TIDA-010054: NOMINAL VOLTAGE AND CURRENT OF MOSFET
Part Number: TIDA-010054
AS PER THE TI DESIGN, WHILE CALCULATING THE TURN OFF SWITCHING LOSS, NOMINAL VOLTAGE AND CURRENT OF THE DEVICE IS REQUIRED, IN THAT IT IS MENTIONED TO TAKE FROM THE DATASEET. MY QUERY IS FROM THE DATASHEET- VDS AND ID IS IT THE NOMINAL VOLTAGE AND CURRENT OF THE MOSFET? I HAD ENCLOSED THE DATASHEET ALSO FOR YOUR REFERENCE.
KINDLY ADDRESS THIS ISSUE, AS FOR BUILDING THE SAME PROTOTYPE (DAB) WITH IGBT WE NEED TO CALCULATE THE SWITCHING LOSSES.0160.C3M0075120K.pdf
