TIDA-010262: PoDL (PSE controller, PD controller) for 10BASE-T1S
Part Number: TIDA-010262
Other Parts Discussed in Thread: TIDA-010261
Sorry I don't know much about PoDL.
Is there a PoDL (PSE controller, PD controller) for IEEE802.3cg 10BASE-T1S?
If it supports 10BASE-T1L, is it also OK for 10BASE-T1S?
    the PSE and PD controller is in this design implemented in a discrete way, for 10BASE-T1L.
    For T1S, you do PoDL in a different way, as you have a multidrop architecture. The most simple approach uses a passive coupling network and no PSE or PD controller.
    Steffen
  • Thank you for your response.
    For T1L, you use a PSE or PD controller, and for T1S, you use a passive coupling network. Is this approach better for cases other than TIDA-010262?
    I am not familiar with the concept of a passive coupling network and would like to learn about it. Could you recommend some websites that explain it?
    I have the following standards documents:
    "IEEE Std 802.3cgTm‐2019"
    "IEEE Std 802.3Tm-2018"
  • For T1L, you can also use a passive network only. If you better use a PSE and PD or an engineered PoDL network depends on your system.
    For T1S, there is no IEEE standard defining a PSE and PD yet.
    On a passive coupling network, you can check the schematic of https://www.ti.com/tool/TIDA-010261 on page 5 and just use this network without the PD controller. The IEEE802.3cg standard you have, also gives an examples on PSE and PD schematics.
    Steffen
    I'm going to learn about the TIDA-010261 schematic.
