Hi TI Support,
I want to config HCI_VS_DRPb_Set_Power_Vector(0xFD82) to CC2564, so API HCI_Send_Raw_Command() is suitable for me.
This is what I use in my code,
result = HCI_Send_Raw_Command(BluetoothStackID, OGF, OCF, g_abPowerVectorPacketSize[i]-2, &tmp[2],&StatusResult,&ResultLength,ResultBuffer,false);
And I print the result and StatusResult.
result = 0;
StatusResult = 246.
Next step, I have to restart bluetooth. Then I get
result = 0;
StatusResult = 65.
HCI_Send_Raw_Command(unsigned int BluetoothStackID, Byte_t Command_OGF, Word_t Command_OCF, Byte_t Command_Length, Byte_t Command_Data[], Byte_t *StatusResult, Byte_t *LengthResult, Byte_t *BufferResult, Boolean_t WaitForResponse);
Would you tell me what numerical value of StatusResult means???? Could you send me some documents ?
Thank you.
