:04 AM Tuesday, March 30, 2021 : Starting download of setup.ini   Attempt no 1 DataSize is 2440
    10:37:04 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
    10:37:04 AM Tuesday, March 30, 2021 : Completing download of setup.ini
    10:37:04 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
    10:37:04 AM Tuesday, March 30, 2021 : Completing download of setup.inx
    10:37:06 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
    10:37:06 AM Tuesday, March 30, 2021 : Starting download of data1.cab   Attempt no 1 DataSize is 31725431
    10:37:07 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
    10:37:07 AM Tuesday, March 30, 2021 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
    10:37:07 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
    10:37:07 AM Tuesday, March 30, 2021 : Completing download of 0x0409.ini
    10:37:08 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
    10:37:08 AM Tuesday, March 30, 2021 : Starting download of data1.hdr   Attempt no 1 DataSize is 4250556
    10:37:11 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
    10:37:12 AM Tuesday, March 30, 2021 : Completing download of data1.hdr
    10:37:13 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
    10:37:13 AM Tuesday, March 30, 2021 : Starting download of data2.cab   Attempt no 1 DataSize is 170870784
    10:37:14 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
    10:37:14 AM Tuesday, March 30, 2021 : Completing download of data1.cab
    10:37:15 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
    10:37:15 AM Tuesday, March 30, 2021 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1634216
    10:37:16 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
    10:37:17 AM Tuesday, March 30, 2021 : Completing download of ISSetup.dll
    10:37:19 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
    10:37:19 AM Tuesday, March 30, 2021 : Starting download of layout.bin   Attempt no 1 DataSize is 886
    10:37:19 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
    10:37:19 AM Tuesday, March 30, 2021 : Completing download of layout.bin
    10:37:22 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
    10:37:22 AM Tuesday, March 30, 2021 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
    10:37:23 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
    10:37:23 AM Tuesday, March 30, 2021 : Completing download of pspInstall.pdf
    10:37:26 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
    10:37:26 AM Tuesday, March 30, 2021 : Starting download of setup.bmp   Attempt no 1 DataSize is 552056
    10:37:26 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
    10:37:26 AM Tuesday, March 30, 2021 : Completing download of setup.bmp
    10:37:28 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
    10:37:28 AM Tuesday, March 30, 2021 : Starting download of data7.cab   Attempt no 1 DataSize is 8329915
    10:37:33 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
    10:37:33 AM Tuesday, March 30, 2021 : Completing download of data7.cab
    10:37:35 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
    10:37:35 AM Tuesday, March 30, 2021 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
    10:38:25 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
    10:38:25 AM Tuesday, March 30, 2021 : Completing download of data2.cab
    10:38:28 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
    10:38:28 AM Tuesday, March 30, 2021 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
    10:39:38 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
    10:39:39 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
    10:39:40 AM Tuesday, March 30, 2021 : Completing download of data5.cab
    10:39:41 AM Tuesday, March 30, 2021 : Completing download of data6.cab
    10:39:43 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
    10:39:43 AM Tuesday, March 30, 2021 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
    10:39:44 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
    10:39:44 AM Tuesday, March 30, 2021 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
    10:41:06 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
    10:41:08 AM Tuesday, March 30, 2021 : Completing download of data4.cab
    10:41:11 AM Tuesday, March 30, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
    10:41:11 AM Tuesday, March 30, 2021 : Starting download of installsetup.exe   Attempt no 1 DataSize is 951208
    10:41:12 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
    10:41:13 AM Tuesday, March 30, 2021 : Completing download of installsetup.exe
    10:41:22 AM Tuesday, March 30, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
    10:41:24 AM Tuesday, March 30, 2021 : Library URL: https://software-dl.ti.com/pspice/esd/models/library/library.zip
    10:41:25 AM Tuesday, March 30, 2021 : Response Content length = 93468223
    10:41:46 AM Tuesday, March 30, 2021 : Comparing content length
    10:41:46 AM Tuesday, March 30, 2021 : Content Match Success.
    10:41:46 AM Tuesday, March 30, 2021 : C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip bytes downloaded = 93468223
    10:41:46 AM Tuesday, March 30, 2021 : Lib downloaded sucessfully at: C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip
    10:41:46 AM Tuesday, March 30, 2021 : Completing download of data3.cab
    10:41:46 AM Tuesday, March 30, 2021 : 5113548 5113548
    10:41:46 AM Tuesday, March 30, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
    10:41:47 AM Tuesday, March 30, 2021 : Allegro Installation Start pid: 18840
    10:42:04 AM Tuesday, March 30, 2021 : NumberOfComponentsToBeInstalled = 34906
    10:42:04 AM Tuesday, March 30, 2021 : Updated NumberOfComponentsToBeInstalled = 35608.56
    10:42:04 AM Tuesday, March 30, 2021 : Updated NumberOfComponentsInstalled = 350
    10:49:45 AM Tuesday, March 30, 2021 : Feature transfer complete..disabling close button
    10:49:46 AM Tuesday, March 30, 2021 : Installing: Runtime packages and redistributables
    10:50:21 AM Tuesday, March 30, 2021 : Installing: Configuring documentation
    10:50:27 AM Tuesday, March 30, 2021 : Installing: Configuring file associations
    10:50:30 AM Tuesday, March 30, 2021 : Installing: Setting permissions for files and folders
    10:50:49 AM Tuesday, March 30, 2021 : Installing: Creating Registries
    10:50:49 AM Tuesday, March 30, 2021 : Installing: SQL Lite ODBC Driver
    10:50:58 AM Tuesday, March 30, 2021 : Installing: Finishing Installation
    10:51:19 AM Tuesday, March 30, 2021 : Unzipping Library start
    10:51:19 AM Tuesday, March 30, 2021 : ExtractZipFile start:
    10:51:19 AM Tuesday, March 30, 2021 : Extraction command: C:\Cadence\PSpiceTI\tools\bin\cdsUnzip.exe -o "C:\Cadence\PSpiceTI\PSpiceTI\Lib\library.zip" -d "C:\SPB_Data\cdssetup\pspTILibDir"
    10:55:38 AM Tuesday, March 30, 2021 : Unzipping finished
    10:55:38 AM Tuesday, March 30, 2021 : Downloading License file
    10:55:38 AM Tuesday, March 30, 2021 : error_code cdsVblDownloadLicense: VblSuccess
    10:55:38 AM Tuesday, March 30, 2021 : Downloading License file finish
    10:55:38 AM Tuesday, March 30, 2021 : PrepareUninstallation
    10:55:38 AM Tuesday, March 30, 2021 : strLocalPath: C:\Users\manauo.AD\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
    10:55:38 AM Tuesday, March 30, 2021 : strLocalConfigPath: C:\Users\manauo.AD\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
    10:55:38 AM Tuesday, March 30, 2021 : strCachedLocForFV174Installer: "C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
    10:55:38 AM Tuesday, March 30, 2021 : ClearRunOnceIfNotNeeded()
    10:55:38 AM Tuesday, March 30, 2021 : installSetupValue =
    10:56:32 AM Tuesday, March 30, 2021 : Capture Viewer
    11:45:40 AM Tuesday, April 13, 2021 : Deleting file : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
    11:45:40 AM Tuesday, April 13, 2021 : Response Content length = 1724
    11:45:40 AM Tuesday, April 13, 2021 : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
    11:45:40 AM Tuesday, April 13, 2021 : Reading Json URL File
    11:45:40 AM Tuesday, April 13, 2021 : Setting TI Library URL from Json URL File
    11:45:40 AM Tuesday, April 13, 2021 : setting media download server URL from Json File
    11:45:40 AM Tuesday, April 13, 2021 : setting Dll path from Json File
    11:45:40 AM Tuesday, April 13, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    11:45:40 AM Tuesday, April 13, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    11:45:40 AM Tuesday, April 13, 2021 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip
    11:45:40 AM Tuesday, April 13, 2021 : TI Launched in uninstallation mode as remove found in command line
    11:45:40 AM Tuesday, April 13, 2021 : Message: Do you want to completely remove the selected application and all of its features?
    11:45:47 AM Tuesday, April 13, 2021 : Target Dir: C:\Cadence\PSpiceTI
    11:45:47 AM Tuesday, April 13, 2021 : Working Dir: C:\SPB_Data
    11:45:47 AM Tuesday, April 13, 2021 : Uninstallation exe path ctor: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}
    11:45:47 AM Tuesday, April 13, 2021 : Uninstallation exe path: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\installsetup.exe
    11:45:47 AM Tuesday, April 13, 2021 : 22678402 22678402
    11:45:47 AM Tuesday, April 13, 2021 : Setup EXE Argument: /hide_progress /hide_splash DMHandle="22678402"  -Wrapper Uninstall !Quiet="C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\silentinstall-TI.ini"
    11:45:57 AM Tuesday, April 13, 2021 : Message 1004: Uninstalling: Removing files from Firewall Exceptions
    11:46:23 AM Tuesday, April 13, 2021 : Message 1004: Uninstalling: Removing shortcuts
    11:46:23 AM Tuesday, April 13, 2021 : NumberOfComponentsToBeInstalled = 34906
    11:46:23 AM Tuesday, April 13, 2021 : Updated NumberOfFeaturesToBeUninstalled = 36303
    11:46:23 AM Tuesday, April 13, 2021 : Updated NumberOfFeaturesUninstalled = 1397
    11:46:23 AM Tuesday, April 13, 2021 : Message 1004: Uninstalling: Uninstalling files
    11:47:29 AM Tuesday, April 13, 2021 : Message 1002: Uninstalling: Finishing Uninstallation
    11:47:42 AM Tuesday, April 13, 2021 : uninstallation sucessfull
    11:47:42 AM Tuesday, April 13, 2021 : Clearing Registry: TIPSpice.Resources.Email.reg
    11:47:42 AM Tuesday, April 13, 2021 : Cleared Registry settings
    11:47:42 AM Tuesday, April 13, 2021 : This installation requires a reboot.
    11:40:03 AM Tuesday, April 20, 2021 : Initializing
    11:40:03 AM Tuesday, April 20, 2021 : Deleting file : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
    11:40:03 AM Tuesday, April 20, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
    11:40:04 AM Tuesday, April 20, 2021 : Response Content length = 1724
    11:40:04 AM Tuesday, April 20, 2021 : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
    11:40:04 AM Tuesday, April 20, 2021 : Reading Json URL File
    11:40:04 AM Tuesday, April 20, 2021 : setting media download server URL from Json File
    11:40:04 AM Tuesday, April 20, 2021 : setting Dll path from Json File
    11:40:04 AM Tuesday, April 20, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    11:40:04 AM Tuesday, April 20, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    11:40:04 AM Tuesday, April 20, 2021 : parameter count = 1
    11:40:04 AM Tuesday, April 20, 2021 : -wrapper
    11:40:04 AM Tuesday, April 20, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system:
    11:40:16 AM Tuesday, April 20, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
    11:40:16 AM Tuesday, April 20, 2021 : error_code cdsVblRequestLicense: VblSuccess
    11:40:20 AM Tuesday, April 20, 2021 : Set Installation and Home Directory()
    11:40:20 AM Tuesday, April 20, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
    11:40:20 AM Tuesday, April 20, 2021 : Reading CDS_HOME environment variable
    11:40:20 AM Tuesday, April 20, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
    11:40:20 AM Tuesday, April 20, 2021 : First time installation. CDS_HOME will be set to default HOME directory.
    11:40:20 AM Tuesday, April 20, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it.
    11:40:20 AM Tuesday, April 20, 2021 : Creating directory : C:\cds_spb_home
    11:40:22 AM Tuesday, April 20, 2021 : Checking for memory space
    11:40:22 AM Tuesday, April 20, 2021 : Memory space available
    11:40:22 AM Tuesday, April 20, 2021 : Target Dir: C:\Cadence\PSpiceTI
    11:40:22 AM Tuesday, April 20, 2021 : Working Dir: C:\cds_spb_home
    11:40:22 AM Tuesday, April 20, 2021 : Silent ini file created
    11:40:26 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
    11:40:26 AM Tuesday, April 20, 2021 : Starting download of data1.cab   Attempt no 1 DataSize is 31723644
    11:40:26 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
    11:40:26 AM Tuesday, April 20, 2021 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
    11:40:26 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
    11:40:26 AM Tuesday, April 20, 2021 : Completing download of 0x0409.ini
    11:40:28 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
    11:40:28 AM Tuesday, April 20, 2021 : Starting download of data1.hdr   Attempt no 1 DataSize is 4968262
    11:40:30 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
    11:40:30 AM Tuesday, April 20, 2021 : Completing download of data1.cab
    11:40:30 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
    11:40:30 AM Tuesday, April 20, 2021 : Completing download of data1.hdr
    11:40:32 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
    11:40:32 AM Tuesday, April 20, 2021 : Starting download of data2.cab   Attempt no 1 DataSize is 170137600
    11:40:32 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
    11:40:32 AM Tuesday, April 20, 2021 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637864
    11:40:33 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
    11:40:33 AM Tuesday, April 20, 2021 : Completing download of ISSetup.dll
    11:40:35 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
    11:40:35 AM Tuesday, April 20, 2021 : Starting download of layout.bin   Attempt no 1 DataSize is 994
    11:40:35 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
    11:40:35 AM Tuesday, April 20, 2021 : Completing download of layout.bin
    11:40:37 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
    11:40:37 AM Tuesday, April 20, 2021 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
    11:40:37 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
    11:40:37 AM Tuesday, April 20, 2021 : Completing download of pspInstall.pdf
    11:40:39 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
    11:40:39 AM Tuesday, April 20, 2021 : Starting download of setup.bmp   Attempt no 1 DataSize is 552056
    11:40:39 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
    11:40:39 AM Tuesday, April 20, 2021 : Completing download of setup.bmp
    11:40:40 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
    11:40:40 AM Tuesday, April 20, 2021 : Starting download of setup.ini   Attempt no 1 DataSize is 2440
    11:40:40 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
    11:40:40 AM Tuesday, April 20, 2021 : Completing download of setup.ini
    11:40:43 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
    11:40:43 AM Tuesday, April 20, 2021 : Starting download of setup.inx   Attempt no 1 DataSize is 571158
    11:40:43 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
    11:40:43 AM Tuesday, April 20, 2021 : Completing download of setup.inx
    11:40:44 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
    11:40:44 AM Tuesday, April 20, 2021 : Starting download of data9.cab   Attempt no 1 DataSize is 76919236
    11:40:58 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
    11:40:58 AM Tuesday, April 20, 2021 : Completing download of data9.cab
    11:40:59 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
    11:41:00 AM Tuesday, April 20, 2021 : Completing download of data2.cab
    11:41:00 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
    11:41:00 AM Tuesday, April 20, 2021 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
    11:41:03 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
    11:41:03 AM Tuesday, April 20, 2021 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
    11:41:44 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
    11:41:45 AM Tuesday, April 20, 2021 : Completing download of data4.cab
    11:41:47 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
    11:41:47 AM Tuesday, April 20, 2021 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
    11:41:48 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
    11:41:49 AM Tuesday, April 20, 2021 : Completing download of data3.cab
    11:41:50 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
    11:41:50 AM Tuesday, April 20, 2021 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
    11:42:30 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
    11:42:31 AM Tuesday, April 20, 2021 : Completing download of data5.cab
    11:42:33 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
    11:42:34 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
    11:42:34 AM Tuesday, April 20, 2021 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
    11:42:34 AM Tuesday, April 20, 2021 : Completing download of data6.cab
    11:42:36 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
    11:42:36 AM Tuesday, April 20, 2021 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
    11:43:13 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
    11:43:14 AM Tuesday, April 20, 2021 : Completing download of data7.cab
    11:43:17 AM Tuesday, April 20, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
    11:43:17 AM Tuesday, April 20, 2021 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954856
    11:43:17 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
    11:43:17 AM Tuesday, April 20, 2021 : Completing download of installsetup.exe
    11:43:18 AM Tuesday, April 20, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
    11:43:18 AM Tuesday, April 20, 2021 : Completing download of data8.cab
    11:43:18 AM Tuesday, April 20, 2021 : 5311612 5311612
    11:43:18 AM Tuesday, April 20, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
    11:43:19 AM Tuesday, April 20, 2021 : Allegro Installation Start pid: 22500
    11:43:28 AM Tuesday, April 20, 2021 : NumberOfComponentsToBeInstalled = 39559
    11:43:28 AM Tuesday, April 20, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55
    11:43:28 AM Tuesday, April 20, 2021 : Updated NumberOfComponentsInstalled = 396
    11:50:22 AM Tuesday, April 20, 2021 : Feature transfer complete..disabling close button
    11:50:22 AM Tuesday, April 20, 2021 : Installing: Runtime packages and redistributables
    11:50:42 AM Tuesday, April 20, 2021 : Installing: Configuring documentation
    11:50:43 AM Tuesday, April 20, 2021 : Installing: Configuring file associations
    11:50:44 AM Tuesday, April 20, 2021 : Installing: Setting permissions for files and folders
    11:50:50 AM Tuesday, April 20, 2021 : Installing: Creating Registries
    11:50:50 AM Tuesday, April 20, 2021 : Installing: SQL Lite ODBC Driver
    11:50:52 AM Tuesday, April 20, 2021 : Installing: Finishing Installation
    11:51:09 AM Tuesday, April 20, 2021 : Running Library Configuration Executable
    11:51:09 AM Tuesday, April 20, 2021 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
    11:54:50 AM Tuesday, April 20, 2021 : orLibraryDownLoad.exe returned : 0
    11:54:50 AM Tuesday, April 20, 2021 : Library Installation completed successfully.
    11:54:50 AM Tuesday, April 20, 2021 : Downloading License file
    11:54:51 AM Tuesday, April 20, 2021 : error_code cdsVblDownloadLicense: VblSuccess
    11:54:51 AM Tuesday, April 20, 2021 : Downloading License file finish
    11:54:51 AM Tuesday, April 20, 2021 : PrepareUninstallation
    11:54:51 AM Tuesday, April 20, 2021 : strLocalPath: C:\Users\manauo.AD\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
    11:54:51 AM Tuesday, April 20, 2021 : strCachedLocForFV174Installer: "C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
    11:54:51 AM Tuesday, April 20, 2021 : ClearRunOnceIfNotNeeded()
    11:54:51 AM Tuesday, April 20, 2021 : installSetupValue =
    11:56:35 AM Tuesday, April 20, 2021 : Capture Viewer
    11:56:35 AM Tuesday, April 20, 2021 : Deleting installation files
    11:57:07 AM Tuesday, April 20, 2021 : TI Launched in uninstallation mode as remove found in command line
    11:57:07 AM Tuesday, April 20, 2021 : Message: Do you want to completely remove the selected application and all of its features?
    11:57:09 AM Tuesday, April 20, 2021 : Target Dir: C:\Cadence\PSpiceTI
    11:57:09 AM Tuesday, April 20, 2021 : Working Dir:
    11:57:09 AM Tuesday, April 20, 2021 : Silent ini file created
    11:57:09 AM Tuesday, April 20, 2021 : Uninstallation exe path ctor: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}
    11:57:09 AM Tuesday, April 20, 2021 : Uninstallation exe path: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\installsetup.exe
    11:57:09 AM Tuesday, April 20, 2021 : 1970822 1970822
    11:57:09 AM Tuesday, April 20, 2021 : Setup EXE Argument: /hide_progress /hide_splash DMHandle="1970822"  -Wrapper Uninstall !Quiet="C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\silentinstall-TI.ini"
    11:57:18 AM Tuesday, April 20, 2021 : Message 1004: Uninstalling: Removing files from Firewall Exceptions
    11:57:45 AM Tuesday, April 20, 2021 : Message 1004: Uninstalling: Removing shortcuts
    11:57:45 AM Tuesday, April 20, 2021 : NumberOfComponentsToBeInstalled = 39559
    11:57:45 AM Tuesday, April 20, 2021 : Updated NumberOfFeaturesToBeUninstalled = 41142
    11:57:45 AM Tuesday, April 20, 2021 : Updated NumberOfFeaturesUninstalled = 1583
    11:57:45 AM Tuesday, April 20, 2021 : Message 1004: Uninstalling: Uninstalling files
    11:59:13 AM Tuesday, April 20, 2021 : Message 1002: Uninstalling: Finishing Uninstallation
    11:59:27 AM Tuesday, April 20, 2021 : uninstallation sucessfull
    11:59:27 AM Tuesday, April 20, 2021 : Clearing Registry: TIPSpice.Resources.Email.reg
    11:59:27 AM Tuesday, April 20, 2021 : Cleared Registry settings
    11:59:27 AM Tuesday, April 20, 2021 : This installation requires a reboot.
    7:11:20 AM Thursday, June 3, 2021 : Initializing
    7:11:20 AM Thursday, June 3, 2021 : Deleting file : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
    7:11:20 AM Thursday, June 3, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
    7:11:20 AM Thursday, June 3, 2021 : Response Content length = 1724
    7:11:20 AM Thursday, June 3, 2021 : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
    7:11:20 AM Thursday, June 3, 2021 : Reading Json URL File
    7:11:20 AM Thursday, June 3, 2021 : setting media download server URL from Json File
    7:11:20 AM Thursday, June 3, 2021 : setting Dll path from Json File
    7:11:20 AM Thursday, June 3, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    7:11:20 AM Thursday, June 3, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    7:11:20 AM Thursday, June 3, 2021 : parameter count = 1
    7:11:20 AM Thursday, June 3, 2021 : -wrapper
    7:11:21 AM Thursday, June 3, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system:
    7:11:37 AM Thursday, June 3, 2021 : error_code cdsVblRegisterInstallation: -8
    7:11:37 AM Thursday, June 3, 2021 : strErrorMsgDesc: Access key entered is not in expected format. Please go to http://e2e.ti.com for further assistance.
    7:11:54 AM Thursday, June 3, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
    7:11:54 AM Thursday, June 3, 2021 : error_code cdsVblRequestLicense: VblSuccess
    7:11:56 AM Thursday, June 3, 2021 : Set Installation and Home Directory()
    7:11:56 AM Thursday, June 3, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
    7:11:56 AM Thursday, June 3, 2021 : Reading CDS_HOME environment variable
    7:11:56 AM Thursday, June 3, 2021 : CDS_HOME is present and set to C:\cds_spb_home. No need to set CDS_HOME
    7:11:59 AM Thursday, June 3, 2021 : Checking for memory space
    7:11:59 AM Thursday, June 3, 2021 : Memory space available
    7:11:59 AM Thursday, June 3, 2021 : Target Dir: C:\Cadence\PSpiceTI
    7:11:59 AM Thursday, June 3, 2021 : Working Dir: C:\cds_spb_home
    7:11:59 AM Thursday, June 3, 2021 : Silent ini file created
    7:12:01 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
    7:12:01 AM Thursday, June 3, 2021 : Starting download of data1.cab   Attempt no 1 DataSize is 31723644
    7:12:01 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
    7:12:01 AM Thursday, June 3, 2021 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
    7:12:01 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
    7:12:01 AM Thursday, June 3, 2021 : Completing download of 0x0409.ini
    7:12:04 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
    7:12:04 AM Thursday, June 3, 2021 : Starting download of data1.hdr   Attempt no 1 DataSize is 4968262
    7:12:04 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
    7:12:04 AM Thursday, June 3, 2021 : Completing download of data1.cab
    7:12:05 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
    7:12:05 AM Thursday, June 3, 2021 : Completing download of data1.hdr
    7:12:06 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
    7:12:06 AM Thursday, June 3, 2021 : Starting download of data2.cab   Attempt no 1 DataSize is 170137600
    7:12:07 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
    7:12:07 AM Thursday, June 3, 2021 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637864
    7:12:08 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
    7:12:08 AM Thursday, June 3, 2021 : Completing download of ISSetup.dll
    7:12:10 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
    7:12:10 AM Thursday, June 3, 2021 : Starting download of layout.bin   Attempt no 1 DataSize is 994
    7:12:10 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
    7:12:10 AM Thursday, June 3, 2021 : Completing download of layout.bin
    7:12:12 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
    7:12:12 AM Thursday, June 3, 2021 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
    7:12:12 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
    7:12:12 AM Thursday, June 3, 2021 : Completing download of pspInstall.pdf
    7:12:14 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
    7:12:14 AM Thursday, June 3, 2021 : Starting download of setup.bmp   Attempt no 1 DataSize is 552056
    7:12:15 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
    7:12:15 AM Thursday, June 3, 2021 : Completing download of setup.bmp
    7:12:17 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
    7:12:17 AM Thursday, June 3, 2021 : Starting download of setup.ini   Attempt no 1 DataSize is 2440
    7:12:17 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
    7:12:17 AM Thursday, June 3, 2021 : Completing download of setup.ini
    7:12:19 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
    7:12:19 AM Thursday, June 3, 2021 : Starting download of setup.inx   Attempt no 1 DataSize is 571158
    7:12:19 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
    7:12:19 AM Thursday, June 3, 2021 : Completing download of setup.inx
    7:12:21 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
    7:12:21 AM Thursday, June 3, 2021 : Starting download of data9.cab   Attempt no 1 DataSize is 76919236
    7:12:22 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
    7:12:22 AM Thursday, June 3, 2021 : Completing download of data2.cab
    7:12:25 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
    7:12:25 AM Thursday, June 3, 2021 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
    7:12:34 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
    7:12:34 AM Thursday, June 3, 2021 : Completing download of data9.cab
    7:12:36 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
    7:12:36 AM Thursday, June 3, 2021 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
    7:12:55 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
    7:12:55 AM Thursday, June 3, 2021 : Completing download of data3.cab
    7:12:57 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
    7:12:57 AM Thursday, June 3, 2021 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
    7:13:10 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
    7:13:11 AM Thursday, June 3, 2021 : Completing download of data4.cab
    7:13:13 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
    7:13:13 AM Thursday, June 3, 2021 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
    7:13:29 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
    7:13:29 AM Thursday, June 3, 2021 : Completing download of data5.cab
    7:13:32 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
    7:13:32 AM Thursday, June 3, 2021 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
    7:13:49 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
    7:13:50 AM Thursday, June 3, 2021 : Completing download of data6.cab
    7:13:52 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
    7:13:52 AM Thursday, June 3, 2021 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
    7:14:07 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
    7:14:08 AM Thursday, June 3, 2021 : Completing download of data7.cab
    7:14:10 AM Thursday, June 3, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
    7:14:10 AM Thursday, June 3, 2021 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954856
    7:14:10 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
    7:14:11 AM Thursday, June 3, 2021 : Completing download of installsetup.exe
    7:14:19 AM Thursday, June 3, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
    7:14:20 AM Thursday, June 3, 2021 : Completing download of data8.cab
    7:14:20 AM Thursday, June 3, 2021 : 8389570 8389570
    7:14:20 AM Thursday, June 3, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
    7:14:20 AM Thursday, June 3, 2021 : Allegro Installation Start pid: 17208
    7:14:30 AM Thursday, June 3, 2021 : NumberOfComponentsToBeInstalled = 39559
    7:14:30 AM Thursday, June 3, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55
    7:14:30 AM Thursday, June 3, 2021 : Updated NumberOfComponentsInstalled = 396
    7:19:57 AM Thursday, June 3, 2021 : Feature transfer complete..disabling close button
    7:19:57 AM Thursday, June 3, 2021 : Installing: Runtime packages and redistributables
    7:20:21 AM Thursday, June 3, 2021 : Installing: Configuring documentation
    7:20:22 AM Thursday, June 3, 2021 : Installing: Configuring file associations
    7:20:23 AM Thursday, June 3, 2021 : Installing: Setting permissions for files and folders
    7:20:30 AM Thursday, June 3, 2021 : Installing: Creating Registries
    7:20:30 AM Thursday, June 3, 2021 : Installing: SQL Lite ODBC Driver
    7:20:32 AM Thursday, June 3, 2021 : Installing: Finishing Installation
    7:20:50 AM Thursday, June 3, 2021 : Running Library Configuration Executable
    7:20:50 AM Thursday, June 3, 2021 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
    7:23:29 AM Thursday, June 3, 2021 : orLibraryDownLoad.exe returned : 0
    7:23:29 AM Thursday, June 3, 2021 : Library Installation completed successfully.
    7:23:29 AM Thursday, June 3, 2021 : Downloading License file
    7:23:30 AM Thursday, June 3, 2021 : error_code cdsVblDownloadLicense: VblSuccess
    7:23:30 AM Thursday, June 3, 2021 : Downloading License file finish
    7:23:30 AM Thursday, June 3, 2021 : PrepareUninstallation
    7:23:30 AM Thursday, June 3, 2021 : strLocalPath: C:\Users\manauo.AD\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
    7:23:30 AM Thursday, June 3, 2021 : strCachedLocForFV174Installer: "C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
    7:23:30 AM Thursday, June 3, 2021 : ClearRunOnceIfNotNeeded()
    7:23:30 AM Thursday, June 3, 2021 : installSetupValue =
    7:37:56 AM Thursday, June 3, 2021 : Capture Viewer
    7:37:56 AM Thursday, June 3, 2021 : Deleting installation files
    7:43:22 AM Thursday, June 3, 2021 : TI Launched in uninstallation mode as remove found in command line
    7:43:22 AM Thursday, June 3, 2021 : Message: Do you want to completely remove the selected application and all of its features?
    7:43:24 AM Thursday, June 3, 2021 : Target Dir: C:\Cadence\PSpiceTI
    7:43:24 AM Thursday, June 3, 2021 : Working Dir:
    7:43:24 AM Thursday, June 3, 2021 : Silent ini file created
    7:43:24 AM Thursday, June 3, 2021 : Uninstallation exe path ctor: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}
    7:43:24 AM Thursday, June 3, 2021 : Uninstallation exe path: C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\installsetup.exe
    7:43:24 AM Thursday, June 3, 2021 : 34014772 34014772
    7:43:24 AM Thursday, June 3, 2021 : Setup EXE Argument: /hide_progress /hide_splash DMHandle="34014772"  -Wrapper Uninstall !Quiet="C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\silentinstall-TI.ini"
    7:43:34 AM Thursday, June 3, 2021 : Message 1004: Uninstalling: Removing files from Firewall Exceptions
    7:43:54 AM Thursday, June 3, 2021 : Message 1004: Uninstalling: Removing shortcuts
    7:43:54 AM Thursday, June 3, 2021 : NumberOfComponentsToBeInstalled = 39559
    7:43:54 AM Thursday, June 3, 2021 : Updated NumberOfFeaturesToBeUninstalled = 41142
    7:43:54 AM Thursday, June 3, 2021 : Updated NumberOfFeaturesUninstalled = 1583
    7:43:54 AM Thursday, June 3, 2021 : Message 1004: Uninstalling: Uninstalling files
    7:45:19 AM Thursday, June 3, 2021 : Message 1002: Uninstalling: Finishing Uninstallation
    7:45:33 AM Thursday, June 3, 2021 : uninstallation sucessfull
    7:45:33 AM Thursday, June 3, 2021 : Clearing Registry: TIPSpice.Resources.Email.reg
    7:45:33 AM Thursday, June 3, 2021 : Cleared Registry settings
    7:45:33 AM Thursday, June 3, 2021 : This installation requires a reboot.
    7:38:36 AM Friday, June 4, 2021 : Initializing
    7:38:36 AM Friday, June 4, 2021 : Deleting file : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
    7:38:36 AM Friday, June 4, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
    7:38:37 AM Friday, June 4, 2021 : Response Content length = 1724
    7:38:37 AM Friday, June 4, 2021 : C:\Users\manauo.AD\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724
    7:38:37 AM Friday, June 4, 2021 : Reading Json URL File
    7:38:37 AM Friday, June 4, 2021 : setting media download server URL from Json File
    7:38:37 AM Friday, June 4, 2021 : setting Dll path from Json File
    7:38:37 AM Friday, June 4, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
    7:38:37 AM Friday, June 4, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
    7:38:37 AM Friday, June 4, 2021 : parameter count = 1
    7:38:37 AM Friday, June 4, 2021 : -wrapper
    7:38:37 AM Friday, June 4, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system:
    7:39:01 AM Friday, June 4, 2021 : error_code cdsVblRegisterInstallation: VblSuccess
    7:39:01 AM Friday, June 4, 2021 : error_code cdsVblRequestLicense: VblSuccess
    7:39:04 AM Friday, June 4, 2021 : Set Installation and Home Directory()
    7:39:04 AM Friday, June 4, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI
    7:39:04 AM Friday, June 4, 2021 : Reading CDS_HOME environment variable
    7:39:04 AM Friday, June 4, 2021 : CDS_HOME is present and set to C:\cds_spb_home. No need to set CDS_HOME
    7:39:07 AM Friday, June 4, 2021 : Checking for memory space
    7:39:07 AM Friday, June 4, 2021 : Memory space available
    7:39:07 AM Friday, June 4, 2021 : Target Dir: C:\Cadence\PSpiceTI
    7:39:07 AM Friday, June 4, 2021 : Working Dir: C:\cds_spb_home
    7:39:07 AM Friday, June 4, 2021 : Silent ini file created
    7:39:10 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
    7:39:10 AM Friday, June 4, 2021 : Starting download of data1.cab   Attempt no 1 DataSize is 31723644
    7:39:11 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
    7:39:11 AM Friday, June 4, 2021 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
    7:39:11 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
    7:39:11 AM Friday, June 4, 2021 : Completing download of 0x0409.ini
    7:39:13 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
    7:39:13 AM Friday, June 4, 2021 : Starting download of data1.hdr   Attempt no 1 DataSize is 4968262
    7:39:14 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
    7:39:14 AM Friday, June 4, 2021 : Completing download of data1.cab
    7:39:16 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
    7:39:16 AM Friday, June 4, 2021 : Completing download of data1.hdr
    7:39:16 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
    7:39:16 AM Friday, June 4, 2021 : Starting download of data2.cab   Attempt no 1 DataSize is 170137600
    7:39:18 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
    7:39:18 AM Friday, June 4, 2021 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637864
    7:39:19 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
    7:39:19 AM Friday, June 4, 2021 : Completing download of ISSetup.dll
    7:39:21 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
    7:39:21 AM Friday, June 4, 2021 : Starting download of layout.bin   Attempt no 1 DataSize is 994
    7:39:21 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
    7:39:21 AM Friday, June 4, 2021 : Completing download of layout.bin
    7:39:22 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
    7:39:22 AM Friday, June 4, 2021 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
    7:39:23 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
    7:39:23 AM Friday, June 4, 2021 : Completing download of pspInstall.pdf
    7:39:25 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
    7:39:25 AM Friday, June 4, 2021 : Starting download of setup.bmp   Attempt no 1 DataSize is 552056
    7:39:26 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
    7:39:26 AM Friday, June 4, 2021 : Completing download of setup.bmp
    7:39:27 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
    7:39:27 AM Friday, June 4, 2021 : Starting download of setup.ini   Attempt no 1 DataSize is 2440
    7:39:27 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
    7:39:27 AM Friday, June 4, 2021 : Completing download of setup.ini
    7:39:30 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
    7:39:30 AM Friday, June 4, 2021 : Starting download of setup.inx   Attempt no 1 DataSize is 571158
    7:39:30 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
    7:39:30 AM Friday, June 4, 2021 : Completing download of setup.inx
    7:39:32 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
    7:39:32 AM Friday, June 4, 2021 : Completing download of data2.cab
    7:39:33 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
    7:39:33 AM Friday, June 4, 2021 : Starting download of data9.cab   Attempt no 1 DataSize is 76919236
    7:39:35 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
    7:39:35 AM Friday, June 4, 2021 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
    7:39:41 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
    7:39:42 AM Friday, June 4, 2021 : Completing download of data9.cab
    7:39:43 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
    7:39:43 AM Friday, June 4, 2021 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
    7:40:18 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
    7:40:20 AM Friday, June 4, 2021 : Completing download of data3.cab
    7:40:22 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
    7:40:22 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
    7:40:22 AM Friday, June 4, 2021 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
    7:40:23 AM Friday, June 4, 2021 : Completing download of data4.cab
    7:40:25 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
    7:40:25 AM Friday, June 4, 2021 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
    7:40:56 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
    7:40:57 AM Friday, June 4, 2021 : Completing download of data5.cab
    7:40:59 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
    7:40:59 AM Friday, June 4, 2021 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
    7:41:00 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
    7:41:01 AM Friday, June 4, 2021 : Completing download of data6.cab
    7:41:03 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
    7:41:03 AM Friday, June 4, 2021 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
    7:41:33 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
    7:41:33 AM Friday, June 4, 2021 : Completing download of data7.cab
    7:41:36 AM Friday, June 4, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
    7:41:36 AM Friday, June 4, 2021 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954856
    7:41:36 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
    7:41:36 AM Friday, June 4, 2021 : Completing download of installsetup.exe
    7:41:37 AM Friday, June 4, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
    7:41:38 AM Friday, June 4, 2021 : Completing download of data8.cab
    7:41:38 AM Friday, June 4, 2021 : 198188 198188
    7:41:38 AM Friday, June 4, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
    7:41:38 AM Friday, June 4, 2021 : Allegro Installation Start pid: 6040
    7:41:47 AM Friday, June 4, 2021 : NumberOfComponentsToBeInstalled = 39559
    7:41:47 AM Friday, June 4, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55
    7:41:47 AM Friday, June 4, 2021 : Updated NumberOfComponentsInstalled = 396
    7:46:22 AM Friday, June 4, 2021 : Feature transfer complete..disabling close button
    7:46:22 AM Friday, June 4, 2021 : Installing: Runtime packages and redistributables
    7:46:41 AM Friday, June 4, 2021 : Installing: Configuring documentation
    7:46:42 AM Friday, June 4, 2021 : Installing: Configuring file associations
    7:46:43 AM Friday, June 4, 2021 : Installing: Setting permissions for files and folders
    7:46:49 AM Friday, June 4, 2021 : Installing: Creating Registries
    7:46:49 AM Friday, June 4, 2021 : Installing: SQL Lite ODBC Driver
    7:46:51 AM Friday, June 4, 2021 : Installing: Finishing Installation
    7:47:08 AM Friday, June 4, 2021 : Running Library Configuration Executable
    7:47:08 AM Friday, June 4, 2021 : Starting process: C:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
    7:49:02 AM Friday, June 4, 2021 : orLibraryDownLoad.exe returned : 0
    7:49:02 AM Friday, June 4, 2021 : Library Installation completed successfully.
    7:49:02 AM Friday, June 4, 2021 : Downloading License file
    7:49:02 AM Friday, June 4, 2021 : error_code cdsVblDownloadLicense: VblSuccess
    7:49:02 AM Friday, June 4, 2021 : Downloading License file finish
    7:49:02 AM Friday, June 4, 2021 : PrepareUninstallation
    7:49:02 AM Friday, June 4, 2021 : strLocalPath: C:\Users\manauo.AD\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
    7:49:02 AM Friday, June 4, 2021 : strCachedLocForFV174Installer: "C:\Users\manauo.AD\AppData\Roaming\InstallShield Installation Information\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
    7:49:02 AM Friday, June 4, 2021 : ClearRunOnceIfNotNeeded()
    7:49:02 AM Friday, June 4, 2021 : installSetupValue =
    8:00:22 AM Friday, June 4, 2021 : Capture Viewer
    8:00:22 AM Friday, June 4, 2021 : Deleting installation files
  • Hi Matthew,
    Does the crash happen immediately after you try to launch PSpice for TI?
    Would you please go into your Windows TEMP directory (enter %TEMP% in file manager and hit "ENTER") and look for a directory called "capture..." and zip it up then share with us? This is a temp directory so things get deleted automatically, please do this immediately after you run into a crash.
    JC
    Yes, it is immediately after attempting to launch - the program does not get to the point of opening, the crash occurs while loading.
    The specified temp directory is attached.
    Capture255452062.zip
  • Hello Matthew,
    Thank you for sharing the additional information. We will let you know our findings shortly.
    -Jackie
  • Hello Matthew,
    We are asking the software developer, Cadence Design Systems, for help troubleshooting your issue. I will let you know their response.
    Thank you,
    Jackie
  • Hello Matthew,
    Please confirm for me that you experience this issue even after restarting your machine.
    Thank you,
    Jackie
  • Yes, restarting my machine after installing did not resolve the issue.
  • Thank you. I will let you know if the developer has further questions.
  • Hello Matthew,
    The developer would like to discuss directly with you to debug the issue. I am going to contact you through this forum's private messaging system. Please accept the friend request and I will send you a message.
    Thank you,
    Jackie
  • Hi Jackie,
    I stumbled into the solution after recalling a similar issue I had had with Eagle PCB in the past (after a Windows update, Eagle would open but only display black screen. No updates were installed recently around the time that PSPICE was installed, but it jogged my memory). The problem turned out to be that after the update, Windows was handling the GPU allocation differently.
    The solution that worked for me (at least as far as the program opening and getting to the start page, I haven’t had time to really test it yet) was to go to the “Graphics settings” menu in Windows, select the application, and change the graphics preference from “Let Windows decide” to “Power saving”.
  • Hello Matthew,
    Thank you for sharing this workaround with us. It is a very strange issue that we will have to fix in a future release.
    Thank you again,
    Jackie
