Ultralow-Power Blood Pressure and Heart Rate Monitor
Other Parts Discussed in Thread: LMV324
Good afternoon,
Please I'm working to build the exact design for the blood pressure and heart rate. and I want to read the signal using Labview so which part is not useful in the design  so i can take it from the BOM because i no need to mess with the Board.
As well I do have some other question about parts:
- the Buzzer do there is any part Number for that
- R8 800K can I use one of the 0805 787k/0805 806k
- LCD1        CON20*2P do I need this part if I need the signal only through the Pc
- MBRA320  can I use the MBRA320T3G
- TPS763XX can I use TPS76333DBVR
- LMV324 can I use LMV324 sop-14
- MP3V5050 can use MP3V5050GC6U
- CAT24C32 can I use CAT24C32WI-GT3
- U11    BP300UF    Is there is any part number for this
- Y1     XIAL-2*5V  is there is any part number for this
The link for the BOM will be here http://www.ti.com/tool/TIDM-BPM
Thank you very much for your help and the best collaboration.
    I'm not intimately familiar with this particular TI Design, but all the information we have is provided on the page as an example.  I am unable to further clarify part numbers not stated in the BOM.   Thanks for understanding.
    Based on the block diagram in the User's Guide, I would say that the LCD and Buzzer are not critical and could be removed if you rather connect to a PC instead when you design your system.  In that case, you probably won't be using battery-powered either so you probably would update the regulator to support your input voltage.
    Good luck!
    JD
  • Can you please provide me the Parts which need to be changed or taken off. to make the blood pressure running from the computer
    thank you a lot
