PSPICE-FOR-TI: Simluation Error
Part Number: PSPICE-FOR-TI
Dear,
I received an error infor shown as below.
ERROR(ORPSIM-16583): Detected an imported model containing transistors or diodes. For such models, PSpice for TI supports a minimum of one and maximum of three traces. Reduce the number of traces and simulate again.
How should it be solved?
    but I did not import any 3rd-party library in this sch. all 74hc series come from the tool itself. and I update the lib timely
  • Hi Feng,
    would you please share your project with us? You can archive it according to this post: e2e.ti.com/.../faq-pspice-for-ti-how-do-i-share-pspice-for-ti-projects
    JC
  • Hi Feng,
    Thanks for the file. We are looking at this.
    JC
  • Hi Feng,
    Do you get this error?
    ERROR(ORPSIM-16152): Invalid number: Error while converting token 'maxICC' to double value. Token can be a constant or expression
    JC
  • no. below is the error notes.
  • Hi Feng,
    Please turn on the following option and run the simulation again, then share the file "design.out"?
    JC
  • design.out.txt
    **** 07/30/21 22:54:21 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ********
     ** Profile: "SCHEMATIC1-design"  [ c:\users\cnfezha14\onedrive - abb\.01.work\workspace\ao820\spice\design1-pspicefiles\schematic1\d
     ****     CIRCUIT DESCRIPTION
    ** Creating circuit file "design.cir"
    ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
    *Libraries:
    * Profile Libraries :
    * Local Libraries :
    * From [PSPICE NETLIST] section of C:\cds_spb_home\cdssetup\OrCAD_PSpiceTIPSpice_Install\17.4.0\PSpice.ini file:
    .lib "nom_pspti.lib"
    .lib "nom.lib"
    *Analysis directives:
    .TRAN  0 1000ns 0
    .OPTIONS LIBRARY
    .OPTIONS ADVCONV
    .OPTIONS FILEMODELSEARCH
    .PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
    .INC "..\SCHEMATIC1.net"
    **** INCLUDING SCHEMATIC1.net ****
    * source DESIGN1
    X_U1         N00371 N00711 N00424 VCC 0 SN74AHC1G00
    X_U2         N00393 N00371 VCC 0 SN74AHC1G04
    V_V1         VCC 0 3.3
    R_R1         N00400 N00424  1m TC=0,0
    R_R2         N00400 N00371  100k TC=0,0
    C_C1         N00400 N00393  1n  TC=0,0
    R_R3         0 N00393  100k TC=0,0
    C_C2         0 N00711  1n  TC=0,0
    R_R4         N00711 VCC  100k TC=0,0
    **** RESUMING design.cir ****
    .END
    **** FROM LIBRARY SN74AHC1G00.lib ****
    .SUBCKT SN74AHC1G00 Y A B VCC AGND
    XU1 Y A B VCC AGND LOGIC_GATE_2PIN_OD_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    .ENDS
    **** FROM LIBRARY SN74AHC1G04.lib ****
    .SUBCKT SN74AHC1G04 Y A VCC AGND
    XU1 Y A VCC VCC AGND LOGIC_GATE_2PIN_OD_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    .ENDS
    .SUBCKT LOGIC_GATE_2PIN_OD_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 OUT A B VCC GND
    .PARAM VCC_ABS_MAX = 7
    .PARAM VCC_MAX = 5.5
    .PARAM RA = 2200000000
    .PARAM RB = 2200000000
    .PARAM CA = 1e-11
    .PARAM CB = 1e-11
    .PARAM ROEZ = 2000.0000000000016
    .PARAM COEZ = 1e-11
    RA  A  GND {RA}
    RB  B  GND {RB}
    CA  A  GND {CA}
    CB  B  GND {CB}
    XUA NA A VCC GND LOGIC_INPUT_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    XUB NB B VCC GND LOGIC_INPUT_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    XOUTPD NOUTG NOUTTPD VCC GND TPD_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    XUOUT NOUTTPD NOUT_INT VCC GND LOGIC_PP_OUTPUT_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    XICC VCC GND NVIOUT LOGIC_ICC_LVC_2i_NAND_PP_CMOS_SN74AHC1G00
    SICC VCC GND VCC GND SW1
    H1 NVIOUT GND VIOUT 1
    VIOUT NOUT_INT OUTsw 0
    SIOFF OUTsw OUT VCC GND SW2
    DA2 GND A D1
    DB2 GND B D1
    DO2 GND OUT D1
    RDA1 NA1 GND 1e6
    SDA1 NA1 A VCC GND SW2
    RDB1 NB1 GND 1e6
    SDB1 NB1 B VCC GND SW2
    RDO1 NO1 GND 1e6
    SDO1 NO1 OUT VCC GND SW2
    .MODEL SW1 VSWITCH VON = {VCC_ABS_MAX} VOFF = {VCC_MAX} RON = 10 ROFF = 60e6
    .MODEL SW2 VSWITCH VON = {0.55} VOFF = {0.45} RON = 10m ROFF = 100e6
    .MODEL D1 D
    .ENDS
    .SUBCKT LOGIC_GATE_2PIN_OD_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 OUT A B VCC GND
    .PARAM RA = 880000000
    .PARAM RB = 880000000
    .PARAM CA = 1e-11
    .PARAM CB = 1e-11
    .PARAM ROEZ = 2000
    .PARAM COEZ = 3e-12
    RA  A  GND {RA}
    RB  B  GND {RB}
    CA  A  GND {CA}
    CB  B  GND {CB}
    XUA NA A VCC GND LOGIC_INPUT_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    XUB NB B VCC GND LOGIC_INPUT_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    XOUTPD NOUTG NOUTTPD VCC GND TPD_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    XUOUT NOUTTPD NOUT_INT VCC GND LOGIC_PP_OUTPUT_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    XICC VCC GND NVIOUT LOGIC_ICC_AHC_1i_NAND_PP_CMOS_SN74AHC1G04
    DA2 GND A D1
    DB2 GND B D1
    DO2 GND OUT D1
    RDA1 NA1 GND 1e6
    RDB1 NB1 GND 1e6
    RDO1 NO1 GND 1e6
    .MODEL D1 D
    .ENDS
    .SUBCKT LOGIC_INPUT_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 OUT IN VCC VEE
    .PARAM STANDARD_INPUT_SELECT = 1
    .PARAM SCHMITT_TRIGGER_INPUT_SELECT = 0
    ESTD_THR VSTD_THR VEE TABLE {V(VCC,VEE)} =
    +(1,0.5)
    +(1.8,0.9)
    +(2.5,1.25)
    +(3.3,1.65)
    +(5,2.5)
    +(6,3)
    ETRP_P VTRP_P VEE TABLE {V(VCC,VEE)} =
    +(3,1.2)
    +(4.5,1.75)
    +(5.5,2.15)
    ETRP_N VTRP_N VEE TABLE {V(VCC,VEE)} =
    +(3,0.9)
    +(4.5,1.35)
    +(5.5,1.65)
    EHYST VHYST VEE TABLE {V(VCC,VEE)} =
    +(3,0.3)
    +(4.5,0.4)
    +(5.5,0.5)
    ETRUE NTRUE VEE VALUE = {V(VCC,VEE)}
    EFALSE NFALSE VEE VALUE = {0}
    EBETA BETA VEE VALUE = {V(VHYST,VEE)/(V(NTRUE,VEE) - V(NFALSE,VEE) + V(VHYST,VEE))}
    EFB NFB VEE VALUE = {(1 - V(BETA,VEE))*V(IN,VEE) + V(BETA,VEE)*V(CURR_OUT,VEE)}
    EREF NREF VEE VALUE = {0.5*(1 - V(BETA,VEE))*(V(VTRP_P,VEE) + V(VTRP_N,VEE))
    + + 0.5*V(BETA,VEE)*(V(NTRUE,VEE) + V(NFALSE,VEE))}
    EDIFF NDIFF VEE VALUE = {V(NFB,NREF)}
    ESWITCH VSWITCH VEE VALUE = {0.5*(-SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
    ESWITCH1 VSWITCH1 VEE VALUE = {0.5*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
    GCOMP VEE CURR_OUT VALUE = {SCHMITT_TRIGGER_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
    GSTD VEE CURR_OUT VALUE = {STANDARD_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(IN,VSTD_THR)) + ABS(SGN(V(IN,VSTD_THR))))}
    ROUT CURR_OUT VEE 1
    EMID MID VEE VALUE = {0.5*(V(VCC,VEE) + V(VEE))}
    EARG NARG VEE VALUE = {V(CURR_OUT,VEE) - V(MID,VEE)}
    EOUT OUT VEE VALUE = {0.5*(SGN(V(NARG,VEE)) + ABS(SGN(V(NARG,VEE) ) ) )}
    .PARAM MAXICC = .0009
    .PARAM VT = .7
    .PARAM VCC_MIN = 3
    EV_VT1 VTN VEE VALUE = { VT }
    EV_VT2 VTP VEE VALUE = { V(VCC,VEE) - VT }
    ETEST TEST VEE VALUE = {.9*V(VCC,VEE)}
    EVTHDIFF VTH_DIFF VEE VALUE = {V(IN,VSTD_THR)}
    EVTHPDIFF VTHP_DIFF VEE VALUE = {V(IN,VTRP_P)}
    EVTHNDIFF VTHN_DIFF VEE VALUE = {V(IN,VTRP_N)}
    EVTNDIFF VTN_DIFF VEE VALUE = { V(IN,VTN) }
    EVTPDIFF VTP_DIFF VEE VALUE = { V(IN,VTP) }
    GICCVA VCC VEE VALUE = { (-ABS(( (1+SGN(V(VTN_DIFF,VEE)) ) )/2 -1) *
    + 2*MAXICC*((V(IN,VEE)-VT)/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH,VEE)}
    GICCVB VCC VEE VALUE = { (ABS(( (1+SGN(V(VTHP_DIFF,VEE)) ) )/2 -1) *
    GICCVC VCC VEE VALUE = { ( ABS(  (1+SGN(V(VTHN_DIFF,VEE)) ) )/2  *
    + 2*MAXICC*((V(IN,VEE)-(V(VCC,VEE)-VT))/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH1,VEE)}
    GICCVD VCC VEE VALUE = { (-ABS(  (1+SGN(V(VTP_DIFF,VEE)) ) )/2  *
    .ENDS
    .SUBCKT LOGIC_FUNCTION_2_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 A B OUT VCC VEE
    .PARAM AND  = 0
    .PARAM NAND = 1
    .PARAM OR   = 0
    .PARAM NOR  = 0
    .PARAM XOR  = 0
    .PARAM XNOR = 0
    GAND  VEE N1 VALUE = {AND*V(A,VEE)*V(B,VEE)}
    GNAND VEE N1 VALUE = {NAND*(1 - V(A,VEE)*V(B,VEE))}
    GOR   VEE N1 VALUE = {OR*(MIN(V(A,VEE) + V(B,VEE),1))}
    GNOR  VEE N1 VALUE = {NOR*(1 - MIN(V(A,VEE) + V(B,VEE),1))}
    GXOR  VEE N1 VALUE = {XOR*((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE)))}
    GXNOR VEE N1 VALUE = {XNOR*(1 - ((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE))))}
    RN1 N1 VEE 1
    EOUT OUT VEE N1 VEE 1
    .ENDS
    .SUBCKT TPD_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 IN OUT VCC VEE
    .PARAM TPDELAY1 = 1N
    .PARAM RS = 10K
    .PARAM CS = {-TPDELAY1/(RS*LOG(0.5))}
    ETPDNORM NTPDNORM VEE TABLE {V(VCC,VEE)} =
    +(3.3,6.7)
    +(5,4.7)
    G1 IN N1 VALUE = {V(IN,N1)/(V(NTPDNORM,VEE)*RS)}
    RZ IN N1 10G
    C1 N1 VEE {CS}
    E1 N2 VEE VALUE = {0.5*(1 + SGN(V(N1,VEE) - 0.5))}
    EOUT OUT VEE N2 VEE 1
    .ENDS
    .SUBCKT LOGIC_PP_OUTPUT_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 IN OUT VCC VEE
    EROH NROH VEE TABLE {V(VCC,VEE)} =
    +(2,2000)
    +(3,105)
    +(4.5,70)
    EROL NROL VEE TABLE {V(VCC,VEE)} =
    +(2,2000)
    +(3,90)
    +(4.5,46.25)
    E1 N1 VEE VALUE = {V(VCC,VEE)*V(IN,VEE)}
    GOUT N1 OUT VALUE = {V(N1,OUT)*(V(IN,VEE)/V(NROH,VEE) + (1 - V(IN,VEE))/V(NROL,VEE))}
    .ENDS
    .SUBCKT LOGIC_ICC_LVC_2i_NAND_PP_CMOS_SN74AHC1G00 VCC VEE VIOUT
    .PARAM ICC = 5e-09
    .PARAM VCC_MIN = 2
    GICC VCC VEE VALUE = {ICC*0.5*(1 + SGN(V(VCC,VEE) - VCC_MIN))}
    EGNDF GNDF 0 VALUE = {0.5*(V(VCC) + V(VEE))}
    GOUTP VCC GNDF VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
    GOUTN GNDF VEE VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
    .ENDS
    .SUBCKT LOGIC_INPUT_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 OUT IN VCC VEE
    +(1,0.5)
    +(1.8,0.9)
    +(2.5,1.25)
    +(3.3,1.65)
    +(5,2.5)
    +(6,3)
    +(4.5,1.5)
    +(5.5,1.6)
    +(4.5,0.7)
    +(5.5,0.8)
    +(4.5,0.8)
    +(5.5,0.8)
    ROUT CURR_OUT VEE 1
    .PARAM VT = .7
    .PARAM VCC_MIN = 2
    .ENDS
    .SUBCKT LOGIC_FUNCTION_2_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 A B OUT VCC VEE
    .PARAM AND  = 0
    .PARAM NAND = 1
    .PARAM OR   = 0
    .PARAM NOR  = 0
    .PARAM XOR  = 0
    .PARAM XNOR = 0
    RN1 N1 VEE 1
    .ENDS
    .SUBCKT TPD_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 IN OUT VCC VEE
    .PARAM RS = 10K
    +(3.3,5.75)
    +(5,4)
    RZ IN N1 10G
    C1 N1 VEE {CS}
    .ENDS
    .SUBCKT LOGIC_PP_OUTPUT_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 IN OUT VCC VEE
    +(2,0)
    +(3,63)
    +(4.5,42)
    +(2,1200)
    +(3,54)
    +(4.5,27.75)
    .ENDS
    .SUBCKT LOGIC_ICC_AHC_1i_NAND_PP_CMOS_SN74AHC1G04 VCC VEE VIOUT
    .PARAM ICC = 1.25e-07
    .PARAM VCC_MIN = 2
    .ENDS
     ****     Diode MODEL PARAMETERS
                   X_U1.XU1.D1     X_U2.XU1.D1
              IS   10.000000E-15   10.000000E-15
     ****     Voltage Controlled Switch MODEL PARAMETERS
                   X_U1.XU1.SW1    X_U1.XU1.SW2    X_U2.XU1.SW1    X_U2.XU1.SW2
             RON   10                .01           10                .01
            ROFF   60.000000E+06  100.000000E+06   60.000000E+06  100.000000E+06
             VON    7                .55            7                .55
            VOFF    5.5              .45            5.5              .45
    ABORTING SIMULATION
     ****     JOB STATISTICS SUMMARY
    Node counts:
      Top level (NUNODS)                =           7
      External (NCNODS)                 =         135
      Total (NUMNOD)                    =         135
    Total device count (NUMEL)          =         205
      Capacitors (C)                    =           8
      Diodes (D)                        =           6
      VCVS (E)                          =         108
      VCCS (G)                          =          46
      CCVS (H)                          =           2
      Resistors (R)                     =          22
      VSwitches (S)                     =          10
      Voltage Sources (V)               =           3
    Number of subcircuits (X)           =          16
    Matrix statistics:
      Matrix size (NSTOP)               =         248
      Initial no. elements (NTTAR)      =         535
      No. elements w/ fillin (NTTBR)    =         535
      No. fillins (IFILL)               =           0
      No. overflows (NTTOV)             =           0
      No. LU operations (IOPS)          =           0
      Percent sparsity (PERSPA)         =      99.130
    Analysis statistics:
      No. total time points (NUMTTP)    =           0
      No. rejected time points (NUMRTP) =           0
      No. iterations (NUMNIT)           =           0
    Load Threads                        =           1
    Runtime statistics:                       Seconds      Iterations
      Matrix load                       =        0.00
      Matrix solution                   =        0.00               1
      Readin                            =         .61
      General setup                     =        0.00
      CMI setup                     =        0.00
      Setup                             =        0.00
      DC sweep                          =        0.00               0
      Bias point                        =        0.00               0
      AC and noise                      =        0.00               0
      Total transient analysis          =        0.00
      Output                            =        0.00
      Overhead                          =         .06
      License check-out time            =       11.61
      Total job time (using Solver 1)   =         .61
