I get almost all the way through the installation of PSpice for TI and get the following error (see below). Also attached is the cdsPspiceTIlog.txt file which doesn't show an details of what the error is
0310.cdsPspiceTIlog.txt
1:42:12 PM Thursday, June 17, 2021 : Initializing 1:42:12 PM Thursday, June 17, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 1:42:13 PM Thursday, June 17, 2021 : Response Content length = 1724 1:42:13 PM Thursday, June 17, 2021 : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 1:42:13 PM Thursday, June 17, 2021 : Reading Json URL File 1:42:13 PM Thursday, June 17, 2021 : setting media download server URL from Json File 1:42:13 PM Thursday, June 17, 2021 : Reading Json URL File 1:42:13 PM Thursday, June 17, 2021 : setting Dll path from Json File 1:42:13 PM Thursday, June 17, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 1:42:13 PM Thursday, June 17, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 1:42:13 PM Thursday, June 17, 2021 : parameter count = 1 1:42:13 PM Thursday, June 17, 2021 : -wrapper 1:42:14 PM Thursday, June 17, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system: 1:42:43 PM Thursday, June 17, 2021 : error_code cdsVblRegisterInstallation: VblSuccess 1:42:43 PM Thursday, June 17, 2021 : error_code cdsVblRequestLicense: VblSuccess 1:42:50 PM Thursday, June 17, 2021 : Set Installation and Home Directory() 1:42:50 PM Thursday, June 17, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI 1:42:50 PM Thursday, June 17, 2021 : Reading CDS_HOME environment variable 1:42:50 PM Thursday, June 17, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 1:42:50 PM Thursday, June 17, 2021 : First time installation. CDS_HOME will be set to default HOME directory. 1:42:50 PM Thursday, June 17, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it. 1:42:50 PM Thursday, June 17, 2021 : Creating directory : C:\cds_spb_home 1:42:53 PM Thursday, June 17, 2021 : Checking for memory space 1:42:53 PM Thursday, June 17, 2021 : Memory space available 1:42:53 PM Thursday, June 17, 2021 : Target Dir: C:\Cadence\PSpiceTI 1:42:53 PM Thursday, June 17, 2021 : Working Dir: C:\cds_spb_home 1:42:53 PM Thursday, June 17, 2021 : Silent ini file created 1:42:57 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK 1:42:57 PM Thursday, June 17, 2021 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480 1:42:57 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini 1:42:57 PM Thursday, June 17, 2021 : Completing download of 0x0409.ini 1:42:58 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK 1:42:58 PM Thursday, June 17, 2021 : Starting download of data1.cab Attempt no 1 DataSize is 31723644 1:43:10 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab 1:43:10 PM Thursday, June 17, 2021 : Completing download of data1.cab 1:43:12 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK 1:43:12 PM Thursday, June 17, 2021 : Starting download of data2.cab Attempt no 1 DataSize is 170137600 1:43:57 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab 1:43:57 PM Thursday, June 17, 2021 : Completing download of data2.cab 1:44:01 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK 1:44:01 PM Thursday, June 17, 2021 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1637864 1:44:01 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll 1:44:01 PM Thursday, June 17, 2021 : Completing download of ISSetup.dll 1:44:06 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK 1:44:06 PM Thursday, June 17, 2021 : Starting download of layout.bin Attempt no 1 DataSize is 994 1:44:06 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin 1:44:06 PM Thursday, June 17, 2021 : Completing download of layout.bin 1:44:09 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK 1:44:09 PM Thursday, June 17, 2021 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357 1:44:09 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf 1:44:09 PM Thursday, June 17, 2021 : Completing download of pspInstall.pdf 1:44:11 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK 1:44:11 PM Thursday, June 17, 2021 : Starting download of setup.bmp Attempt no 1 DataSize is 552056 1:44:11 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp 1:44:11 PM Thursday, June 17, 2021 : Completing download of setup.bmp 1:44:15 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK 1:44:15 PM Thursday, June 17, 2021 : Starting download of setup.ini Attempt no 1 DataSize is 2440 1:44:15 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 1:44:15 PM Thursday, June 17, 2021 : Completing download of setup.ini 1:44:17 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK 1:44:17 PM Thursday, June 17, 2021 : Starting download of setup.inx Attempt no 1 DataSize is 571158 1:44:17 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 1:44:17 PM Thursday, June 17, 2021 : Completing download of setup.inx 1:44:18 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK 1:44:18 PM Thursday, June 17, 2021 : Starting download of data9.cab Attempt no 1 DataSize is 76919236 1:44:28 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab 1:44:29 PM Thursday, June 17, 2021 : Completing download of data9.cab 1:44:30 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK 1:44:30 PM Thursday, June 17, 2021 : Starting download of data3.cab Attempt no 1 DataSize is 209715200 1:44:58 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab 1:44:59 PM Thursday, June 17, 2021 : Completing download of data3.cab 1:45:00 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK 1:45:00 PM Thursday, June 17, 2021 : Starting download of data1.hdr Attempt no 1 DataSize is 4968262 1:45:01 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr 1:45:01 PM Thursday, June 17, 2021 : Completing download of data1.hdr 1:45:02 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK 1:45:02 PM Thursday, June 17, 2021 : Starting download of data4.cab Attempt no 1 DataSize is 209715200 1:45:03 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK 1:45:03 PM Thursday, June 17, 2021 : Starting download of data5.cab Attempt no 1 DataSize is 209715200 1:45:43 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab 1:45:44 PM Thursday, June 17, 2021 : Completing download of data4.cab 1:45:45 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab 1:45:45 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK 1:45:45 PM Thursday, June 17, 2021 : Starting download of data6.cab Attempt no 1 DataSize is 209715200 1:45:46 PM Thursday, June 17, 2021 : Completing download of data5.cab 1:45:47 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK 1:45:47 PM Thursday, June 17, 2021 : Starting download of data7.cab Attempt no 1 DataSize is 209715200 1:46:28 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab 1:46:29 PM Thursday, June 17, 2021 : Completing download of data6.cab 1:46:30 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab 1:46:30 PM Thursday, June 17, 2021 : Completing download of data7.cab 1:46:31 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK 1:46:31 PM Thursday, June 17, 2021 : Starting download of data8.cab Attempt no 1 DataSize is 209715200 1:46:32 PM Thursday, June 17, 2021 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK 1:46:32 PM Thursday, June 17, 2021 : Starting download of installsetup.exe Attempt no 1 DataSize is 954856 1:46:32 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe 1:46:32 PM Thursday, June 17, 2021 : Completing download of installsetup.exe 1:47:36 PM Thursday, June 17, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab 1:47:37 PM Thursday, June 17, 2021 : Completing download of data8.cab 1:47:37 PM Thursday, June 17, 2021 : 1248250 1248250 1:47:37 PM Thursday, June 17, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe 1:47:37 PM Thursday, June 17, 2021 : Allegro Installation Start pid: 22408 1:47:44 PM Thursday, June 17, 2021 : NumberOfComponentsToBeInstalled = 39559 1:47:44 PM Thursday, June 17, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55 1:47:44 PM Thursday, June 17, 2021 : Updated NumberOfComponentsInstalled = 396 1:51:18 PM Thursday, June 17, 2021 : Feature transfer complete..disabling close button 1:51:39 PM Thursday, June 17, 2021 : An error occured and installation needs to close. Refer log for more details Error Code: 1099 1:51:39 PM Thursday, June 17, 2021 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall for error details. 3:30:31 PM Friday, June 18, 2021 : Initializing 3:30:31 PM Friday, June 18, 2021 : Deleting file : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 3:30:31 PM Friday, June 18, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 3:30:34 PM Friday, June 18, 2021 : Response Content length = 1724 3:30:34 PM Friday, June 18, 2021 : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 3:30:34 PM Friday, June 18, 2021 : Reading Json URL File 3:30:34 PM Friday, June 18, 2021 : setting media download server URL from Json File 3:30:34 PM Friday, June 18, 2021 : Reading Json URL File 3:30:34 PM Friday, June 18, 2021 : setting Dll path from Json File 3:30:34 PM Friday, June 18, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 3:30:34 PM Friday, June 18, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 3:30:34 PM Friday, June 18, 2021 : parameter count = 1 3:30:34 PM Friday, June 18, 2021 : -wrapper 3:30:35 PM Friday, June 18, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system: 3:50:31 PM Friday, June 18, 2021 : error_code cdsVblRegisterInstallation: VblSuccess 3:50:31 PM Friday, June 18, 2021 : error_code cdsVblRequestLicense: VblSuccess 3:50:34 PM Friday, June 18, 2021 : Set Installation and Home Directory() 3:50:34 PM Friday, June 18, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI 3:50:34 PM Friday, June 18, 2021 : Reading CDS_HOME environment variable 3:50:34 PM Friday, June 18, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 3:50:34 PM Friday, June 18, 2021 : First time installation. CDS_HOME will be set to default HOME directory. 3:50:35 PM Friday, June 18, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it. 3:50:35 PM Friday, June 18, 2021 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 3:50:44 PM Friday, June 18, 2021 : Checking for memory space 3:50:44 PM Friday, June 18, 2021 : Memory space available 3:50:44 PM Friday, June 18, 2021 : Target Dir: C:\Cadence\PSpiceTI 3:50:44 PM Friday, June 18, 2021 : Working Dir: C:\cds_spb_home 3:50:44 PM Friday, June 18, 2021 : Silent ini file created 3:50:44 PM Friday, June 18, 2021 : Skipping download of 0x0409.ini DataSize is 22480 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini 3:50:44 PM Friday, June 18, 2021 : Skipping download of data1.hdr DataSize is 4968262 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr 3:50:44 PM Friday, June 18, 2021 : Skipping download of data1.cab DataSize is 31723644 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab 3:50:44 PM Friday, June 18, 2021 : Skipping download of ISSetup.dll DataSize is 1637864 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll 3:50:44 PM Friday, June 18, 2021 : Skipping download of layout.bin DataSize is 994 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin 3:50:44 PM Friday, June 18, 2021 : Skipping download of pspInstall.pdf DataSize is 85357 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf 3:50:44 PM Friday, June 18, 2021 : Skipping download of setup.bmp DataSize is 552056 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp 3:50:44 PM Friday, June 18, 2021 : Skipping download of setup.ini DataSize is 2440 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 3:50:44 PM Friday, June 18, 2021 : Skipping download of setup.inx DataSize is 571158 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 3:50:44 PM Friday, June 18, 2021 : Skipping download of data9.cab DataSize is 76919236 3:50:44 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab 3:50:45 PM Friday, June 18, 2021 : Skipping download of data2.cab DataSize is 170137600 3:50:45 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab 3:50:45 PM Friday, June 18, 2021 : Skipping download of data3.cab DataSize is 209715200 3:50:45 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab 3:50:45 PM Friday, June 18, 2021 : Skipping download of data4.cab DataSize is 209715200 3:50:45 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab 3:50:46 PM Friday, June 18, 2021 : Skipping download of data5.cab DataSize is 209715200 3:50:46 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab 3:50:46 PM Friday, June 18, 2021 : Skipping download of data6.cab DataSize is 209715200 3:50:46 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab 3:50:46 PM Friday, June 18, 2021 : Skipping download of data7.cab DataSize is 209715200 3:50:46 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab 3:50:46 PM Friday, June 18, 2021 : Skipping download of installsetup.exe DataSize is 954856 3:50:46 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe 3:50:46 PM Friday, June 18, 2021 : 265564 265564 3:50:46 PM Friday, June 18, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe 3:50:46 PM Friday, June 18, 2021 : Skipping download of data8.cab DataSize is 209715200 3:50:46 PM Friday, June 18, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab 3:50:47 PM Friday, June 18, 2021 : Allegro Installation Start pid: 19652 3:50:53 PM Friday, June 18, 2021 : NumberOfComponentsToBeInstalled = 39559 3:50:53 PM Friday, June 18, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55 3:50:53 PM Friday, June 18, 2021 : Updated NumberOfComponentsInstalled = 396 3:53:41 PM Friday, June 18, 2021 : Feature transfer complete..disabling close button 4:07:51 PM Friday, June 18, 2021 : An error occured and installation needs to close. Refer log for more details Error Code: 1099 4:07:51 PM Friday, June 18, 2021 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall for error details. 10:13:52 PM Friday, June 18, 2021 : Message: Cannot connect to server because there is no Internet connection. Check Internet connection of the system and run installer again. 11:49:27 AM Monday, July 19, 2021 : Initializing 11:49:27 AM Monday, July 19, 2021 : Deleting file : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 11:49:27 AM Monday, July 19, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 11:49:28 AM Monday, July 19, 2021 : Response Content length = 1724 11:49:28 AM Monday, July 19, 2021 : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:49:28 AM Monday, July 19, 2021 : Reading Json URL File 11:49:28 AM Monday, July 19, 2021 : setting media download server URL from Json File 11:49:28 AM Monday, July 19, 2021 : Reading Json URL File 11:49:28 AM Monday, July 19, 2021 : setting Dll path from Json File 11:49:28 AM Monday, July 19, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:49:28 AM Monday, July 19, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:49:28 AM Monday, July 19, 2021 : parameter count = 1 11:49:28 AM Monday, July 19, 2021 : -wrapper 11:49:29 AM Monday, July 19, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system: 11:51:00 AM Monday, July 19, 2021 : error_code cdsVblRegisterInstallation: VblSuccess 11:51:01 AM Monday, July 19, 2021 : error_code cdsVblRequestLicense: VblSuccess 11:51:05 AM Monday, July 19, 2021 : Set Installation and Home Directory() 11:51:05 AM Monday, July 19, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI 11:51:05 AM Monday, July 19, 2021 : Reading CDS_HOME environment variable 11:51:05 AM Monday, July 19, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 11:51:05 AM Monday, July 19, 2021 : First time installation. CDS_HOME will be set to default HOME directory. 11:51:05 AM Monday, July 19, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it. 11:51:05 AM Monday, July 19, 2021 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 11:51:13 AM Monday, July 19, 2021 : Checking for memory space 11:51:13 AM Monday, July 19, 2021 : Memory space available 11:51:13 AM Monday, July 19, 2021 : Target Dir: C:\Cadence\PSpiceTI 11:51:13 AM Monday, July 19, 2021 : Working Dir: C:\cds_spb_home 11:51:13 AM Monday, July 19, 2021 : Silent ini file created 11:51:13 AM Monday, July 19, 2021 : Skipping download of 0x0409.ini DataSize is 22480 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini 11:51:13 AM Monday, July 19, 2021 : Skipping download of data1.hdr DataSize is 4968262 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr 11:51:13 AM Monday, July 19, 2021 : Skipping download of data1.cab DataSize is 31723644 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab 11:51:13 AM Monday, July 19, 2021 : Skipping download of ISSetup.dll DataSize is 1637864 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll 11:51:13 AM Monday, July 19, 2021 : Skipping download of layout.bin DataSize is 994 11:51:13 AM Monday, July 19, 2021 : Skipping download of pspInstall.pdf DataSize is 85357 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf 11:51:13 AM Monday, July 19, 2021 : Skipping download of setup.bmp DataSize is 552056 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp 11:51:13 AM Monday, July 19, 2021 : Skipping download of setup.ini DataSize is 2440 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 11:51:13 AM Monday, July 19, 2021 : Skipping download of setup.inx DataSize is 571158 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 11:51:13 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin 11:51:14 AM Monday, July 19, 2021 : Skipping download of data9.cab DataSize is 76919236 11:51:14 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab 11:51:14 AM Monday, July 19, 2021 : Skipping download of data2.cab DataSize is 170137600 11:51:14 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab 11:51:14 AM Monday, July 19, 2021 : Skipping download of data3.cab DataSize is 209715200 11:51:14 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab 11:51:14 AM Monday, July 19, 2021 : Skipping download of data4.cab DataSize is 209715200 11:51:14 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab 11:51:15 AM Monday, July 19, 2021 : Skipping download of data5.cab DataSize is 209715200 11:51:15 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab 11:51:15 AM Monday, July 19, 2021 : Skipping download of data6.cab DataSize is 209715200 11:51:15 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab 11:51:16 AM Monday, July 19, 2021 : Skipping download of data7.cab DataSize is 209715200 11:51:16 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab 11:51:16 AM Monday, July 19, 2021 : Skipping download of installsetup.exe DataSize is 954856 11:51:16 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe 11:51:16 AM Monday, July 19, 2021 : 266464 266464 11:51:16 AM Monday, July 19, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe 11:51:16 AM Monday, July 19, 2021 : Skipping download of data8.cab DataSize is 209715200 11:51:16 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab 11:51:16 AM Monday, July 19, 2021 : Allegro Installation Start pid: 26468 11:51:23 AM Monday, July 19, 2021 : NumberOfComponentsToBeInstalled = 39559 11:51:23 AM Monday, July 19, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55 11:51:23 AM Monday, July 19, 2021 : Updated NumberOfComponentsInstalled = 396 11:55:22 AM Monday, July 19, 2021 : Feature transfer complete..disabling close button 11:55:50 AM Monday, July 19, 2021 : An error occured and installation needs to close. Refer log for more details Error Code: 1099 11:55:50 AM Monday, July 19, 2021 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall for error details. 11:57:41 AM Monday, July 19, 2021 : Initializing 11:57:41 AM Monday, July 19, 2021 : Deleting file : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt 11:57:41 AM Monday, July 19, 2021 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt 11:57:41 AM Monday, July 19, 2021 : Response Content length = 1724 11:57:41 AM Monday, July 19, 2021 : C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1724 11:57:41 AM Monday, July 19, 2021 : Reading Json URL File 11:57:41 AM Monday, July 19, 2021 : setting media download server URL from Json File 11:57:41 AM Monday, July 19, 2021 : Reading Json URL File 11:57:41 AM Monday, July 19, 2021 : setting Dll path from Json File 11:57:41 AM Monday, July 19, 2021 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 11:57:41 AM Monday, July 19, 2021 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 11:57:41 AM Monday, July 19, 2021 : parameter count = 1 11:57:41 AM Monday, July 19, 2021 : -wrapper 11:57:42 AM Monday, July 19, 2021 : ReleaseVersion in XML: 17.40.006 InstalledVersion on system: 11:57:54 AM Monday, July 19, 2021 : error_code cdsVblRegisterInstallation: VblSuccess 11:57:55 AM Monday, July 19, 2021 : error_code cdsVblRequestLicense: VblSuccess 11:58:00 AM Monday, July 19, 2021 : Set Installation and Home Directory() 11:58:00 AM Monday, July 19, 2021 : Setting default Installation directory : C:\Cadence\PSpiceTI 11:58:00 AM Monday, July 19, 2021 : Reading CDS_HOME environment variable 11:58:00 AM Monday, July 19, 2021 : CDS_HOME is not present or is empty. Need to set CDS_HOME. 11:58:00 AM Monday, July 19, 2021 : First time installation. CDS_HOME will be set to default HOME directory. 11:58:00 AM Monday, July 19, 2021 : Checking if CDS_HOME directory exists and whether user has permission to create it. 11:58:00 AM Monday, July 19, 2021 : HOME directory exists. Checking for write permissions in :C:\cds_spb_home 11:58:02 AM Monday, July 19, 2021 : Checking for memory space 11:58:02 AM Monday, July 19, 2021 : Memory space available 11:58:02 AM Monday, July 19, 2021 : Target Dir: C:\Cadence\PSpiceTI 11:58:02 AM Monday, July 19, 2021 : Working Dir: C:\cds_spb_home 11:58:02 AM Monday, July 19, 2021 : Silent ini file created 11:58:02 AM Monday, July 19, 2021 : Skipping download of 0x0409.ini DataSize is 22480 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini 11:58:02 AM Monday, July 19, 2021 : Skipping download of data1.hdr DataSize is 4968262 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr 11:58:02 AM Monday, July 19, 2021 : Skipping download of data1.cab DataSize is 31723644 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab 11:58:02 AM Monday, July 19, 2021 : Skipping download of ISSetup.dll DataSize is 1637864 11:58:02 AM Monday, July 19, 2021 : Skipping download of layout.bin DataSize is 994 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll 11:58:02 AM Monday, July 19, 2021 : Skipping download of pspInstall.pdf DataSize is 85357 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin 11:58:02 AM Monday, July 19, 2021 : Skipping download of setup.ini DataSize is 2440 11:58:02 AM Monday, July 19, 2021 : Skipping download of setup.inx DataSize is 571158 11:58:02 AM Monday, July 19, 2021 : Skipping download of setup.bmp DataSize is 552056 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf 11:58:02 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 11:58:03 AM Monday, July 19, 2021 : Skipping download of data9.cab DataSize is 76919236 11:58:03 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab 11:58:03 AM Monday, July 19, 2021 : Skipping download of data2.cab DataSize is 170137600 11:58:03 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab 11:58:03 AM Monday, July 19, 2021 : Skipping download of data3.cab DataSize is 209715200 11:58:03 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab 11:58:03 AM Monday, July 19, 2021 : Skipping download of data4.cab DataSize is 209715200 11:58:03 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab 11:58:04 AM Monday, July 19, 2021 : Skipping download of data5.cab DataSize is 209715200 11:58:04 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab 11:58:04 AM Monday, July 19, 2021 : Skipping download of data6.cab DataSize is 209715200 11:58:04 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab 11:58:04 AM Monday, July 19, 2021 : Skipping download of data7.cab DataSize is 209715200 11:58:04 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab 11:58:04 AM Monday, July 19, 2021 : Skipping download of installsetup.exe DataSize is 954856 11:58:04 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe 11:58:05 AM Monday, July 19, 2021 : 594052 594052 11:58:05 AM Monday, July 19, 2021 : Setup exe path: C:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe 11:58:05 AM Monday, July 19, 2021 : Skipping download of data8.cab DataSize is 209715200 11:58:05 AM Monday, July 19, 2021 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab 11:58:05 AM Monday, July 19, 2021 : Allegro Installation Start pid: 29608 11:58:12 AM Monday, July 19, 2021 : NumberOfComponentsToBeInstalled = 39559 11:58:12 AM Monday, July 19, 2021 : Updated NumberOfComponentsToBeInstalled = 40354.55 11:58:12 AM Monday, July 19, 2021 : Updated NumberOfComponentsInstalled = 396 12:02:00 PM Monday, July 19, 2021 : Feature transfer complete..disabling close button 12:07:23 PM Monday, July 19, 2021 : An error occured and installation needs to close. Refer log for more details Error Code: 1099 12:07:23 PM Monday, July 19, 2021 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\Lgunseor\AppData\Roaming\Cadence\PspiceTIInstall for error details.
Larry A. Gunseor
