Hello, Steffen Graf,
We continue to check the behavior of IO-Link Master(TIDA-010016) .
Now we are still trying to merge below EtherCAT demo CCS project to TIDA-010016.
http://software-dl.ti.com/processor-industrial-sw/esd/PRU_ICSS_EtherCAT_Slave/latest/index_FDS.html
1: We success to create IOLONK-Master CCS project from your advice.
2: Then I add EtherCAT demo CCS project related files (*.c and *.h) and success to build.
3: At first I removed IOLINK tasks by commenting out like below & success to run EtherCAT demo with Twincat GUI.
// Task_create((Task_FuncPtr)IOLink_LEDTask, &taskParams, NULL);
// Task_create((Task_FuncPtr)IOLink_powerSwitchTask, &taskParams, NULL);
// Task_create((Task_FuncPtr)IO_Link_Master_Stack_Task, &taskParams, NULL);
// Task_create((Task_FuncPtr)IOLink_autosenTask, &taskParams, NULL);
// Task_create((Task_FuncPtr)IOLink_printTask, &taskParams, NULL);
4: Then I add Iolink tasks step by step by removing those comment-out and still run EtherCAT demo.
5: If I add IO_Link_Master_Stack_Task, some exception occurred like below.
6: Then I re-run by adding break point to "0x8003f178" and the program runs & stop at like below break-point.
7: If I crick "Assembly step over icon" on CCS, then program go to exception handler.
Question:
Are there any recommended way to analyze this exception?
We would appreciate if you tell us any clue to solve this problem.
P.S. I add modified "main_iolink_test.c" as a reference.
/* * Copyright (C) 2018 Texas Instruments Incorporated - http:;www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /* file: main_iolink_test.c * * brief: IO-Link master unit test code */ /* ========================================================================== */ /* Include Files */ /* ========================================================================== */ #include <stdint.h> #include <xdc/std.h> #include <xdc/cfg/global.h> #include <xdc/runtime/System.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/sysbios/knl/Semaphore.h> #include <xdc/runtime/Error.h> #include <ti/sysbios/knl/Clock.h> #include <ti/starterware/include/hw/am437x.h> #include <ti/starterware/include/am43xx/chipdb_defs.h> #include <ti/starterware/include/soc_control.h> #include <ti/starterware/include/prcm.h> #include <ti/csl/src/ip/icss/V1/cslr_icss_cfg.h> #include <ti/drv/pruss/pruicss.h> #include <ti/drv/iolink/src/v0/IOLINK_v0.h> #include <ti/drv/iolink/test/stack_test/src/ioLink_LEDTask.h> #include <ti/drv/iolink/test/stack_test/src/ioLink_powerSwitchTask.h> #include <ti/drv/iolink/test/stack_test/src/ioLink_printTask.h> #include <ti/drv/iolink/test/stack_test/src/ioLink_autosenTask.h> #include <ti/board/board.h> IOLINK_Handle iolinkHandles[2] = {NULL, }; extern IOLINK_v0_Callbacks iolinkCallbacks; extern void mst_main (void); /* ========================================================================== */ /* Function Definitions */ /* ========================================================================== */ void IO_Link_Master_Stack_Task(UArg arg0) { IOLINK_Params params; uint32_t instance = 0; /* Initialize the PRU IO-Link driver */ IOLINK_init(); /* Open IO-Link instance */ IOLINK_Params_init(¶ms); iolinkHandles[instance] = IOLINK_open(instance, ¶ms); /* run the IO-Link master stack */ if (iolinkHandles[instance] != NULL) { IOLINK_control(iolinkHandles[instance], IOLINK_CTRL_SET_CALLBACKS, (void *)(&iolinkCallbacks)); mst_main(); } } int32_t IOLINK_boardInit(void) { Board_STATUS boardStatus; uint32_t timerInstance = 4; int32_t retVal = 0; // boardStatus = Board_init(BOARD_INIT_MODULE_CLOCK | // BOARD_INIT_ICSS_PINMUX | // BOARD_INIT_UART_STDIO); if (boardStatus == BOARD_SOK) { PRCMModuleEnable(CHIPDB_MOD_ID_PWMSS, 0, 0); /* Clock source selection */ SOCCtrlTimerClkSrcSelect(timerInstance, SOC_CTRL_DMTIMER_CLK_SRC_M_OSC_24M); PRCMModuleEnable(CHIPDB_MOD_ID_DMTIMER, timerInstance , FALSE); PRCMModuleEnable(CHIPDB_MOD_ID_DMTIMER, timerInstance + 2, FALSE); /*Pinmux for LatchO in AM437x IDK*/ *((uint32_t *)0x44E10978) = 0x00050006; //Board_phyReset(2); /* Set ICSS1 in no standby mode */ HW_WR_FIELD32(0x54426000U + CSL_ICSSCFG_SYSCFG, CSL_ICSSCFG_SYSCFG_STANDBY_MODE , 1); } else { retVal = -1; } return (retVal); } void task1(uint32_t arg0, uint32_t arg1); int main() { Task_Params taskParams; Board_init( // BOARD_INIT_PINMUX_CONFIG | BOARD_INIT_MODULE_CLOCK | BOARD_INIT_ICSS_PINMUX | BOARD_INIT_UART_STDIO); Task_Params_init(&taskParams); taskParams.priority = 4; taskParams.stackSize = 2048; //*TIESC_TASK_STACK_SIZE_MUL; Task_create(task1, &taskParams, NULL); if (IOLINK_boardInit() == 0) { // create a new task for the LED driver Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.stackSize = 2048*4; taskParams.instance->name = "ioLink LED Task"; // Task_create((Task_FuncPtr)IOLink_LEDTask, &taskParams, NULL); // create a new task for the high side switch driver Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.stackSize = 2048*4; taskParams.instance->name = "ioLink Power Switch Task"; Task_create((Task_FuncPtr)IOLink_powerSwitchTask, &taskParams, NULL); // create the IO-Link Master Stack Task Task_Params_init(&taskParams); taskParams.priority = 11; taskParams.stackSize = 2048; taskParams.instance->name = "ioLink Master Task"; Task_create((Task_FuncPtr)IO_Link_Master_Stack_Task, &taskParams, NULL); // create the IO-Link Master Autosen device controlTask Task_Params_init(&taskParams); taskParams.priority = 9; // lower priority than the master stack task and other control tasks taskParams.stackSize = 2048; taskParams.instance->name = "ioLink Master Autosen device control Task"; Task_create((Task_FuncPtr)IOLink_autosenTask, &taskParams, NULL); // create the IO-Link Stack Test Print Task Task_Params_init(&taskParams); taskParams.priority = 8; // lowest priority taskParams.stackSize = 2048; taskParams.instance->name = "ioLink Master Print Task"; Task_create((Task_FuncPtr)IOLink_printTask, &taskParams, NULL); BIOS_start(); } return 0; }
