PSPICE-FOR-TI: Some installation problem
Part Number: PSPICE-FOR-TI
Dear team,
When I reinstall the PSPICE for TI, I got this message box:
after I click "Help", then I got this message box:
Could you please help with providing instructions for this?
Hank Lin
  • Hi Hank,
    Did you get a prompt to upgrade from S009 to S010?
    I may need you to pull the install log, and to check the license location.
    Install log can be found at:
    %appdata%\Cadence\PSpiceTIInstall
    File cdsPspiceTIlog.txt
    License can be found at:
    %appdata%\Cadence\VBL\TI_PSpice_231
    File license.txt
    David
  • Dear David,
    It seems that the path is not the same. could you please help with figuring out?
    Hank Lin
  • %appdata% is a shortcut.
    It should take you to: C:\Users\<useraccount>\AppData\Roaming
    For me, it's C:\Users\a0187457\AppData\Roaming
    So you should be looking in something like: C:\Users\a0187457\AppData\Roaming\Cadence\VBL\TI_PSpice_231
    Not sure if you customer has installed the newest, 231 or the older 174.
    David
  • Hi David,
    please refer to the log and license file. thank you so much!
    2437.cdsPspiceTIlog.txt
    2437.license.txt
    # This email has been sent by an  automated
    # process. Please do  not reply to this email.
    #     COSLITE INFORMATION
    # PLEASE NOTE:  Your license file may contain COSLITE product depending on
    # your entitlement. This license will allow some digital tools to access
    # support.cadence.com content (via CadenceHelp) without requiring login.
    # This is a zero cost license and will be active as long as the primary tool
    # license is active. More information is available at
    # https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009Mns6UAC
    # For any further questions, please use the feedback option in the
    # https://support.cadence.com site and someone from the product team will get
    # back to you.
    #     TERMS AND CONDITIONS
    # IF THESE PRODUCTS ARE PROVIDED FOR USE FREE OF CHARGE, THEN THESE TERMS
    # AND CONDITIONS ("TERMS"), ALONG WITH THE TERMS AND CONDITIONS FOUND AT
    # http://www.cadence.com/termsandconditions/templicense ARE THE SOLE AND
    # EXCLUSIVE AGREEMENT FOR USE OF THESE PRODUCTS.
    # If these Products have been approved by Cadence for Use on a
    # secure cloud service platform, the definition of Designated Equipment
    # shall mean such approved secure cloud service platform, which shall
    # include any and all security measures which are at least as stringent
    # as the security measures that Licensee itself uses to store its own
    # confidential or proprietary information, but in any event shall include
    # all reasonable security measures sufficient to ensure compliance
    # with the Terms.
    # IF THESE PRODUCTS ARE PROVIDED PURSUANT TO A PAID LICENSE, THEN THESE
    # TERMS ALONG WITH YOUR SIGNED LICENSE AGREEMENT WITH CADENCE SHALL
    # GOVERN YOUR USE OF THE PRODUCTS.
    # Please read these Terms carefully prior to downloading or using the
    # products. You must protect the product(s) from unauthorized
    # reproduction, publication, use or distribution.  If any product or
    # portion thereof is copied to or used on a computer connected to a
    # network, you must ensure that the product may not be used or copied
    # by unlicensed persons.
    # To help ensure that you are only using authorized copies of the
    # product(s), Cadence may utilize monitoring technologies to obtain and
    # transmit non-proprietary data on unauthorized modifications to the
    # product(s).  No such data will be collected or transmitted unless
    # unauthorized modifications to a product or unauthorized hosting of the
    # license server or product(s) are suspected.
    # By downloading the product(s), you confirm that you have the authority
    # to act on behalf of your employer.  By downloading or using the
    # product(s) you hereby agree to the use of such technology and
    # transmission of such non-proprietary data by Cadence.
    # IF YOU DO NOT AGREE TO THESE TERMS AND CONDITIONS, YOU MUST
    # IMMEDIATELY DELETE THIS  CORRESPONDENCE AND YOU MAY NOT USE THE
    # LICENSE FILE OR ANY PRODUCTS INCLUDED THEREIN
    #     CADENCE CUSTOMER SUPPORT
    # If you have questions regarding this license file, please contact
    # Cadence customer support. The support information is available under
    # https://support.cadence.com/apex/CadenceSupportScreen
    # You may use your Cadence Online Support account to access the
    # Cadence Electronic Software Download(ESD) Servers by going to
    # http://downloads.cadence.com Software Releases are available for
    # download for customers world-wide.
    # THIS LICENSE FILE HAS BEEN GENERATED FOR HOSTID dc462837e272 bc0ff3c451c0 54dba035990f 00ffbb152dda dc462837e273 de462837e272 dc462837e276
    #          CUSTOMER DETAILS
    #          Customer Name:TI_PSPICE
    #           Server  Name:TWTY2PC3304
    #       Server  Location:TW
    #                Host Id:dc462837e272 bc0ff3c451c0 54dba035990f 00ffbb152dda dc462837e273 de462837e272 dc462837e276
    #           Contact Name:Su Wen Tao
    #             Contact Id:tao.su@deltaww.com
    #                   Date:Tue Feb 20 01:47:06 PST 2024
    #  Lic.File Generated By:Su Wen Tao
    #               Comments:
    #     INSTRUCTIONS
    #  1. Please   replace  "Cadence_SERVER"  with  hostname  of your machine
    #     in line   "SERVER Cadence_SERVER  &lt;hostid&gt; 5280".
    #  2. Please replace the relative path(  eg. ./cdslmd   ) to absolute path
    #     in the DAEMON line(s).
    #  3. Cadence now ships a complete license file for each server, so combining
    #     license files with a VENDOR_STRING value other than DEMO is no longer
    #     permitted.  Please contact your field administrator if you believe that
    #     product licenses are missing from this file.
    #  4. Some  e-mail utilities ( commonly on PC or  Macintosh  systems ) may
    #     modify the text of an e-mailed license file,   changes such as  word
    #     or line wrapping or  subdivision into  multiple sections,  when they
    #     receive or forward this file.  The resulting keys will be unreadable
    #     by the software security.To avoid this, these changes must be undone
    #     or the e-mail utility options disabled.
    ########################### LICENSE KEYS START HERE ######################
    SERVER TWTY2PC3304 dc462837e272 bc0ff3c451c0 54dba035990f 00ffbb152dda dc462837e273 de462837e272 dc462837e276 5280
    DAEMON cdslmd ./cdslmd
    FEATURE PSpice_TI cdslmd 17.4 29-jul-2024 uncounted \
               2F88C3F4279134CA9281 VENDOR_STRING=UHD:PERM \
               HOSTID="dc462837e272 bc0ff3c451c0 54dba035990f 00ffbb152dda \
               dc462837e273 de462837e272 dc462837e276" \
               vendor_info=20-feb-2024 \
               ISSUER=CDNSa1fa940177748308912b022c35bb9461 ISSUED=20-feb-2024 \
               SN=2024-02-20T01:46:30.437 TS_OK SIGN2="08B3 2964 825F 2E1B \
               312F 15F7 7921 8F28 67AF 8854 8682 40A3 180B 9D5D ED7E 0FF6 \
               9AC1 0218 D386 1AD5 383F E340 1F61 F457 22D6 4464 2FA0 8908 \
               F738 408C"
    ########################## LICENSE KEYS END HERE ######################
    ##     PRODUCT TO FEATURE MAPPING
    ########################### for  [REGULAR] products #################
    # Product Id  : PA4000,  [Version: 17.4]
    # Product Name: PSpice-TI Simulator
    # Licensed Rights:
    #   Start Date: 20-feb-2024 Exp Date: 29-jul-2024   Product Qty: 1 Type: Floating
    #   Product Comments:
    #   Feature: PSpice_TI                      [Version: 17.4] [Feature Qty Per Product: 1]
    Hank Lin
  • Hi Hank,
    This is a license for 17.4 You should be on 23.1.
    Please uninstall PSpice for TI. Then, go to ti.com/tool/PSPICE-FOR-TI and request again.
    You'll get a link, along with the access code. Please install and lets see if that fixes your problem.
    David
