Part Number: TIDA-00489
Other Parts Discussed in Thread: CC1310, TIDA-01476
Hello guys,
we are using the TIDA-00489 design with the sensor example of the 15.4Stack SDK 3.2. I just stumbled over the BoardGpioInitTable[] of the sensor example SDK, which looks like this:
const PIN_Config BoardGpioInitTable[] = {
CC1310_LAUNCHXL_PIN_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
CC1310_LAUNCHXL_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
CC1310_LAUNCHXL_PIN_BTN1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS, /* Button is active low */
CC1310_LAUNCHXL_PIN_BTN2 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS, /* Button is active low */
CC1310_LAUNCHXL_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN, /* External flash chip select */
CC1310_LAUNCHXL_UART_RX | PIN_INPUT_EN | PIN_PULLDOWN, /* UART RX via debugger back channel */
CC1310_LAUNCHXL_UART_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* UART TX via debugger back channel */
CC1310_LAUNCHXL_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI master out - slave in */
CC1310_LAUNCHXL_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI master in - slave out */
CC1310_LAUNCHXL_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN, /* SPI clock */
CC1310_LAUNCHXL_DIO16_TDO | PIN_INPUT_EN | PIN_NOPULL | PIN_HYSTERESIS, /* PIR low */
CC1310_LAUNCHXL_DIO17_TDI | PIN_INPUT_EN | PIN_NOPULL | PIN_HYSTERESIS, /* PIR high */
PIN_TERMINATE
This table (like the rest of the sensor example from the SDK) seems to be fitting for the CC1310_Launchpad. In the TIDA-01476, which has the same hardware design as the TIDA-00489, there is also a software example for a sensor. The BoardGPIOInitTable[] looks different:
Board_PIR_Out_Lo | PIN_INPUT_EN | PIN_NOPULL | PIN_HYSTERESIS, /* PIR low */
Board_PIR_Out_Hi | PIN_INPUT_EN | PIN_NOPULL | PIN_HYSTERESIS, /* PIR high */
Board_Mode | PIN_INPUT_EN | PIN_NOPULL | PIN_HYSTERESIS, /* Backdoor to prevent shutdown */
Board_TEST26 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* Testpoint, DIO_26 */
Board_TEST27 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* Testpoint, DIO_27 */
Board_TEST28 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* Testpoint, DIO_28 */
Board_TEST29 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL, /* Testpoint, DIO_29 */
PIN_TERMINATE /* Terminate list */
Are there any benefits in changing my BoardGpioInitTable to the one of the TIDA-01476 firmware? I am hesitating since I dont want to change a running system. Besides, the current consumption during idle is at about 2.7µA and none of the SPI, LED or UART PINs are connected in the TIDA-00489 layout anyway.
Hope you can give me advice on this.
Best wishes
Slev1n
