Other Parts Discussed in Thread: TPS82130
H all,
I have a question related to the reference design of Dual Active Bridge TIDA-010054.
https://www.ti.com/tool/TIDA-010054
I have been designing a control law for single Dual Active Bridge to stablize the output voltage and evaluate it with my Simulink model. I have been also consulting quite a lot of references and the reference design by TI as well. And I see that most of the references consider the load as a resistor (probably for simplicity).
I have checked with my simulation and find down that the control loop is only stable with resistive load and not stable without load (it was clear in this reference design, whether or not the output voltage is stable without load. But my feeling is it's not the stable). I have also tested it with the load as a current source and it is not stable either. I dont understand this point. If you know the answer, could you please share with me why single Dual Active Bridge is not stable without load?
Thanks in advance,
Anh Nguyen
