I just installed PSpice_TI 17.400, but is not working.
The license is not working, also licence.txt file is empty.
Can I solve the problem in some ways ?
Hello Bogdan,
If you are using a VPN, please try disabling the VPN and relaunching the tool. If that does not work, can you please share the installation log? It can be found at %appdata%\Cadence\PSpiceTIInstall\cdsPspiceTIlog.txt. %appdata% is a system variable which you can just type into the file manager. Can you please confirm that your operating system is Windows 10?
Thank you,
Jackie
Hello Jackie,
Yes, I have Windows 10 and with VPN off - not working.
The only log I found is attached.
[GENERAL_LOG] Count=150 (11:44:27) Log_Entry1=>> DetectRunningUnattended (11:44:27) Log_Entry2=>> CopyUnattendIniToSTATUS_FILE (11:44:27) Log_Entry3=<< CopyUnattendIniToSTATUS_FILE (11:44:27) Log_Entry4=>> ConvertUnattendedCMDLINE (11:44:27) Log_Entry5=<< ConvertUnattendedCMDLINE (11:44:27) Log_Entry6=>> CmdLineUnattendedSetFeatureStates (11:44:27) Log_Entry7=Read failed (11:44:27) Log_Entry8=<< CmdLineUnattendedSetFeatureStates (11:44:27) Log_Entry9=>> CmdLineUnattendedSetOnMaintenanceFlag (11:44:27) Log_Entry10=Read failed (11:44:27) Log_Entry11=<< CmdLineUnattendedSetOnMaintenanceFlag (11:44:27) Log_Entry12=>> CmdLineUnattendedSetRebootIfReqdFlag (11:44:27) Log_Entry13=Read failed (11:44:27) Log_Entry14=<< CmdLineUnattendedSetRebootIfReqdFlag (11:44:27) Log_Entry15=>> CmdLineUnattendedSetTargetDir (11:44:27) Log_Entry16=Read failed (11:44:27) Log_Entry17=<< CmdLineUnattendedSetTargetDir (11:44:27) Log_Entry18=>> CmdLineUnattendedSetRollbackFlag (11:44:27) Log_Entry19=Read failed (11:44:27) Log_Entry20=<< CmdLineUnattendedSetRollbackFlag (11:44:27) Log_Entry21=<< DetectRunningUnattended (11:44:27) Log_Entry22=Command Line arguments passed : DMHandle="6818512" -Wrapper !Quiet="C:\Users\z-kummarikunta.srika\AppData\Roaming\Cadence\PspiceTIInstall\silentinstall-TI.ini" (11:44:27) Log_Entry23=Installation has detected a reboot pending from a previous installation. Setup will proceed with the installation. (11:44:27) Log_Entry24=Entering CDN_OnProductsInstallBefore function. (11:44:27) Log_Entry25=Server Installation is in progress. (11:44:27) Log_Entry26=Working Directory:C:\SPB_Data (11:44:27) Log_Entry27=Reading all the features. (11:44:27) Log_Entry28=Reading Completed for all the features. (11:44:27) Log_Entry29=>> GetUnattendedData (11:44:27) Log_Entry30=<< GetUnattendedData (11:44:27) Log_Entry31=Exiting CDN_OnProductsInstallBefore function. (11:44:27) Log_Entry32=DmHandle received from Wrapper and set: 6818512 (11:44:28) Log_Entry33=>> SetUnattendedTargetDir (11:44:28) Log_Entry34=>> GetUnattendedData (11:44:28) Log_Entry35=<< GetUnattendedData (11:44:28) Log_Entry36=Setting TARGETDIR to: C:\Cadence\PSpiceTI (11:44:28) Log_Entry37=<< SetUnattendedTargetDir (11:44:28) Log_Entry38=>> GetUnattendedData (11:44:28) Log_Entry39=Read failed (11:44:28) Log_Entry40=Read failed (11:44:28) Log_Entry41=No CMDLINE value for WorkingDir--reading Data section. (11:44:28) Log_Entry42=WorkingDir = C:\cds_spb_home (11:44:28) Log_Entry43=<< GetUnattendedData (11:44:28) Log_Entry44=Leaving OnFirstUIBefore function (11:44:28) Log_Entry45=Leaving OnFirstUIBefore function in Uninstall mode (11:44:28) Log_Entry46=Finding UI Handle (11:44:28) Log_Entry47=Sending Files Count (11:48:15) Log_Entry48=Sending message 1005 to Wrapper: Feature transfer complete (11:48:15) Log_Entry49=Entering OnFirstUIAfter function (11:48:15) Log_Entry50=Entering CDN_OnProductsInstallAfter function. (11:48:15) Log_Entry51=Sending message 1004 to Wrapper: Runtime packages and redistributables (11:48:16) Log_Entry52=Created User Library. (11:48:16) Log_Entry53=Created INI Files. (11:48:16) Log_Entry54=Creating Compnts.dat file. (11:48:16) Log_Entry55=Backing up Compnts.dat. (11:48:16) Log_Entry56=>> GetUnattendedData (11:48:16) Log_Entry57=Read failed (11:48:16) Log_Entry58=Read failed (11:48:16) Log_Entry59=No CMDLINE value for WorkingDir--reading Data section. (11:48:16) Log_Entry60=WorkingDir = C:\cds_spb_home (11:48:16) Log_Entry61=<< GetUnattendedData (11:48:16) Log_Entry62=Written General Section. (11:48:16) Log_Entry63=Written Products Section. (11:48:16) Log_Entry64=Written License stuff Section. (11:48:16) Log_Entry65=Written Foot print Section. (11:48:16) Log_Entry66=C:\Users\Z-KUMM~1.SRI\AppData\Local\Temp\{6AB4E52B-E45A-48C9-A846-D18BD64D9D87}\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\InstallConfig.exe /hide_progress INSTALL_LOCATION="C:\Cadence\PSpiceTI" INST_PRINTER VC_REDIST_12_64 VC_REDIST_15 FW_ADD:HARMONY (11:48:37) Log_Entry67=Sending message 1004 to Wrapper: Configuring documentation (11:48:39) Log_Entry68=Sending message 1004 to Wrapper: Configuring file associations (11:48:39) Log_Entry69=Entering CreateFileAssociations function. (11:48:40) Log_Entry70=Leaving CreateFileAssociations function. (11:48:40) Log_Entry71=Starting ... SPB_BroadcastEnvChange. (11:48:40) Log_Entry72=SPB_EnvSetVarUserHome() (11:48:40) Log_Entry73=HandleCDSHOME_For_PSpiceTI() (11:48:40) Log_Entry74=Reading SET_CDS_HOME from ini file (11:48:40) Log_Entry75=>> GetUnattendedData (11:48:40) Log_Entry76=<< GetUnattendedData (11:48:40) Log_Entry77=>> GetUnattendedData (11:48:40) Log_Entry78=Read failed (11:48:40) Log_Entry79=Read failed (11:48:40) Log_Entry80=No CMDLINE value for WorkingDir--reading Data section. (11:48:40) Log_Entry81=WorkingDir = C:\cds_spb_home (11:48:40) Log_Entry82=<< GetUnattendedData (11:48:40) Log_Entry83=Setting CDS_HOME environment variable to C:\cds_spb_home (11:48:40) Log_Entry84=Starting ... SPB_BroadcastEnvChange. (11:48:40) Log_Entry85=SPB_BroadcastEnvChange Completed. (11:48:40) Log_Entry86=Sending message 1004 to Wrapper: Setting permissions for files and folders (11:48:46) Log_Entry87=Sending message 1004 to Wrapper: Creating Registries (11:48:46) Log_Entry88=Entering Capture-PSpice Part Search ODBC Creation function. (11:48:46) Log_Entry89=Creating PSpice Search ODBC Entries (11:48:46) Log_Entry90=Sending message 1004 to Wrapper: SQL Lite ODBC Driver (11:48:46) Log_Entry91=Installing SQL Lite ODBC Driver (11:48:48) Log_Entry92=Checking for sqlite3.dll in msbase folder (11:48:48) Log_Entry93=Copying sqlite3.dll toC:\WINDOWS\system32\ (11:48:48) Log_Entry94=Checking for updated sqlite odbc driver (11:48:48) Log_Entry95=Installing updated sqlite odbc driver (11:48:50) Log_Entry96=Leaving CDN_OnProductsInstallAfter function. (11:48:50) Log_Entry97=>> GetUnattendedData (11:48:50) Log_Entry98=Read failed (11:48:50) Log_Entry99=Read failed (11:48:50) Log_Entry100=No CMDLINE value for GEN_DOC_INDEX--reading Data section. (11:48:50) Log_Entry101=Read failed (11:48:50) Log_Entry102=No DATA value for GEN_DOC_INDEX. (11:48:50) Log_Entry103=<< GetUnattendedData (11:48:50) Log_Entry104=>> GetUnattendedData (11:48:50) Log_Entry105=Read failed (11:48:50) Log_Entry106=Read failed (11:48:50) Log_Entry107=No CMDLINE value for REMOVE_CADENCE_PATH--reading Data section. (11:48:50) Log_Entry108=Read failed (11:48:50) Log_Entry109=No DATA value for REMOVE_CADENCE_PATH. (11:48:50) Log_Entry110=<< GetUnattendedData (11:48:50) Log_Entry111=Leaving OnFirstUIAfter function (11:48:50) Log_Entry112=Sending message 1002 to Wrapper: Finishing Installation (11:48:50) Log_Entry113=Sending message 1003 to Wrapper: PSpice for TI 2020 (11:48:50) Log_Entry114=>> PreserveUnattendStatusFile (11:48:50) Log_Entry115=>> GenerateDateTimeAsString (11:48:50) Log_Entry116=<< GenerateDateTimeAsString (11:48:50) Log_Entry117=Copying: C:\Users\Z-KUMM~1.SRI\AppData\Local\Temp\{6AB4E52B-E45A-48C9-A846-D18BD64D9D87}\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\UnAttendStat.txt (11:48:50) Log_Entry118=To: C:\Cadence\PSpiceTI\UnAttendStat06152021_114850.txt (11:48:50) Log_Entry119=****************************************************************************************************************** (11:48:50) Log_Entry120=*** Logging closed *** (11:48:50) Log_Entry121=****************************************************************************************************************** (11:48:52) Log_Entry122=<< PreserveUnattendStatusFile (11:48:52) Log_Entry123=>> PreserveLogFile (11:48:52) Log_Entry124=>> DetectRunningUnattended (11:48:52) Log_Entry125=>> CopyUnattendIniToSTATUS_FILE (11:48:52) Log_Entry126=<< CopyUnattendIniToSTATUS_FILE (11:48:52) Log_Entry127=>> ConvertUnattendedCMDLINE (11:48:52) Log_Entry128=<< ConvertUnattendedCMDLINE (11:48:52) Log_Entry129=>> CmdLineUnattendedSetFeatureStates (11:48:52) Log_Entry130=Read failed (11:48:52) Log_Entry131=<< CmdLineUnattendedSetFeatureStates (11:48:52) Log_Entry132=>> CmdLineUnattendedSetOnMaintenanceFlag (11:48:52) Log_Entry133=Read failed (11:48:52) Log_Entry134=<< CmdLineUnattendedSetOnMaintenanceFlag (11:48:52) Log_Entry135=>> CmdLineUnattendedSetRebootIfReqdFlag (11:48:52) Log_Entry136=Read failed (11:48:52) Log_Entry137=<< CmdLineUnattendedSetRebootIfReqdFlag (11:48:52) Log_Entry138=>> CmdLineUnattendedSetTargetDir (11:48:52) Log_Entry139=Read failed (11:48:52) Log_Entry140=<< CmdLineUnattendedSetTargetDir (11:48:52) Log_Entry141=>> CmdLineUnattendedSetRollbackFlag (11:48:52) Log_Entry142=Read failed (11:48:52) Log_Entry143=<< CmdLineUnattendedSetRollbackFlag (11:48:52) Log_Entry144=<< DetectRunningUnattended (11:48:52) Log_Entry145=>> GetUnattendedData (11:48:52) Log_Entry146=<< GetUnattendedData (11:48:52) Log_Entry147=>> GenerateDateTimeAsString (11:48:52) Log_Entry148=<< GenerateDateTimeAsString (11:48:52) Log_Entry149=Copying: C:\Users\Z-KUMM~1.SRI\AppData\Local\Temp\{6AB4E52B-E45A-48C9-A846-D18BD64D9D87}\{A74FAFD7-6510-4067-95FD-1F90BEF78B8F}\InstLogSpb.txt (11:48:52) Log_Entry150=To: C:\Cadence\PSpiceTI\InstLogSpb06152021_114852.txt [INSTALLED_PROGRAM_LIST_BEFORE_INST] Count=396 PRODUCT1=Cisco AnyConnect Secure Mobility Client PRODUCT2=Citrix Workspace 1912 PRODUCT3=E-Sys 3.32.2 (build 53457) PRODUCT4=Erlang OTP 20 (9.2) PRODUCT5=Free Screen Video Recorder PRODUCT6=FreeCommander XE PRODUCT7=HP Photo Creations PRODUCT8=Integrity Lifecycle Manager Client 11 PRODUCT9=Mathcad PDSi viewable support PRODUCT10=Microsoft Edge PRODUCT11=Microsoft Edge Update PRODUCT12=Microsoft Edge WebView2 Runtime PRODUCT13=National Instruments Software PRODUCT14=Notepad++ (32-bit x86) PRODUCT15=RabbitMQ Server 3.7.3 PRODUCT16=NI LabWindows/CVI 2019 Code Generator PRODUCT17=Realtek USB Ethernet Controller All-In-One Windows Driver PRODUCT18=NI-RPC 16.0.0f0 for Phar Lap ETS PRODUCT19=NI Customer Experience Improvement Program PRODUCT20=Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 PRODUCT21=NI UsiCore PRODUCT22=NI Device Monitor 19.0 PRODUCT23=Vector CANoe Test Report Viewer PRODUCT24=NI Uninstaller 20.0.0 PRODUCT25=Vector CANdelaStudio 8.5 SP3 PRODUCT26=NI LabVIEW Runtime Interop 2019 PRODUCT27=9130B Series Software PRODUCT28=NI LabWindows/CVI Real-Time Runtime 2019 PRODUCT29=NI-488.2 C/C++ Support 20.0 PRODUCT30=Realtek USB Audio PRODUCT31=NI System Configuration Runtime 20.0.0 PRODUCT32=NI-DAQmx ADE Support 20.0.0 PRODUCT33=NI-PCI Bridge Driver 20.0 PRODUCT34=NI Curl 2020 PRODUCT35=Vector ShellExtensions 32-bit PRODUCT36=NI LabVIEW Runtime 2019 SP1 f1 PRODUCT37=NI Xerces Delay Load 2.7.10 PRODUCT38=NI-VISA USB Passport 20.0.0 PRODUCT39=NI Controller Driver 20.0 PRODUCT40=NI LabVIEW Run-Time Engine 2010 SP1 PRODUCT41=NI LabVIEW 2020 Deployment Framework PRODUCT42=Math Kernel Libraries PRODUCT43=Citrix Web Helper PRODUCT44=NI LabWindows/CVI 2019 Analysis Library PRODUCT45=HP OneDrive Plugin PRODUCT46=NI-VISA GPIB Passport 20.0.0 PRODUCT47=NI Logos XT Support PRODUCT48=ANSYS Electromagnetics Suite 19.2 PRODUCT49=MSXML 4.0 SP3 Parser PRODUCT50=Vector FIBEX Explorer 3.3 PRODUCT51=NI LabVIEW 2019 Deployable License PRODUCT52=NI LabVIEW Runtime 2014 SP1 Non-English Support. PRODUCT53=NI Certificates 2.0.2 PRODUCT54=NI EulaDepot PRODUCT55=NI Assistant Framework LabVIEW 2019 Support PRODUCT56=NI SSL LabVIEW RTE 2020 Support PRODUCT57=Vector Security Manager PRODUCT58=HP FTP Plugin PRODUCT59=NI-DAQmx Support for LabVIEW RTE 20.0 PRODUCT60=Vector AUTOSAR Explorer 1.7 PRODUCT61=HP SharePoint Plugin PRODUCT62=NI Command Line Interface for LabVIEW PRODUCT63=NI-VISA 20.0.0 PRODUCT64=ANSYS Electromagnetics Suite 2020 R1 PRODUCT65=NI-488.2 Documentation 20.0 PRODUCT66=NI LabVIEW 2020 Real-Time NBFifo PRODUCT67=NI-PAL 20.0 PRODUCT68=NI Error Reporting 2020 PRODUCT69=IZArc Command Line Add-On 1.1 PRODUCT70=Veoneer Fonts PRODUCT71=NI License Manager PRODUCT72=WIF Core Dependencies Windows 20.0.0 PRODUCT73=Java 1.8.162 PRODUCT74=GoTo Opener PRODUCT75=NI-RoCo Error Files 20.0.0 PRODUCT76=NI PXI Platform Software Error Files 19.0 PRODUCT77=Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.24.28127 PRODUCT78=NI System API Web-Service 32-bit 20.0.0 PRODUCT79=NI LabVIEW Run-Time Engine Interop 2013 PRODUCT80=NI PXI Platform Services Runtime 20.0 PRODUCT81=NI-VISA 20.0.0 MAX Provider PRODUCT82=NI LabVIEW 2010 Real-Time NBFifo PRODUCT83=NI Measurement Studio ComponentWorks UI PRODUCT84=NI-488.2 MAX Support 20.0 PRODUCT85=NI-VISA System API Support 20.0.0 PRODUCT86=NI Remote Provider for MAX 20.0.0 PRODUCT87=Microsoft Visual C++ 2019 X86 Minimum Runtime - 14.24.28127 PRODUCT88=NI LabWindows/CVI Shared Runtime 2019 PRODUCT89=NI Authentication 2020 PRODUCT90=Self-service Plug-in PRODUCT91=NI-488.2 Store Item 20.0 PRODUCT92=NI-VISA ENET Passport 20.0.0 PRODUCT93=NI AFW Custom UI Assemblies PRODUCT94=NI LabVIEW 2018 Real-Time NBFifo PRODUCT95=Citrix Workspace(SSON) PRODUCT96=HP Support Assistant PRODUCT97=Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 PRODUCT98=Intel� PROSet/Wireless Software PRODUCT99=NI LabVIEW 2018 Run-Time Engine Web Server PRODUCT100=NI Web Application Server 2020 PRODUCT101=NI LabVIEW MAX XML PRODUCT102=Teams Machine-Wide Installer PRODUCT103=NI MAX Remote Configuration Installer 20.0 PRODUCT104=NI LabVIEW 2019 Run-Time Engine Web Server PRODUCT105=NI LabVIEW Runtime Interop 2018 PRODUCT106=NI PXI Platform Services 20.0 Expert PRODUCT107=Notepad++ PRODUCT108=NI Help Assistant 2.2.0 PRODUCT109=NI System Logging Utilities PRODUCT110=NI-VISA .NET Runtime 19.0.0 PRODUCT111=NI Measurement Studio Recipe Processor PRODUCT112=NI Assistant Framework PRODUCT113=HRInfoPC 2.7.20.21 ro-RO PRODUCT114=Dassault Systemes Fonts PRODUCT115=Cisco AnyConnect Umbrella Roaming Security Module PRODUCT116=NI Controller Driver C Language Support 20.0 PRODUCT117=HP Support Solutions Framework PRODUCT118=NI LabVIEW 2020 Report Generation Toolkit License PRODUCT119=NI System State Publisher PRODUCT120=Vector ODXStudio 4.0 SP2 PRODUCT121=NI WS Repl Library 2020 PRODUCT122=NI LabVIEW Runtime Interop 2020 PRODUCT123=NI-RIO USBLAN 19.0 PRODUCT124=Citrix Screen Casting for Windows PRODUCT125=NI Assistant Framework LabVIEW 2017 Support PRODUCT126=NI-DAQmx SCXI 20.0.0 PRODUCT127=Microsoft Silverlight 5.1 PRODUCT128=NI Python Interface PRODUCT129=Citrix Workspace(Aero) PRODUCT130=NI LabWindows/CVI 2015 DLL Builder for LabVIEW PRODUCT131=NI-DIM 20.0.0 PRODUCT132=NI-VISA Serial Passport 20.0.0 PRODUCT133=NI-DAQmx Lang Runtime 20.0 for .NET Framework 4.0 (64-bit) PRODUCT134=NI-DAQmx Lang Runtime 20.0 for .NET Framework 4.5 (64-bit) PRODUCT135=NI-DAQmx MIO Device Drivers 20.0.0 PRODUCT136=NI Sync Domain Service 20.0.0 PRODUCT137=NI LabVIEW 2020 Run-Time Engine Web Server PRODUCT138=NI-488.2 19.0 PRODUCT139=NI LabWindows/CVI 2013 SP2 Low-Level Driver (Original) PRODUCT140=NI VISA Shared Components Wrapper Core PRODUCT141=NI Ethernet Device Enumerator PRODUCT142=NI Trace Engine PRODUCT143=NI Web Server Deployment Support for LabVIEW 2020 32-bit PRODUCT144=NI-488.2 Example Common 19.0 PRODUCT145=NI LabWindows/CVI Shared Runtime OpenMP 2019 PRODUCT146=NI LabWindows/CVI 2013 SP2 Low-Level Driver (Updated) PRODUCT147=HP Hotkey Support PRODUCT148=NI-DAQmx DAQ Assistant 20.0.0 PRODUCT149=NI USI 15.0.0 PRODUCT150=NI mDNS Responder 19.0.0 PRODUCT151=NI-VISA TULIP Passport 20.0.0 PRODUCT152=NI-DAQmx STC 20.0.0 PRODUCT153=NI CodeSignAPI 19.0.0 PRODUCT154=Tektronix OpenChoice Desktop PRODUCT155=Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660 PRODUCT156=Microsoft Intune Management Extension PRODUCT157=Cisco AnyConnect Start Before Login Module PRODUCT158=NI System API Windows 32-bit 20.0.0 PRODUCT159=HP Customer Experience Enhancements PRODUCT160=NI Security Update (KB 67L8LCQW) PRODUCT161=NI RTSI Cable Core Installer 20.0.0 PRODUCT162=NI-MXLC Core 20.0.0 PRODUCT163=NI Remote PXI Provider for MAX 19.0.0 PRODUCT164=Arriver Fonts PRODUCT165=NI SSL Support PRODUCT166=Citrix Authentication Manager PRODUCT167=Math Kernel Libraries PRODUCT168=NI MetaSuite Installer PRODUCT169=NI-DAQmx and NI-DAQ Common Documents 20.0.0 PRODUCT170=NI LabWindows/CVI 2019 DataSocket Library PRODUCT171=Microsoft Visual C++ 2005 Redistributable PRODUCT172=ResourceCentral Addin PRODUCT173=NI LabVIEW 2020 License PRODUCT174=NI LabVIEW Run-Time Engine Interop 2010 PRODUCT175=NI Network Discovery 20.0 PRODUCT176=NI Web Pipeline 19.0 PRODUCT177=Teams Machine-Wide Installer PRODUCT178=NI-PXIPF Error 19.5.0 PRODUCT179=NI LabWindows/CVI 2019 TDMS Library PRODUCT180=NI-DAQmx Support 20.0 for .NET Framework 4.0 PRODUCT181=HP EmailSMTP Plugin PRODUCT182=Vector Platform Manager 1.4 PRODUCT183=NI PXI Platform Services Store Item 20.0 PRODUCT184=NI-DAQmx Lang Runtime 20.0 for .NET Framework 4.5 PRODUCT185=NI DataPlugin Python 19.6 for Windows PRODUCT186=NI MSI Properties PRODUCT187=Citrix Workspace(USB) PRODUCT188=NI-VISA .NET Development Support 19.0.0 PRODUCT189=Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.40660 PRODUCT190=NI-488.2 DLL Direct Entry Support 19.0 PRODUCT191=Microsoft Azure Information Protection PRODUCT192=NI LabWindows/CVI 2019 .NET Library PRODUCT193=NI Portable Configuration 19.5.0 PRODUCT194=NI-ORB 20.0 PRODUCT195=NI-Cabled PCIe 20.0 PRODUCT196=Vector Autosar Tool Selector PRODUCT197=W&T USB Redirector PRODUCT198=NI-DAQmx Timing Installer 20.0.0 PRODUCT199=NI OPC Support PRODUCT200=NI-DAQmx MX Expert Framework 20.0.0 PRODUCT201=NI Physical Interface Extension Installer 20.0.0 PRODUCT202=9130B Series Software PRODUCT203=NI USI AOP5 DataPlugin 19.5.0 PRODUCT204=NI-MRU 20.0.0 PRODUCT205=NI-VISA Interactive Control 20.0.0 PRODUCT206=NI Remote System Discovery Troubleshooting Wizard 20.0 PRODUCT207=Vector CANdela Persistors 9.0 PRODUCT208=NI MDF Support PRODUCT209=NI LabVIEW 2010 SP1 Deployable License PRODUCT210=NI ActiveX Container PRODUCT211=Cisco AnyConnect Diagnostics and Reporting Tool PRODUCT212=NI Distributed System Manager 2020 PRODUCT213=NI LabVIEW Runtime Interop 2014 PRODUCT214=NI-DAQmx Support for C 20.0.0 PRODUCT215=NI-QPXI 20.0.0 PRODUCT216=Microsoft Office Korrekturhilfen 2016 � Deutsch PRODUCT217=Microsoft Office Proofing Tools 2016 - English PRODUCT218=Microsoft Office Nyelvi ellenorzo eszk�z�k 2016 � magyar PRODUCT219=Microsoft Office ????? 2016 - ??? PRODUCT220=Microsoft Office ?? ?? ?? 2016 - ??? PRODUCT221=Narzedzia sprawdzajace pakietu Microsoft Office 2016 � polski PRODUCT222=Revisores de Texto do Microsoft Office 2016 � Portugu�s (Brasil) PRODUCT223=Instrumente de verificare Microsoft Office 2016 - Rom�na PRODUCT224=???????? ???????? ???????????? Microsoft Office 2016 � ??????? PRODUCT225=Microsoft Office Proofing Tools 2016 � svenska PRODUCT226=Microsoft Office Proofing Tools 2016 - ??? PRODUCT227=Microsoft Office 2016 Yazim Denetleme Ara�lari - T�rk�e PRODUCT228=Microsoft Office ???? 2016 - ???? PRODUCT229=Uirlis� Prof�la Microsoft Office 2016 - Gaeilge PRODUCT230=Office 16 Click-to-Run Extensibility Component PRODUCT231=Office 16 Click-to-Run Localization Component PRODUCT232=NI-VISA Headers 20.0.0 PRODUCT233=NI LabWindows/CVI Shared Runtime Core 2019 PRODUCT234=Online Plug-in PRODUCT235=NI-DAQmx 653x Installer 14.5.0 PRODUCT236=NI-VISA Runtime 20.0.0 PRODUCT237=NI-488.2 Utilities 19.5 PRODUCT238=Tektronix OpenChoice TekVisa PRODUCT239=NI System Configuration 20.0.0 LabVIEW Support PRODUCT240=NI LabVIEW Runtime 2019 SP1 Non-English Support. PRODUCT241=IZArc 4.4 PRODUCT242=NI-488.2 Visual Basic Support 19.0 PRODUCT243=NI-DAQmx 20.0.0 PRODUCT244=NI Measurement Studio Common Runtime 19.0 for .NET Framework 4.0 PRODUCT245=Citrix Workspace Inside PRODUCT246=Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 PRODUCT247=HP DeskJet 2600 series Help PRODUCT248=Vector License Client PRODUCT249=NI LabVIEW Runtime 2020 PRODUCT250=NI LabWindows/CVI Diadem Connectivity Support PRODUCT251=NI-VISA ENET-Serial Passport 20.0.0 PRODUCT252=NI LabVIEW 2013 Run-Time Engine Non-English Support. PRODUCT253=Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 PRODUCT254=Tina 9 - TI PRODUCT255=NI Atomic PXIe Peripheral Module Driver 19.1.0 PRODUCT256=NI-DAQmx FSL Installer 20.0.0 PRODUCT257=NI System Web Server Base 2020 PRODUCT258=Math Kernel Libraries PRODUCT259=NI-MDBG 20.0.0f2 PRODUCT260=NI Launcher PRODUCT261=NI-MXLC (32-bit) PRODUCT262=NI SLCP 4.1 PRODUCT263=NI-DAQmx/LabVIEW shared documentation 20.0.0 PRODUCT264=NI Logos 20.0 PRODUCT265=Vector CANoe Test Report Viewer PRODUCT266=NI Measurement Studio ComponentWorks 3D Graph PRODUCT267=NI DataFinder Desktop Quit PRODUCT268=NI LabVIEW C Interface PRODUCT269=NI Math Kernel Libraries PRODUCT270=NI-Xlator 19.5.0f0 PRODUCT271=Adobe Acrobat Reader DC PRODUCT272=Extended Asian Language font pack for Adobe Acrobat Reader DC PRODUCT273=Mathcad PDSi viewable support PRODUCT274=NI MXI Manager 20.0 PRODUCT275=NI-DAQmx Lang Runtime 20.0 for .NET Framework 4.0 PRODUCT276=HP Google Drive Plugin PRODUCT277=NI LabVIEW 2013 Run-Time Engine Web Server PRODUCT278=NI Assistant Framework LabVIEW 2020 Support PRODUCT279=NI Microsoft Visual C++ 2015 Run-Time PRODUCT280=NI-DAQmx MAX Configuration Support 20.0.0 PRODUCT281=NI AFW Custom UI PRODUCT282=NI PXI Platform Framework 20.0.0 PRODUCT283=Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 PRODUCT284=NI SSL LabVIEW RTE 2019 Support PRODUCT285=NI Measurement Studio Common Development 19.0 for .NET Framework 4.0 PRODUCT286=NI LabVIEW 2015 Real-Time NBFifo PRODUCT287=NI RTSI UI Provider 19.1.0 PRODUCT288=NI-DAQmx Common Digital 20.0.0 PRODUCT289=NI-PAL 19.5 Error Files PRODUCT290=NI VIPM Helper 2020 PRODUCT291=NI DataSocket 19.0 PRODUCT292=Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 PRODUCT293=NI-VISA Examples 20.0.0 PRODUCT294=NI SSL LabVIEW RTE 2013 Support PRODUCT295=NI LabVIEW Run-Time Engine 2013 PRODUCT296=NI Assistant Framework LabVIEW 2018 Support PRODUCT297=NI TDM Streaming 19.0 PRODUCT298=NI Measurement & Automation Explorer 20.0.0 PRODUCT299=NI Error Reporting Interface 20.0 PRODUCT300=Microsoft Search in Bing PRODUCT301=NI PXI Platform Services .NET Support 20.0 PRODUCT302=NI-DAQmx Support 20.0 for .NET Framework 4.5 PRODUCT303=NI Software Provider for MAX 19.0.0 PRODUCT304=NI System Web Server 2020 PRODUCT305=HP Dropbox Plugin PRODUCT306=NI-VISA Errors 20.0.0 PRODUCT307=Intel(R) Trusted Connect Services Client PRODUCT308=Mathcad 15 M045 PRODUCT309=Vector ODXStudio 4.1 P1 PRODUCT310=NI LabVIEW Runtime 2020 Non-English Support. PRODUCT311=Intel(R) Trusted Connect Service Client x86 PRODUCT312=NI PXI Platform Services C Language Support 20.0 PRODUCT313=Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 PRODUCT314=NI-488.2 Runtime 20.0 PRODUCT315=NI-APAL 19.0 Error Files PRODUCT316=NI-VISA Remote Passport 20.0.0 PRODUCT317=NI LabWindows/CVI 2019 Internet Library PRODUCT318=NI LabVIEW 2019 Real-Time Error Dialog PRODUCT319=NI-DAQmx NI Device Monitor Support Installer 19.0.0 PRODUCT320=DefaultPackMSI PRODUCT321=NI LabWindows/CVI 2019 Network Variable Library PRODUCT322=NI Web-Based Configuration and Monitoring 20.0 PRODUCT323=NI-VISA Documentation 20.0.0 PRODUCT324=NI Update Service 19.0 PRODUCT325=NI-VISA Development Support Compatibility PRODUCT326=NI DataFinder Client API PRODUCT327=NI LabWindows/CVI 2019 ActiveX Library PRODUCT328=NI JSON Map Files PRODUCT329=NI Service Locator 2020 PRODUCT330=Microsoft Azure Information Protection PRODUCT331=Vector License Manager 1.4 PRODUCT332=NI LabVIEW 2013 SP1 Deployable License PRODUCT333=NI LabVIEW Web Server for Run-Time Engine PRODUCT334=NI LabWindows/CVI Shared Runtime 2019 PRODUCT335=Microsoft ASP.NET MVC 2 PRODUCT336=NI LabVIEW Runtime 2014 SP1 f5 PRODUCT337=Convert PRODUCT338=Citrix Workspace(DV) PRODUCT339=NI LabWindows/CVI Instrument Driver Runtime 2019 PRODUCT340=Project Reader PRODUCT341=NI LabVIEW 2019 Real-Time NBFifo PRODUCT342=Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.40660 PRODUCT343=Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.24.28127 PRODUCT344=NI PXI Platform Services Configuration 20.0 PRODUCT345=VI Package Manager 2020 PRODUCT346=NI LabVIEW Broker PRODUCT347=Vector Support Assistant PRODUCT348=NI .NET Framework 4.6.2 PRODUCT349=Math Kernel Libraries PRODUCT350=NI LabVIEW Runtime 2018 SP1 f4 PRODUCT351=NI Variable Engine 2019 PRODUCT352=NI-VISA Development Common (32-Bit) 20.0.0 PRODUCT353=NI VC2008MSMs x86 PRODUCT354=Microsoft Visual C++ 2019 X86 Additional Runtime - 14.24.28127 PRODUCT355=Veoneer StartUp 1.0 en-US PRODUCT356=Intel(R) Chipset Device Software PRODUCT357=NI-DAQmx Store Product 20.0.0 PRODUCT358=NI TDM Excel Add-In 19.0 PRODUCT359=NI VISA.NET Shared Components Wrapper Core PRODUCT360=NI System API Client for WIF 20.0.0 PRODUCT361=Math Kernel Libraries PRODUCT362=NI MXS 20.0.0 PRODUCT363=NI LabWindows/CVI 2019 Network Streams Library PRODUCT364=Cisco AnyConnect Secure Mobility Client PRODUCT365=NI LabVIEW 2012 Real-Time NBFifo PRODUCT366=Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40660 PRODUCT367=NI-RPC 19.0.0f0 PRODUCT368=Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 PRODUCT369=NI RTSI PAL Device Library Installer 20.0.0 PRODUCT370=NI VC2010SP1MSMs x86 PRODUCT371=NI SSL LabVIEW RTE 2018 Support PRODUCT372=NI-Mesa PRODUCT373=NI Registration Wizard PRODUCT374=NI-RoCo 20.0 (32-bit) PRODUCT375=NI AFW UI Assemblies PRODUCT376=NI LabWindows/CVI 2019 .NET Reflector Library PRODUCT377=NI-VISA Driver Development Wizard 20.0.0 PRODUCT378=NI LabVIEW Runtime 2018 SP1 Non-English Support. PRODUCT379=Reset NI Config 19.0.0 PRODUCT380=Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 PRODUCT381=NI-DAQmx Dynamic Signal Acquisition Installer 20.0.0 PRODUCT382=Vector CANdelaStudio 9.0 PRODUCT383=Microsoft VC++ redistributables repacked. PRODUCT384=NI System Monitor 20.0 PRODUCT385=NI-DAQmx Switch Core 20.0.0 PRODUCT386=NI GMP Windows 32-bit Installer 13.5.0 PRODUCT387=NI LabWindows/CVI OpenGL Library 2019 PRODUCT388=NI-RPC 19.0.0f0 for Phar Lap ETS PRODUCT389=NI System Configuration .NET Runtime for .NET Framework 4.6 PRODUCT390=Thunderbolt� Software PRODUCT391=NI-VISA PXI Passport 20.0.0 PRODUCT392=NI LabVIEW 2015 Deployable License PRODUCT393=NI-MXDF 20.0.0f1 PRODUCT394=NI I/O Trace 20.0.0 PRODUCT395=NI OPCEnum Shared PRODUCT396=NI LabVIEW 2020 Database Connectivity Toolkit License [SYSTEM_ENV_VAR_BEFORE_INST] ComSpec=%SystemRoot%\system32\cmd.exe DriverData=C:\Windows\System32\Drivers\DriverData OS=Windows_NT PROCESSOR_ARCHITECTURE=AMD64 TEMP=%SystemRoot%\TEMP TMP=%SystemRoot%\TEMP USERNAME=SYSTEM windir=%SystemRoot% ANSYSEM_ROOT201=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 CANoe_InstallDir=C:\Program Files\Vector CANoe 10.0\Exec64\ CANoe_InstallDir64=C:\Program Files\Vector CANoe 10.0\Exec64\ deployment.expiration.check.enabled=false MAN_CHM_INDEX=C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkutil.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkapi.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tcltk.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkcurses.idx;C:/Program Files (x86)/Integrity/ILMClient11/etc/isman.idx MAN_HTM_PATHS=C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/pod;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/ext;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/lib MAN_TXT_INDEX=C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkutil.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkapi.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tcltk.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkcurses.idx;C:/Program Files (x86)/Integrity/ILMClient11/etc/isman.idx MGLS_LICENSE_FILE=1717@de01-englic03 Path=C:\Program Files (x86)\Integrity\ILMClient11\bin;C:\ProgramData\Oracle\Java\javapath;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\PROGRA~2\INTEGR~2\Toolkit\mksnt;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\1.Storage\1.Projects\Task VEVA GVP3 Maintenance\KAFAS 2\SW +Tools\nvd Kafas;C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files\Microsoft VS Code\bin PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.sh;.ksh;.csh;.sed;.awk;.pl PSModulePath=%ProgramFiles%\WindowsPowerShell\Modules;%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft Azure Information Protection\Powershell ROOTDIR=C:/PROGRA~2/INTEGR~2/Toolkit SAP_IPv6_ACTIVE=1 SAPLOGON_INI_FILE=C:\WINDOWS\saplogon.ini SIMPLORER_HOME=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 SIMPMSCoSimDLL=C:\Program Files\AnsysEM\AnsysEM19.2\Win64\SIMPMSCoSim.dll SIMPPncSimCoSimDLL=C:\Program Files\AnsysEM\AnsysEM19.2\Win64\SIMPncSimCoSim.dll:LoadCoSimInterface SIWAVE_INSTALL_DIR=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 UATDATA=C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77 VXIPNPPATH=C:\Program Files (x86)\IVI Foundation\VISA\ VXIPNPPATH64=C:\Program Files\IVI Foundation\VISA\ RABBITMQ_BASE=C:\ProgramData\RabbitMQ ERLANG_HOME=C:\Program Files\erl9.2 RABBITMQ_NODENAME=rabbit@localhost RABBITMQ_CONFIG_FILE="C:\ProgramData\National Instruments\Skyline\RabbitMQ\rabbitmq" NIEXTCCOMPILERSUPP=C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\ NIDAQmxSwitchDir=C:\Program Files (x86)\National Instruments\NI-DAQ\Switch\ NUMBER_OF_PROCESSORS=12 PROCESSOR_LEVEL=6 PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 10, GenuineIntel PROCESSOR_REVISION=9e0a MLM_LICENSE_FILE=27000@DE01-ENGLIC02.CORP.INT [USER_ENV_VAR_BEFORE_INST] Path=%USERPROFILE%\AppData\Local\Microsoft\WindowsApps; TEMP=%USERPROFILE%\AppData\Local\Temp TMP=%USERPROFILE%\AppData\Local\Temp [STEPS_EXECUTED] Count=6 STEP1=Post_Install_SetUp_UnInstall_Icon STEP2=Post_Install_copy_Updates STEP3=Post_Install_Create_user_lib STEP4=Post_Install_Create_user_lib STEP5=Post_Install_components_dat STEP6=Post_Install_Write_env_var [Open_Access] Path=C:\Cadence\PSpiceTI [INSTALLATION INFO] Installation type=STANDALONE [SYSTEM_ENV_VAR_AFTER_INST] ComSpec=%SystemRoot%\system32\cmd.exe DriverData=C:\Windows\System32\Drivers\DriverData OS=Windows_NT PROCESSOR_ARCHITECTURE=AMD64 TEMP=%SystemRoot%\TEMP TMP=%SystemRoot%\TEMP USERNAME=SYSTEM windir=%SystemRoot% ANSYSEM_ROOT201=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 CANoe_InstallDir=C:\Program Files\Vector CANoe 10.0\Exec64\ CANoe_InstallDir64=C:\Program Files\Vector CANoe 10.0\Exec64\ deployment.expiration.check.enabled=false MAN_CHM_INDEX=C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkutil.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkapi.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tcltk.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/chm/tkcurses.idx;C:/Program Files (x86)/Integrity/ILMClient11/etc/isman.idx MAN_HTM_PATHS=C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/pod;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/ext;C:/PROGRA~2/INTEGR~2/Toolkit/etc/htm/perl/lib MAN_TXT_INDEX=C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkutil.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkapi.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tcltk.idx;C:/PROGRA~2/INTEGR~2/Toolkit/etc/tkcurses.idx;C:/Program Files (x86)/Integrity/ILMClient11/etc/isman.idx MGLS_LICENSE_FILE=1717@de01-englic03 Path=C:\Program Files (x86)\Integrity\ILMClient11\bin;C:\ProgramData\Oracle\Java\javapath;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\PROGRA~2\INTEGR~2\Toolkit\mksnt;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\1.Storage\1.Projects\Task VEVA GVP3 Maintenance\KAFAS 2\SW +Tools\nvd Kafas;C:\Program Files (x86)\National Instruments\Shared\LabVIEW CLI;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files\Microsoft VS Code\bin PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.sh;.ksh;.csh;.sed;.awk;.pl PSModulePath=%ProgramFiles%\WindowsPowerShell\Modules;%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules;C:\Program Files (x86)\Microsoft Azure Information Protection\Powershell ROOTDIR=C:/PROGRA~2/INTEGR~2/Toolkit SAP_IPv6_ACTIVE=1 SAPLOGON_INI_FILE=C:\WINDOWS\saplogon.ini SIMPLORER_HOME=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 SIMPMSCoSimDLL=C:\Program Files\AnsysEM\AnsysEM19.2\Win64\SIMPMSCoSim.dll SIMPPncSimCoSimDLL=C:\Program Files\AnsysEM\AnsysEM19.2\Win64\SIMPncSimCoSim.dll:LoadCoSimInterface SIWAVE_INSTALL_DIR=C:\Program Files\AnsysEM\AnsysEM20.1\Win64 UATDATA=C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77 VXIPNPPATH=C:\Program Files (x86)\IVI Foundation\VISA\ VXIPNPPATH64=C:\Program Files\IVI Foundation\VISA\ RABBITMQ_BASE=C:\ProgramData\RabbitMQ ERLANG_HOME=C:\Program Files\erl9.2 RABBITMQ_NODENAME=rabbit@localhost RABBITMQ_CONFIG_FILE="C:\ProgramData\National Instruments\Skyline\RabbitMQ\rabbitmq" NIEXTCCOMPILERSUPP=C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\ NIDAQmxSwitchDir=C:\Program Files (x86)\National Instruments\NI-DAQ\Switch\ NUMBER_OF_PROCESSORS=12 PROCESSOR_LEVEL=6 PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 10, GenuineIntel PROCESSOR_REVISION=9e0a MLM_LICENSE_FILE=27000@DE01-ENGLIC02.CORP.INT [USER_ENV_VAR_AFTER_INST] Path=%USERPROFILE%\AppData\Local\Microsoft\WindowsApps; TEMP=%USERPROFILE%\AppData\Local\Temp TMP=%USERPROFILE%\AppData\Local\Temp CDS_LISTENER_MODE=LOCAL CDS_HOME=C:\cds_spb_home
Hello Bogdan,
Please look in C:\Users\ < your user name > \AppData\Roaming\Cadence\PSpiceTIInstall to locate the file called cdsPspiceTIlog.txt. If this file does not exist, please send us a screenshot of this folder's contents.
Thank you,
Jackie
Hello Bogdan,
Did you perform the installation or someone else? Did you install with administrator privileges or user privileges? PSpice for TI is intended to be installed by the user with basic user privileges. If you used administrator privileges, or someone else installed for you, please uninstall and try the installation with regular user privileges for your own account (not administrator).
Thank you,
Jackie
Hello Jackie,
This may be the issue, I used administrator privileges. I will try with my own account.
