Hey Remukee,
Have you also changed MAX_NUM_PDU? A sniffer capture will help understand what is going on over the air with regards to throughput.
You can also change the connection interval when you need to transmit the data. If the connection interval is every 1s, then this will slow things down quite a bit (as opposed to a 10ms interval).
Please see the following related threads as they might help:
