Hi, I used the WEBENCH Designer to find a buck converter regulating a voltage in of 3.4 to 3.6V, with a desired regulated voltage out of 3.3V and 0.3A.
Actually I wasn't expecting it to find anything, as I understand that some margin is required. However it found a solution using an LMZ10503.
I'd like to know if this is really going to work or not. Its datasheet only rates it up to 2.5V for these operating parameters, and I need 3.3V out. Doesn't it require a larger margin, as in the datasheet?
