Other Parts Discussed in Thread: TIDA-010938
Can you provide details on voltage rating at each stage of design TIDA-010938? I need section wise voltage rating.
THanks and Regards,
AJay P
THanks and Regards,
AJay P
Hi Ajay,
You can find the detailed specifications of each stage in the design guide located under design files on TIDA-010938 reference design | TI.com.
Veda
Hi Veda,
Thanks for your reply, I have a doubt regarding how have you given the digital MCU for MPPT like 5V supply?
Hi Ajay,
A buck converter is used to step down voltage from 12V rail down to 5V on the board. I suggest you go through the design guide which has descriptions of all the sub-blocks and the converter design along with test results and measurements. Additionally you will also find the schematic and PCB project, all under design resources section on the page TIDA-010938 reference design | TI.com. The PCB project is present under CAD/CAE Symbol.
Veda
