CC2564MODA: MSP430FR5994: SPPLEDemo-Bluetopia for MSP430 microcontroller unable to open stack
Part Number: CC2564MODA
Other Parts Discussed in Thread: MSP430F5438A, MSP-TS430PN80B, MSP430FR5994, , , CC2564, TEST2
I'm currently working on a project where we decided to use an SPPLE profile to transfer data, which I intend to implement with MSP430FR5994 connected to the CC2564MODA using the Bluetopia stack. For now, I'm using the SPPLEDemo included in the Bluetopia samples for the MSP430 microcontrollers. I've migrated to the MSP430 bluetopia sample from the MSP430F5438A to the microcontroller I'm using. During the migration, I also did some simplifications in the port declarations.  Hardware-wise I'm using a BOOST-CC2564MODA connected to an MSP-TS430PN80B with an MSP430FR5994, connecting P6.0 and P6. to rx and tx of the BOOST board, respectively; P5.7 to nSD; P4.2 and P4.1  to cts and rts of the BOOST board, respectively; and supply and ground references together.
However, right now, I'm having issues opening the stack. The OpenStack function at SPPLEDemo.c file always returns -4, which means there is an HCI initialization error, and it can't open the stack. Since we own an MSP-EXP432P401R LaunchPad,  I loaded the SPPLEDemo or the MSP432 microcontrollers, which I could use with no issues at all. Then I connected a logic analyzer to understand the differences they might have in the initialization.
In the attached picture, you'll find what the logic analyzer shown, and in the attached excel file, you will find all the events from each microcontroller confronted. What I find interesting is that the first send and receive messages are equal, but all the other ones are quite different. Also, I don't understand how come if there is an HCI initialization error, the HCI does communicate.
I don't know if you could tell me how to interpret these messages, if there's any documentation about the opcodes, or why both stacks would fill the buffers differently for the initialization.
If you know where the mistake could be or how to solve the issue, it would be helpful.
Thanks in advance, and best regards,
Diana Ramírez
SniffUARTBLE_MSP430Vs432.xlsx
  • Hi Diana,
    I will respond here this week.
    Jacob
  • Hi Jacob,
    Thanks for your response. I suppose you have a lot of inquiries to answer, but I would like to know if you have any news for me. I'm sorry if I'm rushing you, but we are stuck with this part of the project because of this issue.
    Thanks and best regards,
    Diana
  • Hi Diana,
    Can you list which stacks you are using for the SPPLEDemo on the MSP430 and the MSP432? The two devices require different stacks and I want to make sure you are aware of them. Since you are using a CC2564MODA, these are the correct stacks for the MCUs:
    Be sure to connect CTS of the MSP430 to the RTS of the CC2564MODA and vice versa.
    From the picture you shared, it looks like the UART communication between the MSP430 and the CC2564MODA is successful.
    Can you confirm that you are using the MSP430 stack and have CTS --> RTS and RTS --> CTS?
    Jacob
  • Hi Jacob,
    Yes, I'm using different stacks. For the MSP432, I'm using version 4.0.3.0 for the MSP432 family, while for the MSP430, I'm using version 1.5 R2 or the MSP430 family.
    RTS of the microcontroller is connected to the CTS of the CC2564MODA and vice-versa, and I can confirm you I'm using the MSP430 1.5 R2 version.
    The communication between MSP430 and CC2564MODA is successful, but the stack doesn't open. When I examine the messages, they are different from those generated by the MSP432 stack. Moreover, the message from the MSP430 somewhat coincides with the Base Patch Data declared on line 45 of the file CC265X.h
      /* The following is the binary representation of the Base Patch Data.*/
    static BTPSCONST BTPSVEND_PATCH_LOCATION unsigned char BasePatch[] =
       0x01, 0x37, 0xFE, 0x02, 0x06, 0x0F, 0x01, 0x05, 0xFF, 0xFF, 0xA0, 0x62, 0x08, 0x00, 0xFA, 0x06,
       0x0F, 0x3D, 0x55, 0xFB, 0x01, 0x00, 0x1F, 0x00, 0x00, 0x05, 0x00, 0x05, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0x05, 0x00, 0x05, 0xC0, 0x01, 0x40, 0x1F, 0x30, 0x05, 0x00, 0x04, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0x3D, 0x01, 0x04, 0xC0, 0x03, 0xC0, 0x1E, 0x38, 0x76, 0x02, 0x04, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0xAE, 0x03, 0x04, 0xC0, 0x03, 0xC0, 0x1E, 0x38, 0xAE, 0x0B, 0x01, 0x00, 0x34, 0x30, 0x41,
       0x02, 0x00, 0x00, 0x00, 0x00, 0x80, 0x7F, 0x12, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x31, 0x9D,
       0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE2,
       0x48, 0x00, 0x78, 0x02, 0x28, 0x0F, 0xD1, 0xE1, 0x48, 0x41, 0x88, 0x09, 0x09, 0x0B, 0xD2, 0x41,
       0x88, 0x49, 0x08, 0x08, 0xD2, 0x42, 0x88, 0x10, 0x21, 0x01, 0x05, 0xFF, 0xFF, 0x9A, 0x63, 0x08,
       0x00, 0xFA, 0x11, 0x43, 0x41, 0x80, 0x02, 0x88, 0x01, 0x21, 0x89, 0x03, 0x11, 0x43, 0x01, 0x80,
       0xF7, 0x46, 0xD8, 0x48, 0x00, 0x78, 0x02, 0x28, 0x0F, 0xD1, 0xD7, 0x48, 0x41, 0x88, 0x09, 0x09,
       0x0B, 0xD2, 0x41, 0x88, 0x49, 0x08, 0x08, 0xD2, 0x10, 0x22, 0x41, 0x88, 0x91, 0x43, 0x41, 0x80,
       0x01, 0x22, 0x92, 0x03, 0x01, 0x88, 0x91, 0x43, 0x01, 0x80, 0xF7, 0x46, 0x10, 0xB5, 0x03, 0x7E,
       0xE2, 0x49, 0xE3, 0x4A, 0xE4, 0x48, 0x00, 0x2B, 0x09, 0xD1, 0x94, 0x38, 0x82, 0x18, 0x04, 0x20,
       0x00, 0x23, 0x01, 0x24, 0xA6, 0x46, 0xDF, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD, 0x82, 0x18,
       0x04, 0x20, 0x00, 0x23, 0x01, 0x24, 0xA6, 0x46, 0xDA, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD,
       0xF0, 0xB5, 0x04, 0x69, 0xC7, 0x26, 0x30, 0x5D, 0x04, 0x28, 0x24, 0xD1, 0xC8, 0x25, 0x28, 0x5D,
       0x18, 0x28, 0x03, 0xD1, 0x6A, 0x20, 0x00, 0x5D, 0x04, 0x28, 0x16, 0xD0, 0x28, 0x5D, 0x19, 0x28,
       0x19, 0xD1, 0xCE, 0x20, 0x00, 0x5D, 0x16, 0x28, 0x15, 0xD1, 0xB5, 0x27, 0x38, 0x5D, 0x01, 0x21,
       0x8E, 0x46, 0xCE, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x22, 0x38, 0x5D, 0x60, 0x21, 0x41, 0x43,
       0xCB, 0x48, 0x42, 0x54, 0x32, 0x55, 0x2A, 0x55, 0xF0, 0xBD, 0x20, 0x1C, 0x01, 0x21, 0x8E, 0x46,
       0xC8, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xF0, 0xBD, 0xF0, 0xB5, 0x86, 0xB0, 0x07, 0x1C, 0xB8, 0x69,
       0x03, 0x90, 0xB9, 0x8A, 0x04, 0x91, 0x00, 0x25, 0x6C, 0x46, 0x25, 0x71, 0x65, 0x71, 0xC2, 0x48,
       0x44, 0x38, 0x08, 0x1A, 0x01, 0x28, 0x0B, 0xD9, 0x05, 0x38, 0x09, 0xD0, 0x68, 0x38, 0x01, 0x28,
       0x06, 0xD9, 0x04, 0x38, 0x04, 0xD0, 0x2F, 0x38, 0x02, 0xD0, 0x24, 0x38, 0x01, 0x05, 0xFF, 0xFF,
       0x94, 0x64, 0x08, 0x00, 0xFA, 0x02, 0x28, 0x0B, 0xD8, 0x00, 0x97, 0x04, 0x98, 0x03, 0x99, 0x01,
       0xAA, 0x63, 0x1D, 0x01, 0x26, 0xB6, 0x46, 0xE8, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x00, 0x28, 0x5F,
       0xD1, 0x04, 0x98, 0xB3, 0x49, 0x41, 0x1A, 0xE5, 0x48, 0x37, 0xD0, 0x75, 0x39, 0x2C, 0xD0, 0x2C,
       0x39, 0x02, 0xD0, 0x14, 0x39, 0x3F, 0xD0, 0x53, 0xE0, 0x03, 0x98, 0x29, 0x1C, 0x01, 0x26, 0xB6,
       0x46, 0xE7, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x05, 0x90, 0xB6, 0x46, 0xE6, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x28, 0x02, 0xD1, 0x02, 0x20, 0x60, 0x71, 0x02, 0xE0, 0x00, 0x78, 0xE2, 0x49, 0x0D,
       0x56, 0x02, 0xA8, 0x05, 0x99, 0xB6, 0x46, 0xE1, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x05, 0x70, 0x03,
       0x20, 0x6A, 0x46, 0x10, 0x70, 0x03, 0x98, 0x9E, 0x49, 0xA1, 0x31, 0x52, 0x79, 0x02, 0xAB, 0xB6,
       0x46, 0xED, 0x4D, 0xFE, 0x44, 0x28, 0x47, 0x28, 0xE0, 0x0E, 0x21, 0x01, 0x22, 0x96, 0x46, 0xEB,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x28, 0x08, 0xD0, 0x22, 0xE0, 0x0D, 0x21, 0x01, 0x22, 0x96,
       0x46, 0xE6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x28, 0x1A, 0xD1, 0x0C, 0x20, 0x60, 0x71, 0x01,
       0x21, 0x68, 0x46, 0x01, 0x71, 0x17, 0xE0, 0x03, 0x98, 0x01, 0x21, 0x8E, 0x46, 0xE0, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x02, 0x21, 0xDF, 0x48, 0x02, 0x79, 0x01, 0x2A, 0x03, 0xD1, 0x45, 0x23, 0xDE,
       0x4A, 0x12, 0x78, 0x1A, 0x54, 0x4C, 0x30, 0x01, 0x39, 0xF5, 0xD1, 0xEF, 0x48, 0x9E, 0x30, 0x38,
       0x62, 0x20, 0x79, 0x01, 0x28, 0x0A, 0xD1, 0x03, 0x98, 0x04, 0x99, 0x62, 0x79, 0x01, 0x23, 0x9E,
       0x46, 0xEA, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE8, 0x48, 0x9E, 0x30, 0x38, 0x62, 0x06, 0xB0, 0x01,
       0x05, 0xFF, 0xFF, 0x8E, 0x65, 0x08, 0x00, 0xFA, 0xF0, 0xBD, 0xF8, 0xB5, 0x06, 0x1C, 0xB5, 0x69,
       0xB2, 0x8A, 0xE5, 0x48, 0x01, 0x1C, 0x11, 0x39, 0x52, 0x1A, 0x65, 0xD0, 0x12, 0x1A, 0xE3, 0x49,
       0x22, 0xD0, 0x07, 0x3A, 0x00, 0xD0, 0x8E, 0xE0, 0x0E, 0x20, 0x40, 0x19, 0x06, 0x22, 0xAA, 0x80,
       0x08, 0x22, 0x6A, 0x80, 0x09, 0x78, 0x02, 0x29, 0x0C, 0xD1, 0xDD, 0x49, 0x01, 0x24, 0xA6, 0x46,
       0xDD, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x21, 0xA6, 0x46, 0xDA, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x00, 0x22, 0x00, 0xE0, 0x0C, 0x22, 0x28, 0x1C, 0x87, 0x21, 0x89, 0x00, 0x01, 0x23, 0x9E, 0x46,
       0xD6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x6B, 0xE0, 0x08, 0x78, 0x02, 0x28, 0x33, 0xD1, 0x0B, 0x20,
       0x40, 0x19, 0x01, 0x24, 0xA6, 0x46, 0xD1, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x90, 0xA6, 0x46,
       0xD0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x06, 0x00, 0x0E, 0xA6, 0x46, 0xCE, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x07, 0x1C, 0x0E, 0x20, 0x40, 0x19, 0x00, 0x99, 0xA6, 0x46, 0x96, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x06, 0x21, 0xA9, 0x80, 0x07, 0x21, 0x69, 0x80, 0x00, 0x2F, 0x0B, 0xD0, 0x00, 0x99,
       0xC9, 0x0A, 0x08, 0xD3, 0x3A, 0x21, 0xC9, 0x19, 0x05, 0x22, 0xA6, 0x46, 0xC3, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x00, 0x22, 0x08, 0xE0, 0x00, 0x21, 0x05, 0x22, 0xA6, 0x46, 0xC0, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x02, 0x22, 0x00, 0xE0, 0x0C, 0x22, 0x28, 0x1C, 0xBD, 0x49, 0x01, 0x23, 0x9E, 0x46,
       0xBD, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x2B, 0xE0, 0x2F, 0x1C, 0x06, 0x20, 0xA8, 0x80, 0x0E, 0x20,
       0x40, 0x19, 0x40, 0x21, 0x01, 0x24, 0xA6, 0x46, 0xB8, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x94, 0x48,
       0x01, 0x1C, 0x01, 0x05, 0xFF, 0xFF, 0x88, 0x66, 0x08, 0x00, 0xFA, 0xCF, 0x22, 0x8A, 0x73, 0x0E,
       0x31, 0x61, 0x22, 0x0A, 0x74, 0x06, 0x30, 0x19, 0x21, 0x02, 0x78, 0xBA, 0x73, 0x01, 0x37, 0x01,
       0x30, 0x01, 0x39, 0xF9, 0xD1, 0x04, 0x20, 0xAF, 0x49, 0x0A, 0x78, 0xBA, 0x73, 0x01, 0x37, 0x01,
       0x31, 0x01, 0x38, 0xF9, 0xD1, 0x40, 0x20, 0x68, 0x80, 0x28, 0x1C, 0x81, 0x21, 0x49, 0x00, 0x00,
       0x22, 0xA6, 0x46, 0x9F, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xEB, 0x48, 0xFA, 0x30, 0x30, 0x62, 0xF8,
       0xBD, 0x30, 0xB5, 0x05, 0x1C, 0xE9, 0x48, 0x00, 0x78, 0x00, 0x28, 0x17, 0xD1, 0x01, 0x24, 0xA6,
       0x46, 0xE7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x00, 0x28, 0x0B, 0xD1, 0xA6, 0x46, 0xE5, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x01, 0x28, 0x05, 0xD0, 0xA6, 0x46, 0xE3, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x01,
       0x28, 0x04, 0xD1, 0x00, 0x20, 0x28, 0x60, 0xE0, 0x48, 0x52, 0x30, 0x28, 0x62, 0x30, 0xBD, 0xE8,
       0x57, 0x08, 0x00, 0x60, 0x7A, 0x1A, 0x00, 0x70, 0xB5, 0xDD, 0x49, 0x80, 0x8A, 0x88, 0x42, 0x20,
       0xD1, 0xDC, 0x4B, 0xDC, 0x4A, 0x00, 0x21, 0x40, 0x20, 0x80, 0x5C, 0x00, 0x28, 0x0E, 0xD0, 0x18,
       0x78, 0xDA, 0x4E, 0x8C, 0x00, 0xDA, 0x4D, 0x2C, 0x19, 0x25, 0x6A, 0xB5, 0x42, 0x0B, 0xD8, 0x64,
       0x68, 0xB4, 0x42, 0x08, 0xD8, 0x01, 0x24, 0x8C, 0x40, 0xA0, 0x43, 0x18, 0x70, 0xA8, 0x32, 0x01,
       0x31, 0x07, 0x29, 0xE8, 0xDB, 0x70, 0xBD, 0x0A, 0x06, 0x12, 0x0E, 0x01, 0x21, 0x91, 0x40, 0x01,
       0x43, 0x19, 0x70, 0x70, 0xBD, 0xC0, 0x46, 0x17, 0x71, 0x08, 0x00, 0xC9, 0x98, 0x00, 0x00, 0x65,
       0x70, 0x08, 0x00, 0xD3, 0x03, 0x00, 0x00, 0xC9, 0xA2, 0x00, 0x00, 0x76, 0xA0, 0x1B, 0x00, 0x6D,
       0x97, 0x00, 0x00, 0x5B, 0xFD, 0x01, 0x05, 0xFF, 0xFF, 0x82, 0x67, 0x08, 0x00, 0xFA, 0x00, 0x00,
       0x70, 0xB5, 0x06, 0x1C, 0xB5, 0x69, 0x28, 0x88, 0x00, 0x0A, 0x01, 0x02, 0x35, 0x20, 0x00, 0x02,
       0x08, 0x1A, 0x28, 0xD0, 0x09, 0x21, 0x49, 0x02, 0x40, 0x1A, 0x04, 0xD0, 0x3F, 0x21, 0x09, 0x02,
       0x40, 0x1A, 0x39, 0xD0, 0x70, 0xBD, 0xBD, 0x48, 0x00, 0x68, 0x00, 0x28, 0x0E, 0xD1, 0xE8, 0x88,
       0x00, 0x04, 0xA9, 0x88, 0x08, 0x43, 0x01, 0x24, 0xA6, 0x46, 0x5A, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x28, 0x1C, 0xA6, 0x46, 0xB6, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x34, 0xE0, 0x7D, 0x20, 0xC0, 0x00,
       0x01, 0x24, 0xA6, 0x46, 0xB5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x28, 0x1C, 0xA6, 0x46, 0xB1, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x27, 0xE0, 0xE8, 0x88, 0x11, 0x21, 0x49, 0x01, 0x41, 0x43, 0xE4, 0x48,
       0x40, 0x18, 0x3B, 0x21, 0x0A, 0x5C, 0x3C, 0x21, 0x09, 0x5C, 0x11, 0x43, 0x05, 0xD1, 0x00, 0x21,
       0x01, 0x22, 0x96, 0x46, 0xA8, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46,
       0xA3, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x0E, 0xE0, 0xE8, 0x88, 0x80, 0x00, 0xEE, 0x49, 0x08, 0x58,
       0x00, 0x21, 0x01, 0x24, 0xA6, 0x46, 0xED, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x28, 0x1C, 0xA6, 0x46,
       0x9B, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xE7, 0x49, 0x05, 0x20, 0x00, 0x02, 0x40, 0x18, 0x30, 0x62,
       0x70, 0xBD, 0xC0, 0x46, 0xF9, 0x06, 0x18, 0x00, 0xC0, 0x61, 0x1A, 0x00, 0x10, 0xB5, 0x04, 0x1C,
       0xE3, 0x48, 0x00, 0x78, 0x01, 0x28, 0x08, 0xD1, 0x60, 0x69, 0x01, 0x21, 0x8E, 0x46, 0x90, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xEB, 0x48, 0x1A, 0x30, 0x20, 0x62, 0x10, 0xBD, 0xD1, 0x2B, 0x00, 0x00,
       0x65, 0x8B, 0x01, 0x00, 0x50, 0x21, 0x08, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x7C, 0x68, 0x08, 0x00,
       0xFA, 0x69, 0x2C, 0x00, 0x00, 0x30, 0xB5, 0x04, 0x1C, 0xA1, 0x69, 0x00, 0x29, 0x1C, 0xD0, 0x20,
       0x69, 0x02, 0x78, 0xFF, 0x2A, 0x18, 0xD0, 0x8A, 0x88, 0x89, 0x18, 0x08, 0x22, 0xCA, 0x42, 0x13,
       0xD0, 0x39, 0x22, 0x12, 0x5C, 0x0A, 0x2A, 0x0F, 0xD1, 0x09, 0x7A, 0x4A, 0x08, 0x0F, 0x2A, 0x0B,
       0xD1, 0xC9, 0x07, 0xC9, 0x0F, 0x0F, 0x22, 0x2A, 0x23, 0x01, 0x25, 0xAE, 0x46, 0xE7, 0x4D, 0xFE,
       0x44, 0x28, 0x47, 0x7B, 0x48, 0xF0, 0x30, 0x20, 0x62, 0x30, 0xBD, 0xC0, 0x46, 0x0D, 0x78, 0x05,
       0x00, 0x2F, 0x4A, 0x05, 0x00, 0xEF, 0x36, 0x00, 0x00, 0x00, 0x14, 0x08, 0x00, 0xAD, 0x11, 0x08,
       0x00, 0x70, 0xB5, 0x85, 0xB0, 0x05, 0x1C, 0x68, 0x69, 0xE6, 0x4E, 0x01, 0x24, 0x34, 0x70, 0x01,
       0x7A, 0x89, 0x06, 0x09, 0x0E, 0xE4, 0x4A, 0x52, 0x58, 0x69, 0x46, 0xA6, 0x46, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x20, 0x30, 0x70, 0x68, 0x46, 0x01, 0x7C, 0x06, 0x29, 0x04, 0xD0, 0xA6, 0x46, 0xDF,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x04, 0xE0, 0xDE, 0x4A, 0x34, 0x21, 0x88, 0x5C, 0x01, 0x30, 0x88,
       0x54, 0xDC, 0x48, 0x4E, 0x30, 0x28, 0x62, 0x05, 0xB0, 0x70, 0xBD, 0xC0, 0x46, 0x81, 0x60, 0x00,
       0x00, 0x99, 0x77, 0x05, 0x00, 0x13, 0x10, 0x00, 0x00, 0x41, 0x10, 0x08, 0x00, 0xFF, 0xFF, 0xFF,
       0x1F, 0x53, 0x2C, 0x00, 0x00, 0xC1, 0x50, 0x02, 0x00, 0x73, 0x2C, 0x00, 0x00, 0x71, 0x8B, 0x04,
       0x00, 0x9B, 0x8B, 0x04, 0x00, 0x21, 0xA7, 0x05, 0x00, 0xC1, 0xAD, 0x05, 0x00, 0x15, 0x20, 0x00,
       0x00, 0xA7, 0x50, 0x02, 0x00, 0x91, 0x1C, 0x04, 0x00, 0x5C, 0x63, 0x08, 0x00, 0xF8, 0xB5, 0x07,
       0x1C, 0x7C, 0x69, 0x3D, 0x69, 0x38, 0x7F, 0x17, 0x21, 0x40, 0x1A, 0x01, 0x05, 0xFF, 0xFF, 0x76,
       0x69, 0x08, 0x00, 0xFA, 0x26, 0xD0, 0x0D, 0x38, 0x16, 0xD0, 0x5B, 0x38, 0x63, 0xD1, 0xFF, 0x20,
       0x7D, 0x30, 0x00, 0x5D, 0x0C, 0x28, 0x5E, 0xD1, 0xDC, 0x48, 0xE9, 0x78, 0x41, 0x70, 0x29, 0x79,
       0x81, 0x70, 0x69, 0x79, 0xC1, 0x70, 0xA9, 0x79, 0x01, 0x71, 0xE9, 0x79, 0x41, 0x71, 0x29, 0x7A,
       0xC1, 0x80, 0xA9, 0x7A, 0x01, 0x81, 0x4E, 0xE0, 0x01, 0x25, 0xAE, 0x46, 0xD4, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0xAE, 0x46, 0xD3, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x28, 0x43, 0xD0, 0xD2, 0x48,
       0xC4, 0x38, 0x3D, 0xE0, 0xFF, 0x20, 0x7D, 0x30, 0x06, 0x19, 0x28, 0x78, 0x30, 0x70, 0x31, 0x78,
       0x02, 0x20, 0x08, 0x40, 0x30, 0x70, 0x01, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xCC, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x70, 0x80, 0x02, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xC8, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xB0, 0x80, 0xFF, 0x20, 0x83, 0x30, 0x00, 0x19, 0x00, 0x90, 0x02, 0x35,
       0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xC2, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x99, 0x08, 0x80,
       0x02, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xBE, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x99,
       0x48, 0x80, 0xB1, 0x88, 0x70, 0x88, 0x08, 0x43, 0x40, 0x08, 0x1C, 0xD2, 0x00, 0x98, 0x00, 0x88,
       0x00, 0x28, 0x18, 0xD0, 0x4A, 0x08, 0x90, 0x42, 0x15, 0xDC, 0x08, 0x29, 0x10, 0xDB, 0xB2, 0x48,
       0xB1, 0x49, 0x40, 0x18, 0x38, 0x62, 0x60, 0x7E, 0x00, 0x28, 0x10, 0xD0, 0x26, 0x20, 0x00, 0x5D,
       0x04, 0x28, 0x0C, 0xDA, 0x20, 0x22, 0x11, 0x5D, 0xF7, 0x20, 0x08, 0x40, 0x10, 0x55, 0xF8, 0xBD,
       0xAA, 0x48, 0x12, 0x38, 0x00, 0xE0, 0xA9, 0x48, 0xA7, 0x49, 0x40, 0x18, 0x38, 0x62, 0x01, 0x05,
       0xFF, 0xFF, 0x70, 0x6A, 0x08, 0x00, 0xFA, 0xF8, 0xBD, 0xC0, 0x46, 0x25, 0x00, 0x00, 0x00, 0xEF,
       0x22, 0x08, 0x00, 0x5D, 0x8B, 0x04, 0x00, 0x7B, 0x5F, 0x03, 0x00, 0xAB, 0xB9, 0x03, 0x00, 0xBF,
       0x70, 0x05, 0x00, 0x76, 0x81, 0x00, 0x00, 0x05, 0x63, 0x08, 0x00, 0x60, 0x19, 0x08, 0x00, 0x10,
       0x27, 0x00, 0x00, 0xCC, 0x24, 0x08, 0x00, 0x2C, 0x51, 0x08, 0x00, 0x2D, 0x61, 0x04, 0x00, 0xE9,
       0x3F, 0x05, 0x00, 0x5B, 0xF5, 0x00, 0x00, 0xBB, 0x16, 0x04, 0x00, 0xF8, 0xB5, 0xDF, 0x4F, 0x97,
       0x48, 0x00, 0x78, 0x02, 0x28, 0x0C, 0xD1, 0x01, 0x24, 0xA6, 0x46, 0xDC, 0x48, 0xFE, 0x44, 0x00,
       0x47, 0xA6, 0x46, 0xDB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0xDA, 0x48, 0xFE, 0x44, 0x00,
       0x47, 0x01, 0x24, 0xA6, 0x46, 0xD9, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0xD8, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0xA6, 0x46, 0xD7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x23, 0x4E, 0x00, 0x25, 0x00,
       0x95, 0x38, 0x20, 0x80, 0x5D, 0x0C, 0x28, 0x25, 0xD1, 0xF0, 0x78, 0x00, 0x28, 0x04, 0xD0, 0x3A,
       0x20, 0x80, 0x5D, 0x0E, 0x28, 0x00, 0xD1, 0x00, 0x94, 0x3B, 0x20, 0x81, 0x5D, 0x3C, 0x20, 0x80,
       0x5D, 0x08, 0x43, 0x17, 0xD1, 0xFF, 0x20, 0x6D, 0x30, 0x80, 0x19, 0xA6, 0x46, 0xCA, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x00, 0x28, 0x0E, 0xD0, 0x04, 0x20, 0xA6, 0x46, 0xC7, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x28, 0x07, 0xD0, 0xC5, 0x80, 0x35, 0x21, 0x09, 0x02, 0x01, 0x80, 0xA6, 0x46, 0xC3,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x11, 0x20, 0x40, 0x01, 0x86, 0x19, 0x01, 0x35, 0x07, 0x2D, 0xCF,
       0xD3, 0x00, 0x98, 0x00, 0x28, 0x03, 0xD1, 0x39, 0x78, 0xDF, 0x20, 0x08, 0x40, 0x02, 0xE0, 0x39,
       0x78, 0x01, 0x05, 0xFF, 0xFF, 0x6A, 0x6B, 0x08, 0x00, 0xFA, 0x20, 0x20, 0x08, 0x43, 0x38, 0x70,
       0xBA, 0x48, 0x07, 0x68, 0xBA, 0x49, 0xFF, 0x22, 0x3D, 0x32, 0x56, 0x18, 0xEB, 0x4A, 0x53, 0x5C,
       0x00, 0x25, 0x26, 0xE0, 0x00, 0x00, 0x08, 0x00, 0xA8, 0x00, 0x32, 0x58, 0xB5, 0x20, 0x81, 0x5C,
       0xE7, 0x48, 0x88, 0x40, 0x07, 0x42, 0x1B, 0xD0, 0xC5, 0x20, 0x80, 0x5C, 0x00, 0x28, 0x17, 0xD1,
       0x50, 0x8D, 0x06, 0x21, 0x41, 0x43, 0x06, 0x31, 0x10, 0x8F, 0x88, 0x42, 0x10, 0xDA, 0x04, 0x20,
       0xA6, 0x46, 0xEC, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x43, 0x21, 0x49, 0x02, 0x01, 0x80, 0xC5, 0x80,
       0xA6, 0x46, 0xA5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xA4, 0x48, 0x07, 0x68, 0xE6, 0x48, 0x03, 0x78,
       0x01, 0x35, 0x9D, 0x42, 0xD8, 0xD3, 0xF8, 0xBD, 0xD5, 0xB4, 0x02, 0x00, 0x84, 0x26, 0x08, 0x00,
       0x17, 0x8C, 0x04, 0x00, 0x69, 0x63, 0x08, 0x00, 0x10, 0xB5, 0x92, 0x4B, 0x15, 0x3B, 0xDF, 0x48,
       0x00, 0x78, 0x19, 0x78, 0x81, 0x42, 0x0D, 0xDD, 0x07, 0x21, 0xDD, 0x48, 0x00, 0x22, 0x40, 0x24,
       0x24, 0x5C, 0x00, 0x2C, 0x02, 0xD0, 0x52, 0x1C, 0x12, 0x06, 0x12, 0x0E, 0xA8, 0x30, 0x01, 0x39,
       0xF5, 0xD1, 0x1A, 0x70, 0x10, 0xBD, 0xC0, 0x46, 0x5D, 0xF0, 0x03, 0x00, 0xF0, 0xB5, 0x01, 0x24,
       0xA6, 0x46, 0x37, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0x36, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x00, 0x28, 0x10, 0xD0, 0x11, 0x27, 0x09, 0x26, 0xE8, 0x4D, 0x3E, 0x20, 0x40, 0x5D, 0xFF, 0x28,
       0x06, 0xD0, 0x3B, 0x20, 0x47, 0x55, 0x28, 0x1C, 0xA6, 0x46, 0xE5, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x50, 0x35, 0x01, 0x3E, 0xF1, 0xD1, 0xF0, 0xBD, 0x55, 0xF6, 0x00, 0x00, 0x00, 0xB5, 0xE1, 0x48,
       0x00, 0x88, 0x02, 0x28, 0x01, 0x05, 0xFF, 0xFF, 0x64, 0x6C, 0x08, 0x00, 0xFA, 0x01, 0xDA, 0x01,
       0x21, 0x02, 0xE0, 0x40, 0x1E, 0x01, 0x04, 0x09, 0x0C, 0xDD, 0x48, 0x00, 0x22, 0x01, 0x23, 0x9E,
       0x46, 0xDC, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x00, 0xBD, 0x6A, 0x63, 0x08, 0x00, 0xB4, 0x8A, 0x06,
       0x00, 0x61, 0x97, 0x04, 0x00, 0x28, 0x19, 0x08, 0x00, 0x57, 0x98, 0x04, 0x00, 0xF0, 0xB5, 0xA4,
       0xB0, 0x06, 0x1C, 0x31, 0x7C, 0x75, 0x69, 0xA8, 0x7C, 0x00, 0x28, 0x03, 0xD1, 0x28, 0x68, 0xC0,
       0x78, 0x00, 0x28, 0x25, 0xD1, 0x04, 0x29, 0x23, 0xD1, 0x28, 0x68, 0x01, 0x78, 0x1B, 0x20, 0x01,
       0x24, 0xA6, 0x46, 0xCD, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x06, 0x09, 0x0E, 0x68, 0x46, 0xA6,
       0x46, 0xCA, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x12, 0x21, 0x4F, 0x19, 0x01, 0x06, 0x09, 0x0E, 0x68,
       0x46, 0x3A, 0x1C, 0xA6, 0x46, 0xC6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE8, 0x74, 0x05, 0x48, 0x39,
       0x1C, 0xA6, 0x46, 0xC4, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x01, 0xD0, 0x02, 0x20, 0x30,
       0x61, 0x24, 0xB0, 0xF0, 0xBD, 0x70, 0x63, 0x08, 0x00, 0x37, 0x98, 0x01, 0x00, 0x37, 0x9B, 0x01,
       0x00, 0x0D, 0xE2, 0x00, 0x00, 0xDC, 0x0C, 0x00, 0x00, 0x3A, 0x0E, 0x00, 0x00, 0x73, 0x2C, 0x00,
       0x00, 0x41, 0x10, 0x08, 0x00, 0xFF, 0xB5, 0x00, 0x90, 0xB7, 0x48, 0x06, 0x1C, 0x32, 0x3E, 0x60,
       0x21, 0x89, 0x19, 0x00, 0x78, 0x0A, 0x78, 0x00, 0x2A, 0x75, 0xD0, 0x09, 0x7B, 0x00, 0x29, 0x72,
       0xD1, 0xFF, 0x28, 0x5F, 0xD1, 0x34, 0x1C, 0xB1, 0x48, 0x05, 0x1C, 0x01, 0x95, 0xB0, 0x48, 0x02,
       0x90, 0x00, 0x27, 0xE1, 0x88, 0xAD, 0x48, 0x81, 0x42, 0x2B, 0xD0, 0xA9, 0x42, 0x15, 0xDB, 0xA9,
       0x42, 0x27, 0xD1, 0xAB, 0x49, 0x78, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x5E, 0x6D, 0x08, 0x00, 0xFA,
       0x30, 0x18, 0x4C, 0x22, 0x10, 0x5A, 0x08, 0x1A, 0x01, 0x22, 0x96, 0x46, 0xA8, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x01, 0x04, 0x09, 0x0C, 0x20, 0x89, 0x09, 0x18, 0x01, 0x9A, 0x02, 0x98, 0x10, 0x18,
       0x81, 0x42, 0x13, 0xD2, 0xE5, 0x88, 0x20, 0x89, 0x01, 0x90, 0x38, 0x06, 0x00, 0x0E, 0x03, 0x90,
       0x9E, 0x49, 0x40, 0x00, 0x30, 0x18, 0x4C, 0x22, 0x10, 0x5A, 0x08, 0x1A, 0x01, 0x22, 0x96, 0x46,
       0x9B, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x04, 0x00, 0x0C, 0x02, 0x90, 0x10, 0x34, 0x01, 0x37,
       0x03, 0x2F, 0xCB, 0xDB, 0x94, 0x48, 0x01, 0x99, 0x81, 0x42, 0x1A, 0xD0, 0x02, 0x2D, 0x09, 0xDA,
       0x03, 0x98, 0x01, 0x99, 0x00, 0x22, 0xD2, 0x43, 0x01, 0x23, 0x9E, 0x46, 0x91, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x2A, 0xE0, 0x03, 0x98, 0x01, 0x1C, 0x09, 0x01, 0x71, 0x58, 0x69, 0x18, 0x01, 0x39,
       0x89, 0x01, 0x8A, 0x09, 0x01, 0x99, 0x01, 0x23, 0x9E, 0x46, 0x89, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x1B, 0xE0, 0x01, 0x20, 0x86, 0x46, 0x87, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x15, 0xE0, 0x1C, 0x21,
       0x41, 0x43, 0x70, 0x18, 0x89, 0x21, 0x08, 0x5C, 0x00, 0x01, 0x30, 0x18, 0x01, 0x89, 0x03, 0x20,
       0x00, 0x22, 0xD2, 0x43, 0x01, 0x23, 0x9E, 0x46, 0x7E, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x04, 0xE0,
       0x01, 0x20, 0x86, 0x46, 0x7D, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x7C, 0x49, 0xCE, 0x31, 0x00, 0x98,
       0x01, 0x62, 0x00, 0x90, 0xFF, 0xBD, 0xD4, 0x0F, 0x08, 0x00, 0x53, 0x63, 0x05, 0x00, 0xAD, 0x98,
       0x02, 0x00, 0x15, 0x7E, 0x04, 0x00, 0x1D, 0x6C, 0x08, 0x00, 0x5D, 0x6C, 0x08, 0x00, 0xE9, 0x6B,
       0x08, 0x00, 0xF7, 0x64, 0x04, 0x00, 0x9B, 0x60, 0x04, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x58, 0x6E,
       0x08, 0x00, 0xFA, 0xDB, 0x3F, 0x05, 0x00, 0x7C, 0x63, 0x08, 0x00, 0x48, 0x25, 0x08, 0x00, 0xF8,
       0xB5, 0x00, 0x90, 0x65, 0x4A, 0x32, 0x3A, 0x54, 0x20, 0x86, 0x18, 0x21, 0x20, 0xC0, 0x43, 0x80,
       0x5D, 0x1C, 0x21, 0x41, 0x43, 0x8C, 0x18, 0x88, 0x34, 0x70, 0x78, 0x68, 0x49, 0x82, 0x07, 0x4A,
       0xD1, 0x40, 0x06, 0x80, 0x0F, 0x06, 0xD1, 0x20, 0x78, 0x02, 0x28, 0x03, 0xD0, 0xB0, 0x88, 0x62,
       0x4A, 0x02, 0x42, 0x40, 0xD0, 0x08, 0x78, 0x31, 0x7E, 0x00, 0x29, 0x06, 0xD1, 0x00, 0x21, 0x31,
       0x73, 0x40, 0x1C, 0x00, 0x06, 0x00, 0x0E, 0x5D, 0x49, 0x08, 0x70, 0x0A, 0x28, 0x35, 0xDD, 0x5C,
       0x4F, 0x37, 0x20, 0xC0, 0x5D, 0xC0, 0x08, 0x15, 0xD3, 0x02, 0x20, 0x01, 0x25, 0xAE, 0x46, 0x59,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x02, 0x20, 0x58, 0x49, 0x08, 0x70, 0xAE, 0x46, 0x58, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x60, 0x68, 0x14, 0x21, 0x41, 0x43, 0x78, 0x18, 0x00, 0x7B, 0xAE, 0x46, 0x54,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x01, 0x25, 0x53, 0x4F, 0x3D, 0x80, 0x2C, 0x1C, 0xAE, 0x46, 0x52,
       0x48, 0xFE, 0x44, 0x00, 0x47, 0x3D, 0x80, 0xAE, 0x46, 0x50, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x35,
       0x73, 0x47, 0x49, 0x00, 0x20, 0x08, 0x70, 0x03, 0x20, 0xB9, 0x21, 0xC9, 0x00, 0xA6, 0x46, 0x4C,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0xE0, 0x00, 0x20, 0x08, 0x70, 0x48, 0x49, 0xBE, 0x31, 0x00,
       0x98, 0x01, 0x62, 0xF8, 0xBD, 0xC0, 0x46, 0x6A, 0x0A, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x10,
       0xB5, 0x04, 0x1C, 0x00, 0x20, 0x01, 0x21, 0x8E, 0x46, 0x43, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x40,
       0x1C, 0x03, 0xD1, 0x41, 0x48, 0xFF, 0x30, 0x5F, 0x30, 0x20, 0x62, 0x10, 0xBD, 0x01, 0x05, 0xFF,
       0xFF, 0x52, 0x6F, 0x08, 0x00, 0xFA, 0x00, 0x7C, 0x14, 0x28, 0x01, 0xD0, 0x00, 0x20, 0x00, 0xE0,
       0x03, 0x20, 0x3D, 0x49, 0x08, 0x80, 0xF7, 0x46, 0x75, 0x60, 0x04, 0x00, 0xB2, 0x2F, 0x08, 0x00,
       0x83, 0x50, 0x08, 0x00, 0x60, 0x19, 0x08, 0x00, 0xF0, 0xB5, 0x87, 0x69, 0xC1, 0x69, 0x00, 0x29,
       0x2D, 0xD0, 0x09, 0x88, 0xC9, 0x1E, 0x07, 0xD0, 0x26, 0x4A, 0x10, 0x3A, 0x89, 0x1A, 0x01, 0xD0,
       0x00, 0x21, 0x06, 0xE0, 0x01, 0x21, 0x01, 0xE0, 0x01, 0x21, 0x09, 0x04, 0xB5, 0x22, 0xD2, 0x5D,
       0x91, 0x40, 0x2F, 0x4C, 0x22, 0x68, 0x2F, 0x4D, 0x11, 0x42, 0x04, 0xD0, 0x07, 0x60, 0x2B, 0x1C,
       0xFF, 0x33, 0x13, 0x33, 0x03, 0x62, 0x00, 0x29, 0x11, 0xD0, 0x7B, 0x8D, 0x06, 0x26, 0x5E, 0x43,
       0x26, 0x4B, 0x9B, 0x1B, 0x3E, 0x8F, 0x9E, 0x42, 0x02, 0xDA, 0x8A, 0x43, 0x22, 0x60, 0xF0, 0xBD,
       0x0A, 0x43, 0x22, 0x60, 0x00, 0x21, 0x81, 0x60, 0xFF, 0x35, 0x0B, 0x35, 0x05, 0x62, 0xF0, 0xBD,
       0xF4, 0x46, 0x08, 0x00, 0xA5, 0x1E, 0x02, 0x00, 0x8C, 0x18, 0x08, 0x00, 0x36, 0x02, 0x1A, 0x00,
       0x15, 0x49, 0x05, 0x00, 0xA7, 0x31, 0x05, 0x00, 0x0D, 0x9E, 0x01, 0x00, 0xF7, 0x64, 0x01, 0x00,
       0x81, 0x8A, 0x02, 0x00, 0x26, 0x23, 0x08, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xE2, 0x04, 0x00, 0x00,
       0x6D, 0x94, 0x05, 0x00, 0x81, 0xA3, 0x02, 0x00, 0xEB, 0xA3, 0x02, 0x00, 0x4F, 0xA3, 0x02, 0x00,
       0x65, 0xAD, 0x02, 0x00, 0x20, 0x20, 0x00, 0x00, 0xFC, 0x62, 0x08, 0x00, 0xC0, 0x17, 0x08, 0x00,
       0x59, 0xA9, 0x03, 0x00, 0xEA, 0x51, 0x08, 0x00, 0x05, 0x64, 0x05, 0x00, 0xFB, 0xA1, 0x02, 0x00,
       0x82, 0x07, 0x1A, 0x00, 0xF1, 0x16, 0x04, 0x00, 0x59, 0xAA, 0x02, 0x00, 0xF5, 0xD3, 0x04, 0x00,
       0x01, 0x05, 0xFF, 0xFF, 0x4C, 0x70, 0x08, 0x00, 0xFA, 0x49, 0xA3, 0x00, 0x00, 0x8D, 0x7E, 0x00,
       0x00, 0x46, 0x24, 0x19, 0x00, 0xF9, 0xFF, 0x00, 0x00, 0x7C, 0x63, 0x08, 0x00, 0x17, 0x8C, 0x04,
       0x00, 0x40, 0x1E, 0x80, 0x00, 0xE5, 0x4B, 0x19, 0x50, 0xE3, 0x49, 0x0A, 0x50, 0xF7, 0x46, 0x80,
       0x69, 0xB8, 0x21, 0x09, 0x5C, 0x01, 0x29, 0x06, 0xD0, 0xB5, 0x21, 0x08, 0x5C, 0x60, 0x21, 0x41,
       0x43, 0xDF, 0x4A, 0x00, 0x20, 0x50, 0x54, 0xDF, 0x48, 0x1B, 0x30, 0xF7, 0x46, 0x10, 0xB5, 0x04,
       0x1C, 0xDD, 0x48, 0x00, 0x68, 0x01, 0x21, 0x8E, 0x46, 0xDC, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xE0,
       0x68, 0x0C, 0x30, 0xE0, 0x60, 0xDA, 0x48, 0xFF, 0x30, 0x02, 0x30, 0x10, 0xBD, 0x10, 0xB5, 0x43,
       0x69, 0x19, 0x88, 0x09, 0x06, 0x09, 0x0E, 0xD7, 0x4A, 0x02, 0x29, 0x02, 0xD0, 0x10, 0x1C, 0x87,
       0x30, 0x10, 0xBD, 0xD1, 0x49, 0x09, 0x6B, 0x89, 0x68, 0xC9, 0x88, 0x09, 0x05, 0x0C, 0x0D, 0xA1,
       0x0A, 0x06, 0xD0, 0xE3, 0x49, 0x1E, 0x31, 0x8C, 0x42, 0x02, 0xD8, 0x59, 0x88, 0x01, 0x31, 0x01,
       0xE0, 0xD9, 0x88, 0x05, 0x31, 0x41, 0x60, 0x10, 0x1C, 0x9F, 0x30, 0x10, 0xBD, 0x00, 0xB5, 0x01,
       0x1C, 0x48, 0x68, 0xC9, 0x69, 0xB5, 0x22, 0x51, 0x5C, 0xDC, 0x22, 0x4A, 0x43, 0xE7, 0x49, 0x89,
       0x18, 0x08, 0x22, 0x01, 0x23, 0x9E, 0x46, 0xE6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE5, 0x48, 0x3F,
       0x30, 0x00, 0xBD, 0x40, 0x69, 0x01, 0x8F, 0xC0, 0x8E, 0x40, 0x1A, 0x00, 0x04, 0x01, 0x0C, 0xE4,
       0x48, 0x40, 0x0A, 0x81, 0x42, 0x02, 0xD3, 0xE3, 0x48, 0xFB, 0x38, 0x00, 0xE0, 0xDF, 0x48, 0xDE,
       0x49, 0x40, 0x18, 0xF7, 0x46, 0xF0, 0xB5, 0x82, 0x69, 0x16, 0x04, 0x36, 0x0C, 0x04, 0x21, 0x11,
       0x40, 0x08, 0x20, 0x01, 0x05, 0xFF, 0xFF, 0x46, 0x71, 0x08, 0x00, 0xFA, 0x10, 0x40, 0x08, 0x43,
       0x28, 0xD0, 0xDC, 0x48, 0x04, 0x38, 0xFF, 0x21, 0x3D, 0x31, 0x0F, 0x18, 0xD9, 0x49, 0x08, 0x5C,
       0x00, 0x24, 0x1D, 0xE0, 0xA0, 0x00, 0x3D, 0x58, 0xC2, 0x20, 0x40, 0x5D, 0x00, 0x28, 0x14, 0xD0,
       0xF0, 0x08, 0x06, 0xD3, 0xB5, 0x20, 0x40, 0x5D, 0x01, 0x21, 0x8E, 0x46, 0xDF, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x30, 0x09, 0x09, 0xD3, 0xB5, 0x20, 0x40, 0x5D, 0x0A, 0x30, 0x00, 0x06, 0x00, 0x0E,
       0x01, 0x21, 0x8E, 0x46, 0xD9, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x01, 0x34, 0xE5, 0x48, 0x00, 0x78,
       0x84, 0x42, 0xDF, 0xD3, 0xE4, 0x48, 0x87, 0x30, 0xF0, 0xBD, 0x70, 0xB5, 0x06, 0x1C, 0xB0, 0x68,
       0xE2, 0x4D, 0x00, 0x28, 0x02, 0xD1, 0x28, 0x1C, 0xDF, 0x30, 0x70, 0xBD, 0x95, 0x4C, 0x04, 0x3C,
       0x20, 0x7A, 0x02, 0x28, 0x08, 0xD0, 0xE5, 0x49, 0x08, 0x5C, 0x01, 0x21, 0x8E, 0x46, 0xE4, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x00, 0x28, 0x02, 0xD0, 0x28, 0x1C, 0xCF, 0x30, 0x70, 0xBD, 0x00, 0x20,
       0x20, 0x60, 0x70, 0x60, 0x28, 0x1C, 0xFF, 0x30, 0x20, 0x30, 0x70, 0xBD, 0x10, 0xB5, 0xAD, 0x49,
       0x11, 0x31, 0x06, 0x22, 0x00, 0x23, 0x0C, 0x78, 0xFF, 0x2C, 0x02, 0xD1, 0x5B, 0x1C, 0x1B, 0x06,
       0x1B, 0x0E, 0xDC, 0x31, 0x01, 0x3A, 0xF6, 0xD1, 0x43, 0x60, 0xE7, 0x48, 0x19, 0x30, 0x10, 0xBD,
       0x01, 0x1C, 0xE6, 0x4B, 0x1A, 0x78, 0xE6, 0x48, 0x05, 0x2A, 0x04, 0xD1, 0xE6, 0x4A, 0x12, 0x68,
       0x12, 0x78, 0x01, 0x2A, 0x02, 0xD0, 0x4B, 0x60, 0x5B, 0x30, 0xF7, 0x46, 0x7D, 0x30, 0xF7, 0x46,
       0x10, 0xB5, 0x01, 0x1C, 0xEB, 0x48, 0x00, 0x68, 0xEC, 0x4C, 0x00, 0x28, 0x0B, 0xD0, 0x88, 0x69,
       0x09, 0x7A, 0x01, 0x22, 0x96, 0x46, 0x01, 0x05, 0xFF, 0xFF, 0x40, 0x72, 0x08, 0x00, 0xFA, 0xE7,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x02, 0xD0, 0x20, 0x1C, 0x21, 0x30, 0x10, 0xBD, 0x20,
       0x1C, 0x33, 0x30, 0x10, 0xBD, 0xF8, 0xB5, 0x81, 0x69, 0x00, 0x91, 0xDF, 0x4C, 0x25, 0x1C, 0x0C,
       0x3D, 0xE9, 0x68, 0x08, 0x22, 0x57, 0x18, 0x40, 0x69, 0xDE, 0x4A, 0x00, 0x28, 0x02, 0xD0, 0x10,
       0x1C, 0xD3, 0x30, 0xF8, 0xBD, 0x00, 0x26, 0x04, 0xE0, 0x70, 0x1C, 0x06, 0x06, 0x36, 0x0E, 0x06,
       0x37, 0x21, 0x68, 0x48, 0x88, 0x86, 0x42, 0x14, 0xDA, 0x38, 0x1C, 0x00, 0x99, 0x01, 0x22, 0x96,
       0x46, 0xD5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0xEE, 0xD1, 0x0C, 0x34, 0xE8, 0x68, 0x41,
       0x88, 0x01, 0x20, 0x88, 0x40, 0xE1, 0x6F, 0x81, 0x43, 0xE1, 0x67, 0xE9, 0x68, 0x48, 0x88, 0x01,
       0x38, 0x48, 0x80, 0xCB, 0x48, 0xFF, 0x30, 0x14, 0x30, 0xF8, 0xBD, 0x01, 0x1C, 0xCC, 0x48, 0x02,
       0x78, 0xCA, 0x48, 0x00, 0x2A, 0x01, 0xD0, 0xED, 0x30, 0xF7, 0x46, 0x41, 0x22, 0x4A, 0x60, 0x39,
       0x30, 0xF7, 0x46, 0xF8, 0xB5, 0x06, 0x1C, 0x75, 0x69, 0xB7, 0x69, 0x31, 0x6A, 0x30, 0x7F, 0x00,
       0x28, 0x2D, 0xD1, 0x01, 0x21, 0xA8, 0x8D, 0x18, 0x28, 0x27, 0xDC, 0xC4, 0x48, 0x00, 0x78, 0x00,
       0x90, 0x00, 0x24, 0x01, 0x22, 0xA2, 0x40, 0x00, 0x98, 0x10, 0x42, 0x1B, 0xD0, 0xBD, 0x48, 0x20,
       0x5C, 0x11, 0x21, 0x49, 0x01, 0x41, 0x43, 0xBB, 0x48, 0x41, 0x18, 0xFF, 0x20, 0x1E, 0x30, 0x40,
       0x5C, 0x01, 0x28, 0x01, 0xD1, 0x02, 0x20, 0x00, 0xE0, 0x00, 0x20, 0xC9, 0x78, 0x08, 0x18, 0xB8,
       0x49, 0x08, 0x5C, 0xA9, 0x8D, 0x01, 0x22, 0x96, 0x46, 0xE9, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x48,
       0x1C, 0x01, 0x06, 0x09, 0x0E, 0x01, 0x34, 0x07, 0x2C, 0x01, 0x05, 0xFF, 0xFF, 0x3A, 0x73, 0x08,
       0x00, 0xFA, 0xDB, 0xDB, 0xA8, 0x8D, 0x01, 0xE0, 0x48, 0x7D, 0xA9, 0x8D, 0x48, 0x43, 0x39, 0x68,
       0x40, 0x18, 0x80, 0x01, 0x80, 0x09, 0x38, 0x60, 0x70, 0x60, 0xAA, 0x48, 0x5D, 0x30, 0xF8, 0xBD,
       0x01, 0x1C, 0x4A, 0x68, 0x13, 0x06, 0x1B, 0x0E, 0xA9, 0x48, 0x03, 0xD1, 0x90, 0x4B, 0x1B, 0x78,
       0x03, 0x2B, 0x05, 0xD0, 0x00, 0x2A, 0x01, 0xD0, 0x1D, 0x30, 0xF7, 0x46, 0xFF, 0x30, 0xF7, 0x46,
       0x97, 0x4A, 0x30, 0x23, 0x9B, 0x5C, 0x00, 0x2B, 0x07, 0xD1, 0x94, 0x4B, 0x92, 0x88, 0x9A, 0x42,
       0x03, 0xD1, 0xA0, 0x4A, 0x12, 0x78, 0x00, 0x2A, 0x01, 0xD0, 0x00, 0x22, 0x00, 0xE0, 0x07, 0x22,
       0x4A, 0x60, 0xFF, 0x30, 0xA2, 0x30, 0xF7, 0x46, 0x40, 0x69, 0x78, 0x21, 0x09, 0x5A, 0x9A, 0x48,
       0xAC, 0x29, 0x01, 0xDA, 0x3B, 0x30, 0xF7, 0x46, 0x89, 0x30, 0xF7, 0x46, 0x01, 0x1C, 0x7C, 0x48,
       0x02, 0x78, 0xF0, 0x48, 0x05, 0x2A, 0x07, 0xD1, 0x20, 0x22, 0x51, 0x5C, 0x01, 0x29, 0x03, 0xD1,
       0xEB, 0x49, 0x09, 0x78, 0x49, 0x08, 0x01, 0xD2, 0x8F, 0x30, 0xF7, 0x46, 0x85, 0x30, 0xF7, 0x46,
       0xE9, 0x48, 0x59, 0x30, 0xF7, 0x46, 0xE9, 0x48, 0x67, 0x30, 0xF7, 0x46, 0xC1, 0x69, 0x82, 0x69,
       0x51, 0x1A, 0x01, 0x61, 0xE6, 0x48, 0x73, 0x30, 0xF7, 0x46, 0x00, 0x21, 0x41, 0x60, 0xE5, 0x48,
       0xA1, 0x30, 0xF7, 0x46, 0x04, 0xF3, 0x1A, 0x00, 0x80, 0x7B, 0x08, 0x00, 0x76, 0xA0, 0x1B, 0x00,
       0x6D, 0x97, 0x00, 0x00, 0x6C, 0x55, 0x08, 0x00, 0x4F, 0x61, 0x04, 0x00, 0x39, 0xC1, 0x02, 0x00,
       0x7D, 0xC4, 0x02, 0x00, 0x81, 0xB0, 0x00, 0x90, 0x00, 0x21, 0x68, 0x46, 0x42, 0x88, 0x03, 0x88,
       0x93, 0x42, 0x03, 0xD1, 0x02, 0x78, 0x40, 0x78, 0x90, 0x42, 0x0F, 0xD0, 0x01, 0x05, 0xFF, 0xFF,
       0x34, 0x74, 0x08, 0x00, 0xFA, 0x00, 0x98, 0xC3, 0x0F, 0x1E, 0x20, 0x00, 0x9A, 0xC2, 0x40, 0xD2,
       0x07, 0xD2, 0x0F, 0x93, 0x42, 0x00, 0xD0, 0x01, 0x31, 0x18, 0x29, 0x03, 0xD8, 0x1A, 0x28, 0x03,
       0xD1, 0x02, 0x29, 0x01, 0xD2, 0x00, 0x20, 0x03, 0xE0, 0x13, 0x1C, 0x01, 0x38, 0xED, 0xD5, 0x01,
       0x20, 0x01, 0xB0, 0xF7, 0x46, 0xE1, 0x04, 0x00, 0x00, 0xF0, 0xB5, 0x06, 0x1C, 0x77, 0x68, 0x0A,
       0x25, 0x05, 0xE0, 0xA6, 0x46, 0xF2, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x07, 0x1C, 0x01, 0x3D, 0x00,
       0x2D, 0x07, 0xD0, 0x38, 0x1C, 0x01, 0x24, 0xA6, 0x46, 0xF5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00,
       0x28, 0xEF, 0xD0, 0x77, 0x60, 0xF0, 0x69, 0xB0, 0x60, 0xF2, 0x48, 0xFF, 0x30, 0x34, 0x30, 0xF0,
       0xBD, 0x5C, 0x27, 0x08, 0x00, 0x4B, 0x1E, 0x04, 0x00, 0x05, 0x5E, 0x02, 0x00, 0xC9, 0x98, 0x00,
       0x00, 0x83, 0x05, 0x00, 0x00, 0xF0, 0xFF, 0xFF, 0x00, 0xE2, 0x04, 0x00, 0x00, 0x6A, 0x0A, 0x00,
       0x00, 0x4C, 0x25, 0x08, 0x00, 0x10, 0xB5, 0x44, 0x68, 0x3A, 0x20, 0x00, 0x5D, 0x22, 0x28, 0x06,
       0xD1, 0x20, 0x1C, 0x00, 0x21, 0x01, 0x22, 0x96, 0x46, 0xE9, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x20,
       0x1C, 0x00, 0x21, 0x01, 0x22, 0x96, 0x46, 0xF5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xF4, 0x48, 0x6F,
       0x30, 0x10, 0xBD, 0xC0, 0x46, 0x47, 0x93, 0x02, 0x00, 0x30, 0xB5, 0x04, 0x1C, 0x2A, 0x48, 0xBF,
       0x38, 0x01, 0x78, 0x02, 0x29, 0x01, 0xD1, 0x00, 0x21, 0x01, 0x70, 0xEE, 0x49, 0xEE, 0x48, 0x42,
       0x1C, 0x1D, 0x20, 0x00, 0x23, 0x01, 0x25, 0xAE, 0x46, 0xEC, 0x4D, 0xFE, 0x44, 0x28, 0x47, 0x60,
       0x69, 0x00, 0x68, 0x60, 0x60, 0xEA, 0x48, 0xFF, 0x30, 0x3A, 0x30, 0x30, 0xBD, 0xB2, 0x2F, 0x01,
       0x05, 0xFF, 0xFF, 0x2E, 0x75, 0x08, 0x00, 0xFA, 0x08, 0x00, 0x49, 0xA0, 0x02, 0x00, 0x25, 0x6E,
       0x03, 0x00, 0x10, 0xB5, 0xE6, 0x49, 0xE4, 0x4A, 0xFF, 0x32, 0x38, 0x32, 0x1D, 0x20, 0x00, 0x23,
       0x01, 0x24, 0xA6, 0x46, 0xE0, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0xDD, 0x48, 0xC0, 0x1D, 0x10, 0xBD,
       0xC0, 0x46, 0x3C, 0x91, 0x06, 0x00, 0x17, 0x62, 0x04, 0x00, 0xF0, 0xB5, 0x9C, 0x46, 0x1B, 0x4C,
       0x0E, 0x1C, 0x26, 0x40, 0x05, 0x1C, 0x25, 0x40, 0x2F, 0x1C, 0x77, 0x43, 0x09, 0x0C, 0x00, 0x0C,
       0x03, 0x1C, 0x4B, 0x43, 0x69, 0x43, 0x70, 0x43, 0x05, 0x1C, 0x25, 0x40, 0x0C, 0x40, 0x64, 0x19,
       0x00, 0x0C, 0x09, 0x0C, 0x08, 0x18, 0x39, 0x0C, 0x61, 0x18, 0x09, 0x0C, 0x00, 0xD0, 0x01, 0x30,
       0x21, 0x04, 0xCF, 0x19, 0xC3, 0x18, 0x60, 0x46, 0x07, 0x60, 0x13, 0x60, 0xF0, 0xBD, 0xEF, 0x8A,
       0x04, 0x00, 0x41, 0x10, 0x08, 0x00, 0xD9, 0xAE, 0x02, 0x00, 0xF4, 0x62, 0x08, 0x00, 0x1C, 0xB5,
       0xE1, 0x49, 0x6A, 0x46, 0x01, 0xAB, 0x01, 0x24, 0xA6, 0x46, 0xDF, 0x4C, 0xFE, 0x44, 0x20, 0x47,
       0x01, 0x98, 0xC1, 0x0B, 0x00, 0x98, 0x40, 0x04, 0x08, 0x43, 0x1C, 0xBD, 0xC0, 0x46, 0xFF, 0xFF,
       0x00, 0x00, 0x48, 0x25, 0x08, 0x00, 0xEC, 0x0E, 0x08, 0x00, 0x5D, 0x86, 0x01, 0x00, 0xDD, 0xF8,
       0x03, 0x00, 0x79, 0x1C, 0x04, 0x00, 0xDD, 0x84, 0x01, 0x00, 0x6A, 0x63, 0x08, 0x00, 0x00, 0x16,
       0x08, 0x00, 0x00, 0x00, 0x08, 0x00, 0x09, 0x82, 0x01, 0x00, 0x05, 0x63, 0x08, 0x00, 0x08, 0x63,
       0x08, 0x00, 0xBD, 0x7B, 0x03, 0x00, 0xF5, 0x50, 0x08, 0x00, 0xE5, 0x85, 0x00, 0x00, 0xF0, 0xB5,
       0x8D, 0xB0, 0x03, 0xA8, 0x01, 0x21, 0x8E, 0x46, 0xF0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xF0, 0x48,
       0x06, 0x90, 0x01, 0x05, 0xFF, 0xFF, 0x28, 0x76, 0x08, 0x00, 0xFA, 0x72, 0x38, 0x06, 0x90, 0xEE,
       0x48, 0x07, 0x90, 0x06, 0x38, 0x07, 0x90, 0x38, 0x21, 0x41, 0x80, 0x01, 0x20, 0x86, 0x46, 0xE9,
       0x48, 0xFE, 0x44, 0x00, 0x47, 0x03, 0xA8, 0x08, 0x90, 0x4C, 0x48, 0x09, 0x90, 0x69, 0x38, 0x09,
       0x90, 0x00, 0x20, 0x0A, 0x90, 0x0A, 0x98, 0x00, 0x06, 0x00, 0x0E, 0x0B, 0x90, 0xE3, 0x48, 0x0B,
       0x99, 0x01, 0x22, 0x96, 0x46, 0xE2, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0xF6, 0xD0, 0x08,
       0x98, 0x00, 0x68, 0x09, 0x99, 0x89, 0x6A, 0x01, 0x24, 0xA6, 0x46, 0xDD, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x28, 0x00, 0xD5, 0x40, 0x42, 0xA6, 0x46, 0xDB, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x05,
       0x1C, 0x0B, 0x98, 0x01, 0xA9, 0x02, 0xAA, 0x64, 0x23, 0xA6, 0x46, 0xD7, 0x4E, 0xFE, 0x44, 0x30,
       0x47, 0x68, 0x46, 0x0C, 0x90, 0x00, 0x89, 0x46, 0x1B, 0x15, 0xD5, 0xDB, 0x4F, 0x39, 0x1C, 0x30,
       0x1C, 0xA6, 0x46, 0x07, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x4D, 0x42, 0x30, 0x1C, 0x39, 0x1C, 0xA6,
       0x46, 0xCF, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x00, 0xD0, 0x01, 0x35, 0x6F, 0x43, 0xBE,
       0x19, 0x02, 0xE0, 0x6D, 0x94, 0x05, 0x00, 0x00, 0x25, 0x01, 0x98, 0x40, 0x1B, 0x80, 0x01, 0x80,
       0x09, 0x0A, 0x99, 0x00, 0x29, 0x2C, 0xD1, 0x01, 0x9A, 0x06, 0x99, 0x4A, 0x60, 0x0C, 0x9A, 0x12,
       0x89, 0xCA, 0x81, 0x08, 0x60, 0x8E, 0x81, 0xC2, 0x4D, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xC7,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x02, 0x20, 0x07, 0x99, 0x08, 0x80, 0xA6, 0x46, 0xBE, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0xA6, 0x46, 0xBC, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xB3, 0x48, 0x04, 0x21, 0xA6,
       0x46, 0xB3, 0x4A, 0xFE, 0x44, 0x01, 0x05, 0xFF, 0xFF, 0x22, 0x77, 0x08, 0x00, 0xFA, 0x10, 0x47,
       0x00, 0x28, 0xF7, 0xD1, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xB6, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0xA6, 0x46, 0xB5, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x0A, 0xE0, 0x0C, 0x9B, 0x0B, 0x99, 0x19, 0x70,
       0x31, 0x04, 0x09, 0x0C, 0x01, 0x9A, 0x1B, 0x89, 0xA6, 0x46, 0xB0, 0x4C, 0xFE, 0x44, 0x20, 0x47,
       0x09, 0x98, 0x04, 0x30, 0x09, 0x90, 0x08, 0x98, 0x04, 0x30, 0x08, 0x90, 0x0A, 0x98, 0x01, 0x30,
       0x0A, 0x90, 0x03, 0x28, 0x00, 0xD2, 0x72, 0xE7, 0xA9, 0x48, 0xFF, 0x30, 0x0C, 0x30, 0x0D, 0xB0,
       0xF0, 0xBD, 0xC0, 0x46, 0x55, 0x53, 0x08, 0x00, 0x37, 0xEB, 0x03, 0x00, 0x3D, 0x68, 0x03, 0x00,
       0xDB, 0xF5, 0x02, 0x00, 0xD1, 0x7A, 0x02, 0x00, 0xC9, 0x9C, 0x03, 0x00, 0x30, 0xB5, 0x40, 0x69,
       0x00, 0x28, 0x1F, 0xD0, 0x00, 0x68, 0x85, 0x08, 0x01, 0x24, 0xA6, 0x46, 0x9F, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x01, 0x1C, 0x28, 0x1C, 0xA6, 0x46, 0x90, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28,
       0x00, 0xDA, 0x40, 0x42, 0x03, 0x21, 0x09, 0x02, 0x41, 0x43, 0xC8, 0x0B, 0x28, 0x18, 0x81, 0x00,
       0x99, 0x48, 0x00, 0x88, 0x80, 0x00, 0x08, 0x1A, 0x00, 0x01, 0x00, 0x09, 0xA6, 0x46, 0x94, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x93, 0x48, 0x45, 0x30, 0x30, 0xBD, 0x70, 0xB5, 0x05, 0x1C, 0xAC, 0x8B,
       0x92, 0x48, 0x84, 0x42, 0x07, 0xD0, 0x68, 0x69, 0x40, 0x30, 0x2C, 0x21, 0x01, 0x22, 0x96, 0x46,
       0x8F, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xE0, 0x1E, 0x91, 0x4C, 0x0E, 0xD0, 0x8D, 0x49, 0x40, 0x1A,
       0x16, 0xD1, 0x8D, 0x49, 0x20, 0x1C, 0x8D, 0x4A, 0x12, 0x18, 0x15, 0x20, 0x00, 0x23, 0x01, 0x26,
       0xB6, 0x46, 0x2D, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x01, 0x05, 0xFF, 0xFF, 0x1C, 0x78, 0x08, 0x00,
       0xFA, 0x0A, 0xE0, 0x8A, 0x49, 0x20, 0x1C, 0x8A, 0x4A, 0x12, 0x18, 0x15, 0x20, 0x00, 0x23, 0x01,
       0x26, 0xB6, 0x46, 0x27, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x40, 0x20, 0x28, 0x62, 0x20, 0x1C, 0x29,
       0x30, 0x70, 0xBD, 0xC0, 0x46, 0xDB, 0xE3, 0x03, 0x00, 0x41, 0x69, 0x49, 0x8D, 0x06, 0x22, 0x4A,
       0x43, 0x06, 0x32, 0x11, 0x04, 0x09, 0x0C, 0x81, 0x60, 0x7B, 0x49, 0x7A, 0x48, 0x0C, 0x30, 0x40,
       0x18, 0xF7, 0x46, 0xC0, 0x46, 0x1D, 0x74, 0x08, 0x00, 0x0B, 0xE2, 0x03, 0x00, 0x41, 0x69, 0x49,
       0x8D, 0x06, 0x22, 0x4A, 0x43, 0x06, 0x32, 0x82, 0x60, 0x73, 0x49, 0x75, 0x48, 0x18, 0x30, 0x40,
       0x18, 0xF7, 0x46, 0xC0, 0x46, 0x8B, 0x96, 0x01, 0x00, 0x30, 0xB5, 0x72, 0x4A, 0x00, 0x28, 0x09,
       0xD0, 0x13, 0x18, 0x84, 0x18, 0xA5, 0x7B, 0x4D, 0x19, 0xA5, 0x73, 0x01, 0x28, 0x02, 0xD9, 0x5C,
       0x7B, 0x0C, 0x19, 0x5C, 0x73, 0x4E, 0x28, 0x09, 0xD2, 0x13, 0x18, 0x82, 0x18, 0x14, 0x7C, 0x0C,
       0x19, 0x14, 0x74, 0x4D, 0x28, 0x02, 0xD2, 0x58, 0x7C, 0x08, 0x18, 0x58, 0x74, 0x30, 0xBD, 0xC0,
       0x46, 0x91, 0xE5, 0x02, 0x00, 0x71, 0xE3, 0x02, 0x00, 0x39, 0x75, 0x08, 0x00, 0xCD, 0x98, 0x01,
       0x00, 0x65, 0x70, 0x08, 0x00, 0x95, 0xF4, 0x03, 0x00, 0xF9, 0x74, 0x08, 0x00, 0xF0, 0xB5, 0x07,
       0x1C, 0x5D, 0x4E, 0x5E, 0x4D, 0x00, 0x24, 0x2A, 0x78, 0x00, 0x2A, 0x1E, 0xD0, 0x6B, 0x20, 0x81,
       0x5D, 0x4B, 0x1C, 0xA0, 0x19, 0xC0, 0x7E, 0x00, 0x07, 0x00, 0x0F, 0x98, 0x42, 0x0B, 0xD0, 0x98,
       0x42, 0x13, 0xDD, 0x50, 0x1C, 0x01, 0x06, 0x09, 0x0E, 0x20, 0x1C, 0x01, 0x22, 0x96, 0x46, 0x54,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x09, 0xE0, 0x50, 0x1C, 0x00, 0x06, 0x01, 0x05, 0xFF, 0xFF, 0x16,
       0x79, 0x08, 0x00, 0xFA, 0x00, 0x0E, 0x41, 0x43, 0x20, 0x1C, 0x01, 0x22, 0x96, 0x46, 0x4E, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x35, 0x01, 0x34, 0x4F, 0x2C, 0xD9, 0xD3, 0x78, 0x68, 0x40, 0x0B,
       0x78, 0x60, 0x4B, 0x48, 0x4A, 0x49, 0x08, 0x18, 0xF0, 0xBD, 0x00, 0xA6, 0x0E, 0x00, 0x61, 0x75,
       0x08, 0x00, 0xF0, 0xB5, 0x85, 0xB0, 0x06, 0x06, 0x36, 0x0E, 0x6C, 0x46, 0x26, 0x70, 0x03, 0x21,
       0x08, 0x1A, 0x60, 0x70, 0x02, 0xA8, 0x04, 0xA9, 0x03, 0xAA, 0x01, 0xAB, 0x01, 0x25, 0xAE, 0x46,
       0x41, 0x4F, 0xFE, 0x44, 0x38, 0x47, 0x35, 0x48, 0xFD, 0x38, 0xA1, 0x89, 0x81, 0x42, 0x03, 0xDB,
       0xA0, 0x89, 0xFF, 0x38, 0x91, 0x38, 0x01, 0xE0, 0xA0, 0x89, 0xC8, 0x30, 0xA0, 0x80, 0x6B, 0x46,
       0x1E, 0x70, 0x02, 0x98, 0x99, 0x88, 0x04, 0x9A, 0x9B, 0x89, 0xAE, 0x46, 0x20, 0x4C, 0xFE, 0x44,
       0x20, 0x47, 0x05, 0xB0, 0xF0, 0xBD, 0x70, 0xB5, 0x34, 0x48, 0x00, 0x78, 0x01, 0x24, 0xA6, 0x46,
       0x33, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x32, 0x4D, 0x28, 0x78, 0x00, 0x28, 0x09, 0xD1, 0x31, 0x49,
       0x32, 0x4A, 0xAD, 0x32, 0x0E, 0x20, 0x00, 0x23, 0xA6, 0x46, 0x31, 0x4E, 0xFE, 0x44, 0x30, 0x47,
       0x2C, 0x70, 0x2E, 0x48, 0x67, 0x30, 0x70, 0xBD, 0x00, 0xB5, 0x2E, 0x48, 0x00, 0x78, 0x01, 0x21,
       0x8E, 0x46, 0x26, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x28, 0x48, 0xC1, 0x30, 0x00, 0xBD, 0x87, 0xCA,
       0x04, 0x00, 0xFB, 0x16, 0x04, 0x00, 0x72, 0x61, 0x1A, 0x00, 0x2F, 0x4A, 0x05, 0x00, 0x65, 0xCB,
       0x04, 0x00, 0xB5, 0x75, 0x08, 0x00, 0x9B, 0xC3, 0x03, 0x00, 0x6D, 0x94, 0x05, 0x00, 0x70, 0x61,
       0x1A, 0x00, 0xF1, 0x16, 0x04, 0x00, 0x89, 0x49, 0x05, 0x00, 0xC1, 0xC0, 0x03, 0x00, 0x01, 0x05,
       0xFF, 0xFF, 0x10, 0x7A, 0x08, 0x00, 0xFA, 0x51, 0xC2, 0x03, 0x00, 0xFB, 0xBC, 0x03, 0x00, 0xE2,
       0x04, 0x00, 0x00, 0x61, 0x48, 0x05, 0x00, 0x51, 0xCA, 0x04, 0x00, 0x87, 0x24, 0x04, 0x00, 0x45,
       0x25, 0x04, 0x00, 0x48, 0x53, 0x08, 0x00, 0xD9, 0xFC, 0x00, 0x00, 0x91, 0x1C, 0x04, 0x00, 0x10,
       0x20, 0x00, 0x00, 0x45, 0x78, 0x08, 0x00, 0x6F, 0x03, 0x00, 0x00, 0x51, 0x8C, 0x00, 0x00, 0x69,
       0x78, 0x08, 0x00, 0x0B, 0x05, 0x00, 0x00, 0xD0, 0x11, 0x08, 0x00, 0x50, 0x21, 0x08, 0x00, 0x38,
       0x30, 0x19, 0x00, 0x85, 0x78, 0x08, 0x00, 0x43, 0x02, 0x00, 0x00, 0x8D, 0x42, 0x01, 0x00, 0xA5,
       0xC4, 0x03, 0x00, 0x0C, 0x18, 0x08, 0x00, 0x45, 0x79, 0x08, 0x00, 0x07, 0x63, 0x08, 0x00, 0xCB,
       0x79, 0x08, 0x00, 0x17, 0x38, 0x04, 0x00, 0xD1, 0x8C, 0x03, 0x00, 0x65, 0x70, 0x08, 0x00, 0x5C,
       0x18, 0x08, 0x00, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x10, 0xF8, 0xFF, 0xBD, 0xFF, 0xB5, 0x68,
       0x46, 0xFF, 0xF7, 0x4B, 0xFA, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x1A, 0xFF, 0xFF,
       0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x5B, 0xFF, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF,
       0xF7, 0xEC, 0xF8, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x46, 0xFA, 0xFF, 0xBD, 0xFF,
       0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x52, 0xFA, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x21,
       0xF9, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0xC0, 0xF9, 0xFF, 0xBD, 0xFF, 0xB5, 0x68,
       0x46, 0xFE, 0xF7, 0x8D, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xB4, 0xFC, 0xFF,
       0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x69, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE,
       0xF7, 0x01, 0x05, 0xFF, 0x4F, 0x0A, 0x7B, 0x08, 0x00, 0x4A, 0x3A, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5,
       0x68, 0x46, 0xFE, 0xF7, 0x4A, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x38, 0xFD,
       0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x93, 0xFE, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46,
       0xFE, 0xF7, 0xA6, 0xFE, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xEB, 0xFD, 0xFF, 0xBD,
       0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xC3, 0xFD, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7,
       0x19, 0xFE, 0xFF, 0xBD, 0x01, 0x05, 0xFF, 0x8D, 0x78, 0x7B, 0x08, 0x00, 0x88, 0x00, 0xB5, 0xF9,
       0xF0, 0xDB, 0xF8, 0x00, 0xBD, 0xF1, 0x70, 0x08, 0x00, 0x91, 0x70, 0x08, 0x00, 0xB1, 0x70, 0x08,
       0x00, 0x17, 0x71, 0x08, 0x00, 0xDF, 0x77, 0x08, 0x00, 0xFD, 0x02, 0x18, 0x00, 0x73, 0x70, 0x08,
       0x00, 0x39, 0x71, 0x08, 0x00, 0xA5, 0x71, 0x08, 0x00, 0xE7, 0x71, 0x08, 0x00, 0x0B, 0x72, 0x08,
       0x00, 0x2B, 0x72, 0x08, 0x00, 0x99, 0x79, 0x08, 0x00, 0x89, 0x03, 0x18, 0x00, 0x61, 0x03, 0x18,
       0x00, 0xBD, 0x72, 0x08, 0x00, 0xD5, 0x72, 0x08, 0x00, 0xE5, 0x73, 0x08, 0x00, 0x57, 0x72, 0x08,
       0x00, 0x59, 0x73, 0x08, 0x00, 0x69, 0x78, 0x08, 0x00, 0xA1, 0x73, 0x08, 0x00, 0xF3, 0x73, 0x08,
       0x00, 0xB5, 0x73, 0x08, 0x00, 0xD9, 0x73, 0x08, 0x00, 0xDF, 0x73, 0x08, 0x00, 0x69, 0x74, 0x08,
       0x00, 0xC5, 0x74, 0x08, 0x00, 0x39, 0x75, 0x08, 0x00, 0x15, 0x76, 0x08, 0x00, 0x91, 0x77, 0x08,
       0x00, 0xD9, 0x78, 0x08, 0x00, 0x01, 0x05, 0xFF, 0x85, 0x04, 0xF3, 0x1A, 0x00, 0x80, 0x36, 0x5E,
       0x02, 0x00, 0x38, 0xC2, 0x02, 0x00, 0x00, 0xC5, 0x02, 0x00, 0x9C, 0x9C, 0x00, 0x00, 0x70, 0x8C,
       0x00, 0x00, 0x02, 0x69, 0x00, 0x00, 0x84, 0x97, 0x00, 0x00, 0x6A, 0xA0, 0x02, 0x00, 0xF0, 0x6E,
       0x03, 0x00, 0xF0, 0x8A, 0x04, 0x00, 0x32, 0xAF, 0x02, 0x00, 0xF4, 0xF8, 0x03, 0x00, 0x24, 0x8D,
       0x03, 0x00, 0xA8, 0x55, 0x00, 0x00, 0x00, 0x16, 0x04, 0x00, 0x14, 0x85, 0x01, 0x00, 0x54, 0x82,
       0x01, 0x00, 0x42, 0x7B, 0x02, 0x00, 0xAC, 0xF9, 0x03, 0x00, 0xD6, 0x7B, 0x03, 0x00, 0x5C, 0x91,
       0x00, 0x00, 0x1C, 0x86, 0x00, 0x00, 0x68, 0x9D, 0x03, 0x00, 0xB4, 0xEB, 0x03, 0x00, 0x78, 0x68,
       0x03, 0x00, 0x3E, 0xF6, 0x02, 0x00, 0x3C, 0xE3, 0x03, 0x00, 0xDC, 0xE3, 0x02, 0x00, 0xCE, 0x98,
       0x01, 0x00, 0x3A, 0xBD, 0x03, 0x00, 0x72, 0x25, 0x04, 0x00, 0xCE, 0x44, 0x01, 0x00, 0x01, 0x05,
       0xFF, 0xFF, 0x00, 0x00, 0x18, 0x00, 0xFA, 0xFF, 0xB5, 0x00, 0x93, 0x01, 0x92, 0x02, 0x91, 0x06,
       0x1C, 0xE4, 0x4F, 0x38, 0x78, 0x44, 0x1E, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x21, 0xC9, 0x03, 0x01,
       0xE0, 0x7D, 0x21, 0x09, 0x02, 0xD2, 0x48, 0x01, 0x22, 0x96, 0x46, 0xD1, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x03, 0x91, 0xD4, 0x48, 0x00, 0x78, 0x02, 0x28, 0x00, 0xD0, 0xB8, 0xE0, 0xD3, 0x4D, 0xCD,
       0x48, 0x01, 0x2E, 0x53, 0xD0, 0x06, 0x1C, 0xB0, 0x89, 0x00, 0x2C, 0x02, 0xD0, 0x7D, 0x20, 0x00,
       0x02, 0x01, 0xE0, 0x01, 0x20, 0xC0, 0x03, 0x02, 0x99, 0x48, 0x43, 0xC7, 0x49, 0x08, 0x18, 0xF0,
       0x49, 0x01, 0x22, 0x96, 0x46, 0xC6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xB1, 0x81, 0x38, 0x78, 0x01,
       0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0xC1, 0x4C, 0x0F,
       0x27, 0x21, 0x88, 0x39, 0x40, 0x22, 0x88, 0x12, 0x09, 0x3A, 0x40, 0x8A, 0x42, 0x04, 0xDD, 0x21,
       0x88, 0x09, 0x11, 0x09, 0x07, 0x0F, 0x0F, 0x01, 0xE0, 0x21, 0x88, 0x0F, 0x40, 0x02, 0x99, 0x41,
       0x43, 0xB6, 0x48, 0x40, 0x18, 0xDF, 0x49, 0x01, 0x22, 0x96, 0x46, 0xB4, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x28, 0x1C, 0x00, 0x8E, 0x1F, 0x22, 0x10, 0x40, 0x40, 0x18, 0xA1, 0x89, 0x11, 0x40, 0x08,
       0x18, 0x31, 0x8A, 0x08, 0x18, 0x29, 0x88, 0x09, 0x0A, 0x08, 0x18, 0x29, 0x89, 0x09, 0x0A, 0x08,
       0x18, 0x39, 0x18, 0x01, 0x98, 0x40, 0x18, 0x05, 0x30, 0x01, 0x04, 0x09, 0x0C, 0xDC, 0x48, 0x00,
       0x22, 0x01, 0x23, 0x9E, 0x46, 0xDB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x54, 0xE0, 0x06, 0x1C, 0x30,
       0x88, 0x00, 0x2C, 0x02, 0xD0, 0x7D, 0x20, 0x00, 0x02, 0x01, 0xE0, 0x01, 0x20, 0xC0, 0x03, 0x02,
       0x99, 0x01, 0x05, 0xFF, 0xFF, 0xFA, 0x00, 0x18, 0x00, 0xFA, 0x48, 0x43, 0x9D, 0x49, 0x08, 0x18,
       0xC6, 0x49, 0x01, 0x22, 0x96, 0x46, 0x9C, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x31, 0x80, 0x38, 0x78,
       0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x97, 0x4C,
       0x0F, 0x25, 0xA1, 0x88, 0x09, 0x09, 0x29, 0x40, 0xA2, 0x88, 0x2A, 0x40, 0x8A, 0x42, 0x03, 0xDD,
       0xA1, 0x88, 0x09, 0x07, 0x0D, 0x0F, 0x02, 0xE0, 0xA1, 0x88, 0x09, 0x09, 0x0D, 0x40, 0x1F, 0x27,
       0x02, 0x99, 0x41, 0x43, 0x8B, 0x48, 0x40, 0x18, 0xB4, 0x49, 0x01, 0x22, 0x96, 0x46, 0x8A, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x89, 0x38, 0x40, 0x40, 0x18, 0xB1, 0x88, 0x39, 0x40, 0x08, 0x18,
       0x21, 0x89, 0x39, 0x40, 0x08, 0x18, 0x87, 0x49, 0x09, 0x88, 0x09, 0x0A, 0x08, 0x18, 0x85, 0x49,
       0x09, 0x89, 0x09, 0x0A, 0x08, 0x18, 0x29, 0x18, 0x01, 0x98, 0x40, 0x18, 0x05, 0x30, 0x01, 0x04,
       0x09, 0x0C, 0xB1, 0x48, 0x00, 0x22, 0x01, 0x23, 0x9E, 0x46, 0xB0, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x00, 0x98, 0x03, 0x99, 0x41, 0x18, 0xAE, 0x48, 0x40, 0x18, 0xAF, 0x49, 0x01, 0x22, 0x96, 0x46,
       0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x08, 0xE0, 0xA9, 0x48, 0x00, 0x99, 0x40, 0x18, 0xAA, 0x49,
       0x01, 0x22, 0x96, 0x46, 0x70, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1C, 0xA5, 0x49, 0x08, 0x80,
       0x09, 0x99, 0xA6, 0x48, 0x49, 0x1C, 0x01, 0xD0, 0x59, 0x30, 0x00, 0xE0, 0x61, 0x30, 0x00, 0x90,
       0xFF, 0xBD, 0xF8, 0xB5, 0x05, 0x1C, 0x9E, 0x48, 0x40, 0x19, 0x9F, 0x49, 0x01, 0x24, 0xA6, 0x46,
       0x65, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1C, 0x9A, 0x49, 0x08, 0x80, 0x6B, 0x48, 0x00, 0x78,
       0x01, 0x28, 0x02, 0xD1, 0x01, 0x05, 0xFF, 0xFF, 0xF4, 0x01, 0x18, 0x00, 0xFA, 0x01, 0x20, 0xC0,
       0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x68, 0x43, 0x5C, 0x4E, 0x30, 0x18, 0x85, 0x49, 0xA6,
       0x46, 0x5B, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x09, 0x04, 0x09, 0x0C, 0x94, 0x48, 0x04, 0x30, 0x06,
       0x22, 0xA6, 0x46, 0x91, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x90, 0x48, 0x5A, 0x30, 0x00, 0x21, 0xA6,
       0x46, 0x8F, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x1C, 0x8C, 0x48, 0x08, 0x21, 0xA6, 0x46, 0x8C,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC7, 0x19, 0x14, 0x2F, 0x00, 0xD8, 0x14, 0x27, 0x55, 0x48, 0x00,
       0x78, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x68,
       0x43, 0x30, 0x18, 0x70, 0x49, 0xA6, 0x46, 0x46, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1B, 0x05,
       0x38, 0x01, 0x04, 0x09, 0x0C, 0x7D, 0x48, 0x2C, 0x30, 0x00, 0x22, 0xA6, 0x46, 0x7A, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x7D, 0x4F, 0x38, 0x1C, 0x08, 0x21, 0xA6, 0x46, 0x79, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x90, 0x38, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00,
       0x99, 0x88, 0x42, 0x06, 0xDD, 0x38, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0x71, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x05, 0xE0, 0x38, 0x1C, 0x08, 0x21, 0xA6, 0x46, 0x6D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07,
       0x1C, 0x6A, 0x48, 0x00, 0x21, 0xA6, 0x46, 0x6A, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x3F, 0x18, 0x08,
       0x37, 0x34, 0x48, 0x00, 0x78, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D,
       0x20, 0x00, 0x02, 0x68, 0x43, 0x30, 0x18, 0x4F, 0x49, 0xA6, 0x46, 0x25, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x78, 0x18, 0x01, 0x04, 0x09, 0x0C, 0x01, 0x05, 0xFF, 0xFF, 0xEE, 0x02, 0x18, 0x00, 0xFA,
       0x56, 0x48, 0x00, 0x22, 0xA6, 0x46, 0x55, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xF8, 0xBD, 0x10, 0xB5,
       0x43, 0x69, 0x5F, 0x49, 0x09, 0x78, 0x5B, 0x4A, 0x12, 0x78, 0x01, 0x2A, 0x04, 0xD1, 0x1C, 0x78,
       0x00, 0x2C, 0x01, 0xD1, 0x5C, 0x49, 0x09, 0x78, 0x1A, 0x4C, 0x24, 0x78, 0x00, 0x2C, 0x1B, 0xD0,
       0xFF, 0x29, 0x19, 0xD0, 0x01, 0x2A, 0x08, 0xD0, 0x58, 0x4A, 0x12, 0x78, 0x01, 0x2A, 0x13, 0xD0,
       0x1A, 0x78, 0x01, 0x2A, 0x01, 0xD0, 0x02, 0x2A, 0x0E, 0xD1, 0x10, 0x22, 0xD4, 0x56, 0x8C, 0x42,
       0x0A, 0xDD, 0x61, 0x1A, 0x09, 0x06, 0x09, 0x0E, 0x5B, 0x1C, 0x00, 0x24, 0x1C, 0x57, 0x64, 0x1A,
       0x1C, 0x70, 0x01, 0x33, 0x01, 0x3A, 0xF8, 0xD1, 0x48, 0x49, 0x81, 0x60, 0x48, 0x48, 0x15, 0x30,
       0x10, 0xBD, 0x4A, 0x48, 0x15, 0x30, 0xF7, 0x46, 0xC0, 0x46, 0x80, 0xC3, 0xC9, 0x01, 0x6D, 0x94,
       0x05, 0x00, 0xC0, 0x79, 0x1A, 0x00, 0x3F, 0x42, 0x0F, 0x00, 0x05, 0x9A, 0x05, 0x00, 0x28, 0x79,
       0x1A, 0x00, 0xE8, 0x57, 0x08, 0x00, 0x2C, 0x7A, 0x1A, 0x00, 0xFF, 0xB5, 0x05, 0x1C, 0x03, 0x48,
       0x00, 0x78, 0x01, 0x28, 0x05, 0xD1, 0x01, 0x26, 0xF6, 0x03, 0x04, 0xE0, 0xC0, 0x46, 0x5E, 0x56,
       0x08, 0x00, 0x7D, 0x26, 0x36, 0x02, 0x28, 0x48, 0x00, 0x21, 0x01, 0x24, 0xA6, 0x46, 0x38, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x1C, 0x19, 0x48, 0x48, 0x43, 0x31, 0x1C, 0xA6, 0x46, 0x3B, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x91, 0x6D, 0x69, 0xEE, 0x7A, 0x28, 0x1C, 0x21, 0x1C, 0xA6, 0x46,
       0x31, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x1C, 0x28, 0x1C, 0x05, 0x21, 0xA6, 0x46, 0x2D, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x02, 0x90, 0x28, 0x7F, 0x03, 0x90, 0x01, 0x05, 0xFF, 0xFF, 0xE8, 0x03,
       0x18, 0x00, 0xFA, 0xED, 0x7E, 0xFF, 0x2E, 0x04, 0xD0, 0x30, 0x1C, 0xA6, 0x46, 0x29, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x78, 0x1C, 0x19, 0xD0, 0x1B, 0x48, 0x0A, 0x21, 0xA6, 0x46, 0x26, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x06, 0x28, 0x09, 0xD0, 0x01, 0x2E, 0x07, 0xD0, 0x38, 0x1C, 0xA6, 0x46, 0x22,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x09, 0xE0, 0x40, 0x42, 0x0F, 0x00, 0x38, 0x1C, 0x31, 0x1C, 0x03,
       0x9A, 0x2B, 0x1C, 0xA6, 0x46, 0x1E, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x02, 0x98, 0x00, 0x90, 0x28,
       0x1C, 0x39, 0x1C, 0x03, 0x9A, 0x01, 0x9B, 0xA6, 0x46, 0x1A, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x00,
       0x90, 0xFF, 0xBD, 0x04, 0x60, 0x1A, 0x00, 0xC9, 0x49, 0x05, 0x00, 0xE1, 0x04, 0x00, 0x00, 0x48,
       0x53, 0x08, 0x00, 0xE2, 0x04, 0x00, 0x00, 0x71, 0x55, 0x00, 0x00, 0x93, 0x49, 0x05, 0x00, 0x16,
       0x74, 0x1A, 0x00, 0x6B, 0x4A, 0x05, 0x00, 0x42, 0x74, 0x1A, 0x00, 0x44, 0x74, 0x1A, 0x00, 0x66,
       0x63, 0x08, 0x00, 0x10, 0x30, 0x19, 0x00, 0xEF, 0x68, 0x00, 0x00, 0x61, 0x63, 0x08, 0x00, 0x60,
       0x63, 0x08, 0x00, 0x63, 0x63, 0x08, 0x00, 0xFF, 0x15, 0x04, 0x00, 0xA7, 0x4A, 0x05, 0x00, 0xE5,
       0x2B, 0x00, 0x00, 0x81, 0x42, 0x02, 0x00, 0x4D, 0x4A, 0x05, 0x00, 0xD3, 0x01, 0x18, 0x00, 0x55,
       0x3F, 0x02, 0x00, 0x01, 0x00, 0x18, 0x00, 0x6D, 0x94, 0x05, 0x00, 0x70, 0xB5, 0xDF, 0x4D, 0xAE,
       0x7F, 0x01, 0x24, 0xA6, 0x46, 0xDB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xB0, 0x42, 0xF8, 0xD1, 0x03,
       0x20, 0x17, 0x21, 0x89, 0x01, 0xA6, 0x46, 0xD7, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xAD, 0x7F, 0xA6,
       0x46, 0xD4, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA8, 0x42, 0xF9, 0xD1, 0xFE, 0xE7, 0x01, 0x05, 0xFF,
       0xFF, 0xE2, 0x04, 0x18, 0x00, 0xFA, 0xF0, 0xB5, 0x88, 0xB0, 0x0B, 0x21, 0x09, 0x18, 0x68, 0x46,
       0x0C, 0x22, 0x01, 0x24, 0xA6, 0x46, 0xD9, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x68, 0x46, 0x01, 0x78,
       0x03, 0x91, 0x45, 0x78, 0x81, 0x78, 0x04, 0x91, 0xC0, 0x78, 0x05, 0x90, 0x01, 0x98, 0x06, 0x90,
       0x02, 0x98, 0x07, 0x90, 0xA6, 0x46, 0xC8, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xD0, 0x4F, 0x38, 0x78,
       0xCA, 0x4E, 0x81, 0x09, 0x16, 0xD3, 0x14, 0x20, 0xB0, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0xCD, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xC1, 0x48, 0x00, 0x21, 0xA6, 0x46, 0xC1, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0xC0, 0x48, 0x03, 0x21, 0xA6, 0x46, 0xC0, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x39, 0x78, 0xDF, 0x20,
       0x08, 0x40, 0x38, 0x70, 0xC0, 0x09, 0x0A, 0xD3, 0x24, 0x20, 0xB0, 0x80, 0xC8, 0x20, 0xA6, 0x46,
       0xC0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x39, 0x78, 0xBF, 0x20, 0x08, 0x40, 0x38, 0x70, 0xB8, 0x48,
       0x07, 0x2D, 0x09, 0xD0, 0xAA, 0x00, 0xB7, 0x49, 0x0B, 0x1C, 0x38, 0x3B, 0x9B, 0x58, 0x05, 0x1C,
       0xAB, 0x60, 0x88, 0x58, 0x07, 0x90, 0x02, 0xE0, 0x05, 0x1C, 0x06, 0x98, 0xA8, 0x60, 0x07, 0x98,
       0x68, 0x60, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xAB, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x03, 0x98,
       0x81, 0x1E, 0xAD, 0x48, 0x13, 0xD0, 0x01, 0x39, 0x0F, 0xD0, 0x01, 0x39, 0x01, 0xD0, 0x02, 0x21,
       0x0E, 0xE0, 0x05, 0x99, 0x09, 0x07, 0x49, 0x0E, 0x04, 0x9A, 0x52, 0x06, 0x92, 0x0C, 0x51, 0x18,
       0x81, 0x83, 0x15, 0x20, 0xB0, 0x80, 0x20, 0x20, 0x10, 0xE0, 0x21, 0x1C, 0x00, 0xE0, 0x00, 0x21,
       0x89, 0x07, 0x89, 0x0F, 0x05, 0x9A, 0x12, 0x07, 0x52, 0x0E, 0x51, 0x18, 0x04, 0x9A, 0x52, 0x06,
       0x01, 0x05, 0xFF, 0xFF, 0xDC, 0x05, 0x18, 0x00, 0xFA, 0x92, 0x0C, 0x51, 0x18, 0x01, 0x80, 0x11,
       0x20, 0x30, 0x80, 0x04, 0x20, 0x39, 0x78, 0x08, 0x43, 0x38, 0x70, 0x03, 0x98, 0x00, 0x28, 0x05,
       0xD0, 0x90, 0x48, 0x00, 0x21, 0xA6, 0x46, 0x92, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x20, 0xA6,
       0x46, 0x96, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x8D, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x8C, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x03, 0x98, 0x00, 0x28, 0x02, 0xD0, 0xFF, 0x20, 0x02, 0x30, 0x28, 0x80, 0x08,
       0xB0, 0xF0, 0xBD, 0xF8, 0xB5, 0xC1, 0x7A, 0x00, 0x91, 0x07, 0x7B, 0x00, 0x2F, 0x03, 0xD0, 0x01,
       0x2F, 0x02, 0xD1, 0x01, 0x27, 0x00, 0xE0, 0x02, 0x27, 0x01, 0x24, 0xA6, 0x46, 0x7C, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x85, 0x4E, 0x30, 0x78, 0x7F, 0x4D, 0x81, 0x09, 0x16, 0xD3, 0x14, 0x20, 0xA8,
       0x80, 0xC8, 0x20, 0xA6, 0x46, 0x81, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x76, 0x48, 0x00, 0x21, 0xA6,
       0x46, 0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x75, 0x48, 0x03, 0x21, 0xA6, 0x46, 0x74, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x31, 0x78, 0xDF, 0x20, 0x08, 0x40, 0x30, 0x70, 0xC0, 0x09, 0x0A, 0xD3, 0x24,
       0x20, 0xA8, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0x75, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x31, 0x78, 0xBF,
       0x20, 0x08, 0x40, 0x30, 0x70, 0x72, 0x48, 0x01, 0x78, 0x6D, 0x48, 0x01, 0x29, 0x12, 0xD0, 0x00,
       0x99, 0x89, 0x01, 0x41, 0x80, 0x87, 0x80, 0x21, 0x20, 0x28, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0x6B,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x61, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x61, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x02, 0x20, 0x13, 0xE0, 0x00, 0x99, 0x8A, 0x01, 0x02, 0x21, 0x11, 0x43, 0xC1, 0x83, 0x07,
       0x84, 0x25, 0x20, 0x01, 0x05, 0xFF, 0xFF, 0xD6, 0x06, 0x18, 0x00, 0xFA, 0xA8, 0x80, 0xC8, 0x20,
       0xA6, 0x46, 0x60, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x57, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x56, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x40, 0x20, 0x31, 0x78, 0x08, 0x43, 0x30, 0x70, 0xF8, 0xBD, 0xF8, 0xB5,
       0x00, 0x92, 0x0F, 0x1C, 0x05, 0x1C, 0x60, 0x48, 0x01, 0x78, 0x01, 0x24, 0x58, 0x4E, 0xB5, 0x42,
       0x0E, 0xDC, 0x5A, 0x48, 0xB5, 0x42, 0x4D, 0xD0, 0x44, 0x4A, 0xAA, 0x1A, 0x51, 0xD0, 0x01, 0x3A,
       0x48, 0xD0, 0x04, 0x3A, 0x31, 0xD0, 0x68, 0x3A, 0x4B, 0xD0, 0x01, 0x3A, 0x4F, 0xD0, 0x39, 0xE0,
       0x30, 0x1C, 0x2F, 0x30, 0x28, 0x1A, 0x39, 0xD0, 0x24, 0x38, 0x35, 0xD0, 0x01, 0x38, 0x17, 0xD0,
       0x01, 0x38, 0x2F, 0xD1, 0x52, 0x48, 0x00, 0x78, 0x02, 0x28, 0x0E, 0xD1, 0xF8, 0x7A, 0x00, 0x07,
       0x00, 0x0F, 0x47, 0x49, 0x0A, 0x1C, 0xB6, 0x3A, 0x10, 0x70, 0x02, 0x01, 0x02, 0x43, 0x12, 0x01,
       0x02, 0x43, 0x12, 0x01, 0x02, 0x43, 0x0A, 0x80, 0x0B, 0xE0, 0x0C, 0x20, 0x18, 0x70, 0x08, 0xE0,
       0x01, 0x29, 0x01, 0xD0, 0x04, 0x29, 0x04, 0xD1, 0x38, 0x1C, 0xA6, 0x46, 0x3E, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x25, 0x1C, 0x00, 0x98, 0x05, 0x70, 0x4C, 0xE0, 0x00, 0x29, 0x4A, 0xD1, 0xB8, 0x7D,
       0x01, 0x28, 0x47, 0xD1, 0x04, 0x20, 0xA6, 0x46, 0x38, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xFF, 0x20,
       0xB8, 0x75, 0x3F, 0xE0, 0x00, 0x24, 0x3D, 0xE0, 0x3A, 0x48, 0x00, 0xE0, 0x3A, 0x48, 0xF9, 0x7A,
       0x01, 0x70, 0xE6, 0xE7, 0x00, 0x21, 0x06, 0x22, 0xA6, 0x46, 0x37, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x30, 0xE0, 0x03, 0x21, 0x06, 0x22, 0xA6, 0x46, 0x34, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x33, 0x48,
       0x00, 0x68, 0x00, 0x28, 0x13, 0xD1, 0x01, 0x05, 0xFF, 0xDD, 0xD0, 0x07, 0x18, 0x00, 0xD8, 0x04,
       0x3E, 0xB5, 0x42, 0x09, 0xD0, 0x13, 0x48, 0x85, 0x42, 0x20, 0xD1, 0x38, 0x1C, 0x25, 0x1C, 0xA6,
       0x46, 0x26, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xC9, 0xE7, 0x38, 0x1C, 0x25, 0x1C, 0xA6, 0x46, 0x23,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0xC2, 0xE7, 0x04, 0x20, 0xA6, 0x46, 0x27, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x47, 0x21, 0x09, 0x02, 0x01, 0x80, 0x87, 0x80, 0x39, 0x0C, 0xC1, 0x80, 0xA6, 0x46, 0x23,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x23, 0x48, 0x9E, 0x30, 0x06, 0x99, 0x08, 0x62, 0x20, 0x1C, 0xF8,
       0xBD, 0xC0, 0x46, 0x17, 0xFD, 0x00, 0x00, 0x8B, 0x05, 0x05, 0x00, 0xF5, 0xD3, 0x04, 0x00, 0x8C,
       0x4F, 0x08, 0x00, 0x0D, 0x82, 0x03, 0x00, 0x0D, 0x18, 0x19, 0x00, 0x79, 0x48, 0x05, 0x00, 0x62,
       0x1C, 0x19, 0x00, 0x61, 0x48, 0x05, 0x00, 0x44, 0x24, 0x19, 0x00, 0x0C, 0x18, 0x19, 0x00, 0xC8,
       0x8D, 0x06, 0x00, 0x00, 0x30, 0x19, 0x00, 0x21, 0xA7, 0x05, 0x00, 0xD4, 0x0F, 0x08, 0x00, 0xBB,
       0x16, 0x04, 0x00, 0x68, 0x63, 0x08, 0x00, 0x88, 0xFD, 0x00, 0x00, 0x4C, 0xA6, 0x1B, 0x00, 0x6D,
       0x09, 0x18, 0x00, 0xE1, 0x42, 0x02, 0x00, 0x6A, 0x0A, 0x1A, 0x00, 0x27, 0x06, 0x18, 0x00, 0xE3,
       0x04, 0x18, 0x00, 0xE8, 0x57, 0x08, 0x00, 0x41, 0x10, 0x08, 0x00, 0x69, 0x63, 0x08, 0x00, 0x68,
       0x63, 0x08, 0x00, 0x91, 0x48, 0x05, 0x00, 0x2C, 0x51, 0x08, 0x00, 0x9B, 0x60, 0x04, 0x00, 0xE9,
       0x3F, 0x05, 0x00, 0x81, 0x60, 0x00, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0xD0, 0x2D, 0x18, 0x00, 0xFA,
       0xF0, 0xB5, 0xC8, 0x48, 0x00, 0x78, 0x02, 0x28, 0x00, 0xD0, 0x9E, 0xE0, 0xC7, 0x48, 0x05, 0x21,
       0x01, 0x25, 0xAE, 0x46, 0xC6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x1C, 0xC2, 0x48, 0x00, 0x22,
       0xAE, 0x46, 0xC4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE7, 0x48, 0x00, 0x78, 0x00, 0x28, 0x18, 0xD1,
       0x13, 0x20, 0xC1, 0x49, 0x08, 0x80, 0x03, 0x27, 0x39, 0x1C, 0x28, 0x1C, 0xAE, 0x46, 0xBF, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0xF4, 0x4E, 0x30, 0x1C, 0x0A, 0x30, 0x39, 0x1C, 0xAE, 0x46, 0xBC, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xAE, 0x46, 0xB5, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0xB9, 0x4C, 0x27, 0x1C, 0x02, 0x3F, 0x38, 0x1C, 0x02, 0x21, 0x00, 0x22, 0xAE, 0x46,
       0xB4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xB5, 0x4E, 0x30, 0x1C, 0xC8, 0x38, 0x20, 0x60, 0x38, 0x1C,
       0x03, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xAF, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x26, 0x60, 0x38, 0x1C,
       0x04, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xAB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xAC, 0x4E, 0x30, 0x1C,
       0xD1, 0x38, 0x20, 0x60, 0x38, 0x1C, 0x05, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xA5, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x26, 0x60, 0x38, 0x1C, 0x06, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xA1, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x30, 0x1C, 0x32, 0x30, 0x20, 0x60, 0x38, 0x1C, 0x07, 0x21, 0x00, 0x22, 0xAE, 0x46,
       0x9C, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x30, 0x1C, 0x62, 0x30, 0x20, 0x60, 0x38, 0x1C, 0x08, 0x21,
       0x00, 0x22, 0xAE, 0x46, 0x97, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xC2, 0x36, 0x26, 0x60, 0x38, 0x1C,
       0x09, 0x21, 0x00, 0x22, 0xAE, 0x46, 0x93, 0x4B, 0xFE, 0x44, 0x01, 0x05, 0xFF, 0xFF, 0xCA, 0x2E,
       0x18, 0x00, 0xFA, 0x18, 0x47, 0xEE, 0x48, 0x20, 0x60, 0x38, 0x1C, 0x0A, 0x21, 0x00, 0x22, 0xAE,
       0x46, 0x8E, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xEB, 0x48, 0x20, 0x60, 0x38, 0x1C, 0x0B, 0x21, 0x00,
       0x22, 0xAE, 0x46, 0x8A, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE7, 0x48, 0x20, 0x60, 0xE7, 0x48, 0x00,
       0x88, 0x80, 0x0B, 0x0E, 0xD3, 0x00, 0x22, 0x10, 0x1C, 0xC3, 0x00, 0xE5, 0x49, 0x0C, 0x1C, 0x02,
       0x3C, 0xE4, 0x18, 0x25, 0x88, 0x2D, 0x06, 0x2D, 0x0E, 0x25, 0x80, 0xCA, 0x52, 0x01, 0x30, 0x14,
       0x28, 0xF2, 0xDB, 0xF0, 0xBD, 0x10, 0xB5, 0x75, 0x48, 0x00, 0x78, 0x00, 0x28, 0x32, 0xD0, 0x02,
       0x28, 0x3B, 0xD1, 0xDC, 0x48, 0x48, 0x21, 0x09, 0x18, 0x0B, 0x88, 0x01, 0x22, 0x1A, 0x43, 0x0A,
       0x80, 0xD6, 0x4A, 0x70, 0x3A, 0x13, 0x88, 0x9B, 0x10, 0x9B, 0x00, 0x13, 0x80, 0x7C, 0x23, 0x8A,
       0x8E, 0x9A, 0x43, 0x32, 0x23, 0x13, 0x43, 0x8B, 0x86, 0xD3, 0x4B, 0x19, 0x88, 0x49, 0x09, 0x4A,
       0x01, 0x08, 0x21, 0x11, 0x43, 0x19, 0x80, 0x01, 0x88, 0x49, 0x10, 0x49, 0x00, 0x01, 0x80, 0xCF,
       0x4B, 0xFF, 0x24, 0x19, 0x88, 0x21, 0x40, 0x03, 0x22, 0x12, 0x02, 0x0A, 0x43, 0x1A, 0x80, 0x19,
       0x89, 0x21, 0x40, 0xFF, 0x22, 0x01, 0x32, 0x0A, 0x43, 0x1A, 0x81, 0x02, 0x22, 0x01, 0x88, 0x91,
       0x43, 0x01, 0x80, 0x10, 0xBD, 0x07, 0x21, 0x09, 0x02, 0xC5, 0x48, 0x0A, 0x1C, 0x01, 0x24, 0xA6,
       0x46, 0xC4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xC4, 0x48, 0x04, 0x70, 0x10, 0xBD, 0xF0, 0xB5, 0xC3,
       0x4E, 0x06, 0x25, 0x35, 0x70, 0x0F, 0x23, 0x73, 0x70, 0x3D, 0x20, 0xB0, 0x70, 0x55, 0x20, 0xF0,
       0x70, 0x03, 0x20, 0x2A, 0x1C, 0xDA, 0x49, 0xE4, 0x31, 0x01, 0x24, 0xA6, 0x46, 0x01, 0x05, 0xFF,
       0xFF, 0xC4, 0x2F, 0x18, 0x00, 0xFA, 0xBC, 0x4F, 0xFE, 0x44, 0x38, 0x47, 0xB2, 0x78, 0xF3, 0x78,
       0x03, 0x20, 0xD5, 0x49, 0xE5, 0x31, 0xA6, 0x46, 0xB8, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x03, 0x20,
       0xD2, 0x49, 0xE6, 0x31, 0xA6, 0x46, 0xB5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xA6, 0x46, 0xB4, 0x48,
       0xFE, 0x44, 0x00, 0x47, 0xB4, 0x4A, 0x00, 0x21, 0x08, 0x1C, 0x13, 0x68, 0x00, 0x2B, 0x04, 0xD0,
       0x03, 0x07, 0x1E, 0x0F, 0x23, 0x1C, 0xB3, 0x40, 0x19, 0x43, 0x03, 0x07, 0x1B, 0x0F, 0x0F, 0x2B,
       0x05, 0xD1, 0xC6, 0x08, 0x2B, 0x1C, 0x33, 0x40, 0xAC, 0x4E, 0xF1, 0x52, 0x00, 0x21, 0x04, 0x32,
       0x01, 0x30, 0x20, 0x28, 0xE9, 0xD3, 0xA9, 0x48, 0x00, 0x21, 0xA6, 0x46, 0xA9, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x00, 0x26, 0xA8, 0x48, 0x06, 0x70, 0xA8, 0x48, 0x06, 0x70, 0x46, 0x70, 0x19, 0x20,
       0x40, 0x01, 0xA6, 0x49, 0x08, 0x80, 0xFF, 0x21, 0xA6, 0x48, 0x01, 0x70, 0xA6, 0x48, 0x01, 0x70,
       0xA6, 0x48, 0x06, 0x70, 0xA7, 0x48, 0xA5, 0x4A, 0x10, 0x60, 0xA6, 0x48, 0x24, 0x22, 0x02, 0x70,
       0x18, 0x22, 0x42, 0x70, 0x20, 0x22, 0x82, 0x70, 0x10, 0x22, 0xC2, 0x70, 0xA8, 0x4D, 0x28, 0x1C,
       0x00, 0x0A, 0xA1, 0x4A, 0x10, 0x80, 0xA1, 0x48, 0x01, 0x70, 0x08, 0x20, 0xA1, 0x49, 0x08, 0x70,
       0xA6, 0x46, 0xA0, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA0, 0x4F, 0xA6, 0x46, 0xA1, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x39, 0x88, 0x01, 0x40, 0x48, 0x08, 0x04, 0xD0, 0x00, 0x20, 0xC0, 0x43, 0x45, 0x19,
       0x85, 0x42, 0xF2, 0xD1, 0xA6, 0x46, 0x9A, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x39, 0x88, 0x01, 0x40,
       0x48, 0x08, 0x04, 0xD0, 0x5C, 0x20, 0xA6, 0x46, 0x97, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xA6, 0x46,
       0x01, 0x05, 0xFF, 0xFF, 0xBE, 0x30, 0x18, 0x00, 0xFA, 0x96, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x3E,
       0x80, 0x95, 0x48, 0x01, 0x78, 0x88, 0x09, 0x0C, 0xD2, 0x2C, 0x20, 0xC2, 0x43, 0x93, 0x48, 0x03,
       0x1C, 0x01, 0x3B, 0x1A, 0x70, 0x02, 0x70, 0x42, 0x70, 0x18, 0x22, 0xD2, 0x43, 0x82, 0x70, 0xC2,
       0x70, 0x02, 0x71, 0xC8, 0x09, 0x02, 0xD2, 0x0E, 0x20, 0x8D, 0x49, 0x08, 0x70, 0xF0, 0xBD, 0xE8,
       0x57, 0x08, 0x00, 0x6A, 0x31, 0x19, 0x00, 0xC4, 0x61, 0x1A, 0x00, 0x57, 0x4A, 0x05, 0x00, 0xD3,
       0x48, 0x05, 0x00, 0x9E, 0x13, 0x08, 0x00, 0x21, 0x99, 0x05, 0x00, 0x61, 0x48, 0x05, 0x00, 0xFF,
       0x48, 0x05, 0x00, 0x0C, 0x60, 0x1A, 0x00, 0xDC, 0x09, 0x04, 0x00, 0x25, 0x0D, 0x04, 0x00, 0xF0,
       0xB5, 0x94, 0xB0, 0x80, 0x48, 0x06, 0xC8, 0x6D, 0x46, 0x68, 0x46, 0x06, 0xC0, 0x7F, 0x48, 0x06,
       0xC8, 0x02, 0xA8, 0x06, 0xC0, 0x7E, 0x48, 0x06, 0xC8, 0x04, 0xA8, 0x06, 0xC0, 0x7D, 0x48, 0x06,
       0xC8, 0x06, 0xA8, 0x06, 0xC0, 0x7C, 0x48, 0x06, 0xC8, 0x08, 0xA8, 0x06, 0xC0, 0x7B, 0x48, 0x06,
       0xC8, 0x0A, 0xA8, 0x06, 0xC0, 0x7A, 0x48, 0x06, 0xC8, 0x0C, 0xA8, 0x06, 0xC0, 0x79, 0x48, 0x06,
       0xC8, 0x0E, 0xA8, 0x06, 0xC0, 0x78, 0x48, 0x06, 0xC8, 0x10, 0xA8, 0x06, 0xC0, 0x77, 0x48, 0x06,
       0xC8, 0x12, 0xA8, 0x06, 0xC0, 0x0C, 0x20, 0x01, 0x1C, 0x76, 0x4E, 0x30, 0x1C, 0x48, 0x30, 0x01,
       0x24, 0xA6, 0x46, 0x77, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x02, 0x48, 0x00, 0x78, 0x00, 0x28, 0x1C,
       0xD1, 0x01, 0xE0, 0x62, 0x56, 0x08, 0x00, 0x03, 0x27, 0x39, 0x1C, 0x6C, 0x48, 0xA6, 0x46, 0x70,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x36, 0x48, 0x39, 0x1C, 0xA6, 0x46, 0x6D, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x0C, 0x48, 0x01, 0x05, 0xFF, 0xFF, 0xB8, 0x31, 0x18, 0x00, 0xFA, 0x00, 0x21, 0x0C, 0x22,
       0xA6, 0x46, 0x6B, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x2F, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x41, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x1C, 0x04, 0x21, 0xA6, 0x46, 0x3E, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x4F, 0x48, 0x00, 0x78, 0x00, 0x09, 0x09, 0xD2, 0x02, 0xE0, 0xC0, 0x46, 0x14, 0xF6, 0x1A, 0x00,
       0x37, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x5D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x58, 0x48, 0x0E, 0x99,
       0x01, 0x60, 0xA9, 0x8F, 0x81, 0x80, 0x10, 0x99, 0x81, 0x60, 0x11, 0xA9, 0x09, 0x88, 0x81, 0x81,
       0x12, 0x99, 0x01, 0x61, 0x13, 0xA9, 0x09, 0x88, 0x81, 0x82, 0x42, 0x21, 0x51, 0x4D, 0x28, 0x1C,
       0x60, 0x30, 0x01, 0x60, 0x21, 0x1C, 0x28, 0x1C, 0xA6, 0x46, 0x50, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x28, 0x1C, 0xA0, 0x38, 0x00, 0x99, 0x01, 0x60, 0x01, 0x99, 0x41, 0x60, 0x02, 0x99, 0x81, 0x60,
       0x03, 0x99, 0xC1, 0x60, 0x04, 0x99, 0x01, 0x61, 0x05, 0x99, 0x41, 0x61, 0x06, 0x99, 0x81, 0x62,
       0x07, 0x99, 0xC1, 0x62, 0x08, 0x99, 0x81, 0x63, 0x09, 0x99, 0xC1, 0x63, 0x0A, 0x99, 0x01, 0x65,
       0x0B, 0x99, 0x41, 0x65, 0x0C, 0x99, 0x81, 0x66, 0x0D, 0x99, 0xC1, 0x66, 0x28, 0x1C, 0x04, 0x30,
       0x21, 0x1C, 0xA6, 0x46, 0x3D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xA6, 0x46, 0x3A, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x14, 0xB0, 0xF0, 0xBD, 0xC0, 0x46, 0x1E, 0xF6, 0x1A, 0x00, 0x2F, 0x0E, 0x04, 0x00,
       0x6A, 0x12, 0x40, 0x00, 0x85, 0x12, 0x00, 0x00, 0x5C, 0x7B, 0x1A, 0x00, 0x04, 0x09, 0x1A, 0x00,
       0x24, 0x79, 0x1A, 0x00, 0x54, 0x7D, 0x1A, 0x00, 0x2C, 0x7A, 0x1A, 0x00, 0x00, 0x74, 0x1A, 0x00,
       0xDB, 0x4A, 0x05, 0x00, 0x08, 0x51, 0x01, 0x05, 0xFF, 0xC3, 0xB2, 0x32, 0x18, 0x00, 0xBE, 0x08,
       0x00, 0x0C, 0x51, 0x08, 0x00, 0x0B, 0xD4, 0x04, 0x00, 0xF5, 0xD3, 0x04, 0x00, 0x7D, 0x0B, 0x18,
       0x00, 0x80, 0x7B, 0x08, 0x00, 0x84, 0xF3, 0x1A, 0x00, 0x78, 0x61, 0x1A, 0x00, 0x79, 0x48, 0x05,
       0x00, 0x05, 0x63, 0x08, 0x00, 0x00, 0x63, 0x08, 0x00, 0xCC, 0x24, 0x08, 0x00, 0x60, 0x63, 0x08,
       0x00, 0x61, 0x63, 0x08, 0x00, 0x6A, 0x63, 0x08, 0x00, 0xF4, 0x62, 0x08, 0x00, 0x36, 0xA0, 0x1B,
       0x00, 0x08, 0x63, 0x08, 0x00, 0x4C, 0x25, 0x08, 0x00, 0x63, 0x63, 0x08, 0x00, 0xC5, 0x13, 0x08,
       0x00, 0x25, 0x31, 0x18, 0x00, 0x00, 0x7C, 0x1A, 0x00, 0xF0, 0xFF, 0xFF, 0x00, 0x07, 0xFF, 0x03,
       0x00, 0xD7, 0xD3, 0x04, 0x00, 0x1D, 0x2F, 0x18, 0x00, 0xB2, 0x50, 0x08, 0x00, 0x2D, 0x1F, 0x08,
       0x00, 0xBA, 0x21, 0x08, 0x00, 0xE1, 0x04, 0x00, 0x00, 0xA4, 0x62, 0x08, 0x00, 0xAC, 0x62, 0x08,
       0x00, 0xB4, 0x62, 0x08, 0x00, 0xBC, 0x62, 0x08, 0x00, 0xC4, 0x62, 0x08, 0x00, 0xCC, 0x62, 0x08,
       0x00, 0xD4, 0x62, 0x08, 0x00, 0xDC, 0x62, 0x08, 0x00, 0xE4, 0x62, 0x08, 0x00, 0xEC, 0x62, 0x08,
       0x00, 0x08, 0xF0, 0x1A, 0x00, 0x10, 0x60, 0x1A, 0x00, 0x98, 0x0B, 0x1A, 0x00, 0xA0, 0x09, 0x1A,
       0x00, 0xD1, 0x2D, 0x18, 0x00, 0x61, 0x48, 0x05, 0x00, 0xD3, 0x48, 0x05, 0x00, 0x01, 0x05, 0xFF,
       0xFF, 0xFC, 0x08, 0x18, 0x00, 0xFA, 0xF0, 0xB5, 0xD8, 0x49, 0x0D, 0x78, 0x14, 0x2D, 0x2C, 0xDA,
       0xDA, 0x4C, 0x26, 0x1C, 0x30, 0x3E, 0x68, 0x1C, 0x00, 0x06, 0x00, 0x0E, 0x30, 0x70, 0xD3, 0x4B,
       0xAA, 0x00, 0xD3, 0x4F, 0x9F, 0x50, 0x14, 0x28, 0x18, 0xDA, 0xAA, 0x1C, 0x12, 0x06, 0x12, 0x0E,
       0x72, 0x70, 0x80, 0x00, 0xD0, 0x4E, 0x1E, 0x50, 0x14, 0x2A, 0x08, 0xDA, 0xE8, 0x1C, 0x20, 0x70,
       0x90, 0x00, 0xCE, 0x4A, 0x1A, 0x50, 0x08, 0x78, 0x03, 0x30, 0x08, 0x70, 0xF0, 0xBD, 0x0A, 0x70,
       0x01, 0x20, 0x86, 0x46, 0xCB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0x08, 0x70, 0x01, 0x20,
       0x86, 0x46, 0xC7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0x01, 0x20, 0x86, 0x46, 0xC4, 0x48,
       0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0xF8, 0xB5, 0x07, 0x1C, 0xFB, 0x7A, 0xC2, 0x48, 0x03, 0x70,
       0x3A, 0x7B, 0xC1, 0x48, 0x02, 0x70, 0xC1, 0x49, 0x7C, 0x7B, 0x0C, 0x70, 0xC1, 0x48, 0xBD, 0x7B,
       0x05, 0x70, 0xC9, 0x4E, 0x00, 0x2B, 0x00, 0xD0, 0xBE, 0xE0, 0xC2, 0x4A, 0x15, 0x1C, 0x8C, 0x3D,
       0xCB, 0x4E, 0xB6, 0x0B, 0x01, 0x24, 0xA6, 0x46, 0xBB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x29, 0x88,
       0x01, 0x40, 0x48, 0x08, 0x05, 0xD0, 0x30, 0x1C, 0x41, 0x1E, 0x0E, 0x04, 0x36, 0x0C, 0x00, 0x28,
       0xF0, 0xD1, 0xA6, 0x46, 0xB4, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x29, 0x88, 0x01, 0x40, 0x48, 0x08,
       0x04, 0xD0, 0x58, 0x20, 0xA6, 0x46, 0xB0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xAD, 0x48, 0x00, 0x78,
       0xAF, 0x4E, 0x01, 0x28, 0x34, 0xD0, 0x00, 0x20, 0x01, 0x1C, 0x0C, 0x20, 0x02, 0x1C, 0x30, 0x1C,
       0xA6, 0x46, 0xAB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xAB, 0x48, 0x00, 0x21, 0x08, 0x22, 0xA6, 0x46,
       0x01, 0x05, 0xFF, 0xFF, 0xF6, 0x09, 0x18, 0x00, 0xFA, 0xAA, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xA7,
       0x4E, 0x24, 0x36, 0x30, 0x1C, 0x21, 0x1C, 0x0C, 0x22, 0xA6, 0x46, 0xA6, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x07, 0x20, 0x01, 0x1C, 0x20, 0x1C, 0xA6, 0x46, 0xA4, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x14,
       0x20, 0xA6, 0x46, 0xA2, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x07, 0x20, 0xA6, 0x46, 0xA2, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x9F, 0x49, 0x08, 0x70, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xA6, 0x46, 0x99,
       0x4B, 0xFE, 0x44, 0x18, 0x47, 0x9B, 0x4E, 0x5B, 0xE0, 0x30, 0x1C, 0x00, 0x21, 0x08, 0x22, 0xA6,
       0x46, 0x92, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xA6, 0x46, 0x8E,
       0x4B, 0xFE, 0x44, 0x18, 0x47, 0x8E, 0x48, 0x00, 0x21, 0x0A, 0x1C, 0xA6, 0x46, 0x8D, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x8A, 0x48, 0x00, 0x21, 0x08, 0x22, 0xA6, 0x46, 0x89, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x03, 0x20, 0x02, 0x1C, 0x86, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x86, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x0B, 0x20, 0x02, 0x1C, 0x82, 0x48, 0x21, 0x1C, 0x8E, 0x46, 0x82, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x20, 0x1C, 0x06, 0x21, 0x86, 0x46, 0x80, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x20, 0x01,
       0x1C, 0x20, 0x1C, 0x86, 0x46, 0x7D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x14, 0x20, 0xA6, 0x46, 0x7B,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x7B, 0x4E, 0x07, 0x20, 0xA6, 0x46, 0x7A, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x90, 0x06, 0x20, 0xA6, 0x46, 0x77, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x41, 0x00, 0x00,
       0x98, 0x01, 0x43, 0x31, 0x70, 0x6E, 0x48, 0x00, 0x21, 0x03, 0x22, 0xA6, 0x46, 0x6E, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x01, 0x05, 0xFF, 0xFF, 0xF0, 0x0A, 0x18, 0x00, 0xFA, 0x6A, 0x48, 0x00, 0x21,
       0x0B, 0x22, 0xA6, 0x46, 0x6A, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x00, 0x20, 0x28, 0x80, 0x60, 0x48,
       0x04, 0x78, 0x60, 0x48, 0x05, 0x78, 0x32, 0x78, 0x01, 0xE0, 0x30, 0x1C, 0x02, 0x70, 0xF8, 0x7B,
       0x01, 0x2D, 0x25, 0xD1, 0x00, 0x2C, 0x0D, 0xD1, 0x10, 0x1C, 0x09, 0xD0, 0x01, 0x38, 0x05, 0xD0,
       0x01, 0x38, 0x01, 0xD0, 0x06, 0x20, 0x16, 0xE0, 0x04, 0x20, 0x14, 0xE0, 0x02, 0x20, 0x12, 0xE0,
       0x00, 0x20, 0x10, 0xE0, 0x10, 0x1C, 0x0D, 0xD0, 0x01, 0x38, 0x09, 0xD0, 0x01, 0x38, 0x05, 0xD0,
       0x01, 0x38, 0x01, 0xD0, 0x10, 0x20, 0x06, 0xE0, 0x0E, 0x20, 0x04, 0xE0, 0x0C, 0x20, 0x02, 0xE0,
       0x0A, 0x20, 0x00, 0xE0, 0x08, 0x20, 0xC0, 0x19, 0xC1, 0x7B, 0x56, 0x4B, 0x19, 0x70, 0x00, 0x7C,
       0x55, 0x49, 0x08, 0x70, 0x55, 0x48, 0x11, 0x04, 0x09, 0x0C, 0x0C, 0x22, 0x01, 0x23, 0x9E, 0x46,
       0x48, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xF8, 0xBD, 0x70, 0xB5, 0x00, 0x20, 0x67, 0x49, 0x08, 0x70,
       0x67, 0x49, 0xF7, 0x22, 0x0A, 0x70, 0xFF, 0x22, 0x4A, 0x70, 0x8A, 0x70, 0x7F, 0x22, 0xCA, 0x70,
       0x33, 0x4B, 0x19, 0x1F, 0x4B, 0x4A, 0x11, 0x60, 0x4B, 0x49, 0x08, 0x70, 0x61, 0x49, 0x08, 0x70,
       0x61, 0x49, 0x08, 0x70, 0x49, 0x49, 0x08, 0x70, 0x60, 0x49, 0x08, 0x60, 0x49, 0x48, 0x04, 0x1C,
       0x71, 0x3C, 0x01, 0x22, 0x22, 0x70, 0x46, 0x49, 0x19, 0x60, 0x02, 0x21, 0x01, 0x70, 0x46, 0x49,
       0x59, 0x60, 0x03, 0x21, 0x21, 0x71, 0x45, 0x49, 0x99, 0x60, 0x01, 0x1C, 0x33, 0x39, 0x04, 0x25,
       0x0D, 0x70, 0x43, 0x4D, 0xDD, 0x60, 0x05, 0x25, 0xCD, 0x73, 0x42, 0x49, 0x19, 0x61, 0x06, 0x21,
       0xA1, 0x71, 0x41, 0x49, 0x59, 0x61, 0x01, 0x05, 0xFF, 0xFF, 0xEA, 0x0B, 0x18, 0x00, 0xFA, 0x07,
       0x21, 0xE1, 0x71, 0xE1, 0x1D, 0x3F, 0x4D, 0x9D, 0x61, 0x05, 0x1C, 0x48, 0x3D, 0x08, 0x26, 0x2E,
       0x70, 0x3D, 0x4E, 0xDE, 0x61, 0x09, 0x26, 0x4E, 0x77, 0x3C, 0x49, 0x19, 0x62, 0x0A, 0x21, 0x0E,
       0x19, 0x31, 0x70, 0x3B, 0x49, 0x59, 0x62, 0x0B, 0x21, 0xF1, 0x75, 0x3A, 0x49, 0x99, 0x62, 0x1B,
       0x21, 0x09, 0x19, 0x0C, 0x26, 0x0E, 0x70, 0x38, 0x4E, 0xDE, 0x62, 0x0D, 0x26, 0x66, 0x73, 0x37,
       0x4C, 0x1C, 0x63, 0x0E, 0x24, 0x4C, 0x77, 0x36, 0x49, 0x59, 0x63, 0x0F, 0x24, 0x01, 0x1C, 0x21,
       0x31, 0x0C, 0x70, 0x34, 0x49, 0x99, 0x63, 0x10, 0x21, 0xC1, 0x74, 0x33, 0x48, 0xD8, 0x63, 0x11,
       0x20, 0xE8, 0x76, 0x32, 0x49, 0x19, 0x64, 0x03, 0x49, 0x08, 0x70, 0x96, 0x46, 0x30, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x70, 0xBD, 0x04, 0x63, 0x08, 0x00, 0x0C, 0x63, 0x08, 0x00, 0x05, 0x7B, 0x08,
       0x00, 0x0F, 0x7B, 0x08, 0x00, 0xFB, 0x53, 0x08, 0x00, 0xFB, 0x7A, 0x08, 0x00, 0xB1, 0x04, 0x18,
       0x00, 0x62, 0x63, 0x08, 0x00, 0x65, 0x63, 0x08, 0x00, 0x64, 0x63, 0x08, 0x00, 0x66, 0x63, 0x08,
       0x00, 0x07, 0xFF, 0x03, 0x00, 0xD7, 0xD3, 0x04, 0x00, 0x16, 0xF6, 0x1A, 0x00, 0xD3, 0x48, 0x05,
       0x00, 0x8C, 0x7C, 0x1A, 0x00, 0xA7, 0x48, 0x05, 0x00, 0x91, 0x48, 0x05, 0x00, 0x21, 0x99, 0x05,
       0x00, 0xBB, 0x16, 0x04, 0x00, 0x63, 0x63, 0x08, 0x00, 0x67, 0x99, 0x05, 0x00, 0x60, 0x63, 0x08,
       0x00, 0x61, 0x63, 0x08, 0x00, 0x08, 0x31, 0x19, 0x00, 0xFF, 0xFF, 0xFF, 0x1F, 0x88, 0x53, 0x08,
       0x00, 0x06, 0x63, 0x08, 0x00, 0x07, 0x63, 0x08, 0x00, 0x8D, 0x7A, 0x08, 0x00, 0xFD, 0x53, 0x08,
       0x00, 0xE7, 0x7A, 0x08, 0x00, 0xF1, 0x7A, 0x08, 0x00, 0x01, 0x05, 0xFF, 0x85, 0xE4, 0x0C, 0x18,
       0x00, 0x80, 0x19, 0x7B, 0x08, 0x00, 0x41, 0x7B, 0x08, 0x00, 0x4B, 0x7B, 0x08, 0x00, 0x37, 0x7B,
       0x08, 0x00, 0x23, 0x7B, 0x08, 0x00, 0x2D, 0x7B, 0x08, 0x00, 0xA1, 0x7A, 0x08, 0x00, 0xAB, 0x7A,
       0x08, 0x00, 0xB5, 0x7A, 0x08, 0x00, 0xD3, 0x7A, 0x08, 0x00, 0xDD, 0x7A, 0x08, 0x00, 0x97, 0x7A,
       0x08, 0x00, 0xBF, 0x7A, 0x08, 0x00, 0xC9, 0x7A, 0x08, 0x00, 0xFD, 0x08, 0x18, 0x00, 0x69, 0x63,
       0x08, 0x00, 0x5C, 0x63, 0x08, 0x00, 0x68, 0x63, 0x08, 0x00, 0xFC, 0x62, 0x08, 0x00, 0x7C, 0x63,
       0x08, 0x00, 0x10, 0xB5, 0x01, 0x24, 0xA6, 0x46, 0x06, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x08, 0x20,
       0x06, 0x49, 0x04, 0x22, 0x04, 0x4B, 0xA6, 0x46, 0x05, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD,
       0xC0, 0x46, 0xA5, 0x2F, 0x18, 0x00, 0xD0, 0x2D, 0x18, 0x00, 0x0C, 0x04, 0x00, 0x00, 0xD1, 0x5E,
       0x04, 0x00, 0x01, 0x83, 0xFF, 0x14, 0x79, 0x7B, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xDC, 0xFD, 0x05, 0x00, 0x00,
       0x00, 0x00, 0x12, 0x01, 0x0F, 0xFD, 0x01, 0x01, 0x01, 0x1C, 0xFD, 0x14, 0xFF, 0x88, 0x13, 0x00,
       0x00, 0xD0, 0x07, 0x00, 0x00, 0xFF, 0xFF, 0x01, 0xFF, 0xFF, 0xFF, 0xFA, 0x01, 0x00, 0x00, 0x00,
       0x01, 0x1C, 0xFD, 0x14, 0xFF, 0x88, 0x13, 0x00, 0x00, 0xD0, 0x07, 0x00, 0x00, 0xFF, 0xFF, 0x01,
       0xFF, 0xFF, 0xFF, 0xFA, 0x00, 0x00, 0x00, 0x00, 0x01, 0x58, 0xFD, 0x21, 0x01, 0xC4, 0xC4, 0xC4,
       0xE2, 0xE2, 0xE2, 0xF1, 0xEC, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x03, 0x14, 0x0A, 0x90, 0x00, 0x90,
       0x00, 0x3C, 0x0A, 0x32, 0x02, 0x01, 0x01, 0x01, 0x03, 0xF6, 0xEC, 0xF6, 0xEC, 0x01, 0x09, 0xFD,
       0x08, 0x7E, 0x7C, 0x1A, 0x00, 0x10, 0x00, 0x10, 0x00, 0x01, 0x01, 0xFF, 0x06, 0xC6, 0x32, 0x19,
       0x00, 0x10, 0x10, 0x01, 0x01, 0xFF, 0x06, 0x60, 0x32, 0x19, 0x00, 0x32, 0x10, 0x01, 0x82, 0xFD,
       0x14, 0x00, 0x9C, 0x18, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xDC, 0xE6, 0xF0, 0xFA, 0x04,
       0x0E, 0x18, 0xFF, 0x00, 0x00, 0x01, 0x82, 0xFD, 0x14, 0x01, 0x9C, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE,
       0xCE, 0xCE, 0xCE, 0xD8, 0xE2, 0xEC, 0xF6, 0x00, 0x0A, 0x14, 0xFF, 0x00, 0x00, 0x01, 0x82, 0xFD,
       0x14, 0x02, 0x9C, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xD8, 0xE2, 0xEC, 0xF6, 0x00,
       0x0A, 0x14, 0xFF, 0x00, 0x00, 0x01, 0x87, 0xFD, 0x03, 0x0D, 0x0D, 0x0D, 0x01, 0x76, 0xFD, 0x31,
       0x01, 0x21, 0x54, 0x00, 0x00, 0x61, 0x57, 0x00, 0x00, 0x14, 0x05, 0x0A, 0x05, 0x00, 0x07, 0x06,
       0x0A, 0x04, 0x05, 0x08, 0x09, 0x0B, 0x0C, 0x0D, 0x0E, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10,
       0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, 0x00,
       0x00, 0x01, 0x80, 0xFD, 0x06, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x80, 0xFD, 0x06, 0x3C,
       0xF0, 0x5F, 0x00, 0x00, 0x00, 0x01, 0x38, 0xFE, 0x00
    This leads me to think the issue might be in the function that provides the message that fills the Tx buffer, or in the configuration of the project and the patchs that I'm including.
    Thanks and best regards,
    Diana
  • Hi Diana,
    Are you able to debug the demo and set breakpoints? It would be helpful to see what function specifically in OpenStack causes the failure.
    Jacob
  • Hi Jacob,
    Yes, in the picture of the logic analyzer from the first post, the MSP430 signals were recorded between two breakpoints inside the function OpenStack from the SPPLEDemo.c file. The issue comes already from the BSC_Initialize function, which returns -4. After that point, since Result< 0, it doesn't initialize any layer later and displays in the console that it is unable to initialize the stack.
    The BSC_Initialize function declared in the BSCAPI.h file belongs to the precompiled stack libraries, and I can't see the function's source code; I don't know how to debug it further. I tried placing some flags and counters in the HCITRANS functions; to have an idea of how many times and in which order every function was called, but it didn't give much more information than the signal recording.
    If you have any idea of where to place some breakpoints to get more information about the error, or if you have any idea of what may be causing the problem, it would be very helpful.
    Diana
  • Hi Jacob,
    Do you have any updates?
    Diana
  • Hi Diana,
    The BSC_Initialize function allows the user to get a instance of the Bluetopia stack. If the program is failing here, there could be something wrong with the porting. Can you share the HAL modifications you made to port the MSP430.
    Additionally, taking firmware logs will help identify where the HCI communication is failing. Can you take FW logs according to this guide?
    https://www.ti.com/lit/pdf/swau058
    Finally, another UART logic analyzer capture of the MSP430 that shows the hex data sent over RX and TX would be helpful.
    Jacob
  • Hi Jacob,
    Thank you for your response. I'm attaching the files: HAL.c, HAL.h, and HRDWCFG.h that I'm using.
    I followed the guide you suggested. I'm attaching those logs. Also, I will be including a capture from the logic analyzer taken simultaneously to the log from the BTLogger. I saved them in different formats: The .png is an image from the logic analyzer recording, the file <<MSP430FR5994_events.csv>> are the events from the different channels, the file <<MSP430FR5994_log.csv>> is the log in .csv format, and the file <<MSP430FR5994_log.dwflogicacq>> is the log in a software-specific format. The software I use for the logic analyzer is Waveforms from Digilent. If you open the last file there, you may see each event in more detail.
    Diana
    PS: I used .zip files because it was taking too long to upload file by file. I hope it's not an inconvenience.
    MSP430FR5994_logs.zipMSP430FR5994_HW.zip
  • Hi Diana,
    I have received your files and will follow up here this week.
    Jacob
  • Hi Diana,
    Thank you for the firmware logs. Overall, the initialization seems to be successful until the HCI_Command_Complete_VS_LE_Enable_Event which returns an error code of 0x1F (Unspecified Error). I'll continue to look to see what may be causing that.
    I'll also try to assess your HAL but I do not have much experience with the MSP430; it is an older device that we do not actively develop on.
    Jacob
  • Hi Jacob,
    Diana will be out of office for a couple of week, I will take care of this project in the meantime.
    For what I can understand it seems that serial communication between CC2564 and MSP430FR5994 is fine, right? Do you have any hint on where to focus the HAL review?
    Right now we are connecting the two devices through 3.3V, GND, uart_tx, uart_rx, cts, rts, shdn. Is the hardware configuration ok?
    Moreover, is it possible to have the lost of command sent between the devices? So that we can also compare differences with MSP432.
    Thank you.
    Matteo
  • Hi Matteo,
    I'll follow up here tomorrow.
    Jacob
  • Hi Matteo,
    It seems like the communication is failing with the VS_LE_Enable command:
    Can you try programming the MSP430 with HCITester instead? Here is a link to the guide to begin using the program. You will also need the BTS for the CC2564B, which you can find here.
    Once you are able to program the device with HCITester, we can work on removing these lines that I believe are in your CC256X.h patch (in the hex format):
    Jacob
  • Hi Jacob,
    I set up the HCItester. I'm using the "TIInit_6.7.16.xml" and "initscripts-TIInit_6.7.16_bt_spec_4.1", modified as specified in the guide you sent me.
    After that I tried to run the script and i attach here what I'm obtaining.
    The script seems to fail at the "HCI_Command_Complete_VS_Update_Uart_HCI_Baudrate_Event", that is exactly what Diana saw in her first tests.
    I also noticed that I can't find in the script the lines that you are suggesting to remove.
    In your previous message you told me to download the BTS for the CC2564B. I'm currently using the CC2564MODA, does this can lead to any difference?
    Matteo
  • Hi Matteo,
    Do you need BLE for your application? If you do, I suggest the "initscripts-TIInit_6.7.16_ble_add-on.bts." If not, then you should use the "initscripts-TIInit_6.7.16_bt_spec_4.1.bts."
    The issue you see where the script fails is because the MSP430 needs a transparent image to correctly interface with the CC2564B. However, this requires purchasing the MSP Flasher to flash the MSP430 with the bootloader. I think we can get circumvent this with my following debug recommendations:
    1. Download TI wireless tools package (should already have this with HCITester download)
    2. Save current CC256X.h
    3. Open .bts of choice with HCITester and remove the lines enabling Cortex Sleep (0xFDA8) and BLE (0xFD5B, 0xFDDD) if they are present and you do not require BLE for your application
    4. Save the .bts and open it with BTSTransform with the "Create single dimensional array" option
    5. Replace the CC256X.h array with the array from the preview contents
    6. Take FW logs of this process in the same manner as before (with HCI/LMP interface)
    Essentially, I am trying to recreate the CC256X.h file without the HCI commands that cause the MSP430 to hang. Can you follow these steps?
    Jacob
  • Hi Jacob,
    I need BLE in my application.
    I followed your instructions for appropriate debug and:
    1. I verified Ti wirelles package
    2. I saved a copy of the originale CC256X.h
    3. I modified the "initscripts-TIInit_6.7.16_ble_add-on.bts." in order to remove the lines you highligted. Is it correct since I need BLE?
    4. With BTStransform I created the new array.
    Here I have a couple of questions:
    1. In the original CC256X.h file I see two arrays: "BasePatch" array and "LowEnergyPatch" array. Which one do I need to replace? (see CC256X_original.h)
    2. In the new file that I create there are 7 arrays. Do I need to copy the content of all of them inside the  "BasePatch" array o the "LowEnergyPatch" array? (see CC256X_modified.h)
    As soon as I get back your feedback I will procede with the firmware logs acquisition.
    Thank you very much,
    Matteo
    CC256X_original.h
    CC256X_modified.c
    #define PACKETS_COUNT	7
    // Description:   BLE FW Initialization Script
    // Compatibility: BL6450B
    // Last Updated:  19-Oct-2014  13:57:11.15
    // Version:       2.0
    //LE Enable
    const unsigned char g_abPacket01[] = {0x01,0x5b,0xfd,0x02,0x01,0x01};
    // Disable Cortex Sleep
    const unsigned char g_abPacket02[] = {0x01,0xa8,0xfd,0x01,0x01};
    // Cortex Reset (hold in reset while loading IMEM)
    const unsigned char g_abPacket03[] = {0x01,0x09,0xfd,0x08,0x00,0xc0,0x1b,0x00,0x01,0x00,0x01,0x00};
    // Patch Start
    const unsigned char g_abPacket04[] = {0x01,0x05,0xff,0x0d,0xac,0x4b,0x1b,0x00,0x08,0x91,0xff,0x47,0xf2,0x9b,0x35,0x47,
                                   0xf2};
    const unsigned char g_abPacket05[] = {0x01,0x05,0xff,0x55,0x20,0x63,0x1b,0x00,0x50,0x30,0xbd,0x00,0x00,0x00,0x00,0x00,
                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
                                   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
    const unsigned char g_abPacket06[] = {0x01,0x05,0xff,0x5d,0x98,0x73,0x1b,0x00,0x58,0x70,0x47,0x02,0x46,0x14,0x3a,0x1e,
                                   0xd0,0x52,0x1e,0x24,0xd1,0x8a,0x78,0x02,0x2a,0x11,0xd9,0x12,0x1f,0x02,0x2a,0x0e,
                                   0xd9,0x1d,0x3a,0x1c,0xd0,0x92,0x1f,0x02,0x2a,0x19,0xd9,0x09,0x3a,0x17,0xd0,0x89,
                                   0x88,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x4b,0xbe,0x09,
                                   0x89,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x43,0xbe,0x89,
                                   0x88,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x3b,0xbe,0x70,
                                   0x47};
    // Patch End
    //release Cortex Reset
    const unsigned char g_abPacket07[] = {0x01,0x09,0xfd,0x08,0x00,0xc0,0x1b,0x00,0x00,0x00,0x01,0x00};
    const unsigned char*  g_abPacket[] = {g_abPacket01,g_abPacket02,g_abPacket03,g_abPacket04,g_abPacket05,g_abPacket06,g_abPacket07};
  • Hi Matteo,
    I'll follow up tomorrow.
    Jacob
  • Hi Matteo,
    I have some slight adjustments for you. Going back to the "initscripts-TIInit_6.7.16_ble_add-on.bts," you should leave in the Low Energy commands and disable the Cortex Reset and Sleep. We may need to add those commands in again later, but I just want to see if you are able to open the stack first.
    After you modify the .bts, can you use the "Data only" radio button instead of the array in BTS Transform? That should allow you to paste the data into the BasePatch[]. You can leave the LowEnergyPatch alone in the CC256X.h for now.
    Jacob
  • Hi Jacob,
    sorry for the late reply.
    I followed your instructions to run the test:
    1- From HCItester I modified the "initscripts-TIInit_6.7.16_ble_add-on.bts" removing CortexReset and CortexSleep, while leaving in the file the Enable LE command.
    2- From this file I created the output vector with BTStransform using the option "Data only".
    3- I replaced the BasePatch[] vector in the CC256X.h file with file saved from BTStransform.
    4- I did not modify the LowEnergyPacth[] vector in CC256X.h file.
    The file "FW_log1" in the folder "Test1" shows the data obtained with Logger application.
    Also in this case it seems to be that the stack is not correctly initialized.
    I would like to share with you also the firmware logs that I acquired from a test that I made by mistake.
    1- Same as above.
    2- Same as above.
    3-  I replaced the LowEnergy[] vector in the CC256X.h file with file saved from BTStransform.
    4- I did not modify the BasePatch[] vector in CC256X.h file.
    The file "FW_log2" in the folder "Test2"  shows the data obtained with Logger application.
    In this situation it seems to me that stack initialization is completed.
    Don't know if this can help in some way.
    Matteo
    FW_logs.rar
  • Hi Matteo,
    I'll take a look at the two cases you provided and follow up here in a few days. In the meantime, can you try one more scenario? What happens if you try the default CC256X.h file as before, but you comment out the LowEnergy[] array?  I'm wondering if the real problem is with the Low Energy commands.
    Jacob
  • Hi Jacob,
    D you have any update?
    Matteo
  • Sorry I lost your previous reply.
    If I use the original BasePatch and comment the LowEnergyPatch the stack fails to open.
    Do you need firmware logs?
    Matteo
  • Hi Matteo,
    In the case you mentioned where you think the stack is initialized, are you able to try to run an example on the MSP430 from the Bluetopia SDK?
    If you could take one more set of firmware logs from the case above (where you use the original BasePatch while commenting out LowEnergyPatch), that would be helpful. I want to see what part of the patch is causing the stack opening to fail.
    Jacob
  • Hi Jacob,
    We ran the SPPLE demo from the Blutopia SDK. Now we are noticing two unusual behaviors that are happening.
    1: When the demo is debugging, it couldn't open the stack, while when the firmware was running, it reported having opened the stack.
    2: We have the LE_DEMO_DEVICE_NAME defined as "SPPLEDemo_Newronika" in the file SPPLEDemo.c, but when we use the command "getLocalName" from the console, we get the name is void. Nevertheless, when we attempt to change the name from the console, it changes it successfully.
    Attached here are two pictures of the console and the logs.
    This log started at a hardware reset, and the console commands used after opening the stack were:
    -server
    -RegisterSPPLE
    -SetDiscoverabilityMode 2
    -SetConnectabilityMode 1
    -AdvertiseLE 1
    This firmware has the LE patch commented base patch data declared as you suggested.
    FW_log3.rar
    Diana
  • Hi Diana,
    Thank you for the logs. I'll try to respond this week.
    Jacob
  • Hello Jacob,
    Thanks for the reply. Do you have any news?
    Diana.
  • Hi Diana,
    I have not been able to look into this yet, but I will follow up on Monday.
    Jacob
  • Hey Diana,
    In the case #1 above, what are the contents of the CC256X.h file that allow you to first fail opening the stack, but then immediately allow you to open the stack after?
    In that same demo, can you try to run the "Inquiry" command? I want to see if you are actually successful in opening the stack.
    Also, I just want to be sure that you are aware if you use our older Bluetopia stack (such as the Bluetopia 4.0 MSP430 Stack), you will not be able to certify your product with Bluetooth SIG because the profiles will be deprecated. The Bluetopia 4.0 MSP430 Stack is defined by QDID 37180 and QDID 42849.TI always recommends using the latest Bluetopia stack, but we do not have a stack offering for the MSP430.
    Jacob
  • Hello Jacob,
    In case #1 I was using the following content in the CC256x.h file:
    /*****< cc256x.h >*************************************************************/
    /*      Copyright 2008 - 2014 Stonestreet One.                                */
    /*      All Rights Reserved.                                                  */
    /*  CC256X - TI Specific Patch RAM for TI CC256X chips.                       */
    /*  Author:  Tim Cook                                                         */
    /*** MODIFICATION HISTORY *****************************************************/
    /*   mm/dd/yy  F. Lastname    Description of Modification                     */
    /*   07/05/11  Tim Cook       Initial Creation.                               */
    #ifndef _CC256XH_
    #define _CC256XH_
    #include "BaseTypes.h"
       /* ************************** Patch RAM Version ************************** */
       /* - Base        */
       /*   - WL1271L1 (CC256x) BT SP 2.10                                        */
       /* - Add Ons                                                               */
       /*   - XTAL Configuration                                                  */
       /*   - LE Add-On Pack for SP 2.10 (Optional).                              */
       /* If the patch location is not defined then define it to be empty.  */
    #ifndef BTPSVEND_PATCH_LOCATION
       #define BTPSVEND_PATCH_LOCATION
    #endif
       /* For CCS Builds place the patch data into a known section so that  */
       /* it can be relocated above 64K.                                    */
    #ifdef __TI_COMPILER_VERSION__
       #pragma DATA_SECTION(BasePatch, ".patch");
       #pragma DATA_SECTION(LowEnergyPatch, ".patch");
    #endif
       /* The following is the binary representation of the Base Patch Data.*/
    static BTPSCONST BTPSVEND_PATCH_LOCATION unsigned char BasePatch[] =
    /* ORGINAL BASE PATCH */
    #if(1)
       0x01, 0x37, 0xFE, 0x02, 0x06, 0x0F, 0x01, 0x05, 0xFF, 0xFF, 0xA0, 0x62, 0x08, 0x00, 0xFA, 0x06,
       0x0F, 0x3D, 0x55, 0xFB, 0x01, 0x00, 0x1F, 0x00, 0x00, 0x05, 0x00, 0x05, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0x05, 0x00, 0x05, 0xC0, 0x01, 0x40, 0x1F, 0x30, 0x05, 0x00, 0x04, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0x3D, 0x01, 0x04, 0xC0, 0x03, 0xC0, 0x1E, 0x38, 0x76, 0x02, 0x04, 0xC0, 0x03, 0xC0, 0x1E,
       0x38, 0xAE, 0x03, 0x04, 0xC0, 0x03, 0xC0, 0x1E, 0x38, 0xAE, 0x0B, 0x01, 0x00, 0x34, 0x30, 0x41,
       0x02, 0x00, 0x00, 0x00, 0x00, 0x80, 0x7F, 0x12, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x31, 0x9D,
       0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE2,
       0x48, 0x00, 0x78, 0x02, 0x28, 0x0F, 0xD1, 0xE1, 0x48, 0x41, 0x88, 0x09, 0x09, 0x0B, 0xD2, 0x41,
       0x88, 0x49, 0x08, 0x08, 0xD2, 0x42, 0x88, 0x10, 0x21, 0x01, 0x05, 0xFF, 0xFF, 0x9A, 0x63, 0x08,
       0x00, 0xFA, 0x11, 0x43, 0x41, 0x80, 0x02, 0x88, 0x01, 0x21, 0x89, 0x03, 0x11, 0x43, 0x01, 0x80,
       0xF7, 0x46, 0xD8, 0x48, 0x00, 0x78, 0x02, 0x28, 0x0F, 0xD1, 0xD7, 0x48, 0x41, 0x88, 0x09, 0x09,
       0x0B, 0xD2, 0x41, 0x88, 0x49, 0x08, 0x08, 0xD2, 0x10, 0x22, 0x41, 0x88, 0x91, 0x43, 0x41, 0x80,
       0x01, 0x22, 0x92, 0x03, 0x01, 0x88, 0x91, 0x43, 0x01, 0x80, 0xF7, 0x46, 0x10, 0xB5, 0x03, 0x7E,
       0xE2, 0x49, 0xE3, 0x4A, 0xE4, 0x48, 0x00, 0x2B, 0x09, 0xD1, 0x94, 0x38, 0x82, 0x18, 0x04, 0x20,
       0x00, 0x23, 0x01, 0x24, 0xA6, 0x46, 0xDF, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD, 0x82, 0x18,
       0x04, 0x20, 0x00, 0x23, 0x01, 0x24, 0xA6, 0x46, 0xDA, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD,
       0xF0, 0xB5, 0x04, 0x69, 0xC7, 0x26, 0x30, 0x5D, 0x04, 0x28, 0x24, 0xD1, 0xC8, 0x25, 0x28, 0x5D,
       0x18, 0x28, 0x03, 0xD1, 0x6A, 0x20, 0x00, 0x5D, 0x04, 0x28, 0x16, 0xD0, 0x28, 0x5D, 0x19, 0x28,
       0x19, 0xD1, 0xCE, 0x20, 0x00, 0x5D, 0x16, 0x28, 0x15, 0xD1, 0xB5, 0x27, 0x38, 0x5D, 0x01, 0x21,
       0x8E, 0x46, 0xCE, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x22, 0x38, 0x5D, 0x60, 0x21, 0x41, 0x43,
       0xCB, 0x48, 0x42, 0x54, 0x32, 0x55, 0x2A, 0x55, 0xF0, 0xBD, 0x20, 0x1C, 0x01, 0x21, 0x8E, 0x46,
       0xC8, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xF0, 0xBD, 0xF0, 0xB5, 0x86, 0xB0, 0x07, 0x1C, 0xB8, 0x69,
       0x03, 0x90, 0xB9, 0x8A, 0x04, 0x91, 0x00, 0x25, 0x6C, 0x46, 0x25, 0x71, 0x65, 0x71, 0xC2, 0x48,
       0x44, 0x38, 0x08, 0x1A, 0x01, 0x28, 0x0B, 0xD9, 0x05, 0x38, 0x09, 0xD0, 0x68, 0x38, 0x01, 0x28,
       0x06, 0xD9, 0x04, 0x38, 0x04, 0xD0, 0x2F, 0x38, 0x02, 0xD0, 0x24, 0x38, 0x01, 0x05, 0xFF, 0xFF,
       0x94, 0x64, 0x08, 0x00, 0xFA, 0x02, 0x28, 0x0B, 0xD8, 0x00, 0x97, 0x04, 0x98, 0x03, 0x99, 0x01,
       0xAA, 0x63, 0x1D, 0x01, 0x26, 0xB6, 0x46, 0xE8, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x00, 0x28, 0x5F,
       0xD1, 0x04, 0x98, 0xB3, 0x49, 0x41, 0x1A, 0xE5, 0x48, 0x37, 0xD0, 0x75, 0x39, 0x2C, 0xD0, 0x2C,
       0x39, 0x02, 0xD0, 0x14, 0x39, 0x3F, 0xD0, 0x53, 0xE0, 0x03, 0x98, 0x29, 0x1C, 0x01, 0x26, 0xB6,
       0x46, 0xE7, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x05, 0x90, 0xB6, 0x46, 0xE6, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x28, 0x02, 0xD1, 0x02, 0x20, 0x60, 0x71, 0x02, 0xE0, 0x00, 0x78, 0xE2, 0x49, 0x0D,
       0x56, 0x02, 0xA8, 0x05, 0x99, 0xB6, 0x46, 0xE1, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x05, 0x70, 0x03,
       0x20, 0x6A, 0x46, 0x10, 0x70, 0x03, 0x98, 0x9E, 0x49, 0xA1, 0x31, 0x52, 0x79, 0x02, 0xAB, 0xB6,
       0x46, 0xED, 0x4D, 0xFE, 0x44, 0x28, 0x47, 0x28, 0xE0, 0x0E, 0x21, 0x01, 0x22, 0x96, 0x46, 0xEB,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x28, 0x08, 0xD0, 0x22, 0xE0, 0x0D, 0x21, 0x01, 0x22, 0x96,
       0x46, 0xE6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x28, 0x1A, 0xD1, 0x0C, 0x20, 0x60, 0x71, 0x01,
       0x21, 0x68, 0x46, 0x01, 0x71, 0x17, 0xE0, 0x03, 0x98, 0x01, 0x21, 0x8E, 0x46, 0xE0, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x02, 0x21, 0xDF, 0x48, 0x02, 0x79, 0x01, 0x2A, 0x03, 0xD1, 0x45, 0x23, 0xDE,
       0x4A, 0x12, 0x78, 0x1A, 0x54, 0x4C, 0x30, 0x01, 0x39, 0xF5, 0xD1, 0xEF, 0x48, 0x9E, 0x30, 0x38,
       0x62, 0x20, 0x79, 0x01, 0x28, 0x0A, 0xD1, 0x03, 0x98, 0x04, 0x99, 0x62, 0x79, 0x01, 0x23, 0x9E,
       0x46, 0xEA, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE8, 0x48, 0x9E, 0x30, 0x38, 0x62, 0x06, 0xB0, 0x01,
       0x05, 0xFF, 0xFF, 0x8E, 0x65, 0x08, 0x00, 0xFA, 0xF0, 0xBD, 0xF8, 0xB5, 0x06, 0x1C, 0xB5, 0x69,
       0xB2, 0x8A, 0xE5, 0x48, 0x01, 0x1C, 0x11, 0x39, 0x52, 0x1A, 0x65, 0xD0, 0x12, 0x1A, 0xE3, 0x49,
       0x22, 0xD0, 0x07, 0x3A, 0x00, 0xD0, 0x8E, 0xE0, 0x0E, 0x20, 0x40, 0x19, 0x06, 0x22, 0xAA, 0x80,
       0x08, 0x22, 0x6A, 0x80, 0x09, 0x78, 0x02, 0x29, 0x0C, 0xD1, 0xDD, 0x49, 0x01, 0x24, 0xA6, 0x46,
       0xDD, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x21, 0xA6, 0x46, 0xDA, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x00, 0x22, 0x00, 0xE0, 0x0C, 0x22, 0x28, 0x1C, 0x87, 0x21, 0x89, 0x00, 0x01, 0x23, 0x9E, 0x46,
       0xD6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x6B, 0xE0, 0x08, 0x78, 0x02, 0x28, 0x33, 0xD1, 0x0B, 0x20,
       0x40, 0x19, 0x01, 0x24, 0xA6, 0x46, 0xD1, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x90, 0xA6, 0x46,
       0xD0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x06, 0x00, 0x0E, 0xA6, 0x46, 0xCE, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x07, 0x1C, 0x0E, 0x20, 0x40, 0x19, 0x00, 0x99, 0xA6, 0x46, 0x96, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x06, 0x21, 0xA9, 0x80, 0x07, 0x21, 0x69, 0x80, 0x00, 0x2F, 0x0B, 0xD0, 0x00, 0x99,
       0xC9, 0x0A, 0x08, 0xD3, 0x3A, 0x21, 0xC9, 0x19, 0x05, 0x22, 0xA6, 0x46, 0xC3, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x00, 0x22, 0x08, 0xE0, 0x00, 0x21, 0x05, 0x22, 0xA6, 0x46, 0xC0, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x02, 0x22, 0x00, 0xE0, 0x0C, 0x22, 0x28, 0x1C, 0xBD, 0x49, 0x01, 0x23, 0x9E, 0x46,
       0xBD, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x2B, 0xE0, 0x2F, 0x1C, 0x06, 0x20, 0xA8, 0x80, 0x0E, 0x20,
       0x40, 0x19, 0x40, 0x21, 0x01, 0x24, 0xA6, 0x46, 0xB8, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x94, 0x48,
       0x01, 0x1C, 0x01, 0x05, 0xFF, 0xFF, 0x88, 0x66, 0x08, 0x00, 0xFA, 0xCF, 0x22, 0x8A, 0x73, 0x0E,
       0x31, 0x61, 0x22, 0x0A, 0x74, 0x06, 0x30, 0x19, 0x21, 0x02, 0x78, 0xBA, 0x73, 0x01, 0x37, 0x01,
       0x30, 0x01, 0x39, 0xF9, 0xD1, 0x04, 0x20, 0xAF, 0x49, 0x0A, 0x78, 0xBA, 0x73, 0x01, 0x37, 0x01,
       0x31, 0x01, 0x38, 0xF9, 0xD1, 0x40, 0x20, 0x68, 0x80, 0x28, 0x1C, 0x81, 0x21, 0x49, 0x00, 0x00,
       0x22, 0xA6, 0x46, 0x9F, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xEB, 0x48, 0xFA, 0x30, 0x30, 0x62, 0xF8,
       0xBD, 0x30, 0xB5, 0x05, 0x1C, 0xE9, 0x48, 0x00, 0x78, 0x00, 0x28, 0x17, 0xD1, 0x01, 0x24, 0xA6,
       0x46, 0xE7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x00, 0x28, 0x0B, 0xD1, 0xA6, 0x46, 0xE5, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x01, 0x28, 0x05, 0xD0, 0xA6, 0x46, 0xE3, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x01,
       0x28, 0x04, 0xD1, 0x00, 0x20, 0x28, 0x60, 0xE0, 0x48, 0x52, 0x30, 0x28, 0x62, 0x30, 0xBD, 0xE8,
       0x57, 0x08, 0x00, 0x60, 0x7A, 0x1A, 0x00, 0x70, 0xB5, 0xDD, 0x49, 0x80, 0x8A, 0x88, 0x42, 0x20,
       0xD1, 0xDC, 0x4B, 0xDC, 0x4A, 0x00, 0x21, 0x40, 0x20, 0x80, 0x5C, 0x00, 0x28, 0x0E, 0xD0, 0x18,
       0x78, 0xDA, 0x4E, 0x8C, 0x00, 0xDA, 0x4D, 0x2C, 0x19, 0x25, 0x6A, 0xB5, 0x42, 0x0B, 0xD8, 0x64,
       0x68, 0xB4, 0x42, 0x08, 0xD8, 0x01, 0x24, 0x8C, 0x40, 0xA0, 0x43, 0x18, 0x70, 0xA8, 0x32, 0x01,
       0x31, 0x07, 0x29, 0xE8, 0xDB, 0x70, 0xBD, 0x0A, 0x06, 0x12, 0x0E, 0x01, 0x21, 0x91, 0x40, 0x01,
       0x43, 0x19, 0x70, 0x70, 0xBD, 0xC0, 0x46, 0x17, 0x71, 0x08, 0x00, 0xC9, 0x98, 0x00, 0x00, 0x65,
       0x70, 0x08, 0x00, 0xD3, 0x03, 0x00, 0x00, 0xC9, 0xA2, 0x00, 0x00, 0x76, 0xA0, 0x1B, 0x00, 0x6D,
       0x97, 0x00, 0x00, 0x5B, 0xFD, 0x01, 0x05, 0xFF, 0xFF, 0x82, 0x67, 0x08, 0x00, 0xFA, 0x00, 0x00,
       0x70, 0xB5, 0x06, 0x1C, 0xB5, 0x69, 0x28, 0x88, 0x00, 0x0A, 0x01, 0x02, 0x35, 0x20, 0x00, 0x02,
       0x08, 0x1A, 0x28, 0xD0, 0x09, 0x21, 0x49, 0x02, 0x40, 0x1A, 0x04, 0xD0, 0x3F, 0x21, 0x09, 0x02,
       0x40, 0x1A, 0x39, 0xD0, 0x70, 0xBD, 0xBD, 0x48, 0x00, 0x68, 0x00, 0x28, 0x0E, 0xD1, 0xE8, 0x88,
       0x00, 0x04, 0xA9, 0x88, 0x08, 0x43, 0x01, 0x24, 0xA6, 0x46, 0x5A, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x28, 0x1C, 0xA6, 0x46, 0xB6, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x34, 0xE0, 0x7D, 0x20, 0xC0, 0x00,
       0x01, 0x24, 0xA6, 0x46, 0xB5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x28, 0x1C, 0xA6, 0x46, 0xB1, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x27, 0xE0, 0xE8, 0x88, 0x11, 0x21, 0x49, 0x01, 0x41, 0x43, 0xE4, 0x48,
       0x40, 0x18, 0x3B, 0x21, 0x0A, 0x5C, 0x3C, 0x21, 0x09, 0x5C, 0x11, 0x43, 0x05, 0xD1, 0x00, 0x21,
       0x01, 0x22, 0x96, 0x46, 0xA8, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46,
       0xA3, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x0E, 0xE0, 0xE8, 0x88, 0x80, 0x00, 0xEE, 0x49, 0x08, 0x58,
       0x00, 0x21, 0x01, 0x24, 0xA6, 0x46, 0xED, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x28, 0x1C, 0xA6, 0x46,
       0x9B, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xE7, 0x49, 0x05, 0x20, 0x00, 0x02, 0x40, 0x18, 0x30, 0x62,
       0x70, 0xBD, 0xC0, 0x46, 0xF9, 0x06, 0x18, 0x00, 0xC0, 0x61, 0x1A, 0x00, 0x10, 0xB5, 0x04, 0x1C,
       0xE3, 0x48, 0x00, 0x78, 0x01, 0x28, 0x08, 0xD1, 0x60, 0x69, 0x01, 0x21, 0x8E, 0x46, 0x90, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xEB, 0x48, 0x1A, 0x30, 0x20, 0x62, 0x10, 0xBD, 0xD1, 0x2B, 0x00, 0x00,
       0x65, 0x8B, 0x01, 0x00, 0x50, 0x21, 0x08, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x7C, 0x68, 0x08, 0x00,
       0xFA, 0x69, 0x2C, 0x00, 0x00, 0x30, 0xB5, 0x04, 0x1C, 0xA1, 0x69, 0x00, 0x29, 0x1C, 0xD0, 0x20,
       0x69, 0x02, 0x78, 0xFF, 0x2A, 0x18, 0xD0, 0x8A, 0x88, 0x89, 0x18, 0x08, 0x22, 0xCA, 0x42, 0x13,
       0xD0, 0x39, 0x22, 0x12, 0x5C, 0x0A, 0x2A, 0x0F, 0xD1, 0x09, 0x7A, 0x4A, 0x08, 0x0F, 0x2A, 0x0B,
       0xD1, 0xC9, 0x07, 0xC9, 0x0F, 0x0F, 0x22, 0x2A, 0x23, 0x01, 0x25, 0xAE, 0x46, 0xE7, 0x4D, 0xFE,
       0x44, 0x28, 0x47, 0x7B, 0x48, 0xF0, 0x30, 0x20, 0x62, 0x30, 0xBD, 0xC0, 0x46, 0x0D, 0x78, 0x05,
       0x00, 0x2F, 0x4A, 0x05, 0x00, 0xEF, 0x36, 0x00, 0x00, 0x00, 0x14, 0x08, 0x00, 0xAD, 0x11, 0x08,
       0x00, 0x70, 0xB5, 0x85, 0xB0, 0x05, 0x1C, 0x68, 0x69, 0xE6, 0x4E, 0x01, 0x24, 0x34, 0x70, 0x01,
       0x7A, 0x89, 0x06, 0x09, 0x0E, 0xE4, 0x4A, 0x52, 0x58, 0x69, 0x46, 0xA6, 0x46, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x20, 0x30, 0x70, 0x68, 0x46, 0x01, 0x7C, 0x06, 0x29, 0x04, 0xD0, 0xA6, 0x46, 0xDF,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x04, 0xE0, 0xDE, 0x4A, 0x34, 0x21, 0x88, 0x5C, 0x01, 0x30, 0x88,
       0x54, 0xDC, 0x48, 0x4E, 0x30, 0x28, 0x62, 0x05, 0xB0, 0x70, 0xBD, 0xC0, 0x46, 0x81, 0x60, 0x00,
       0x00, 0x99, 0x77, 0x05, 0x00, 0x13, 0x10, 0x00, 0x00, 0x41, 0x10, 0x08, 0x00, 0xFF, 0xFF, 0xFF,
       0x1F, 0x53, 0x2C, 0x00, 0x00, 0xC1, 0x50, 0x02, 0x00, 0x73, 0x2C, 0x00, 0x00, 0x71, 0x8B, 0x04,
       0x00, 0x9B, 0x8B, 0x04, 0x00, 0x21, 0xA7, 0x05, 0x00, 0xC1, 0xAD, 0x05, 0x00, 0x15, 0x20, 0x00,
       0x00, 0xA7, 0x50, 0x02, 0x00, 0x91, 0x1C, 0x04, 0x00, 0x5C, 0x63, 0x08, 0x00, 0xF8, 0xB5, 0x07,
       0x1C, 0x7C, 0x69, 0x3D, 0x69, 0x38, 0x7F, 0x17, 0x21, 0x40, 0x1A, 0x01, 0x05, 0xFF, 0xFF, 0x76,
       0x69, 0x08, 0x00, 0xFA, 0x26, 0xD0, 0x0D, 0x38, 0x16, 0xD0, 0x5B, 0x38, 0x63, 0xD1, 0xFF, 0x20,
       0x7D, 0x30, 0x00, 0x5D, 0x0C, 0x28, 0x5E, 0xD1, 0xDC, 0x48, 0xE9, 0x78, 0x41, 0x70, 0x29, 0x79,
       0x81, 0x70, 0x69, 0x79, 0xC1, 0x70, 0xA9, 0x79, 0x01, 0x71, 0xE9, 0x79, 0x41, 0x71, 0x29, 0x7A,
       0xC1, 0x80, 0xA9, 0x7A, 0x01, 0x81, 0x4E, 0xE0, 0x01, 0x25, 0xAE, 0x46, 0xD4, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0xAE, 0x46, 0xD3, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x28, 0x43, 0xD0, 0xD2, 0x48,
       0xC4, 0x38, 0x3D, 0xE0, 0xFF, 0x20, 0x7D, 0x30, 0x06, 0x19, 0x28, 0x78, 0x30, 0x70, 0x31, 0x78,
       0x02, 0x20, 0x08, 0x40, 0x30, 0x70, 0x01, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xCC, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x70, 0x80, 0x02, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xC8, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xB0, 0x80, 0xFF, 0x20, 0x83, 0x30, 0x00, 0x19, 0x00, 0x90, 0x02, 0x35,
       0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xC2, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x99, 0x08, 0x80,
       0x02, 0x35, 0x28, 0x1C, 0x01, 0x21, 0x8E, 0x46, 0xBE, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00, 0x99,
       0x48, 0x80, 0xB1, 0x88, 0x70, 0x88, 0x08, 0x43, 0x40, 0x08, 0x1C, 0xD2, 0x00, 0x98, 0x00, 0x88,
       0x00, 0x28, 0x18, 0xD0, 0x4A, 0x08, 0x90, 0x42, 0x15, 0xDC, 0x08, 0x29, 0x10, 0xDB, 0xB2, 0x48,
       0xB1, 0x49, 0x40, 0x18, 0x38, 0x62, 0x60, 0x7E, 0x00, 0x28, 0x10, 0xD0, 0x26, 0x20, 0x00, 0x5D,
       0x04, 0x28, 0x0C, 0xDA, 0x20, 0x22, 0x11, 0x5D, 0xF7, 0x20, 0x08, 0x40, 0x10, 0x55, 0xF8, 0xBD,
       0xAA, 0x48, 0x12, 0x38, 0x00, 0xE0, 0xA9, 0x48, 0xA7, 0x49, 0x40, 0x18, 0x38, 0x62, 0x01, 0x05,
       0xFF, 0xFF, 0x70, 0x6A, 0x08, 0x00, 0xFA, 0xF8, 0xBD, 0xC0, 0x46, 0x25, 0x00, 0x00, 0x00, 0xEF,
       0x22, 0x08, 0x00, 0x5D, 0x8B, 0x04, 0x00, 0x7B, 0x5F, 0x03, 0x00, 0xAB, 0xB9, 0x03, 0x00, 0xBF,
       0x70, 0x05, 0x00, 0x76, 0x81, 0x00, 0x00, 0x05, 0x63, 0x08, 0x00, 0x60, 0x19, 0x08, 0x00, 0x10,
       0x27, 0x00, 0x00, 0xCC, 0x24, 0x08, 0x00, 0x2C, 0x51, 0x08, 0x00, 0x2D, 0x61, 0x04, 0x00, 0xE9,
       0x3F, 0x05, 0x00, 0x5B, 0xF5, 0x00, 0x00, 0xBB, 0x16, 0x04, 0x00, 0xF8, 0xB5, 0xDF, 0x4F, 0x97,
       0x48, 0x00, 0x78, 0x02, 0x28, 0x0C, 0xD1, 0x01, 0x24, 0xA6, 0x46, 0xDC, 0x48, 0xFE, 0x44, 0x00,
       0x47, 0xA6, 0x46, 0xDB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0xDA, 0x48, 0xFE, 0x44, 0x00,
       0x47, 0x01, 0x24, 0xA6, 0x46, 0xD9, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0xD8, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0xA6, 0x46, 0xD7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x23, 0x4E, 0x00, 0x25, 0x00,
       0x95, 0x38, 0x20, 0x80, 0x5D, 0x0C, 0x28, 0x25, 0xD1, 0xF0, 0x78, 0x00, 0x28, 0x04, 0xD0, 0x3A,
       0x20, 0x80, 0x5D, 0x0E, 0x28, 0x00, 0xD1, 0x00, 0x94, 0x3B, 0x20, 0x81, 0x5D, 0x3C, 0x20, 0x80,
       0x5D, 0x08, 0x43, 0x17, 0xD1, 0xFF, 0x20, 0x6D, 0x30, 0x80, 0x19, 0xA6, 0x46, 0xCA, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x00, 0x28, 0x0E, 0xD0, 0x04, 0x20, 0xA6, 0x46, 0xC7, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x28, 0x07, 0xD0, 0xC5, 0x80, 0x35, 0x21, 0x09, 0x02, 0x01, 0x80, 0xA6, 0x46, 0xC3,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x11, 0x20, 0x40, 0x01, 0x86, 0x19, 0x01, 0x35, 0x07, 0x2D, 0xCF,
       0xD3, 0x00, 0x98, 0x00, 0x28, 0x03, 0xD1, 0x39, 0x78, 0xDF, 0x20, 0x08, 0x40, 0x02, 0xE0, 0x39,
       0x78, 0x01, 0x05, 0xFF, 0xFF, 0x6A, 0x6B, 0x08, 0x00, 0xFA, 0x20, 0x20, 0x08, 0x43, 0x38, 0x70,
       0xBA, 0x48, 0x07, 0x68, 0xBA, 0x49, 0xFF, 0x22, 0x3D, 0x32, 0x56, 0x18, 0xEB, 0x4A, 0x53, 0x5C,
       0x00, 0x25, 0x26, 0xE0, 0x00, 0x00, 0x08, 0x00, 0xA8, 0x00, 0x32, 0x58, 0xB5, 0x20, 0x81, 0x5C,
       0xE7, 0x48, 0x88, 0x40, 0x07, 0x42, 0x1B, 0xD0, 0xC5, 0x20, 0x80, 0x5C, 0x00, 0x28, 0x17, 0xD1,
       0x50, 0x8D, 0x06, 0x21, 0x41, 0x43, 0x06, 0x31, 0x10, 0x8F, 0x88, 0x42, 0x10, 0xDA, 0x04, 0x20,
       0xA6, 0x46, 0xEC, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x43, 0x21, 0x49, 0x02, 0x01, 0x80, 0xC5, 0x80,
       0xA6, 0x46, 0xA5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xA4, 0x48, 0x07, 0x68, 0xE6, 0x48, 0x03, 0x78,
       0x01, 0x35, 0x9D, 0x42, 0xD8, 0xD3, 0xF8, 0xBD, 0xD5, 0xB4, 0x02, 0x00, 0x84, 0x26, 0x08, 0x00,
       0x17, 0x8C, 0x04, 0x00, 0x69, 0x63, 0x08, 0x00, 0x10, 0xB5, 0x92, 0x4B, 0x15, 0x3B, 0xDF, 0x48,
       0x00, 0x78, 0x19, 0x78, 0x81, 0x42, 0x0D, 0xDD, 0x07, 0x21, 0xDD, 0x48, 0x00, 0x22, 0x40, 0x24,
       0x24, 0x5C, 0x00, 0x2C, 0x02, 0xD0, 0x52, 0x1C, 0x12, 0x06, 0x12, 0x0E, 0xA8, 0x30, 0x01, 0x39,
       0xF5, 0xD1, 0x1A, 0x70, 0x10, 0xBD, 0xC0, 0x46, 0x5D, 0xF0, 0x03, 0x00, 0xF0, 0xB5, 0x01, 0x24,
       0xA6, 0x46, 0x37, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA6, 0x46, 0x36, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x00, 0x28, 0x10, 0xD0, 0x11, 0x27, 0x09, 0x26, 0xE8, 0x4D, 0x3E, 0x20, 0x40, 0x5D, 0xFF, 0x28,
       0x06, 0xD0, 0x3B, 0x20, 0x47, 0x55, 0x28, 0x1C, 0xA6, 0x46, 0xE5, 0x49, 0xFE, 0x44, 0x08, 0x47,
       0x50, 0x35, 0x01, 0x3E, 0xF1, 0xD1, 0xF0, 0xBD, 0x55, 0xF6, 0x00, 0x00, 0x00, 0xB5, 0xE1, 0x48,
       0x00, 0x88, 0x02, 0x28, 0x01, 0x05, 0xFF, 0xFF, 0x64, 0x6C, 0x08, 0x00, 0xFA, 0x01, 0xDA, 0x01,
       0x21, 0x02, 0xE0, 0x40, 0x1E, 0x01, 0x04, 0x09, 0x0C, 0xDD, 0x48, 0x00, 0x22, 0x01, 0x23, 0x9E,
       0x46, 0xDC, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x00, 0xBD, 0x6A, 0x63, 0x08, 0x00, 0xB4, 0x8A, 0x06,
       0x00, 0x61, 0x97, 0x04, 0x00, 0x28, 0x19, 0x08, 0x00, 0x57, 0x98, 0x04, 0x00, 0xF0, 0xB5, 0xA4,
       0xB0, 0x06, 0x1C, 0x31, 0x7C, 0x75, 0x69, 0xA8, 0x7C, 0x00, 0x28, 0x03, 0xD1, 0x28, 0x68, 0xC0,
       0x78, 0x00, 0x28, 0x25, 0xD1, 0x04, 0x29, 0x23, 0xD1, 0x28, 0x68, 0x01, 0x78, 0x1B, 0x20, 0x01,
       0x24, 0xA6, 0x46, 0xCD, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x06, 0x09, 0x0E, 0x68, 0x46, 0xA6,
       0x46, 0xCA, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x12, 0x21, 0x4F, 0x19, 0x01, 0x06, 0x09, 0x0E, 0x68,
       0x46, 0x3A, 0x1C, 0xA6, 0x46, 0xC6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE8, 0x74, 0x05, 0x48, 0x39,
       0x1C, 0xA6, 0x46, 0xC4, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x01, 0xD0, 0x02, 0x20, 0x30,
       0x61, 0x24, 0xB0, 0xF0, 0xBD, 0x70, 0x63, 0x08, 0x00, 0x37, 0x98, 0x01, 0x00, 0x37, 0x9B, 0x01,
       0x00, 0x0D, 0xE2, 0x00, 0x00, 0xDC, 0x0C, 0x00, 0x00, 0x3A, 0x0E, 0x00, 0x00, 0x73, 0x2C, 0x00,
       0x00, 0x41, 0x10, 0x08, 0x00, 0xFF, 0xB5, 0x00, 0x90, 0xB7, 0x48, 0x06, 0x1C, 0x32, 0x3E, 0x60,
       0x21, 0x89, 0x19, 0x00, 0x78, 0x0A, 0x78, 0x00, 0x2A, 0x75, 0xD0, 0x09, 0x7B, 0x00, 0x29, 0x72,
       0xD1, 0xFF, 0x28, 0x5F, 0xD1, 0x34, 0x1C, 0xB1, 0x48, 0x05, 0x1C, 0x01, 0x95, 0xB0, 0x48, 0x02,
       0x90, 0x00, 0x27, 0xE1, 0x88, 0xAD, 0x48, 0x81, 0x42, 0x2B, 0xD0, 0xA9, 0x42, 0x15, 0xDB, 0xA9,
       0x42, 0x27, 0xD1, 0xAB, 0x49, 0x78, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x5E, 0x6D, 0x08, 0x00, 0xFA,
       0x30, 0x18, 0x4C, 0x22, 0x10, 0x5A, 0x08, 0x1A, 0x01, 0x22, 0x96, 0x46, 0xA8, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x01, 0x04, 0x09, 0x0C, 0x20, 0x89, 0x09, 0x18, 0x01, 0x9A, 0x02, 0x98, 0x10, 0x18,
       0x81, 0x42, 0x13, 0xD2, 0xE5, 0x88, 0x20, 0x89, 0x01, 0x90, 0x38, 0x06, 0x00, 0x0E, 0x03, 0x90,
       0x9E, 0x49, 0x40, 0x00, 0x30, 0x18, 0x4C, 0x22, 0x10, 0x5A, 0x08, 0x1A, 0x01, 0x22, 0x96, 0x46,
       0x9B, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x04, 0x00, 0x0C, 0x02, 0x90, 0x10, 0x34, 0x01, 0x37,
       0x03, 0x2F, 0xCB, 0xDB, 0x94, 0x48, 0x01, 0x99, 0x81, 0x42, 0x1A, 0xD0, 0x02, 0x2D, 0x09, 0xDA,
       0x03, 0x98, 0x01, 0x99, 0x00, 0x22, 0xD2, 0x43, 0x01, 0x23, 0x9E, 0x46, 0x91, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x2A, 0xE0, 0x03, 0x98, 0x01, 0x1C, 0x09, 0x01, 0x71, 0x58, 0x69, 0x18, 0x01, 0x39,
       0x89, 0x01, 0x8A, 0x09, 0x01, 0x99, 0x01, 0x23, 0x9E, 0x46, 0x89, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x1B, 0xE0, 0x01, 0x20, 0x86, 0x46, 0x87, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x15, 0xE0, 0x1C, 0x21,
       0x41, 0x43, 0x70, 0x18, 0x89, 0x21, 0x08, 0x5C, 0x00, 0x01, 0x30, 0x18, 0x01, 0x89, 0x03, 0x20,
       0x00, 0x22, 0xD2, 0x43, 0x01, 0x23, 0x9E, 0x46, 0x7E, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x04, 0xE0,
       0x01, 0x20, 0x86, 0x46, 0x7D, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x7C, 0x49, 0xCE, 0x31, 0x00, 0x98,
       0x01, 0x62, 0x00, 0x90, 0xFF, 0xBD, 0xD4, 0x0F, 0x08, 0x00, 0x53, 0x63, 0x05, 0x00, 0xAD, 0x98,
       0x02, 0x00, 0x15, 0x7E, 0x04, 0x00, 0x1D, 0x6C, 0x08, 0x00, 0x5D, 0x6C, 0x08, 0x00, 0xE9, 0x6B,
       0x08, 0x00, 0xF7, 0x64, 0x04, 0x00, 0x9B, 0x60, 0x04, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0x58, 0x6E,
       0x08, 0x00, 0xFA, 0xDB, 0x3F, 0x05, 0x00, 0x7C, 0x63, 0x08, 0x00, 0x48, 0x25, 0x08, 0x00, 0xF8,
       0xB5, 0x00, 0x90, 0x65, 0x4A, 0x32, 0x3A, 0x54, 0x20, 0x86, 0x18, 0x21, 0x20, 0xC0, 0x43, 0x80,
       0x5D, 0x1C, 0x21, 0x41, 0x43, 0x8C, 0x18, 0x88, 0x34, 0x70, 0x78, 0x68, 0x49, 0x82, 0x07, 0x4A,
       0xD1, 0x40, 0x06, 0x80, 0x0F, 0x06, 0xD1, 0x20, 0x78, 0x02, 0x28, 0x03, 0xD0, 0xB0, 0x88, 0x62,
       0x4A, 0x02, 0x42, 0x40, 0xD0, 0x08, 0x78, 0x31, 0x7E, 0x00, 0x29, 0x06, 0xD1, 0x00, 0x21, 0x31,
       0x73, 0x40, 0x1C, 0x00, 0x06, 0x00, 0x0E, 0x5D, 0x49, 0x08, 0x70, 0x0A, 0x28, 0x35, 0xDD, 0x5C,
       0x4F, 0x37, 0x20, 0xC0, 0x5D, 0xC0, 0x08, 0x15, 0xD3, 0x02, 0x20, 0x01, 0x25, 0xAE, 0x46, 0x59,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x02, 0x20, 0x58, 0x49, 0x08, 0x70, 0xAE, 0x46, 0x58, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x60, 0x68, 0x14, 0x21, 0x41, 0x43, 0x78, 0x18, 0x00, 0x7B, 0xAE, 0x46, 0x54,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x01, 0x25, 0x53, 0x4F, 0x3D, 0x80, 0x2C, 0x1C, 0xAE, 0x46, 0x52,
       0x48, 0xFE, 0x44, 0x00, 0x47, 0x3D, 0x80, 0xAE, 0x46, 0x50, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x35,
       0x73, 0x47, 0x49, 0x00, 0x20, 0x08, 0x70, 0x03, 0x20, 0xB9, 0x21, 0xC9, 0x00, 0xA6, 0x46, 0x4C,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0xE0, 0x00, 0x20, 0x08, 0x70, 0x48, 0x49, 0xBE, 0x31, 0x00,
       0x98, 0x01, 0x62, 0xF8, 0xBD, 0xC0, 0x46, 0x6A, 0x0A, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x10,
       0xB5, 0x04, 0x1C, 0x00, 0x20, 0x01, 0x21, 0x8E, 0x46, 0x43, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x40,
       0x1C, 0x03, 0xD1, 0x41, 0x48, 0xFF, 0x30, 0x5F, 0x30, 0x20, 0x62, 0x10, 0xBD, 0x01, 0x05, 0xFF,
       0xFF, 0x52, 0x6F, 0x08, 0x00, 0xFA, 0x00, 0x7C, 0x14, 0x28, 0x01, 0xD0, 0x00, 0x20, 0x00, 0xE0,
       0x03, 0x20, 0x3D, 0x49, 0x08, 0x80, 0xF7, 0x46, 0x75, 0x60, 0x04, 0x00, 0xB2, 0x2F, 0x08, 0x00,
       0x83, 0x50, 0x08, 0x00, 0x60, 0x19, 0x08, 0x00, 0xF0, 0xB5, 0x87, 0x69, 0xC1, 0x69, 0x00, 0x29,
       0x2D, 0xD0, 0x09, 0x88, 0xC9, 0x1E, 0x07, 0xD0, 0x26, 0x4A, 0x10, 0x3A, 0x89, 0x1A, 0x01, 0xD0,
       0x00, 0x21, 0x06, 0xE0, 0x01, 0x21, 0x01, 0xE0, 0x01, 0x21, 0x09, 0x04, 0xB5, 0x22, 0xD2, 0x5D,
       0x91, 0x40, 0x2F, 0x4C, 0x22, 0x68, 0x2F, 0x4D, 0x11, 0x42, 0x04, 0xD0, 0x07, 0x60, 0x2B, 0x1C,
       0xFF, 0x33, 0x13, 0x33, 0x03, 0x62, 0x00, 0x29, 0x11, 0xD0, 0x7B, 0x8D, 0x06, 0x26, 0x5E, 0x43,
       0x26, 0x4B, 0x9B, 0x1B, 0x3E, 0x8F, 0x9E, 0x42, 0x02, 0xDA, 0x8A, 0x43, 0x22, 0x60, 0xF0, 0xBD,
       0x0A, 0x43, 0x22, 0x60, 0x00, 0x21, 0x81, 0x60, 0xFF, 0x35, 0x0B, 0x35, 0x05, 0x62, 0xF0, 0xBD,
       0xF4, 0x46, 0x08, 0x00, 0xA5, 0x1E, 0x02, 0x00, 0x8C, 0x18, 0x08, 0x00, 0x36, 0x02, 0x1A, 0x00,
       0x15, 0x49, 0x05, 0x00, 0xA7, 0x31, 0x05, 0x00, 0x0D, 0x9E, 0x01, 0x00, 0xF7, 0x64, 0x01, 0x00,
       0x81, 0x8A, 0x02, 0x00, 0x26, 0x23, 0x08, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xE2, 0x04, 0x00, 0x00,
       0x6D, 0x94, 0x05, 0x00, 0x81, 0xA3, 0x02, 0x00, 0xEB, 0xA3, 0x02, 0x00, 0x4F, 0xA3, 0x02, 0x00,
       0x65, 0xAD, 0x02, 0x00, 0x20, 0x20, 0x00, 0x00, 0xFC, 0x62, 0x08, 0x00, 0xC0, 0x17, 0x08, 0x00,
       0x59, 0xA9, 0x03, 0x00, 0xEA, 0x51, 0x08, 0x00, 0x05, 0x64, 0x05, 0x00, 0xFB, 0xA1, 0x02, 0x00,
       0x82, 0x07, 0x1A, 0x00, 0xF1, 0x16, 0x04, 0x00, 0x59, 0xAA, 0x02, 0x00, 0xF5, 0xD3, 0x04, 0x00,
       0x01, 0x05, 0xFF, 0xFF, 0x4C, 0x70, 0x08, 0x00, 0xFA, 0x49, 0xA3, 0x00, 0x00, 0x8D, 0x7E, 0x00,
       0x00, 0x46, 0x24, 0x19, 0x00, 0xF9, 0xFF, 0x00, 0x00, 0x7C, 0x63, 0x08, 0x00, 0x17, 0x8C, 0x04,
       0x00, 0x40, 0x1E, 0x80, 0x00, 0xE5, 0x4B, 0x19, 0x50, 0xE3, 0x49, 0x0A, 0x50, 0xF7, 0x46, 0x80,
       0x69, 0xB8, 0x21, 0x09, 0x5C, 0x01, 0x29, 0x06, 0xD0, 0xB5, 0x21, 0x08, 0x5C, 0x60, 0x21, 0x41,
       0x43, 0xDF, 0x4A, 0x00, 0x20, 0x50, 0x54, 0xDF, 0x48, 0x1B, 0x30, 0xF7, 0x46, 0x10, 0xB5, 0x04,
       0x1C, 0xDD, 0x48, 0x00, 0x68, 0x01, 0x21, 0x8E, 0x46, 0xDC, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xE0,
       0x68, 0x0C, 0x30, 0xE0, 0x60, 0xDA, 0x48, 0xFF, 0x30, 0x02, 0x30, 0x10, 0xBD, 0x10, 0xB5, 0x43,
       0x69, 0x19, 0x88, 0x09, 0x06, 0x09, 0x0E, 0xD7, 0x4A, 0x02, 0x29, 0x02, 0xD0, 0x10, 0x1C, 0x87,
       0x30, 0x10, 0xBD, 0xD1, 0x49, 0x09, 0x6B, 0x89, 0x68, 0xC9, 0x88, 0x09, 0x05, 0x0C, 0x0D, 0xA1,
       0x0A, 0x06, 0xD0, 0xE3, 0x49, 0x1E, 0x31, 0x8C, 0x42, 0x02, 0xD8, 0x59, 0x88, 0x01, 0x31, 0x01,
       0xE0, 0xD9, 0x88, 0x05, 0x31, 0x41, 0x60, 0x10, 0x1C, 0x9F, 0x30, 0x10, 0xBD, 0x00, 0xB5, 0x01,
       0x1C, 0x48, 0x68, 0xC9, 0x69, 0xB5, 0x22, 0x51, 0x5C, 0xDC, 0x22, 0x4A, 0x43, 0xE7, 0x49, 0x89,
       0x18, 0x08, 0x22, 0x01, 0x23, 0x9E, 0x46, 0xE6, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE5, 0x48, 0x3F,
       0x30, 0x00, 0xBD, 0x40, 0x69, 0x01, 0x8F, 0xC0, 0x8E, 0x40, 0x1A, 0x00, 0x04, 0x01, 0x0C, 0xE4,
       0x48, 0x40, 0x0A, 0x81, 0x42, 0x02, 0xD3, 0xE3, 0x48, 0xFB, 0x38, 0x00, 0xE0, 0xDF, 0x48, 0xDE,
       0x49, 0x40, 0x18, 0xF7, 0x46, 0xF0, 0xB5, 0x82, 0x69, 0x16, 0x04, 0x36, 0x0C, 0x04, 0x21, 0x11,
       0x40, 0x08, 0x20, 0x01, 0x05, 0xFF, 0xFF, 0x46, 0x71, 0x08, 0x00, 0xFA, 0x10, 0x40, 0x08, 0x43,
       0x28, 0xD0, 0xDC, 0x48, 0x04, 0x38, 0xFF, 0x21, 0x3D, 0x31, 0x0F, 0x18, 0xD9, 0x49, 0x08, 0x5C,
       0x00, 0x24, 0x1D, 0xE0, 0xA0, 0x00, 0x3D, 0x58, 0xC2, 0x20, 0x40, 0x5D, 0x00, 0x28, 0x14, 0xD0,
       0xF0, 0x08, 0x06, 0xD3, 0xB5, 0x20, 0x40, 0x5D, 0x01, 0x21, 0x8E, 0x46, 0xDF, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x30, 0x09, 0x09, 0xD3, 0xB5, 0x20, 0x40, 0x5D, 0x0A, 0x30, 0x00, 0x06, 0x00, 0x0E,
       0x01, 0x21, 0x8E, 0x46, 0xD9, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x01, 0x34, 0xE5, 0x48, 0x00, 0x78,
       0x84, 0x42, 0xDF, 0xD3, 0xE4, 0x48, 0x87, 0x30, 0xF0, 0xBD, 0x70, 0xB5, 0x06, 0x1C, 0xB0, 0x68,
       0xE2, 0x4D, 0x00, 0x28, 0x02, 0xD1, 0x28, 0x1C, 0xDF, 0x30, 0x70, 0xBD, 0x95, 0x4C, 0x04, 0x3C,
       0x20, 0x7A, 0x02, 0x28, 0x08, 0xD0, 0xE5, 0x49, 0x08, 0x5C, 0x01, 0x21, 0x8E, 0x46, 0xE4, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x00, 0x28, 0x02, 0xD0, 0x28, 0x1C, 0xCF, 0x30, 0x70, 0xBD, 0x00, 0x20,
       0x20, 0x60, 0x70, 0x60, 0x28, 0x1C, 0xFF, 0x30, 0x20, 0x30, 0x70, 0xBD, 0x10, 0xB5, 0xAD, 0x49,
       0x11, 0x31, 0x06, 0x22, 0x00, 0x23, 0x0C, 0x78, 0xFF, 0x2C, 0x02, 0xD1, 0x5B, 0x1C, 0x1B, 0x06,
       0x1B, 0x0E, 0xDC, 0x31, 0x01, 0x3A, 0xF6, 0xD1, 0x43, 0x60, 0xE7, 0x48, 0x19, 0x30, 0x10, 0xBD,
       0x01, 0x1C, 0xE6, 0x4B, 0x1A, 0x78, 0xE6, 0x48, 0x05, 0x2A, 0x04, 0xD1, 0xE6, 0x4A, 0x12, 0x68,
       0x12, 0x78, 0x01, 0x2A, 0x02, 0xD0, 0x4B, 0x60, 0x5B, 0x30, 0xF7, 0x46, 0x7D, 0x30, 0xF7, 0x46,
       0x10, 0xB5, 0x01, 0x1C, 0xEB, 0x48, 0x00, 0x68, 0xEC, 0x4C, 0x00, 0x28, 0x0B, 0xD0, 0x88, 0x69,
       0x09, 0x7A, 0x01, 0x22, 0x96, 0x46, 0x01, 0x05, 0xFF, 0xFF, 0x40, 0x72, 0x08, 0x00, 0xFA, 0xE7,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x02, 0xD0, 0x20, 0x1C, 0x21, 0x30, 0x10, 0xBD, 0x20,
       0x1C, 0x33, 0x30, 0x10, 0xBD, 0xF8, 0xB5, 0x81, 0x69, 0x00, 0x91, 0xDF, 0x4C, 0x25, 0x1C, 0x0C,
       0x3D, 0xE9, 0x68, 0x08, 0x22, 0x57, 0x18, 0x40, 0x69, 0xDE, 0x4A, 0x00, 0x28, 0x02, 0xD0, 0x10,
       0x1C, 0xD3, 0x30, 0xF8, 0xBD, 0x00, 0x26, 0x04, 0xE0, 0x70, 0x1C, 0x06, 0x06, 0x36, 0x0E, 0x06,
       0x37, 0x21, 0x68, 0x48, 0x88, 0x86, 0x42, 0x14, 0xDA, 0x38, 0x1C, 0x00, 0x99, 0x01, 0x22, 0x96,
       0x46, 0xD5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0xEE, 0xD1, 0x0C, 0x34, 0xE8, 0x68, 0x41,
       0x88, 0x01, 0x20, 0x88, 0x40, 0xE1, 0x6F, 0x81, 0x43, 0xE1, 0x67, 0xE9, 0x68, 0x48, 0x88, 0x01,
       0x38, 0x48, 0x80, 0xCB, 0x48, 0xFF, 0x30, 0x14, 0x30, 0xF8, 0xBD, 0x01, 0x1C, 0xCC, 0x48, 0x02,
       0x78, 0xCA, 0x48, 0x00, 0x2A, 0x01, 0xD0, 0xED, 0x30, 0xF7, 0x46, 0x41, 0x22, 0x4A, 0x60, 0x39,
       0x30, 0xF7, 0x46, 0xF8, 0xB5, 0x06, 0x1C, 0x75, 0x69, 0xB7, 0x69, 0x31, 0x6A, 0x30, 0x7F, 0x00,
       0x28, 0x2D, 0xD1, 0x01, 0x21, 0xA8, 0x8D, 0x18, 0x28, 0x27, 0xDC, 0xC4, 0x48, 0x00, 0x78, 0x00,
       0x90, 0x00, 0x24, 0x01, 0x22, 0xA2, 0x40, 0x00, 0x98, 0x10, 0x42, 0x1B, 0xD0, 0xBD, 0x48, 0x20,
       0x5C, 0x11, 0x21, 0x49, 0x01, 0x41, 0x43, 0xBB, 0x48, 0x41, 0x18, 0xFF, 0x20, 0x1E, 0x30, 0x40,
       0x5C, 0x01, 0x28, 0x01, 0xD1, 0x02, 0x20, 0x00, 0xE0, 0x00, 0x20, 0xC9, 0x78, 0x08, 0x18, 0xB8,
       0x49, 0x08, 0x5C, 0xA9, 0x8D, 0x01, 0x22, 0x96, 0x46, 0xE9, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x48,
       0x1C, 0x01, 0x06, 0x09, 0x0E, 0x01, 0x34, 0x07, 0x2C, 0x01, 0x05, 0xFF, 0xFF, 0x3A, 0x73, 0x08,
       0x00, 0xFA, 0xDB, 0xDB, 0xA8, 0x8D, 0x01, 0xE0, 0x48, 0x7D, 0xA9, 0x8D, 0x48, 0x43, 0x39, 0x68,
       0x40, 0x18, 0x80, 0x01, 0x80, 0x09, 0x38, 0x60, 0x70, 0x60, 0xAA, 0x48, 0x5D, 0x30, 0xF8, 0xBD,
       0x01, 0x1C, 0x4A, 0x68, 0x13, 0x06, 0x1B, 0x0E, 0xA9, 0x48, 0x03, 0xD1, 0x90, 0x4B, 0x1B, 0x78,
       0x03, 0x2B, 0x05, 0xD0, 0x00, 0x2A, 0x01, 0xD0, 0x1D, 0x30, 0xF7, 0x46, 0xFF, 0x30, 0xF7, 0x46,
       0x97, 0x4A, 0x30, 0x23, 0x9B, 0x5C, 0x00, 0x2B, 0x07, 0xD1, 0x94, 0x4B, 0x92, 0x88, 0x9A, 0x42,
       0x03, 0xD1, 0xA0, 0x4A, 0x12, 0x78, 0x00, 0x2A, 0x01, 0xD0, 0x00, 0x22, 0x00, 0xE0, 0x07, 0x22,
       0x4A, 0x60, 0xFF, 0x30, 0xA2, 0x30, 0xF7, 0x46, 0x40, 0x69, 0x78, 0x21, 0x09, 0x5A, 0x9A, 0x48,
       0xAC, 0x29, 0x01, 0xDA, 0x3B, 0x30, 0xF7, 0x46, 0x89, 0x30, 0xF7, 0x46, 0x01, 0x1C, 0x7C, 0x48,
       0x02, 0x78, 0xF0, 0x48, 0x05, 0x2A, 0x07, 0xD1, 0x20, 0x22, 0x51, 0x5C, 0x01, 0x29, 0x03, 0xD1,
       0xEB, 0x49, 0x09, 0x78, 0x49, 0x08, 0x01, 0xD2, 0x8F, 0x30, 0xF7, 0x46, 0x85, 0x30, 0xF7, 0x46,
       0xE9, 0x48, 0x59, 0x30, 0xF7, 0x46, 0xE9, 0x48, 0x67, 0x30, 0xF7, 0x46, 0xC1, 0x69, 0x82, 0x69,
       0x51, 0x1A, 0x01, 0x61, 0xE6, 0x48, 0x73, 0x30, 0xF7, 0x46, 0x00, 0x21, 0x41, 0x60, 0xE5, 0x48,
       0xA1, 0x30, 0xF7, 0x46, 0x04, 0xF3, 0x1A, 0x00, 0x80, 0x7B, 0x08, 0x00, 0x76, 0xA0, 0x1B, 0x00,
       0x6D, 0x97, 0x00, 0x00, 0x6C, 0x55, 0x08, 0x00, 0x4F, 0x61, 0x04, 0x00, 0x39, 0xC1, 0x02, 0x00,
       0x7D, 0xC4, 0x02, 0x00, 0x81, 0xB0, 0x00, 0x90, 0x00, 0x21, 0x68, 0x46, 0x42, 0x88, 0x03, 0x88,
       0x93, 0x42, 0x03, 0xD1, 0x02, 0x78, 0x40, 0x78, 0x90, 0x42, 0x0F, 0xD0, 0x01, 0x05, 0xFF, 0xFF,
       0x34, 0x74, 0x08, 0x00, 0xFA, 0x00, 0x98, 0xC3, 0x0F, 0x1E, 0x20, 0x00, 0x9A, 0xC2, 0x40, 0xD2,
       0x07, 0xD2, 0x0F, 0x93, 0x42, 0x00, 0xD0, 0x01, 0x31, 0x18, 0x29, 0x03, 0xD8, 0x1A, 0x28, 0x03,
       0xD1, 0x02, 0x29, 0x01, 0xD2, 0x00, 0x20, 0x03, 0xE0, 0x13, 0x1C, 0x01, 0x38, 0xED, 0xD5, 0x01,
       0x20, 0x01, 0xB0, 0xF7, 0x46, 0xE1, 0x04, 0x00, 0x00, 0xF0, 0xB5, 0x06, 0x1C, 0x77, 0x68, 0x0A,
       0x25, 0x05, 0xE0, 0xA6, 0x46, 0xF2, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x07, 0x1C, 0x01, 0x3D, 0x00,
       0x2D, 0x07, 0xD0, 0x38, 0x1C, 0x01, 0x24, 0xA6, 0x46, 0xF5, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x00,
       0x28, 0xEF, 0xD0, 0x77, 0x60, 0xF0, 0x69, 0xB0, 0x60, 0xF2, 0x48, 0xFF, 0x30, 0x34, 0x30, 0xF0,
       0xBD, 0x5C, 0x27, 0x08, 0x00, 0x4B, 0x1E, 0x04, 0x00, 0x05, 0x5E, 0x02, 0x00, 0xC9, 0x98, 0x00,
       0x00, 0x83, 0x05, 0x00, 0x00, 0xF0, 0xFF, 0xFF, 0x00, 0xE2, 0x04, 0x00, 0x00, 0x6A, 0x0A, 0x00,
       0x00, 0x4C, 0x25, 0x08, 0x00, 0x10, 0xB5, 0x44, 0x68, 0x3A, 0x20, 0x00, 0x5D, 0x22, 0x28, 0x06,
       0xD1, 0x20, 0x1C, 0x00, 0x21, 0x01, 0x22, 0x96, 0x46, 0xE9, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x20,
       0x1C, 0x00, 0x21, 0x01, 0x22, 0x96, 0x46, 0xF5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xF4, 0x48, 0x6F,
       0x30, 0x10, 0xBD, 0xC0, 0x46, 0x47, 0x93, 0x02, 0x00, 0x30, 0xB5, 0x04, 0x1C, 0x2A, 0x48, 0xBF,
       0x38, 0x01, 0x78, 0x02, 0x29, 0x01, 0xD1, 0x00, 0x21, 0x01, 0x70, 0xEE, 0x49, 0xEE, 0x48, 0x42,
       0x1C, 0x1D, 0x20, 0x00, 0x23, 0x01, 0x25, 0xAE, 0x46, 0xEC, 0x4D, 0xFE, 0x44, 0x28, 0x47, 0x60,
       0x69, 0x00, 0x68, 0x60, 0x60, 0xEA, 0x48, 0xFF, 0x30, 0x3A, 0x30, 0x30, 0xBD, 0xB2, 0x2F, 0x01,
       0x05, 0xFF, 0xFF, 0x2E, 0x75, 0x08, 0x00, 0xFA, 0x08, 0x00, 0x49, 0xA0, 0x02, 0x00, 0x25, 0x6E,
       0x03, 0x00, 0x10, 0xB5, 0xE6, 0x49, 0xE4, 0x4A, 0xFF, 0x32, 0x38, 0x32, 0x1D, 0x20, 0x00, 0x23,
       0x01, 0x24, 0xA6, 0x46, 0xE0, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0xDD, 0x48, 0xC0, 0x1D, 0x10, 0xBD,
       0xC0, 0x46, 0x3C, 0x91, 0x06, 0x00, 0x17, 0x62, 0x04, 0x00, 0xF0, 0xB5, 0x9C, 0x46, 0x1B, 0x4C,
       0x0E, 0x1C, 0x26, 0x40, 0x05, 0x1C, 0x25, 0x40, 0x2F, 0x1C, 0x77, 0x43, 0x09, 0x0C, 0x00, 0x0C,
       0x03, 0x1C, 0x4B, 0x43, 0x69, 0x43, 0x70, 0x43, 0x05, 0x1C, 0x25, 0x40, 0x0C, 0x40, 0x64, 0x19,
       0x00, 0x0C, 0x09, 0x0C, 0x08, 0x18, 0x39, 0x0C, 0x61, 0x18, 0x09, 0x0C, 0x00, 0xD0, 0x01, 0x30,
       0x21, 0x04, 0xCF, 0x19, 0xC3, 0x18, 0x60, 0x46, 0x07, 0x60, 0x13, 0x60, 0xF0, 0xBD, 0xEF, 0x8A,
       0x04, 0x00, 0x41, 0x10, 0x08, 0x00, 0xD9, 0xAE, 0x02, 0x00, 0xF4, 0x62, 0x08, 0x00, 0x1C, 0xB5,
       0xE1, 0x49, 0x6A, 0x46, 0x01, 0xAB, 0x01, 0x24, 0xA6, 0x46, 0xDF, 0x4C, 0xFE, 0x44, 0x20, 0x47,
       0x01, 0x98, 0xC1, 0x0B, 0x00, 0x98, 0x40, 0x04, 0x08, 0x43, 0x1C, 0xBD, 0xC0, 0x46, 0xFF, 0xFF,
       0x00, 0x00, 0x48, 0x25, 0x08, 0x00, 0xEC, 0x0E, 0x08, 0x00, 0x5D, 0x86, 0x01, 0x00, 0xDD, 0xF8,
       0x03, 0x00, 0x79, 0x1C, 0x04, 0x00, 0xDD, 0x84, 0x01, 0x00, 0x6A, 0x63, 0x08, 0x00, 0x00, 0x16,
       0x08, 0x00, 0x00, 0x00, 0x08, 0x00, 0x09, 0x82, 0x01, 0x00, 0x05, 0x63, 0x08, 0x00, 0x08, 0x63,
       0x08, 0x00, 0xBD, 0x7B, 0x03, 0x00, 0xF5, 0x50, 0x08, 0x00, 0xE5, 0x85, 0x00, 0x00, 0xF0, 0xB5,
       0x8D, 0xB0, 0x03, 0xA8, 0x01, 0x21, 0x8E, 0x46, 0xF0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xF0, 0x48,
       0x06, 0x90, 0x01, 0x05, 0xFF, 0xFF, 0x28, 0x76, 0x08, 0x00, 0xFA, 0x72, 0x38, 0x06, 0x90, 0xEE,
       0x48, 0x07, 0x90, 0x06, 0x38, 0x07, 0x90, 0x38, 0x21, 0x41, 0x80, 0x01, 0x20, 0x86, 0x46, 0xE9,
       0x48, 0xFE, 0x44, 0x00, 0x47, 0x03, 0xA8, 0x08, 0x90, 0x4C, 0x48, 0x09, 0x90, 0x69, 0x38, 0x09,
       0x90, 0x00, 0x20, 0x0A, 0x90, 0x0A, 0x98, 0x00, 0x06, 0x00, 0x0E, 0x0B, 0x90, 0xE3, 0x48, 0x0B,
       0x99, 0x01, 0x22, 0x96, 0x46, 0xE2, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0xF6, 0xD0, 0x08,
       0x98, 0x00, 0x68, 0x09, 0x99, 0x89, 0x6A, 0x01, 0x24, 0xA6, 0x46, 0xDD, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x28, 0x00, 0xD5, 0x40, 0x42, 0xA6, 0x46, 0xDB, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x05,
       0x1C, 0x0B, 0x98, 0x01, 0xA9, 0x02, 0xAA, 0x64, 0x23, 0xA6, 0x46, 0xD7, 0x4E, 0xFE, 0x44, 0x30,
       0x47, 0x68, 0x46, 0x0C, 0x90, 0x00, 0x89, 0x46, 0x1B, 0x15, 0xD5, 0xDB, 0x4F, 0x39, 0x1C, 0x30,
       0x1C, 0xA6, 0x46, 0x07, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x4D, 0x42, 0x30, 0x1C, 0x39, 0x1C, 0xA6,
       0x46, 0xCF, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28, 0x00, 0xD0, 0x01, 0x35, 0x6F, 0x43, 0xBE,
       0x19, 0x02, 0xE0, 0x6D, 0x94, 0x05, 0x00, 0x00, 0x25, 0x01, 0x98, 0x40, 0x1B, 0x80, 0x01, 0x80,
       0x09, 0x0A, 0x99, 0x00, 0x29, 0x2C, 0xD1, 0x01, 0x9A, 0x06, 0x99, 0x4A, 0x60, 0x0C, 0x9A, 0x12,
       0x89, 0xCA, 0x81, 0x08, 0x60, 0x8E, 0x81, 0xC2, 0x4D, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xC7,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x02, 0x20, 0x07, 0x99, 0x08, 0x80, 0xA6, 0x46, 0xBE, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0xA6, 0x46, 0xBC, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xB3, 0x48, 0x04, 0x21, 0xA6,
       0x46, 0xB3, 0x4A, 0xFE, 0x44, 0x01, 0x05, 0xFF, 0xFF, 0x22, 0x77, 0x08, 0x00, 0xFA, 0x10, 0x47,
       0x00, 0x28, 0xF7, 0xD1, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xB6, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0xA6, 0x46, 0xB5, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x0A, 0xE0, 0x0C, 0x9B, 0x0B, 0x99, 0x19, 0x70,
       0x31, 0x04, 0x09, 0x0C, 0x01, 0x9A, 0x1B, 0x89, 0xA6, 0x46, 0xB0, 0x4C, 0xFE, 0x44, 0x20, 0x47,
       0x09, 0x98, 0x04, 0x30, 0x09, 0x90, 0x08, 0x98, 0x04, 0x30, 0x08, 0x90, 0x0A, 0x98, 0x01, 0x30,
       0x0A, 0x90, 0x03, 0x28, 0x00, 0xD2, 0x72, 0xE7, 0xA9, 0x48, 0xFF, 0x30, 0x0C, 0x30, 0x0D, 0xB0,
       0xF0, 0xBD, 0xC0, 0x46, 0x55, 0x53, 0x08, 0x00, 0x37, 0xEB, 0x03, 0x00, 0x3D, 0x68, 0x03, 0x00,
       0xDB, 0xF5, 0x02, 0x00, 0xD1, 0x7A, 0x02, 0x00, 0xC9, 0x9C, 0x03, 0x00, 0x30, 0xB5, 0x40, 0x69,
       0x00, 0x28, 0x1F, 0xD0, 0x00, 0x68, 0x85, 0x08, 0x01, 0x24, 0xA6, 0x46, 0x9F, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x01, 0x1C, 0x28, 0x1C, 0xA6, 0x46, 0x90, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00, 0x28,
       0x00, 0xDA, 0x40, 0x42, 0x03, 0x21, 0x09, 0x02, 0x41, 0x43, 0xC8, 0x0B, 0x28, 0x18, 0x81, 0x00,
       0x99, 0x48, 0x00, 0x88, 0x80, 0x00, 0x08, 0x1A, 0x00, 0x01, 0x00, 0x09, 0xA6, 0x46, 0x94, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0x93, 0x48, 0x45, 0x30, 0x30, 0xBD, 0x70, 0xB5, 0x05, 0x1C, 0xAC, 0x8B,
       0x92, 0x48, 0x84, 0x42, 0x07, 0xD0, 0x68, 0x69, 0x40, 0x30, 0x2C, 0x21, 0x01, 0x22, 0x96, 0x46,
       0x8F, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xE0, 0x1E, 0x91, 0x4C, 0x0E, 0xD0, 0x8D, 0x49, 0x40, 0x1A,
       0x16, 0xD1, 0x8D, 0x49, 0x20, 0x1C, 0x8D, 0x4A, 0x12, 0x18, 0x15, 0x20, 0x00, 0x23, 0x01, 0x26,
       0xB6, 0x46, 0x2D, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x01, 0x05, 0xFF, 0xFF, 0x1C, 0x78, 0x08, 0x00,
       0xFA, 0x0A, 0xE0, 0x8A, 0x49, 0x20, 0x1C, 0x8A, 0x4A, 0x12, 0x18, 0x15, 0x20, 0x00, 0x23, 0x01,
       0x26, 0xB6, 0x46, 0x27, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x40, 0x20, 0x28, 0x62, 0x20, 0x1C, 0x29,
       0x30, 0x70, 0xBD, 0xC0, 0x46, 0xDB, 0xE3, 0x03, 0x00, 0x41, 0x69, 0x49, 0x8D, 0x06, 0x22, 0x4A,
       0x43, 0x06, 0x32, 0x11, 0x04, 0x09, 0x0C, 0x81, 0x60, 0x7B, 0x49, 0x7A, 0x48, 0x0C, 0x30, 0x40,
       0x18, 0xF7, 0x46, 0xC0, 0x46, 0x1D, 0x74, 0x08, 0x00, 0x0B, 0xE2, 0x03, 0x00, 0x41, 0x69, 0x49,
       0x8D, 0x06, 0x22, 0x4A, 0x43, 0x06, 0x32, 0x82, 0x60, 0x73, 0x49, 0x75, 0x48, 0x18, 0x30, 0x40,
       0x18, 0xF7, 0x46, 0xC0, 0x46, 0x8B, 0x96, 0x01, 0x00, 0x30, 0xB5, 0x72, 0x4A, 0x00, 0x28, 0x09,
       0xD0, 0x13, 0x18, 0x84, 0x18, 0xA5, 0x7B, 0x4D, 0x19, 0xA5, 0x73, 0x01, 0x28, 0x02, 0xD9, 0x5C,
       0x7B, 0x0C, 0x19, 0x5C, 0x73, 0x4E, 0x28, 0x09, 0xD2, 0x13, 0x18, 0x82, 0x18, 0x14, 0x7C, 0x0C,
       0x19, 0x14, 0x74, 0x4D, 0x28, 0x02, 0xD2, 0x58, 0x7C, 0x08, 0x18, 0x58, 0x74, 0x30, 0xBD, 0xC0,
       0x46, 0x91, 0xE5, 0x02, 0x00, 0x71, 0xE3, 0x02, 0x00, 0x39, 0x75, 0x08, 0x00, 0xCD, 0x98, 0x01,
       0x00, 0x65, 0x70, 0x08, 0x00, 0x95, 0xF4, 0x03, 0x00, 0xF9, 0x74, 0x08, 0x00, 0xF0, 0xB5, 0x07,
       0x1C, 0x5D, 0x4E, 0x5E, 0x4D, 0x00, 0x24, 0x2A, 0x78, 0x00, 0x2A, 0x1E, 0xD0, 0x6B, 0x20, 0x81,
       0x5D, 0x4B, 0x1C, 0xA0, 0x19, 0xC0, 0x7E, 0x00, 0x07, 0x00, 0x0F, 0x98, 0x42, 0x0B, 0xD0, 0x98,
       0x42, 0x13, 0xDD, 0x50, 0x1C, 0x01, 0x06, 0x09, 0x0E, 0x20, 0x1C, 0x01, 0x22, 0x96, 0x46, 0x54,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x09, 0xE0, 0x50, 0x1C, 0x00, 0x06, 0x01, 0x05, 0xFF, 0xFF, 0x16,
       0x79, 0x08, 0x00, 0xFA, 0x00, 0x0E, 0x41, 0x43, 0x20, 0x1C, 0x01, 0x22, 0x96, 0x46, 0x4E, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x35, 0x01, 0x34, 0x4F, 0x2C, 0xD9, 0xD3, 0x78, 0x68, 0x40, 0x0B,
       0x78, 0x60, 0x4B, 0x48, 0x4A, 0x49, 0x08, 0x18, 0xF0, 0xBD, 0x00, 0xA6, 0x0E, 0x00, 0x61, 0x75,
       0x08, 0x00, 0xF0, 0xB5, 0x85, 0xB0, 0x06, 0x06, 0x36, 0x0E, 0x6C, 0x46, 0x26, 0x70, 0x03, 0x21,
       0x08, 0x1A, 0x60, 0x70, 0x02, 0xA8, 0x04, 0xA9, 0x03, 0xAA, 0x01, 0xAB, 0x01, 0x25, 0xAE, 0x46,
       0x41, 0x4F, 0xFE, 0x44, 0x38, 0x47, 0x35, 0x48, 0xFD, 0x38, 0xA1, 0x89, 0x81, 0x42, 0x03, 0xDB,
       0xA0, 0x89, 0xFF, 0x38, 0x91, 0x38, 0x01, 0xE0, 0xA0, 0x89, 0xC8, 0x30, 0xA0, 0x80, 0x6B, 0x46,
       0x1E, 0x70, 0x02, 0x98, 0x99, 0x88, 0x04, 0x9A, 0x9B, 0x89, 0xAE, 0x46, 0x20, 0x4C, 0xFE, 0x44,
       0x20, 0x47, 0x05, 0xB0, 0xF0, 0xBD, 0x70, 0xB5, 0x34, 0x48, 0x00, 0x78, 0x01, 0x24, 0xA6, 0x46,
       0x33, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x32, 0x4D, 0x28, 0x78, 0x00, 0x28, 0x09, 0xD1, 0x31, 0x49,
       0x32, 0x4A, 0xAD, 0x32, 0x0E, 0x20, 0x00, 0x23, 0xA6, 0x46, 0x31, 0x4E, 0xFE, 0x44, 0x30, 0x47,
       0x2C, 0x70, 0x2E, 0x48, 0x67, 0x30, 0x70, 0xBD, 0x00, 0xB5, 0x2E, 0x48, 0x00, 0x78, 0x01, 0x21,
       0x8E, 0x46, 0x26, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x28, 0x48, 0xC1, 0x30, 0x00, 0xBD, 0x87, 0xCA,
       0x04, 0x00, 0xFB, 0x16, 0x04, 0x00, 0x72, 0x61, 0x1A, 0x00, 0x2F, 0x4A, 0x05, 0x00, 0x65, 0xCB,
       0x04, 0x00, 0xB5, 0x75, 0x08, 0x00, 0x9B, 0xC3, 0x03, 0x00, 0x6D, 0x94, 0x05, 0x00, 0x70, 0x61,
       0x1A, 0x00, 0xF1, 0x16, 0x04, 0x00, 0x89, 0x49, 0x05, 0x00, 0xC1, 0xC0, 0x03, 0x00, 0x01, 0x05,
       0xFF, 0xFF, 0x10, 0x7A, 0x08, 0x00, 0xFA, 0x51, 0xC2, 0x03, 0x00, 0xFB, 0xBC, 0x03, 0x00, 0xE2,
       0x04, 0x00, 0x00, 0x61, 0x48, 0x05, 0x00, 0x51, 0xCA, 0x04, 0x00, 0x87, 0x24, 0x04, 0x00, 0x45,
       0x25, 0x04, 0x00, 0x48, 0x53, 0x08, 0x00, 0xD9, 0xFC, 0x00, 0x00, 0x91, 0x1C, 0x04, 0x00, 0x10,
       0x20, 0x00, 0x00, 0x45, 0x78, 0x08, 0x00, 0x6F, 0x03, 0x00, 0x00, 0x51, 0x8C, 0x00, 0x00, 0x69,
       0x78, 0x08, 0x00, 0x0B, 0x05, 0x00, 0x00, 0xD0, 0x11, 0x08, 0x00, 0x50, 0x21, 0x08, 0x00, 0x38,
       0x30, 0x19, 0x00, 0x85, 0x78, 0x08, 0x00, 0x43, 0x02, 0x00, 0x00, 0x8D, 0x42, 0x01, 0x00, 0xA5,
       0xC4, 0x03, 0x00, 0x0C, 0x18, 0x08, 0x00, 0x45, 0x79, 0x08, 0x00, 0x07, 0x63, 0x08, 0x00, 0xCB,
       0x79, 0x08, 0x00, 0x17, 0x38, 0x04, 0x00, 0xD1, 0x8C, 0x03, 0x00, 0x65, 0x70, 0x08, 0x00, 0x5C,
       0x18, 0x08, 0x00, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x10, 0xF8, 0xFF, 0xBD, 0xFF, 0xB5, 0x68,
       0x46, 0xFF, 0xF7, 0x4B, 0xFA, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x1A, 0xFF, 0xFF,
       0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x5B, 0xFF, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF,
       0xF7, 0xEC, 0xF8, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x46, 0xFA, 0xFF, 0xBD, 0xFF,
       0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x52, 0xFA, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0x21,
       0xF9, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFF, 0xF7, 0xC0, 0xF9, 0xFF, 0xBD, 0xFF, 0xB5, 0x68,
       0x46, 0xFE, 0xF7, 0x8D, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xB4, 0xFC, 0xFF,
       0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x69, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE,
       0xF7, 0x01, 0x05, 0xFF, 0x4F, 0x0A, 0x7B, 0x08, 0x00, 0x4A, 0x3A, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5,
       0x68, 0x46, 0xFE, 0xF7, 0x4A, 0xFC, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x38, 0xFD,
       0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0x93, 0xFE, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46,
       0xFE, 0xF7, 0xA6, 0xFE, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xEB, 0xFD, 0xFF, 0xBD,
       0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7, 0xC3, 0xFD, 0xFF, 0xBD, 0xFF, 0xB5, 0x68, 0x46, 0xFE, 0xF7,
       0x19, 0xFE, 0xFF, 0xBD, 0x01, 0x05, 0xFF, 0x8D, 0x78, 0x7B, 0x08, 0x00, 0x88, 0x00, 0xB5, 0xF9,
       0xF0, 0xDB, 0xF8, 0x00, 0xBD, 0xF1, 0x70, 0x08, 0x00, 0x91, 0x70, 0x08, 0x00, 0xB1, 0x70, 0x08,
       0x00, 0x17, 0x71, 0x08, 0x00, 0xDF, 0x77, 0x08, 0x00, 0xFD, 0x02, 0x18, 0x00, 0x73, 0x70, 0x08,
       0x00, 0x39, 0x71, 0x08, 0x00, 0xA5, 0x71, 0x08, 0x00, 0xE7, 0x71, 0x08, 0x00, 0x0B, 0x72, 0x08,
       0x00, 0x2B, 0x72, 0x08, 0x00, 0x99, 0x79, 0x08, 0x00, 0x89, 0x03, 0x18, 0x00, 0x61, 0x03, 0x18,
       0x00, 0xBD, 0x72, 0x08, 0x00, 0xD5, 0x72, 0x08, 0x00, 0xE5, 0x73, 0x08, 0x00, 0x57, 0x72, 0x08,
       0x00, 0x59, 0x73, 0x08, 0x00, 0x69, 0x78, 0x08, 0x00, 0xA1, 0x73, 0x08, 0x00, 0xF3, 0x73, 0x08,
       0x00, 0xB5, 0x73, 0x08, 0x00, 0xD9, 0x73, 0x08, 0x00, 0xDF, 0x73, 0x08, 0x00, 0x69, 0x74, 0x08,
       0x00, 0xC5, 0x74, 0x08, 0x00, 0x39, 0x75, 0x08, 0x00, 0x15, 0x76, 0x08, 0x00, 0x91, 0x77, 0x08,
       0x00, 0xD9, 0x78, 0x08, 0x00, 0x01, 0x05, 0xFF, 0x85, 0x04, 0xF3, 0x1A, 0x00, 0x80, 0x36, 0x5E,
       0x02, 0x00, 0x38, 0xC2, 0x02, 0x00, 0x00, 0xC5, 0x02, 0x00, 0x9C, 0x9C, 0x00, 0x00, 0x70, 0x8C,
       0x00, 0x00, 0x02, 0x69, 0x00, 0x00, 0x84, 0x97, 0x00, 0x00, 0x6A, 0xA0, 0x02, 0x00, 0xF0, 0x6E,
       0x03, 0x00, 0xF0, 0x8A, 0x04, 0x00, 0x32, 0xAF, 0x02, 0x00, 0xF4, 0xF8, 0x03, 0x00, 0x24, 0x8D,
       0x03, 0x00, 0xA8, 0x55, 0x00, 0x00, 0x00, 0x16, 0x04, 0x00, 0x14, 0x85, 0x01, 0x00, 0x54, 0x82,
       0x01, 0x00, 0x42, 0x7B, 0x02, 0x00, 0xAC, 0xF9, 0x03, 0x00, 0xD6, 0x7B, 0x03, 0x00, 0x5C, 0x91,
       0x00, 0x00, 0x1C, 0x86, 0x00, 0x00, 0x68, 0x9D, 0x03, 0x00, 0xB4, 0xEB, 0x03, 0x00, 0x78, 0x68,
       0x03, 0x00, 0x3E, 0xF6, 0x02, 0x00, 0x3C, 0xE3, 0x03, 0x00, 0xDC, 0xE3, 0x02, 0x00, 0xCE, 0x98,
       0x01, 0x00, 0x3A, 0xBD, 0x03, 0x00, 0x72, 0x25, 0x04, 0x00, 0xCE, 0x44, 0x01, 0x00, 0x01, 0x05,
       0xFF, 0xFF, 0x00, 0x00, 0x18, 0x00, 0xFA, 0xFF, 0xB5, 0x00, 0x93, 0x01, 0x92, 0x02, 0x91, 0x06,
       0x1C, 0xE4, 0x4F, 0x38, 0x78, 0x44, 0x1E, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x21, 0xC9, 0x03, 0x01,
       0xE0, 0x7D, 0x21, 0x09, 0x02, 0xD2, 0x48, 0x01, 0x22, 0x96, 0x46, 0xD1, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x03, 0x91, 0xD4, 0x48, 0x00, 0x78, 0x02, 0x28, 0x00, 0xD0, 0xB8, 0xE0, 0xD3, 0x4D, 0xCD,
       0x48, 0x01, 0x2E, 0x53, 0xD0, 0x06, 0x1C, 0xB0, 0x89, 0x00, 0x2C, 0x02, 0xD0, 0x7D, 0x20, 0x00,
       0x02, 0x01, 0xE0, 0x01, 0x20, 0xC0, 0x03, 0x02, 0x99, 0x48, 0x43, 0xC7, 0x49, 0x08, 0x18, 0xF0,
       0x49, 0x01, 0x22, 0x96, 0x46, 0xC6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xB1, 0x81, 0x38, 0x78, 0x01,
       0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0xC1, 0x4C, 0x0F,
       0x27, 0x21, 0x88, 0x39, 0x40, 0x22, 0x88, 0x12, 0x09, 0x3A, 0x40, 0x8A, 0x42, 0x04, 0xDD, 0x21,
       0x88, 0x09, 0x11, 0x09, 0x07, 0x0F, 0x0F, 0x01, 0xE0, 0x21, 0x88, 0x0F, 0x40, 0x02, 0x99, 0x41,
       0x43, 0xB6, 0x48, 0x40, 0x18, 0xDF, 0x49, 0x01, 0x22, 0x96, 0x46, 0xB4, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x28, 0x1C, 0x00, 0x8E, 0x1F, 0x22, 0x10, 0x40, 0x40, 0x18, 0xA1, 0x89, 0x11, 0x40, 0x08,
       0x18, 0x31, 0x8A, 0x08, 0x18, 0x29, 0x88, 0x09, 0x0A, 0x08, 0x18, 0x29, 0x89, 0x09, 0x0A, 0x08,
       0x18, 0x39, 0x18, 0x01, 0x98, 0x40, 0x18, 0x05, 0x30, 0x01, 0x04, 0x09, 0x0C, 0xDC, 0x48, 0x00,
       0x22, 0x01, 0x23, 0x9E, 0x46, 0xDB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x54, 0xE0, 0x06, 0x1C, 0x30,
       0x88, 0x00, 0x2C, 0x02, 0xD0, 0x7D, 0x20, 0x00, 0x02, 0x01, 0xE0, 0x01, 0x20, 0xC0, 0x03, 0x02,
       0x99, 0x01, 0x05, 0xFF, 0xFF, 0xFA, 0x00, 0x18, 0x00, 0xFA, 0x48, 0x43, 0x9D, 0x49, 0x08, 0x18,
       0xC6, 0x49, 0x01, 0x22, 0x96, 0x46, 0x9C, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x31, 0x80, 0x38, 0x78,
       0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x97, 0x4C,
       0x0F, 0x25, 0xA1, 0x88, 0x09, 0x09, 0x29, 0x40, 0xA2, 0x88, 0x2A, 0x40, 0x8A, 0x42, 0x03, 0xDD,
       0xA1, 0x88, 0x09, 0x07, 0x0D, 0x0F, 0x02, 0xE0, 0xA1, 0x88, 0x09, 0x09, 0x0D, 0x40, 0x1F, 0x27,
       0x02, 0x99, 0x41, 0x43, 0x8B, 0x48, 0x40, 0x18, 0xB4, 0x49, 0x01, 0x22, 0x96, 0x46, 0x8A, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x89, 0x38, 0x40, 0x40, 0x18, 0xB1, 0x88, 0x39, 0x40, 0x08, 0x18,
       0x21, 0x89, 0x39, 0x40, 0x08, 0x18, 0x87, 0x49, 0x09, 0x88, 0x09, 0x0A, 0x08, 0x18, 0x85, 0x49,
       0x09, 0x89, 0x09, 0x0A, 0x08, 0x18, 0x29, 0x18, 0x01, 0x98, 0x40, 0x18, 0x05, 0x30, 0x01, 0x04,
       0x09, 0x0C, 0xB1, 0x48, 0x00, 0x22, 0x01, 0x23, 0x9E, 0x46, 0xB0, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x00, 0x98, 0x03, 0x99, 0x41, 0x18, 0xAE, 0x48, 0x40, 0x18, 0xAF, 0x49, 0x01, 0x22, 0x96, 0x46,
       0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x08, 0xE0, 0xA9, 0x48, 0x00, 0x99, 0x40, 0x18, 0xAA, 0x49,
       0x01, 0x22, 0x96, 0x46, 0x70, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1C, 0xA5, 0x49, 0x08, 0x80,
       0x09, 0x99, 0xA6, 0x48, 0x49, 0x1C, 0x01, 0xD0, 0x59, 0x30, 0x00, 0xE0, 0x61, 0x30, 0x00, 0x90,
       0xFF, 0xBD, 0xF8, 0xB5, 0x05, 0x1C, 0x9E, 0x48, 0x40, 0x19, 0x9F, 0x49, 0x01, 0x24, 0xA6, 0x46,
       0x65, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1C, 0x9A, 0x49, 0x08, 0x80, 0x6B, 0x48, 0x00, 0x78,
       0x01, 0x28, 0x02, 0xD1, 0x01, 0x05, 0xFF, 0xFF, 0xF4, 0x01, 0x18, 0x00, 0xFA, 0x01, 0x20, 0xC0,
       0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x68, 0x43, 0x5C, 0x4E, 0x30, 0x18, 0x85, 0x49, 0xA6,
       0x46, 0x5B, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x09, 0x04, 0x09, 0x0C, 0x94, 0x48, 0x04, 0x30, 0x06,
       0x22, 0xA6, 0x46, 0x91, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x90, 0x48, 0x5A, 0x30, 0x00, 0x21, 0xA6,
       0x46, 0x8F, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x1C, 0x8C, 0x48, 0x08, 0x21, 0xA6, 0x46, 0x8C,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC7, 0x19, 0x14, 0x2F, 0x00, 0xD8, 0x14, 0x27, 0x55, 0x48, 0x00,
       0x78, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D, 0x20, 0x00, 0x02, 0x68,
       0x43, 0x30, 0x18, 0x70, 0x49, 0xA6, 0x46, 0x46, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x1B, 0x05,
       0x38, 0x01, 0x04, 0x09, 0x0C, 0x7D, 0x48, 0x2C, 0x30, 0x00, 0x22, 0xA6, 0x46, 0x7A, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x7D, 0x4F, 0x38, 0x1C, 0x08, 0x21, 0xA6, 0x46, 0x79, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x00, 0x90, 0x38, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x00,
       0x99, 0x88, 0x42, 0x06, 0xDD, 0x38, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0x71, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x05, 0xE0, 0x38, 0x1C, 0x08, 0x21, 0xA6, 0x46, 0x6D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07,
       0x1C, 0x6A, 0x48, 0x00, 0x21, 0xA6, 0x46, 0x6A, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x3F, 0x18, 0x08,
       0x37, 0x34, 0x48, 0x00, 0x78, 0x01, 0x28, 0x02, 0xD1, 0x01, 0x20, 0xC0, 0x03, 0x01, 0xE0, 0x7D,
       0x20, 0x00, 0x02, 0x68, 0x43, 0x30, 0x18, 0x4F, 0x49, 0xA6, 0x46, 0x25, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x78, 0x18, 0x01, 0x04, 0x09, 0x0C, 0x01, 0x05, 0xFF, 0xFF, 0xEE, 0x02, 0x18, 0x00, 0xFA,
       0x56, 0x48, 0x00, 0x22, 0xA6, 0x46, 0x55, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xF8, 0xBD, 0x10, 0xB5,
       0x43, 0x69, 0x5F, 0x49, 0x09, 0x78, 0x5B, 0x4A, 0x12, 0x78, 0x01, 0x2A, 0x04, 0xD1, 0x1C, 0x78,
       0x00, 0x2C, 0x01, 0xD1, 0x5C, 0x49, 0x09, 0x78, 0x1A, 0x4C, 0x24, 0x78, 0x00, 0x2C, 0x1B, 0xD0,
       0xFF, 0x29, 0x19, 0xD0, 0x01, 0x2A, 0x08, 0xD0, 0x58, 0x4A, 0x12, 0x78, 0x01, 0x2A, 0x13, 0xD0,
       0x1A, 0x78, 0x01, 0x2A, 0x01, 0xD0, 0x02, 0x2A, 0x0E, 0xD1, 0x10, 0x22, 0xD4, 0x56, 0x8C, 0x42,
       0x0A, 0xDD, 0x61, 0x1A, 0x09, 0x06, 0x09, 0x0E, 0x5B, 0x1C, 0x00, 0x24, 0x1C, 0x57, 0x64, 0x1A,
       0x1C, 0x70, 0x01, 0x33, 0x01, 0x3A, 0xF8, 0xD1, 0x48, 0x49, 0x81, 0x60, 0x48, 0x48, 0x15, 0x30,
       0x10, 0xBD, 0x4A, 0x48, 0x15, 0x30, 0xF7, 0x46, 0xC0, 0x46, 0x80, 0xC3, 0xC9, 0x01, 0x6D, 0x94,
       0x05, 0x00, 0xC0, 0x79, 0x1A, 0x00, 0x3F, 0x42, 0x0F, 0x00, 0x05, 0x9A, 0x05, 0x00, 0x28, 0x79,
       0x1A, 0x00, 0xE8, 0x57, 0x08, 0x00, 0x2C, 0x7A, 0x1A, 0x00, 0xFF, 0xB5, 0x05, 0x1C, 0x03, 0x48,
       0x00, 0x78, 0x01, 0x28, 0x05, 0xD1, 0x01, 0x26, 0xF6, 0x03, 0x04, 0xE0, 0xC0, 0x46, 0x5E, 0x56,
       0x08, 0x00, 0x7D, 0x26, 0x36, 0x02, 0x28, 0x48, 0x00, 0x21, 0x01, 0x24, 0xA6, 0x46, 0x38, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x1C, 0x19, 0x48, 0x48, 0x43, 0x31, 0x1C, 0xA6, 0x46, 0x3B, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x01, 0x91, 0x6D, 0x69, 0xEE, 0x7A, 0x28, 0x1C, 0x21, 0x1C, 0xA6, 0x46,
       0x31, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x1C, 0x28, 0x1C, 0x05, 0x21, 0xA6, 0x46, 0x2D, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x02, 0x90, 0x28, 0x7F, 0x03, 0x90, 0x01, 0x05, 0xFF, 0xFF, 0xE8, 0x03,
       0x18, 0x00, 0xFA, 0xED, 0x7E, 0xFF, 0x2E, 0x04, 0xD0, 0x30, 0x1C, 0xA6, 0x46, 0x29, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x78, 0x1C, 0x19, 0xD0, 0x1B, 0x48, 0x0A, 0x21, 0xA6, 0x46, 0x26, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x06, 0x28, 0x09, 0xD0, 0x01, 0x2E, 0x07, 0xD0, 0x38, 0x1C, 0xA6, 0x46, 0x22,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x09, 0xE0, 0x40, 0x42, 0x0F, 0x00, 0x38, 0x1C, 0x31, 0x1C, 0x03,
       0x9A, 0x2B, 0x1C, 0xA6, 0x46, 0x1E, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x02, 0x98, 0x00, 0x90, 0x28,
       0x1C, 0x39, 0x1C, 0x03, 0x9A, 0x01, 0x9B, 0xA6, 0x46, 0x1A, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x00,
       0x90, 0xFF, 0xBD, 0x04, 0x60, 0x1A, 0x00, 0xC9, 0x49, 0x05, 0x00, 0xE1, 0x04, 0x00, 0x00, 0x48,
       0x53, 0x08, 0x00, 0xE2, 0x04, 0x00, 0x00, 0x71, 0x55, 0x00, 0x00, 0x93, 0x49, 0x05, 0x00, 0x16,
       0x74, 0x1A, 0x00, 0x6B, 0x4A, 0x05, 0x00, 0x42, 0x74, 0x1A, 0x00, 0x44, 0x74, 0x1A, 0x00, 0x66,
       0x63, 0x08, 0x00, 0x10, 0x30, 0x19, 0x00, 0xEF, 0x68, 0x00, 0x00, 0x61, 0x63, 0x08, 0x00, 0x60,
       0x63, 0x08, 0x00, 0x63, 0x63, 0x08, 0x00, 0xFF, 0x15, 0x04, 0x00, 0xA7, 0x4A, 0x05, 0x00, 0xE5,
       0x2B, 0x00, 0x00, 0x81, 0x42, 0x02, 0x00, 0x4D, 0x4A, 0x05, 0x00, 0xD3, 0x01, 0x18, 0x00, 0x55,
       0x3F, 0x02, 0x00, 0x01, 0x00, 0x18, 0x00, 0x6D, 0x94, 0x05, 0x00, 0x70, 0xB5, 0xDF, 0x4D, 0xAE,
       0x7F, 0x01, 0x24, 0xA6, 0x46, 0xDB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xB0, 0x42, 0xF8, 0xD1, 0x03,
       0x20, 0x17, 0x21, 0x89, 0x01, 0xA6, 0x46, 0xD7, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xAD, 0x7F, 0xA6,
       0x46, 0xD4, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA8, 0x42, 0xF9, 0xD1, 0xFE, 0xE7, 0x01, 0x05, 0xFF,
       0xFF, 0xE2, 0x04, 0x18, 0x00, 0xFA, 0xF0, 0xB5, 0x88, 0xB0, 0x0B, 0x21, 0x09, 0x18, 0x68, 0x46,
       0x0C, 0x22, 0x01, 0x24, 0xA6, 0x46, 0xD9, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x68, 0x46, 0x01, 0x78,
       0x03, 0x91, 0x45, 0x78, 0x81, 0x78, 0x04, 0x91, 0xC0, 0x78, 0x05, 0x90, 0x01, 0x98, 0x06, 0x90,
       0x02, 0x98, 0x07, 0x90, 0xA6, 0x46, 0xC8, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xD0, 0x4F, 0x38, 0x78,
       0xCA, 0x4E, 0x81, 0x09, 0x16, 0xD3, 0x14, 0x20, 0xB0, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0xCD, 0x49,
       0xFE, 0x44, 0x08, 0x47, 0xC1, 0x48, 0x00, 0x21, 0xA6, 0x46, 0xC1, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0xC0, 0x48, 0x03, 0x21, 0xA6, 0x46, 0xC0, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x39, 0x78, 0xDF, 0x20,
       0x08, 0x40, 0x38, 0x70, 0xC0, 0x09, 0x0A, 0xD3, 0x24, 0x20, 0xB0, 0x80, 0xC8, 0x20, 0xA6, 0x46,
       0xC0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x39, 0x78, 0xBF, 0x20, 0x08, 0x40, 0x38, 0x70, 0xB8, 0x48,
       0x07, 0x2D, 0x09, 0xD0, 0xAA, 0x00, 0xB7, 0x49, 0x0B, 0x1C, 0x38, 0x3B, 0x9B, 0x58, 0x05, 0x1C,
       0xAB, 0x60, 0x88, 0x58, 0x07, 0x90, 0x02, 0xE0, 0x05, 0x1C, 0x06, 0x98, 0xA8, 0x60, 0x07, 0x98,
       0x68, 0x60, 0x28, 0x1C, 0x00, 0x21, 0xA6, 0x46, 0xAB, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x03, 0x98,
       0x81, 0x1E, 0xAD, 0x48, 0x13, 0xD0, 0x01, 0x39, 0x0F, 0xD0, 0x01, 0x39, 0x01, 0xD0, 0x02, 0x21,
       0x0E, 0xE0, 0x05, 0x99, 0x09, 0x07, 0x49, 0x0E, 0x04, 0x9A, 0x52, 0x06, 0x92, 0x0C, 0x51, 0x18,
       0x81, 0x83, 0x15, 0x20, 0xB0, 0x80, 0x20, 0x20, 0x10, 0xE0, 0x21, 0x1C, 0x00, 0xE0, 0x00, 0x21,
       0x89, 0x07, 0x89, 0x0F, 0x05, 0x9A, 0x12, 0x07, 0x52, 0x0E, 0x51, 0x18, 0x04, 0x9A, 0x52, 0x06,
       0x01, 0x05, 0xFF, 0xFF, 0xDC, 0x05, 0x18, 0x00, 0xFA, 0x92, 0x0C, 0x51, 0x18, 0x01, 0x80, 0x11,
       0x20, 0x30, 0x80, 0x04, 0x20, 0x39, 0x78, 0x08, 0x43, 0x38, 0x70, 0x03, 0x98, 0x00, 0x28, 0x05,
       0xD0, 0x90, 0x48, 0x00, 0x21, 0xA6, 0x46, 0x92, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xC8, 0x20, 0xA6,
       0x46, 0x96, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x8D, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x8C, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x03, 0x98, 0x00, 0x28, 0x02, 0xD0, 0xFF, 0x20, 0x02, 0x30, 0x28, 0x80, 0x08,
       0xB0, 0xF0, 0xBD, 0xF8, 0xB5, 0xC1, 0x7A, 0x00, 0x91, 0x07, 0x7B, 0x00, 0x2F, 0x03, 0xD0, 0x01,
       0x2F, 0x02, 0xD1, 0x01, 0x27, 0x00, 0xE0, 0x02, 0x27, 0x01, 0x24, 0xA6, 0x46, 0x7C, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x85, 0x4E, 0x30, 0x78, 0x7F, 0x4D, 0x81, 0x09, 0x16, 0xD3, 0x14, 0x20, 0xA8,
       0x80, 0xC8, 0x20, 0xA6, 0x46, 0x81, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x76, 0x48, 0x00, 0x21, 0xA6,
       0x46, 0x75, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x75, 0x48, 0x03, 0x21, 0xA6, 0x46, 0x74, 0x4A, 0xFE,
       0x44, 0x10, 0x47, 0x31, 0x78, 0xDF, 0x20, 0x08, 0x40, 0x30, 0x70, 0xC0, 0x09, 0x0A, 0xD3, 0x24,
       0x20, 0xA8, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0x75, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x31, 0x78, 0xBF,
       0x20, 0x08, 0x40, 0x30, 0x70, 0x72, 0x48, 0x01, 0x78, 0x6D, 0x48, 0x01, 0x29, 0x12, 0xD0, 0x00,
       0x99, 0x89, 0x01, 0x41, 0x80, 0x87, 0x80, 0x21, 0x20, 0x28, 0x80, 0xC8, 0x20, 0xA6, 0x46, 0x6B,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x61, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x61, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x02, 0x20, 0x13, 0xE0, 0x00, 0x99, 0x8A, 0x01, 0x02, 0x21, 0x11, 0x43, 0xC1, 0x83, 0x07,
       0x84, 0x25, 0x20, 0x01, 0x05, 0xFF, 0xFF, 0xD6, 0x06, 0x18, 0x00, 0xFA, 0xA8, 0x80, 0xC8, 0x20,
       0xA6, 0x46, 0x60, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x57, 0x48, 0x0C, 0x21, 0xA6, 0x46, 0x56, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x40, 0x20, 0x31, 0x78, 0x08, 0x43, 0x30, 0x70, 0xF8, 0xBD, 0xF8, 0xB5,
       0x00, 0x92, 0x0F, 0x1C, 0x05, 0x1C, 0x60, 0x48, 0x01, 0x78, 0x01, 0x24, 0x58, 0x4E, 0xB5, 0x42,
       0x0E, 0xDC, 0x5A, 0x48, 0xB5, 0x42, 0x4D, 0xD0, 0x44, 0x4A, 0xAA, 0x1A, 0x51, 0xD0, 0x01, 0x3A,
       0x48, 0xD0, 0x04, 0x3A, 0x31, 0xD0, 0x68, 0x3A, 0x4B, 0xD0, 0x01, 0x3A, 0x4F, 0xD0, 0x39, 0xE0,
       0x30, 0x1C, 0x2F, 0x30, 0x28, 0x1A, 0x39, 0xD0, 0x24, 0x38, 0x35, 0xD0, 0x01, 0x38, 0x17, 0xD0,
       0x01, 0x38, 0x2F, 0xD1, 0x52, 0x48, 0x00, 0x78, 0x02, 0x28, 0x0E, 0xD1, 0xF8, 0x7A, 0x00, 0x07,
       0x00, 0x0F, 0x47, 0x49, 0x0A, 0x1C, 0xB6, 0x3A, 0x10, 0x70, 0x02, 0x01, 0x02, 0x43, 0x12, 0x01,
       0x02, 0x43, 0x12, 0x01, 0x02, 0x43, 0x0A, 0x80, 0x0B, 0xE0, 0x0C, 0x20, 0x18, 0x70, 0x08, 0xE0,
       0x01, 0x29, 0x01, 0xD0, 0x04, 0x29, 0x04, 0xD1, 0x38, 0x1C, 0xA6, 0x46, 0x3E, 0x49, 0xFE, 0x44,
       0x08, 0x47, 0x25, 0x1C, 0x00, 0x98, 0x05, 0x70, 0x4C, 0xE0, 0x00, 0x29, 0x4A, 0xD1, 0xB8, 0x7D,
       0x01, 0x28, 0x47, 0xD1, 0x04, 0x20, 0xA6, 0x46, 0x38, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xFF, 0x20,
       0xB8, 0x75, 0x3F, 0xE0, 0x00, 0x24, 0x3D, 0xE0, 0x3A, 0x48, 0x00, 0xE0, 0x3A, 0x48, 0xF9, 0x7A,
       0x01, 0x70, 0xE6, 0xE7, 0x00, 0x21, 0x06, 0x22, 0xA6, 0x46, 0x37, 0x4B, 0xFE, 0x44, 0x18, 0x47,
       0x30, 0xE0, 0x03, 0x21, 0x06, 0x22, 0xA6, 0x46, 0x34, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x33, 0x48,
       0x00, 0x68, 0x00, 0x28, 0x13, 0xD1, 0x01, 0x05, 0xFF, 0xDD, 0xD0, 0x07, 0x18, 0x00, 0xD8, 0x04,
       0x3E, 0xB5, 0x42, 0x09, 0xD0, 0x13, 0x48, 0x85, 0x42, 0x20, 0xD1, 0x38, 0x1C, 0x25, 0x1C, 0xA6,
       0x46, 0x26, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xC9, 0xE7, 0x38, 0x1C, 0x25, 0x1C, 0xA6, 0x46, 0x23,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0xC2, 0xE7, 0x04, 0x20, 0xA6, 0x46, 0x27, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x47, 0x21, 0x09, 0x02, 0x01, 0x80, 0x87, 0x80, 0x39, 0x0C, 0xC1, 0x80, 0xA6, 0x46, 0x23,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x23, 0x48, 0x9E, 0x30, 0x06, 0x99, 0x08, 0x62, 0x20, 0x1C, 0xF8,
       0xBD, 0xC0, 0x46, 0x17, 0xFD, 0x00, 0x00, 0x8B, 0x05, 0x05, 0x00, 0xF5, 0xD3, 0x04, 0x00, 0x8C,
       0x4F, 0x08, 0x00, 0x0D, 0x82, 0x03, 0x00, 0x0D, 0x18, 0x19, 0x00, 0x79, 0x48, 0x05, 0x00, 0x62,
       0x1C, 0x19, 0x00, 0x61, 0x48, 0x05, 0x00, 0x44, 0x24, 0x19, 0x00, 0x0C, 0x18, 0x19, 0x00, 0xC8,
       0x8D, 0x06, 0x00, 0x00, 0x30, 0x19, 0x00, 0x21, 0xA7, 0x05, 0x00, 0xD4, 0x0F, 0x08, 0x00, 0xBB,
       0x16, 0x04, 0x00, 0x68, 0x63, 0x08, 0x00, 0x88, 0xFD, 0x00, 0x00, 0x4C, 0xA6, 0x1B, 0x00, 0x6D,
       0x09, 0x18, 0x00, 0xE1, 0x42, 0x02, 0x00, 0x6A, 0x0A, 0x1A, 0x00, 0x27, 0x06, 0x18, 0x00, 0xE3,
       0x04, 0x18, 0x00, 0xE8, 0x57, 0x08, 0x00, 0x41, 0x10, 0x08, 0x00, 0x69, 0x63, 0x08, 0x00, 0x68,
       0x63, 0x08, 0x00, 0x91, 0x48, 0x05, 0x00, 0x2C, 0x51, 0x08, 0x00, 0x9B, 0x60, 0x04, 0x00, 0xE9,
       0x3F, 0x05, 0x00, 0x81, 0x60, 0x00, 0x00, 0x01, 0x05, 0xFF, 0xFF, 0xD0, 0x2D, 0x18, 0x00, 0xFA,
       0xF0, 0xB5, 0xC8, 0x48, 0x00, 0x78, 0x02, 0x28, 0x00, 0xD0, 0x9E, 0xE0, 0xC7, 0x48, 0x05, 0x21,
       0x01, 0x25, 0xAE, 0x46, 0xC6, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x01, 0x1C, 0xC2, 0x48, 0x00, 0x22,
       0xAE, 0x46, 0xC4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE7, 0x48, 0x00, 0x78, 0x00, 0x28, 0x18, 0xD1,
       0x13, 0x20, 0xC1, 0x49, 0x08, 0x80, 0x03, 0x27, 0x39, 0x1C, 0x28, 0x1C, 0xAE, 0x46, 0xBF, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0xF4, 0x4E, 0x30, 0x1C, 0x0A, 0x30, 0x39, 0x1C, 0xAE, 0x46, 0xBC, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xAE, 0x46, 0xB5, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0xB9, 0x4C, 0x27, 0x1C, 0x02, 0x3F, 0x38, 0x1C, 0x02, 0x21, 0x00, 0x22, 0xAE, 0x46,
       0xB4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xB5, 0x4E, 0x30, 0x1C, 0xC8, 0x38, 0x20, 0x60, 0x38, 0x1C,
       0x03, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xAF, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x26, 0x60, 0x38, 0x1C,
       0x04, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xAB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xAC, 0x4E, 0x30, 0x1C,
       0xD1, 0x38, 0x20, 0x60, 0x38, 0x1C, 0x05, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xA5, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x26, 0x60, 0x38, 0x1C, 0x06, 0x21, 0x00, 0x22, 0xAE, 0x46, 0xA1, 0x4B, 0xFE, 0x44,
       0x18, 0x47, 0x30, 0x1C, 0x32, 0x30, 0x20, 0x60, 0x38, 0x1C, 0x07, 0x21, 0x00, 0x22, 0xAE, 0x46,
       0x9C, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x30, 0x1C, 0x62, 0x30, 0x20, 0x60, 0x38, 0x1C, 0x08, 0x21,
       0x00, 0x22, 0xAE, 0x46, 0x97, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xC2, 0x36, 0x26, 0x60, 0x38, 0x1C,
       0x09, 0x21, 0x00, 0x22, 0xAE, 0x46, 0x93, 0x4B, 0xFE, 0x44, 0x01, 0x05, 0xFF, 0xFF, 0xCA, 0x2E,
       0x18, 0x00, 0xFA, 0x18, 0x47, 0xEE, 0x48, 0x20, 0x60, 0x38, 0x1C, 0x0A, 0x21, 0x00, 0x22, 0xAE,
       0x46, 0x8E, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xEB, 0x48, 0x20, 0x60, 0x38, 0x1C, 0x0B, 0x21, 0x00,
       0x22, 0xAE, 0x46, 0x8A, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xE7, 0x48, 0x20, 0x60, 0xE7, 0x48, 0x00,
       0x88, 0x80, 0x0B, 0x0E, 0xD3, 0x00, 0x22, 0x10, 0x1C, 0xC3, 0x00, 0xE5, 0x49, 0x0C, 0x1C, 0x02,
       0x3C, 0xE4, 0x18, 0x25, 0x88, 0x2D, 0x06, 0x2D, 0x0E, 0x25, 0x80, 0xCA, 0x52, 0x01, 0x30, 0x14,
       0x28, 0xF2, 0xDB, 0xF0, 0xBD, 0x10, 0xB5, 0x75, 0x48, 0x00, 0x78, 0x00, 0x28, 0x32, 0xD0, 0x02,
       0x28, 0x3B, 0xD1, 0xDC, 0x48, 0x48, 0x21, 0x09, 0x18, 0x0B, 0x88, 0x01, 0x22, 0x1A, 0x43, 0x0A,
       0x80, 0xD6, 0x4A, 0x70, 0x3A, 0x13, 0x88, 0x9B, 0x10, 0x9B, 0x00, 0x13, 0x80, 0x7C, 0x23, 0x8A,
       0x8E, 0x9A, 0x43, 0x32, 0x23, 0x13, 0x43, 0x8B, 0x86, 0xD3, 0x4B, 0x19, 0x88, 0x49, 0x09, 0x4A,
       0x01, 0x08, 0x21, 0x11, 0x43, 0x19, 0x80, 0x01, 0x88, 0x49, 0x10, 0x49, 0x00, 0x01, 0x80, 0xCF,
       0x4B, 0xFF, 0x24, 0x19, 0x88, 0x21, 0x40, 0x03, 0x22, 0x12, 0x02, 0x0A, 0x43, 0x1A, 0x80, 0x19,
       0x89, 0x21, 0x40, 0xFF, 0x22, 0x01, 0x32, 0x0A, 0x43, 0x1A, 0x81, 0x02, 0x22, 0x01, 0x88, 0x91,
       0x43, 0x01, 0x80, 0x10, 0xBD, 0x07, 0x21, 0x09, 0x02, 0xC5, 0x48, 0x0A, 0x1C, 0x01, 0x24, 0xA6,
       0x46, 0xC4, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xC4, 0x48, 0x04, 0x70, 0x10, 0xBD, 0xF0, 0xB5, 0xC3,
       0x4E, 0x06, 0x25, 0x35, 0x70, 0x0F, 0x23, 0x73, 0x70, 0x3D, 0x20, 0xB0, 0x70, 0x55, 0x20, 0xF0,
       0x70, 0x03, 0x20, 0x2A, 0x1C, 0xDA, 0x49, 0xE4, 0x31, 0x01, 0x24, 0xA6, 0x46, 0x01, 0x05, 0xFF,
       0xFF, 0xC4, 0x2F, 0x18, 0x00, 0xFA, 0xBC, 0x4F, 0xFE, 0x44, 0x38, 0x47, 0xB2, 0x78, 0xF3, 0x78,
       0x03, 0x20, 0xD5, 0x49, 0xE5, 0x31, 0xA6, 0x46, 0xB8, 0x4E, 0xFE, 0x44, 0x30, 0x47, 0x03, 0x20,
       0xD2, 0x49, 0xE6, 0x31, 0xA6, 0x46, 0xB5, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xA6, 0x46, 0xB4, 0x48,
       0xFE, 0x44, 0x00, 0x47, 0xB4, 0x4A, 0x00, 0x21, 0x08, 0x1C, 0x13, 0x68, 0x00, 0x2B, 0x04, 0xD0,
       0x03, 0x07, 0x1E, 0x0F, 0x23, 0x1C, 0xB3, 0x40, 0x19, 0x43, 0x03, 0x07, 0x1B, 0x0F, 0x0F, 0x2B,
       0x05, 0xD1, 0xC6, 0x08, 0x2B, 0x1C, 0x33, 0x40, 0xAC, 0x4E, 0xF1, 0x52, 0x00, 0x21, 0x04, 0x32,
       0x01, 0x30, 0x20, 0x28, 0xE9, 0xD3, 0xA9, 0x48, 0x00, 0x21, 0xA6, 0x46, 0xA9, 0x4A, 0xFE, 0x44,
       0x10, 0x47, 0x00, 0x26, 0xA8, 0x48, 0x06, 0x70, 0xA8, 0x48, 0x06, 0x70, 0x46, 0x70, 0x19, 0x20,
       0x40, 0x01, 0xA6, 0x49, 0x08, 0x80, 0xFF, 0x21, 0xA6, 0x48, 0x01, 0x70, 0xA6, 0x48, 0x01, 0x70,
       0xA6, 0x48, 0x06, 0x70, 0xA7, 0x48, 0xA5, 0x4A, 0x10, 0x60, 0xA6, 0x48, 0x24, 0x22, 0x02, 0x70,
       0x18, 0x22, 0x42, 0x70, 0x20, 0x22, 0x82, 0x70, 0x10, 0x22, 0xC2, 0x70, 0xA8, 0x4D, 0x28, 0x1C,
       0x00, 0x0A, 0xA1, 0x4A, 0x10, 0x80, 0xA1, 0x48, 0x01, 0x70, 0x08, 0x20, 0xA1, 0x49, 0x08, 0x70,
       0xA6, 0x46, 0xA0, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xA0, 0x4F, 0xA6, 0x46, 0xA1, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x39, 0x88, 0x01, 0x40, 0x48, 0x08, 0x04, 0xD0, 0x00, 0x20, 0xC0, 0x43, 0x45, 0x19,
       0x85, 0x42, 0xF2, 0xD1, 0xA6, 0x46, 0x9A, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x39, 0x88, 0x01, 0x40,
       0x48, 0x08, 0x04, 0xD0, 0x5C, 0x20, 0xA6, 0x46, 0x97, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xA6, 0x46,
       0x01, 0x05, 0xFF, 0xFF, 0xBE, 0x30, 0x18, 0x00, 0xFA, 0x96, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x3E,
       0x80, 0x95, 0x48, 0x01, 0x78, 0x88, 0x09, 0x0C, 0xD2, 0x2C, 0x20, 0xC2, 0x43, 0x93, 0x48, 0x03,
       0x1C, 0x01, 0x3B, 0x1A, 0x70, 0x02, 0x70, 0x42, 0x70, 0x18, 0x22, 0xD2, 0x43, 0x82, 0x70, 0xC2,
       0x70, 0x02, 0x71, 0xC8, 0x09, 0x02, 0xD2, 0x0E, 0x20, 0x8D, 0x49, 0x08, 0x70, 0xF0, 0xBD, 0xE8,
       0x57, 0x08, 0x00, 0x6A, 0x31, 0x19, 0x00, 0xC4, 0x61, 0x1A, 0x00, 0x57, 0x4A, 0x05, 0x00, 0xD3,
       0x48, 0x05, 0x00, 0x9E, 0x13, 0x08, 0x00, 0x21, 0x99, 0x05, 0x00, 0x61, 0x48, 0x05, 0x00, 0xFF,
       0x48, 0x05, 0x00, 0x0C, 0x60, 0x1A, 0x00, 0xDC, 0x09, 0x04, 0x00, 0x25, 0x0D, 0x04, 0x00, 0xF0,
       0xB5, 0x94, 0xB0, 0x80, 0x48, 0x06, 0xC8, 0x6D, 0x46, 0x68, 0x46, 0x06, 0xC0, 0x7F, 0x48, 0x06,
       0xC8, 0x02, 0xA8, 0x06, 0xC0, 0x7E, 0x48, 0x06, 0xC8, 0x04, 0xA8, 0x06, 0xC0, 0x7D, 0x48, 0x06,
       0xC8, 0x06, 0xA8, 0x06, 0xC0, 0x7C, 0x48, 0x06, 0xC8, 0x08, 0xA8, 0x06, 0xC0, 0x7B, 0x48, 0x06,
       0xC8, 0x0A, 0xA8, 0x06, 0xC0, 0x7A, 0x48, 0x06, 0xC8, 0x0C, 0xA8, 0x06, 0xC0, 0x79, 0x48, 0x06,
       0xC8, 0x0E, 0xA8, 0x06, 0xC0, 0x78, 0x48, 0x06, 0xC8, 0x10, 0xA8, 0x06, 0xC0, 0x77, 0x48, 0x06,
       0xC8, 0x12, 0xA8, 0x06, 0xC0, 0x0C, 0x20, 0x01, 0x1C, 0x76, 0x4E, 0x30, 0x1C, 0x48, 0x30, 0x01,
       0x24, 0xA6, 0x46, 0x77, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x02, 0x48, 0x00, 0x78, 0x00, 0x28, 0x1C,
       0xD1, 0x01, 0xE0, 0x62, 0x56, 0x08, 0x00, 0x03, 0x27, 0x39, 0x1C, 0x6C, 0x48, 0xA6, 0x46, 0x70,
       0x4A, 0xFE, 0x44, 0x10, 0x47, 0x36, 0x48, 0x39, 0x1C, 0xA6, 0x46, 0x6D, 0x4A, 0xFE, 0x44, 0x10,
       0x47, 0x0C, 0x48, 0x01, 0x05, 0xFF, 0xFF, 0xB8, 0x31, 0x18, 0x00, 0xFA, 0x00, 0x21, 0x0C, 0x22,
       0xA6, 0x46, 0x6B, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x2F, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x41, 0x4A,
       0xFE, 0x44, 0x10, 0x47, 0x30, 0x1C, 0x04, 0x21, 0xA6, 0x46, 0x3E, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x4F, 0x48, 0x00, 0x78, 0x00, 0x09, 0x09, 0xD2, 0x02, 0xE0, 0xC0, 0x46, 0x14, 0xF6, 0x1A, 0x00,
       0x37, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x5D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x58, 0x48, 0x0E, 0x99,
       0x01, 0x60, 0xA9, 0x8F, 0x81, 0x80, 0x10, 0x99, 0x81, 0x60, 0x11, 0xA9, 0x09, 0x88, 0x81, 0x81,
       0x12, 0x99, 0x01, 0x61, 0x13, 0xA9, 0x09, 0x88, 0x81, 0x82, 0x42, 0x21, 0x51, 0x4D, 0x28, 0x1C,
       0x60, 0x30, 0x01, 0x60, 0x21, 0x1C, 0x28, 0x1C, 0xA6, 0x46, 0x50, 0x4A, 0xFE, 0x44, 0x10, 0x47,
       0x28, 0x1C, 0xA0, 0x38, 0x00, 0x99, 0x01, 0x60, 0x01, 0x99, 0x41, 0x60, 0x02, 0x99, 0x81, 0x60,
       0x03, 0x99, 0xC1, 0x60, 0x04, 0x99, 0x01, 0x61, 0x05, 0x99, 0x41, 0x61, 0x06, 0x99, 0x81, 0x62,
       0x07, 0x99, 0xC1, 0x62, 0x08, 0x99, 0x81, 0x63, 0x09, 0x99, 0xC1, 0x63, 0x0A, 0x99, 0x01, 0x65,
       0x0B, 0x99, 0x41, 0x65, 0x0C, 0x99, 0x81, 0x66, 0x0D, 0x99, 0xC1, 0x66, 0x28, 0x1C, 0x04, 0x30,
       0x21, 0x1C, 0xA6, 0x46, 0x3D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0xA6, 0x46, 0x3A, 0x48, 0xFE, 0x44,
       0x00, 0x47, 0x14, 0xB0, 0xF0, 0xBD, 0xC0, 0x46, 0x1E, 0xF6, 0x1A, 0x00, 0x2F, 0x0E, 0x04, 0x00,
       0x6A, 0x12, 0x40, 0x00, 0x85, 0x12, 0x00, 0x00, 0x5C, 0x7B, 0x1A, 0x00, 0x04, 0x09, 0x1A, 0x00,
       0x24, 0x79, 0x1A, 0x00, 0x54, 0x7D, 0x1A, 0x00, 0x2C, 0x7A, 0x1A, 0x00, 0x00, 0x74, 0x1A, 0x00,
       0xDB, 0x4A, 0x05, 0x00, 0x08, 0x51, 0x01, 0x05, 0xFF, 0xC3, 0xB2, 0x32, 0x18, 0x00, 0xBE, 0x08,
       0x00, 0x0C, 0x51, 0x08, 0x00, 0x0B, 0xD4, 0x04, 0x00, 0xF5, 0xD3, 0x04, 0x00, 0x7D, 0x0B, 0x18,
       0x00, 0x80, 0x7B, 0x08, 0x00, 0x84, 0xF3, 0x1A, 0x00, 0x78, 0x61, 0x1A, 0x00, 0x79, 0x48, 0x05,
       0x00, 0x05, 0x63, 0x08, 0x00, 0x00, 0x63, 0x08, 0x00, 0xCC, 0x24, 0x08, 0x00, 0x60, 0x63, 0x08,
       0x00, 0x61, 0x63, 0x08, 0x00, 0x6A, 0x63, 0x08, 0x00, 0xF4, 0x62, 0x08, 0x00, 0x36, 0xA0, 0x1B,
       0x00, 0x08, 0x63, 0x08, 0x00, 0x4C, 0x25, 0x08, 0x00, 0x63, 0x63, 0x08, 0x00, 0xC5, 0x13, 0x08,
       0x00, 0x25, 0x31, 0x18, 0x00, 0x00, 0x7C, 0x1A, 0x00, 0xF0, 0xFF, 0xFF, 0x00, 0x07, 0xFF, 0x03,
       0x00, 0xD7, 0xD3, 0x04, 0x00, 0x1D, 0x2F, 0x18, 0x00, 0xB2, 0x50, 0x08, 0x00, 0x2D, 0x1F, 0x08,
       0x00, 0xBA, 0x21, 0x08, 0x00, 0xE1, 0x04, 0x00, 0x00, 0xA4, 0x62, 0x08, 0x00, 0xAC, 0x62, 0x08,
       0x00, 0xB4, 0x62, 0x08, 0x00, 0xBC, 0x62, 0x08, 0x00, 0xC4, 0x62, 0x08, 0x00, 0xCC, 0x62, 0x08,
       0x00, 0xD4, 0x62, 0x08, 0x00, 0xDC, 0x62, 0x08, 0x00, 0xE4, 0x62, 0x08, 0x00, 0xEC, 0x62, 0x08,
       0x00, 0x08, 0xF0, 0x1A, 0x00, 0x10, 0x60, 0x1A, 0x00, 0x98, 0x0B, 0x1A, 0x00, 0xA0, 0x09, 0x1A,
       0x00, 0xD1, 0x2D, 0x18, 0x00, 0x61, 0x48, 0x05, 0x00, 0xD3, 0x48, 0x05, 0x00, 0x01, 0x05, 0xFF,
       0xFF, 0xFC, 0x08, 0x18, 0x00, 0xFA, 0xF0, 0xB5, 0xD8, 0x49, 0x0D, 0x78, 0x14, 0x2D, 0x2C, 0xDA,
       0xDA, 0x4C, 0x26, 0x1C, 0x30, 0x3E, 0x68, 0x1C, 0x00, 0x06, 0x00, 0x0E, 0x30, 0x70, 0xD3, 0x4B,
       0xAA, 0x00, 0xD3, 0x4F, 0x9F, 0x50, 0x14, 0x28, 0x18, 0xDA, 0xAA, 0x1C, 0x12, 0x06, 0x12, 0x0E,
       0x72, 0x70, 0x80, 0x00, 0xD0, 0x4E, 0x1E, 0x50, 0x14, 0x2A, 0x08, 0xDA, 0xE8, 0x1C, 0x20, 0x70,
       0x90, 0x00, 0xCE, 0x4A, 0x1A, 0x50, 0x08, 0x78, 0x03, 0x30, 0x08, 0x70, 0xF0, 0xBD, 0x0A, 0x70,
       0x01, 0x20, 0x86, 0x46, 0xCB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0x08, 0x70, 0x01, 0x20,
       0x86, 0x46, 0xC7, 0x48, 0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0x01, 0x20, 0x86, 0x46, 0xC4, 0x48,
       0xFE, 0x44, 0x00, 0x47, 0xFE, 0xE7, 0xF8, 0xB5, 0x07, 0x1C, 0xFB, 0x7A, 0xC2, 0x48, 0x03, 0x70,
       0x3A, 0x7B, 0xC1, 0x48, 0x02, 0x70, 0xC1, 0x49, 0x7C, 0x7B, 0x0C, 0x70, 0xC1, 0x48, 0xBD, 0x7B,
       0x05, 0x70, 0xC9, 0x4E, 0x00, 0x2B, 0x00, 0xD0, 0xBE, 0xE0, 0xC2, 0x4A, 0x15, 0x1C, 0x8C, 0x3D,
       0xCB, 0x4E, 0xB6, 0x0B, 0x01, 0x24, 0xA6, 0x46, 0xBB, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x29, 0x88,
       0x01, 0x40, 0x48, 0x08, 0x05, 0xD0, 0x30, 0x1C, 0x41, 0x1E, 0x0E, 0x04, 0x36, 0x0C, 0x00, 0x28,
       0xF0, 0xD1, 0xA6, 0x46, 0xB4, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x29, 0x88, 0x01, 0x40, 0x48, 0x08,
       0x04, 0xD0, 0x58, 0x20, 0xA6, 0x46, 0xB0, 0x49, 0xFE, 0x44, 0x08, 0x47, 0xAD, 0x48, 0x00, 0x78,
       0xAF, 0x4E, 0x01, 0x28, 0x34, 0xD0, 0x00, 0x20, 0x01, 0x1C, 0x0C, 0x20, 0x02, 0x1C, 0x30, 0x1C,
       0xA6, 0x46, 0xAB, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xAB, 0x48, 0x00, 0x21, 0x08, 0x22, 0xA6, 0x46,
       0x01, 0x05, 0xFF, 0xFF, 0xF6, 0x09, 0x18, 0x00, 0xFA, 0xAA, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xA7,
       0x4E, 0x24, 0x36, 0x30, 0x1C, 0x21, 0x1C, 0x0C, 0x22, 0xA6, 0x46, 0xA6, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x07, 0x20, 0x01, 0x1C, 0x20, 0x1C, 0xA6, 0x46, 0xA4, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x14,
       0x20, 0xA6, 0x46, 0xA2, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x07, 0x20, 0xA6, 0x46, 0xA2, 0x49, 0xFE,
       0x44, 0x08, 0x47, 0x9F, 0x49, 0x08, 0x70, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xA6, 0x46, 0x99,
       0x4B, 0xFE, 0x44, 0x18, 0x47, 0x9B, 0x4E, 0x5B, 0xE0, 0x30, 0x1C, 0x00, 0x21, 0x08, 0x22, 0xA6,
       0x46, 0x92, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x30, 0x1C, 0x00, 0x21, 0x0C, 0x22, 0xA6, 0x46, 0x8E,
       0x4B, 0xFE, 0x44, 0x18, 0x47, 0x8E, 0x48, 0x00, 0x21, 0x0A, 0x1C, 0xA6, 0x46, 0x8D, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x8A, 0x48, 0x00, 0x21, 0x08, 0x22, 0xA6, 0x46, 0x89, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x03, 0x20, 0x02, 0x1C, 0x86, 0x48, 0x02, 0x21, 0xA6, 0x46, 0x86, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x0B, 0x20, 0x02, 0x1C, 0x82, 0x48, 0x21, 0x1C, 0x8E, 0x46, 0x82, 0x4B, 0xFE, 0x44, 0x18,
       0x47, 0x20, 0x1C, 0x06, 0x21, 0x86, 0x46, 0x80, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x07, 0x20, 0x01,
       0x1C, 0x20, 0x1C, 0x86, 0x46, 0x7D, 0x4A, 0xFE, 0x44, 0x10, 0x47, 0x14, 0x20, 0xA6, 0x46, 0x7B,
       0x49, 0xFE, 0x44, 0x08, 0x47, 0x7B, 0x4E, 0x07, 0x20, 0xA6, 0x46, 0x7A, 0x49, 0xFE, 0x44, 0x08,
       0x47, 0x00, 0x90, 0x06, 0x20, 0xA6, 0x46, 0x77, 0x49, 0xFE, 0x44, 0x08, 0x47, 0x41, 0x00, 0x00,
       0x98, 0x01, 0x43, 0x31, 0x70, 0x6E, 0x48, 0x00, 0x21, 0x03, 0x22, 0xA6, 0x46, 0x6E, 0x4B, 0xFE,
       0x44, 0x18, 0x47, 0x01, 0x05, 0xFF, 0xFF, 0xF0, 0x0A, 0x18, 0x00, 0xFA, 0x6A, 0x48, 0x00, 0x21,
       0x0B, 0x22, 0xA6, 0x46, 0x6A, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0x00, 0x20, 0x28, 0x80, 0x60, 0x48,
       0x04, 0x78, 0x60, 0x48, 0x05, 0x78, 0x32, 0x78, 0x01, 0xE0, 0x30, 0x1C, 0x02, 0x70, 0xF8, 0x7B,
       0x01, 0x2D, 0x25, 0xD1, 0x00, 0x2C, 0x0D, 0xD1, 0x10, 0x1C, 0x09, 0xD0, 0x01, 0x38, 0x05, 0xD0,
       0x01, 0x38, 0x01, 0xD0, 0x06, 0x20, 0x16, 0xE0, 0x04, 0x20, 0x14, 0xE0, 0x02, 0x20, 0x12, 0xE0,
       0x00, 0x20, 0x10, 0xE0, 0x10, 0x1C, 0x0D, 0xD0, 0x01, 0x38, 0x09, 0xD0, 0x01, 0x38, 0x05, 0xD0,
       0x01, 0x38, 0x01, 0xD0, 0x10, 0x20, 0x06, 0xE0, 0x0E, 0x20, 0x04, 0xE0, 0x0C, 0x20, 0x02, 0xE0,
       0x0A, 0x20, 0x00, 0xE0, 0x08, 0x20, 0xC0, 0x19, 0xC1, 0x7B, 0x56, 0x4B, 0x19, 0x70, 0x00, 0x7C,
       0x55, 0x49, 0x08, 0x70, 0x55, 0x48, 0x11, 0x04, 0x09, 0x0C, 0x0C, 0x22, 0x01, 0x23, 0x9E, 0x46,
       0x48, 0x4B, 0xFE, 0x44, 0x18, 0x47, 0xF8, 0xBD, 0x70, 0xB5, 0x00, 0x20, 0x67, 0x49, 0x08, 0x70,
       0x67, 0x49, 0xF7, 0x22, 0x0A, 0x70, 0xFF, 0x22, 0x4A, 0x70, 0x8A, 0x70, 0x7F, 0x22, 0xCA, 0x70,
       0x33, 0x4B, 0x19, 0x1F, 0x4B, 0x4A, 0x11, 0x60, 0x4B, 0x49, 0x08, 0x70, 0x61, 0x49, 0x08, 0x70,
       0x61, 0x49, 0x08, 0x70, 0x49, 0x49, 0x08, 0x70, 0x60, 0x49, 0x08, 0x60, 0x49, 0x48, 0x04, 0x1C,
       0x71, 0x3C, 0x01, 0x22, 0x22, 0x70, 0x46, 0x49, 0x19, 0x60, 0x02, 0x21, 0x01, 0x70, 0x46, 0x49,
       0x59, 0x60, 0x03, 0x21, 0x21, 0x71, 0x45, 0x49, 0x99, 0x60, 0x01, 0x1C, 0x33, 0x39, 0x04, 0x25,
       0x0D, 0x70, 0x43, 0x4D, 0xDD, 0x60, 0x05, 0x25, 0xCD, 0x73, 0x42, 0x49, 0x19, 0x61, 0x06, 0x21,
       0xA1, 0x71, 0x41, 0x49, 0x59, 0x61, 0x01, 0x05, 0xFF, 0xFF, 0xEA, 0x0B, 0x18, 0x00, 0xFA, 0x07,
       0x21, 0xE1, 0x71, 0xE1, 0x1D, 0x3F, 0x4D, 0x9D, 0x61, 0x05, 0x1C, 0x48, 0x3D, 0x08, 0x26, 0x2E,
       0x70, 0x3D, 0x4E, 0xDE, 0x61, 0x09, 0x26, 0x4E, 0x77, 0x3C, 0x49, 0x19, 0x62, 0x0A, 0x21, 0x0E,
       0x19, 0x31, 0x70, 0x3B, 0x49, 0x59, 0x62, 0x0B, 0x21, 0xF1, 0x75, 0x3A, 0x49, 0x99, 0x62, 0x1B,
       0x21, 0x09, 0x19, 0x0C, 0x26, 0x0E, 0x70, 0x38, 0x4E, 0xDE, 0x62, 0x0D, 0x26, 0x66, 0x73, 0x37,
       0x4C, 0x1C, 0x63, 0x0E, 0x24, 0x4C, 0x77, 0x36, 0x49, 0x59, 0x63, 0x0F, 0x24, 0x01, 0x1C, 0x21,
       0x31, 0x0C, 0x70, 0x34, 0x49, 0x99, 0x63, 0x10, 0x21, 0xC1, 0x74, 0x33, 0x48, 0xD8, 0x63, 0x11,
       0x20, 0xE8, 0x76, 0x32, 0x49, 0x19, 0x64, 0x03, 0x49, 0x08, 0x70, 0x96, 0x46, 0x30, 0x48, 0xFE,
       0x44, 0x00, 0x47, 0x70, 0xBD, 0x04, 0x63, 0x08, 0x00, 0x0C, 0x63, 0x08, 0x00, 0x05, 0x7B, 0x08,
       0x00, 0x0F, 0x7B, 0x08, 0x00, 0xFB, 0x53, 0x08, 0x00, 0xFB, 0x7A, 0x08, 0x00, 0xB1, 0x04, 0x18,
       0x00, 0x62, 0x63, 0x08, 0x00, 0x65, 0x63, 0x08, 0x00, 0x64, 0x63, 0x08, 0x00, 0x66, 0x63, 0x08,
       0x00, 0x07, 0xFF, 0x03, 0x00, 0xD7, 0xD3, 0x04, 0x00, 0x16, 0xF6, 0x1A, 0x00, 0xD3, 0x48, 0x05,
       0x00, 0x8C, 0x7C, 0x1A, 0x00, 0xA7, 0x48, 0x05, 0x00, 0x91, 0x48, 0x05, 0x00, 0x21, 0x99, 0x05,
       0x00, 0xBB, 0x16, 0x04, 0x00, 0x63, 0x63, 0x08, 0x00, 0x67, 0x99, 0x05, 0x00, 0x60, 0x63, 0x08,
       0x00, 0x61, 0x63, 0x08, 0x00, 0x08, 0x31, 0x19, 0x00, 0xFF, 0xFF, 0xFF, 0x1F, 0x88, 0x53, 0x08,
       0x00, 0x06, 0x63, 0x08, 0x00, 0x07, 0x63, 0x08, 0x00, 0x8D, 0x7A, 0x08, 0x00, 0xFD, 0x53, 0x08,
       0x00, 0xE7, 0x7A, 0x08, 0x00, 0xF1, 0x7A, 0x08, 0x00, 0x01, 0x05, 0xFF, 0x85, 0xE4, 0x0C, 0x18,
       0x00, 0x80, 0x19, 0x7B, 0x08, 0x00, 0x41, 0x7B, 0x08, 0x00, 0x4B, 0x7B, 0x08, 0x00, 0x37, 0x7B,
       0x08, 0x00, 0x23, 0x7B, 0x08, 0x00, 0x2D, 0x7B, 0x08, 0x00, 0xA1, 0x7A, 0x08, 0x00, 0xAB, 0x7A,
       0x08, 0x00, 0xB5, 0x7A, 0x08, 0x00, 0xD3, 0x7A, 0x08, 0x00, 0xDD, 0x7A, 0x08, 0x00, 0x97, 0x7A,
       0x08, 0x00, 0xBF, 0x7A, 0x08, 0x00, 0xC9, 0x7A, 0x08, 0x00, 0xFD, 0x08, 0x18, 0x00, 0x69, 0x63,
       0x08, 0x00, 0x5C, 0x63, 0x08, 0x00, 0x68, 0x63, 0x08, 0x00, 0xFC, 0x62, 0x08, 0x00, 0x7C, 0x63,
       0x08, 0x00, 0x10, 0xB5, 0x01, 0x24, 0xA6, 0x46, 0x06, 0x48, 0xFE, 0x44, 0x00, 0x47, 0x08, 0x20,
       0x06, 0x49, 0x04, 0x22, 0x04, 0x4B, 0xA6, 0x46, 0x05, 0x4C, 0xFE, 0x44, 0x20, 0x47, 0x10, 0xBD,
       0xC0, 0x46, 0xA5, 0x2F, 0x18, 0x00, 0xD0, 0x2D, 0x18, 0x00, 0x0C, 0x04, 0x00, 0x00, 0xD1, 0x5E,
       0x04, 0x00, 0x01, 0x83, 0xFF, 0x14, 0x79, 0x7B, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xDC, 0xFD, 0x05, 0x00, 0x00,
       0x00, 0x00, 0x12, 0x01, 0x0F, 0xFD, 0x01, 0x01, 0x01, 0x1C, 0xFD, 0x14, 0xFF, 0x88, 0x13, 0x00,
       0x00, 0xD0, 0x07, 0x00, 0x00, 0xFF, 0xFF, 0x01, 0xFF, 0xFF, 0xFF, 0xFA, 0x01, 0x00, 0x00, 0x00,
       0x01, 0x1C, 0xFD, 0x14, 0xFF, 0x88, 0x13, 0x00, 0x00, 0xD0, 0x07, 0x00, 0x00, 0xFF, 0xFF, 0x01,
       0xFF, 0xFF, 0xFF, 0xFA, 0x00, 0x00, 0x00, 0x00, 0x01, 0x58, 0xFD, 0x21, 0x01, 0xC4, 0xC4, 0xC4,
       0xE2, 0xE2, 0xE2, 0xF1, 0xEC, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x03, 0x14, 0x0A, 0x90, 0x00, 0x90,
       0x00, 0x3C, 0x0A, 0x32, 0x02, 0x01, 0x01, 0x01, 0x03, 0xF6, 0xEC, 0xF6, 0xEC, 0x01, 0x09, 0xFD,
       0x08, 0x7E, 0x7C, 0x1A, 0x00, 0x10, 0x00, 0x10, 0x00, 0x01, 0x01, 0xFF, 0x06, 0xC6, 0x32, 0x19,
       0x00, 0x10, 0x10, 0x01, 0x01, 0xFF, 0x06, 0x60, 0x32, 0x19, 0x00, 0x32, 0x10, 0x01, 0x82, 0xFD,
       0x14, 0x00, 0x9C, 0x18, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xD2, 0xDC, 0xE6, 0xF0, 0xFA, 0x04,
       0x0E, 0x18, 0xFF, 0x00, 0x00, 0x01, 0x82, 0xFD, 0x14, 0x01, 0x9C, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE,
       0xCE, 0xCE, 0xCE, 0xD8, 0xE2, 0xEC, 0xF6, 0x00, 0x0A, 0x14, 0xFF, 0x00, 0x00, 0x01, 0x82, 0xFD,
       0x14, 0x02, 0x9C, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xCE, 0xD8, 0xE2, 0xEC, 0xF6, 0x00,
       0x0A, 0x14, 0xFF, 0x00, 0x00, 0x01, 0x87, 0xFD, 0x03, 0x0D, 0x0D, 0x0D, 0x01, 0x76, 0xFD, 0x31,
       0x01, 0x21, 0x54, 0x00, 0x00, 0x61, 0x57, 0x00, 0x00, 0x14, 0x05, 0x0A, 0x05, 0x00, 0x07, 0x06,
       0x0A, 0x04, 0x05, 0x08, 0x09, 0x0B, 0x0C, 0x0D, 0x0E, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10,
       0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, 0x00,
       0x00, 0x01, 0x80, 0xFD, 0x06, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x80, 0xFD, 0x06, 0x3C,
       0xF0, 0x5F, 0x00, 0x00, 0x00, 0x01, 0x38, 0xFE, 0x00
    #endif
       /* MODIFIED BASE PATCH */
    #if(0)
       0x01, 0x5b, 0xfd, 0x02, 0x01, 0x01, 0x01, 0xa8, 0xfd, 0x01, 0x01, 0x01, 0x09, 0xfd, 0x08, 0x00,
       0xc0, 0x1b, 0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x05, 0xff, 0x0d, 0xac, 0x4b, 0x1b, 0x00, 0x08,
       0x91, 0xff, 0x47, 0xf2, 0x9b, 0x35, 0x47, 0xf2, 0x01, 0x05, 0xff, 0x55, 0x20, 0x63, 0x1b, 0x00,
       0x50, 0x30, 0xbd, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
       0x00, 0x01, 0x05, 0xff, 0x5d, 0x98, 0x73, 0x1b, 0x00, 0x58, 0x70, 0x47, 0x02, 0x46, 0x14, 0x3a,
       0x1e, 0xd0, 0x52, 0x1e, 0x24, 0xd1, 0x8a, 0x78, 0x02, 0x2a, 0x11, 0xd9, 0x12, 0x1f, 0x02, 0x2a,
       0x0e, 0xd9, 0x1d, 0x3a, 0x1c, 0xd0, 0x92, 0x1f, 0x02, 0x2a, 0x19, 0xd9, 0x09, 0x3a, 0x17, 0xd0,
       0x89, 0x88, 0x40, 0xf2, 0x00, 0x00, 0xc2, 0xf2, 0x30, 0x00, 0x08, 0x43, 0xfd, 0xf7, 0x4b, 0xbe,
       0x09, 0x89, 0x40, 0xf2, 0x00, 0x00, 0xc2, 0xf2, 0x30, 0x00, 0x08, 0x43, 0xfd, 0xf7, 0x43, 0xbe,
       0x89, 0x88, 0x40, 0xf2, 0x00, 0x00, 0xc2, 0xf2, 0x30, 0x00, 0x08, 0x43, 0xfd, 0xf7, 0x3b, 0xbe,
       0x70, 0x47, 0x01, 0x5b, 0xfd, 0x02, 0x01, 0x00, 0x01, 0xdd, 0xfd, 0x01, 0x01
    #endif
    static BTPSCONST unsigned int BasePatchLength = sizeof(BasePatch);
    static unsigned long BasePatchPointer         = (unsigned long)BasePatch;
       /* The following is the binary representation of the Low Energy Patch*/
       /* Data.                                                             */
    static BTPSCONST BTPSVEND_PATCH_LOCATION unsigned char LowEnergyPatch[] =
    		/* ORIGINAL LOW ENERGY PATCH */
    #if(0)
    		   0x01, 0x5B, 0xFD, 0x02, 0x01, 0x01, 0x01,
    		   0xA8, 0xFD, 0x01, 0x01, 0x01, 0x09, 0xFD, 0x08, 0x00, 0xC0, 0x1B, 0x00, 0x01, 0x00, 0x01, 0x00,
    		   0x01, 0x05, 0xFF, 0x19, 0xBC, 0x00, 0x1B, 0x00, 0x14, 0x37, 0x83, 0x49, 0x00, 0x01, 0xA0, 0x40,
    		   0x5A, 0x78, 0x44, 0x87, 0x46, 0xE8, 0x05, 0xC8, 0x05, 0x62, 0x06, 0x3C, 0x05, 0x01, 0x05, 0xFF,
    		   0x09, 0xFC, 0x00, 0x1B, 0x00, 0x04, 0x28, 0x46, 0x15, 0xE3, 0x01, 0x05, 0xFF, 0x09, 0x34, 0x01,
    		   0x1B, 0x00, 0x04, 0xFA, 0xE2, 0x40, 0xF6, 0x01, 0x05, 0xFF, 0x09, 0x68, 0x01, 0x1B, 0x00, 0x04,
    		   0x00, 0x20, 0xDF, 0xE2, 0x01, 0x05, 0xFF, 0x09, 0xB0, 0x02, 0x1B, 0x00, 0x04, 0x00, 0x20, 0x3B,
    		   0xE2, 0x01, 0x05, 0xFF, 0x0D, 0xB4, 0x03, 0x1B, 0x00, 0x08, 0x01, 0x22, 0x00, 0x21, 0xE8, 0x7D,
    		   0x0B, 0x46, 0x01, 0x05, 0xFF, 0x0D, 0xE0, 0x03, 0x1B, 0x00, 0x08, 0x53, 0x5C, 0x01, 0x22, 0x02,
    		   0x21, 0x00, 0xF0, 0x01, 0x05, 0xFF, 0x09, 0x1C, 0x04, 0x1B, 0x00, 0x04, 0xCD, 0xFD, 0x85, 0xE1,
    		   0x01, 0x05, 0xFF, 0x09, 0x4C, 0x04, 0x1B, 0x00, 0x04, 0x00, 0xF0, 0x6E, 0x81, 0x01, 0x05, 0xFF,
    		   0x09, 0x34, 0x05, 0x1B, 0x00, 0x04, 0xC0, 0xF0, 0xFA, 0x80, 0x01, 0x05, 0xFF, 0x09, 0x50, 0x05,
    		   0x1B, 0x00, 0x04, 0xEC, 0xE0, 0x04, 0xF0, 0x01, 0x05, 0xFF, 0x09, 0xA8, 0x05, 0x1B, 0x00, 0x04,
    		   0xCB, 0xFF, 0xBF, 0xE0, 0x01, 0x05, 0xFF, 0x0D, 0xFC, 0x05, 0x1B, 0x00, 0x08, 0x40, 0xF0, 0x88,
    		   0x80, 0x00, 0x20, 0x93, 0xE0, 0x01, 0x05, 0xFF, 0x09, 0x3C, 0x06, 0x1B, 0x00, 0x04, 0x76, 0xE0,
    		   0x94, 0xF8, 0x01, 0x05, 0xFF, 0x09, 0x8C, 0x06, 0x1B, 0x00, 0x04, 0x23, 0x60, 0x4D, 0xE0, 0x01,
    		   0x05, 0xFF, 0xB9, 0xB8, 0x06, 0x1B, 0x00, 0xB4, 0x94, 0xF8, 0x34, 0x20, 0xC2, 0xF2, 0x00, 0x05,
    		   0xA7, 0x8C, 0x01, 0x11, 0x92, 0x1C, 0xAB, 0x89, 0x01, 0xF0, 0x0F, 0x01, 0x94, 0xF8, 0x33, 0x00,
    		   0x62, 0xF3, 0x09, 0x03, 0x2F, 0x81, 0xAB, 0x81, 0x04, 0xF0, 0xF4, 0xFA, 0x00, 0x21, 0x94, 0xF8,
    		   0x33, 0x00, 0x0A, 0x46, 0x04, 0xF0, 0xB4, 0xFD, 0x94, 0xF8, 0x33, 0x00, 0x4F, 0xF0, 0x03, 0x0A,
    		   0xC4, 0xF8, 0x00, 0xA0, 0x06, 0xEB, 0x40, 0x01, 0xB1, 0xF8, 0x14, 0x06, 0x40, 0x1C, 0xA1, 0xF8,
    		   0x14, 0x06, 0x96, 0xF8, 0x46, 0x06, 0x00, 0x28, 0x08, 0xBF, 0x00, 0x20, 0x0E, 0xD0, 0x09, 0x21,
    		   0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x85, 0xFF, 0x40, 0xF6, 0x6A, 0x20,
    		   0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x85, 0xFF, 0x00, 0x20, 0x06, 0xB0, 0xBD, 0xE8,
    		   0xF0, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x2D, 0xE9, 0xF8, 0x43, 0x40, 0xF2, 0xF8, 0x54, 0xC2, 0xF2, 0x00, 0x04, 0x27, 0x88,
    		   0x0D, 0x46, 0x04, 0x46, 0x79, 0x08, 0x40, 0xF2, 0x00, 0x07, 0x16, 0x46, 0x98, 0x46, 0x0A, 0xD3,
    		   0x01, 0x46, 0x4F, 0xF4, 0xE2, 0x70, 0x13, 0x46, 0x2A, 0x46, 0xCD, 0xF8, 0x01, 0x05, 0xFF, 0xCD,
    		   0x84, 0x07, 0x1B, 0x00, 0xC8, 0x00, 0xF0, 0x1B, 0x82, 0x0E, 0x2C, 0x00, 0xF0, 0xA6, 0x81, 0x11,
    		   0x2C, 0x00, 0xF0, 0xA0, 0x81, 0x97, 0xF8, 0x48, 0x26, 0x4F, 0xF0, 0x01, 0x09, 0x09, 0xFA, 0x04,
    		   0xF1, 0x11, 0x40, 0x31, 0x43, 0x4F, 0xF0, 0x00, 0x06, 0x18, 0xBF, 0x4E, 0x46, 0x01, 0x2D, 0x18,
    		   0xBF, 0x02, 0x2D, 0x72, 0xD1, 0x97, 0xF8, 0x47, 0x16, 0x00, 0x29, 0x6E, 0xD1, 0x47, 0xF6, 0x0E,
    		   0x50, 0xC2, 0xF2, 0x32, 0x00, 0x41, 0xF6, 0x44, 0x41, 0x80, 0xF8, 0x00, 0x80, 0xC2, 0xF2, 0x00,
    		   0x01, 0x09, 0x88, 0x19, 0xB9, 0x0B, 0x21, 0x05, 0xF0, 0x2D, 0xFF, 0x02, 0xE0, 0x0B, 0x21, 0x05,
    		   0xF0, 0x22, 0xFF, 0x46, 0xF6, 0x78, 0x68, 0xC0, 0xF2, 0x00, 0x08, 0x41, 0xF6, 0x28, 0x47, 0x18,
    		   0xF8, 0x04, 0x00, 0xC2, 0xF2, 0x00, 0x07, 0x6E, 0xB9, 0x10, 0x38, 0xC1, 0xB2, 0x47, 0xF6, 0x4C,
    		   0x70, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x16, 0xFF, 0x18, 0xF8, 0x04, 0x00, 0x10, 0x38, 0xC4,
    		   0xB2, 0xB8, 0x7F, 0x09, 0xE0, 0x10, 0x38, 0xC4, 0xB2, 0x47, 0xF6, 0x4C, 0x70, 0x21, 0x46, 0xC2,
    		   0xF2, 0x32, 0x00, 0x05, 0xF0, 0x00, 0xFF, 0xB8, 0x7F, 0x38, 0xB9, 0x47, 0xF6, 0x48, 0x70, 0xC2,
    		   0xF2, 0x32, 0x00, 0x21, 0x46, 0x05, 0xF0, 0xFE, 0xFE, 0x06, 0xE0, 0x21, 0x46, 0x47, 0xF6, 0x48,
    		   0x70, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xEF, 0xFE, 0x02, 0x2D, 0x0E, 0xD0, 0x01, 0x05, 0xFF,
    		   0xCD, 0x4C, 0x08, 0x1B, 0x00, 0xC8, 0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x09, 0x21,
    		   0x05, 0xF0, 0xED, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0,
    		   0xE6, 0xFE, 0x0D, 0xE0, 0x09, 0x21, 0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0,
    		   0xD7, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xD7, 0xFE,
    		   0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x07, 0x21, 0x05, 0xF0, 0xC9, 0xFE, 0x48, 0x46,
    		   0xBD, 0xE8, 0xF8, 0x83, 0x0F, 0x2C, 0x08, 0xBF, 0x05, 0x24, 0x11, 0xD0, 0x10, 0x2C, 0x08, 0xBF,
    		   0x06, 0x24, 0x0D, 0xD0, 0x03, 0x2C, 0x0B, 0xD9, 0x0E, 0x2C, 0x09, 0xD2, 0x24, 0x1F, 0x0C, 0x22,
    		   0xE1, 0xB2, 0x47, 0xF6, 0x0E, 0x50, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x55, 0xFE, 0x04, 0x24,
    		   0x00, 0x2D, 0x00, 0xF0, 0xB6, 0x80, 0xED, 0x1E, 0x47, 0xD0, 0x6D, 0x1E, 0x40, 0xF0, 0xFF, 0x80,
    		   0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x09, 0x21, 0x05, 0xF0, 0xA8, 0xFE, 0x40, 0xF6,
    		   0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xA1, 0xFE, 0x40, 0xF6, 0x6A, 0x20,
    		   0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x9A, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21,
    		   0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x93, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x08, 0x21, 0x01, 0x05,
    		   0xFF, 0xCD, 0x14, 0x09, 0x1B, 0x00, 0xC8, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x85, 0xFE, 0x40,
    		   0xF6, 0x6A, 0x20, 0x06, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x7E, 0xFE, 0x97, 0xF8, 0x47,
    		   0x06, 0x00, 0x28, 0x40, 0xF0, 0xD0, 0x80, 0x46, 0xF6, 0x78, 0x60, 0xC0, 0xF2, 0x00, 0x00, 0x00,
    		   0x5D, 0x10, 0x38, 0xC1, 0xB2, 0x47, 0xF6, 0x44, 0x70, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x6C,
    		   0xFE, 0x47, 0xF6, 0x0E, 0x51, 0x48, 0x46, 0xC2, 0xF2, 0x32, 0x01, 0x81, 0xF8, 0x00, 0x80, 0xBD,
    		   0xE8, 0xF8, 0x83, 0x97, 0xF8, 0x47, 0x06, 0x00, 0x28, 0x37, 0xD1, 0x47, 0xF6, 0x4C, 0x70, 0xC2,
    		   0xF2, 0x32, 0x00, 0x47, 0xF6, 0x60, 0x01, 0x05, 0xF0, 0x73, 0xFE, 0x47, 0xF6, 0x44, 0x70, 0x47,
    		   0xF6, 0x60, 0x01, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x6B, 0xFE, 0x41, 0xF6, 0x46, 0x40, 0xC2,
    		   0xF2, 0x00, 0x00, 0x00, 0x78, 0x08, 0xBB, 0x46, 0xF6, 0x78, 0x60, 0xC0, 0xF2, 0x00, 0x00, 0x00,
    		   0x5D, 0x10, 0x38, 0xC1, 0xB2, 0x47, 0xF6, 0x48, 0x70, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x43,
    		   0xFE, 0x97, 0xF8, 0x4A, 0x06, 0x06, 0x21, 0x04, 0x28, 0x09, 0xD0, 0x01, 0x28, 0x0D, 0xD1, 0x47,
    		   0xF6, 0x40, 0x40, 0xC2, 0xF2, 0x32, 0x00, 0x06, 0x21, 0x05, 0xF0, 0x2E, 0xFE, 0x05, 0xE0, 0x47,
    		   0xF6, 0x70, 0x40, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x27, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x01,
    		   0x05, 0xFF, 0xCD, 0xDC, 0x09, 0x1B, 0x00, 0xC8, 0xC2, 0xF2, 0x32, 0x00, 0x09, 0x21, 0x05, 0xF0,
    		   0x27, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x20, 0xFE,
    		   0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x19, 0xFE, 0x0A, 0x20,
    		   0x04, 0xF0, 0x84, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0,
    		   0x08, 0xFE, 0x40, 0xF6, 0x6A, 0x20, 0x08, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x08, 0xFE,
    		   0x40, 0xF6, 0x6A, 0x20, 0x06, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x01, 0xFE, 0x48, 0x46,
    		   0xBD, 0xE8, 0xF8, 0x83, 0x97, 0xF8, 0x47, 0x06, 0x46, 0xF6, 0x78, 0x65, 0xC0, 0xF2, 0x00, 0x05,
    		   0x00, 0x28, 0x30, 0xD1, 0x28, 0x5D, 0x86, 0xB9, 0x10, 0x38, 0xC1, 0xB2, 0x47, 0xF6, 0x4C, 0x70,
    		   0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xEC, 0xFD, 0x28, 0x5D, 0x10, 0x38, 0xC4, 0xB2, 0x41, 0xF6,
    		   0x46, 0x40, 0xC2, 0xF2, 0x00, 0x00, 0x00, 0x78, 0x0D, 0xE0, 0x10, 0x38, 0xC4, 0xB2, 0x47, 0xF6,
    		   0x4C, 0x70, 0x21, 0x46, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xD3, 0xFD, 0x41, 0xF6, 0x46, 0x40,
    		   0xC2, 0xF2, 0x00, 0x00, 0x00, 0x78, 0x38, 0xB9, 0x47, 0xF6, 0x48, 0x70, 0xC2, 0xF2, 0x32, 0x00,
    		   0x21, 0x46, 0x05, 0xF0, 0xCD, 0xFD, 0x06, 0xE0, 0x21, 0x46, 0x47, 0xF6, 0x48, 0x70, 0xC2, 0xF2,
    		   0x01, 0x05, 0xFF, 0xCD, 0xA4, 0x0A, 0x1B, 0x00, 0xC8, 0x32, 0x00, 0x05, 0xF0, 0xBE, 0xFD, 0x40,
    		   0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x09, 0x21, 0x05, 0xF0, 0xBE, 0xFD, 0x40, 0xF6, 0x6A,
    		   0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xB7, 0xFD, 0x40, 0xF6, 0x6A, 0x20, 0x07,
    		   0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0xB0, 0xFD, 0x01, 0x20, 0xBD, 0xE8, 0xF8, 0x83, 0x97,
    		   0xF8, 0x47, 0x06, 0x58, 0xBB, 0x47, 0xF6, 0x4C, 0x70, 0xC2, 0xF2, 0x32, 0x00, 0x47, 0xF6, 0x60,
    		   0x01, 0x05, 0xF0, 0xB7, 0xFD, 0x47, 0xF6, 0x44, 0x70, 0x47, 0xF6, 0x60, 0x01, 0xC2, 0xF2, 0x32,
    		   0x00, 0x05, 0xF0, 0xAF, 0xFD, 0x47, 0xF6, 0x0E, 0x50, 0x0B, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05,
    		   0xF0, 0x93, 0xFD, 0x97, 0xF8, 0x4A, 0x06, 0x06, 0x21, 0x04, 0x28, 0x09, 0xD0, 0x01, 0x28, 0x0D,
    		   0xD1, 0x47, 0xF6, 0x40, 0x40, 0xC2, 0xF2, 0x32, 0x00, 0x06, 0x21, 0x05, 0xF0, 0x7E, 0xFD, 0x05,
    		   0xE0, 0x47, 0xF6, 0x70, 0x40, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x77, 0xFD, 0x40, 0xF6, 0x6A,
    		   0x20, 0xC2, 0xF2, 0x32, 0x00, 0x09, 0x21, 0x05, 0xF0, 0x77, 0xFD, 0x40, 0xF6, 0x6A, 0x20, 0x02,
    		   0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x70, 0xFD, 0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2,
    		   0xF2, 0x32, 0x00, 0x05, 0xF0, 0x69, 0xFD, 0x0A, 0x20, 0x04, 0xF0, 0xD4, 0xFD, 0x40, 0xF6, 0x6A,
    		   0x20, 0x01, 0x05, 0xFF, 0xBD, 0x6C, 0x0B, 0x1B, 0x00, 0xB8, 0x09, 0x21, 0xC2, 0xF2, 0x32, 0x00,
    		   0x05, 0xF0, 0x58, 0xFD, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0,
    		   0x58, 0xFD, 0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x4A, 0xFD,
    		   0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x43, 0xFD, 0x40, 0xF6,
    		   0x6A, 0x20, 0x08, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x43, 0xFD, 0x40, 0xF6, 0x6A, 0x20,
    		   0x06, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x05, 0xF0, 0x3C, 0xFD, 0x01, 0x20, 0xBD, 0xE8, 0xF8, 0x83,
    		   0x00, 0x00, 0x01, 0x05, 0xFF, 0x11, 0xA4, 0x12, 0x1B, 0x00, 0x0C, 0x4B, 0x46, 0xA1, 0x62, 0x20,
    		   0x79, 0x01, 0x22, 0x19, 0x46, 0xFF, 0xF7, 0x01, 0x05, 0xFF, 0x09, 0x30, 0x13, 0x1B, 0x00, 0x04,
    		   0x31, 0x46, 0xFF, 0xF7, 0x01, 0x05, 0xFF, 0x0D, 0x1C, 0x14, 0x1B, 0x00, 0x08, 0x20, 0x79, 0x1A,
    		   0x46, 0x19, 0x46, 0xFF, 0xF7, 0x01, 0x05, 0xFF, 0xCD, 0xA4, 0x1B, 0x1B, 0x00, 0xC8, 0x2D, 0xE9,
    		   0xF0, 0x47, 0x41, 0xF6, 0xAC, 0x31, 0xC2, 0xF2, 0x00, 0x01, 0x41, 0xF6, 0x30, 0x46, 0x41, 0xF2,
    		   0x30, 0x14, 0x01, 0xF1, 0x14, 0x07, 0xC2, 0xF2, 0x00, 0x06, 0xBA, 0x88, 0xC2, 0xF2, 0x00, 0x04,
    		   0x38, 0x7A, 0x01, 0x25, 0xB2, 0x82, 0x83, 0x01, 0x41, 0xF6, 0x86, 0x42, 0xC2, 0xF2, 0x00, 0x02,
    		   0x84, 0xF8, 0x24, 0x00, 0x03, 0xEB, 0x40, 0x13, 0x15, 0x70, 0xC2, 0x01, 0x02, 0xEB, 0x80, 0x02,
    		   0xA2, 0x18, 0x28, 0x32, 0xF8, 0x79, 0x22, 0x60, 0x40, 0xF2, 0x00, 0x02, 0xA0, 0x72, 0xC2, 0xF2,
    		   0x00, 0x02, 0x02, 0xF2, 0x4C, 0x68, 0xB8, 0x79, 0xD2, 0x18, 0x38, 0x32, 0x62, 0x60, 0x0A, 0x7F,
    		   0xE0, 0x72, 0xD0, 0x01, 0x00, 0xEB, 0x82, 0x00, 0x20, 0x18, 0x54, 0x30, 0x91, 0xE8, 0x0C, 0x00,
    		   0x08, 0x31, 0x80, 0xE8, 0x0C, 0x00, 0x08, 0x22, 0x04, 0xF1, 0x0C, 0x00, 0x03, 0xF0, 0x3C, 0xFC,
    		   0xE0, 0x7A, 0x61, 0x68, 0x81, 0xF8, 0x44, 0x00, 0x20, 0x68, 0x90, 0xF8, 0x37, 0x00, 0x00, 0x28,
    		   0x04, 0xBF, 0x0F, 0x20, 0xF0, 0x75, 0x04, 0xD0, 0x94, 0xF8, 0x24, 0x00, 0x00, 0x1D, 0xC0, 0xB2,
    		   0xF0, 0x75, 0xA3, 0x7A, 0x4F, 0xF0, 0x00, 0x0A, 0x86, 0xF8, 0x16, 0xA0, 0x52, 0x46, 0x04, 0x21,
    		   0xFE, 0xF7, 0x74, 0xFD, 0x41, 0xF2, 0x30, 0x19, 0xC2, 0xF2, 0x00, 0x09, 0xD9, 0xF8, 0x00, 0x10,
    		   0xA3, 0x7A, 0xF0, 0x7D, 0x91, 0xF8, 0x01, 0x05, 0xFF, 0xCD, 0x6C, 0x1C, 0x1B, 0x00, 0xC8, 0x3A,
    		   0x10, 0x2A, 0x46, 0xFE, 0xF7, 0x67, 0xFD, 0x14, 0x20, 0x03, 0xF0, 0x4B, 0xFD, 0x25, 0x72, 0x48,
    		   0xF2, 0x22, 0x0E, 0xB5, 0x75, 0x65, 0x72, 0x41, 0xF6, 0x2C, 0x23, 0xD9, 0xF8, 0x00, 0x20, 0xC2,
    		   0xF2, 0x20, 0x0E, 0x77, 0x21, 0x82, 0xF8, 0x00, 0xA0, 0x82, 0xF8, 0x06, 0xA0, 0x84, 0xF8, 0x25,
    		   0xA0, 0xD9, 0xF8, 0x04, 0x00, 0x4F, 0xF6, 0xFF, 0x7C, 0xC2, 0xF2, 0x00, 0x03, 0x80, 0xF8, 0x42,
    		   0xA0, 0xAE, 0xF8, 0x00, 0x10, 0xAE, 0xF8, 0x06, 0xC0, 0x40, 0xF6, 0x00, 0x3C, 0xD9, 0xF8, 0x00,
    		   0x10, 0xC2, 0xF2, 0x00, 0x0C, 0x02, 0xF1, 0x6C, 0x0E, 0x01, 0xF1, 0x3B, 0x00, 0x0C, 0xF1, 0x8D,
    		   0x01, 0xA3, 0xF8, 0x70, 0xE0, 0xA3, 0xF8, 0x68, 0x00, 0xD9, 0xF8, 0x04, 0xE0, 0xA3, 0xF8, 0x4A,
    		   0x10, 0x0C, 0xF1, 0xCD, 0x00, 0x0E, 0xF1, 0x28, 0x01, 0x1F, 0xFA, 0x81, 0xFC, 0x02, 0xF1, 0x54,
    		   0x01, 0x1F, 0xFA, 0x81, 0xFE, 0xA3, 0xF8, 0x08, 0xC0, 0x02, 0xF1, 0x44, 0x01, 0x89, 0xB2, 0xA3,
    		   0xF8, 0x38, 0xE0, 0x19, 0x85, 0x41, 0xF6, 0x6C, 0x13, 0xC2, 0xF2, 0x00, 0x03, 0x58, 0x87, 0xA3,
    		   0xF8, 0x70, 0xE0, 0xA3, 0xF8, 0x08, 0xC0, 0x19, 0x85, 0x10, 0x6C, 0xA3, 0xF8, 0x60, 0x10, 0x04,
    		   0xF0, 0xDD, 0xF9, 0xD9, 0xF8, 0x00, 0x00, 0x01, 0x6C, 0x49, 0x08, 0x2E, 0xBF, 0xA8, 0xF8, 0x04,
    		   0xA0, 0x02, 0x21, 0xA8, 0xF8, 0x04, 0x10, 0x01, 0x05, 0xFF, 0xAD, 0x34, 0x1D, 0x1B, 0x00, 0xA8,
    		   0xB8, 0xF8, 0x00, 0x10, 0x90, 0xF8, 0x3A, 0x30, 0x94, 0xF8, 0x0A, 0xE0, 0x09, 0x07, 0x49, 0x0E,
    		   0x43, 0xF2, 0x00, 0x02, 0x41, 0xEA, 0xCE, 0x11, 0x01, 0x2B, 0x4F, 0xEA, 0x8E, 0x1C, 0xC2, 0xF2,
    		   0x31, 0x02, 0x91, 0x83, 0xB6, 0xF8, 0x14, 0xE0, 0xA2, 0xF8, 0x1E, 0xC0, 0x15, 0x84, 0x3F, 0x68,
    		   0x2E, 0xD0, 0x2C, 0x30, 0x90, 0xE8, 0x03, 0x00, 0x36, 0x1D, 0x42, 0xF2, 0x48, 0x4C, 0x86, 0xE8,
    		   0x03, 0x00, 0xC2, 0xF2, 0x31, 0x0C, 0xAC, 0xF8, 0x02, 0xE0, 0x4F, 0xF0, 0x15, 0x0A, 0xAC, 0xF8,
    		   0x00, 0xA0, 0xBC, 0xF8, 0x00, 0x00, 0x15, 0x28, 0x02, 0xD0, 0x5E, 0x20, 0x04, 0xF0, 0x6B, 0xFC,
    		   0x40, 0xF2, 0x00, 0x00, 0xC2, 0xF2, 0x00, 0x00, 0x90, 0xF8, 0x05, 0x36, 0x4F, 0xF2, 0x04, 0x01,
    		   0xC2, 0xF2, 0x32, 0x01, 0x10, 0x2B, 0x04, 0xDA, 0x0A, 0x88, 0x28, 0x46, 0x98, 0x40, 0x10, 0x43,
    		   0x08, 0x80, 0x28, 0x46, 0x01, 0xF0, 0x79, 0xFF, 0x03, 0xF0, 0xF6, 0xF8, 0xBD, 0xE8, 0xF0, 0x87,
    		   0x2C, 0x30, 0x90, 0xE8, 0x03, 0x00, 0x0C, 0x36, 0x86, 0xE8, 0x03, 0x00, 0x27, 0x83, 0x01, 0xF0,
    		   0x64, 0xF8, 0xBD, 0xE8, 0xF0, 0x87, 0x2D, 0xE9, 0x01, 0x05, 0xFF, 0x11, 0x2C, 0x21, 0x1B, 0x00,
    		   0x0C, 0xF1, 0xFA, 0x00, 0x21, 0x30, 0x79, 0x0A, 0x46, 0x0B, 0x46, 0xFE, 0xF7, 0x01, 0x05, 0xFF,
    		   0xCD, 0xC0, 0x21, 0x1B, 0x00, 0xC8, 0x2D, 0xE9, 0xF0, 0x43, 0xAD, 0xF1, 0x0C, 0x0D, 0x41, 0xF6,
    		   0xAC, 0x35, 0x41, 0xF6, 0x44, 0x49, 0xC2, 0xF2, 0x00, 0x05, 0xC2, 0xF2, 0x00, 0x09, 0xA8, 0x8A,
    		   0x03, 0x21, 0x6F, 0x8A, 0xA9, 0xF8, 0x00, 0x00, 0x2C, 0x8A, 0x40, 0xF2, 0x0A, 0x50, 0xC2, 0xF2,
    		   0x32, 0x00, 0x04, 0xF0, 0x5F, 0xFA, 0x40, 0xF2, 0x00, 0x06, 0xC2, 0xF2, 0x30, 0x06, 0xB0, 0x46,
    		   0x48, 0xEA, 0x07, 0x08, 0x08, 0xF1, 0x01, 0x08, 0x46, 0xEA, 0x04, 0x06, 0x38, 0xB9, 0x03, 0x21,
    		   0x40, 0xF2, 0x1E, 0x50, 0xC2, 0xF2, 0x32, 0x00, 0x04, 0xF0, 0x4C, 0xFA, 0x20, 0xB1, 0xB9, 0xF8,
    		   0x00, 0x00, 0x00, 0x28, 0x00, 0xF0, 0xAC, 0x80, 0x40, 0xF6, 0x31, 0x31, 0xC2, 0xF2, 0x00, 0x01,
    		   0x04, 0x22, 0x68, 0x46, 0x03, 0xF0, 0x36, 0xF9, 0x00, 0x98, 0x03, 0xF0, 0x51, 0xFF, 0x01, 0xA8,
    		   0x04, 0xF0, 0xE6, 0xF8, 0x41, 0xF6, 0x5C, 0x34, 0xC2, 0xF2, 0x00, 0x04, 0x04, 0xF1, 0x0C, 0x07,
    		   0x08, 0x22, 0x05, 0xF1, 0x08, 0x01, 0x07, 0xF1, 0x0C, 0x00, 0x03, 0xF0, 0x23, 0xF9, 0xE8, 0x7D,
    		   0x84, 0xF8, 0x31, 0x00, 0x04, 0xF0, 0x5B, 0xF8, 0x29, 0x7E, 0x84, 0xF8, 0x36, 0x00, 0x00, 0x22,
    		   0x84, 0xF8, 0x30, 0x10, 0x31, 0xF0, 0x01, 0x03, 0x08, 0xBF, 0x01, 0x22, 0x01, 0x20, 0x00, 0x29,
    		   0x84, 0xF8, 0x2E, 0x20, 0x1C, 0xBF, 0x06, 0x29, 0x00, 0x20, 0x2A, 0x8A, 0x69, 0x8A, 0x01, 0x05,
    		   0xFF, 0xCD, 0x88, 0x22, 0x1B, 0x00, 0xC8, 0x84, 0xF8, 0x2F, 0x00, 0xA2, 0x84, 0xE1, 0x84, 0x70,
    		   0x78, 0x00, 0xF0, 0x3F, 0x00, 0xC1, 0x00, 0x50, 0x31, 0x84, 0xF8, 0x34, 0x00, 0x21, 0x85, 0x98,
    		   0xF8, 0x00, 0x00, 0x00, 0xF0, 0x3F, 0x00, 0xC1, 0x00, 0x50, 0x31, 0x84, 0xF8, 0x35, 0x00, 0x61,
    		   0x85, 0x30, 0x78, 0x06, 0x22, 0xB1, 0x1C, 0x80, 0x11, 0x00, 0xF0, 0x01, 0x00, 0x84, 0xF8, 0x37,
    		   0x00, 0x38, 0x46, 0x03, 0xF0, 0xEB, 0xF8, 0x94, 0xF8, 0x30, 0x00, 0x01, 0x28, 0x09, 0xD1, 0x30,
    		   0x78, 0x06, 0xF1, 0x08, 0x01, 0xC2, 0x11, 0xB8, 0x1D, 0x84, 0xF8, 0x38, 0x20, 0x06, 0x22, 0x03,
    		   0xF0, 0xDD, 0xF8, 0xA8, 0x7D, 0x4F, 0xF0, 0x01, 0x02, 0x30, 0xB9, 0x04, 0xF0, 0x04, 0xF8, 0x84,
    		   0xF8, 0x33, 0x00, 0x94, 0xF8, 0x30, 0x00, 0x10, 0xE0, 0x94, 0xF8, 0x31, 0x10, 0x94, 0xF8, 0x33,
    		   0x00, 0x40, 0x1C, 0xC0, 0xB2, 0x03, 0x28, 0x08, 0xBF, 0x00, 0x20, 0x02, 0xFA, 0x00, 0xF3, 0x19,
    		   0x42, 0xF6, 0xD0, 0x84, 0xF8, 0x33, 0x00, 0x94, 0xF8, 0x30, 0x00, 0x01, 0x28, 0x07, 0xD0, 0x00,
    		   0x25, 0x89, 0xF8, 0x03, 0x50, 0x89, 0xF8, 0x02, 0x50, 0x28, 0x46, 0x01, 0x26, 0x06, 0xE0, 0x10,
    		   0x20, 0x01, 0x26, 0x89, 0xF8, 0x03, 0x00, 0x00, 0x25, 0x89, 0xF8, 0x02, 0x60, 0x94, 0xF8, 0x33,
    		   0x10, 0x41, 0xF6, 0x2C, 0x42, 0xC2, 0xF2, 0x00, 0x02, 0x53, 0x5C, 0x04, 0x21, 0x2A, 0x46, 0x01,
    		   0x05, 0xFF, 0x51, 0x50, 0x23, 0x1B, 0x00, 0x4C, 0xFE, 0xF7, 0xF7, 0xF9, 0x43, 0xF2, 0x20, 0x00,
    		   0x84, 0xF8, 0x39, 0x50, 0x40, 0xF2, 0x0D, 0x02, 0xC2, 0xF2, 0x31, 0x00, 0x84, 0xF8, 0x32, 0x50,
    		   0xC2, 0xF2, 0x00, 0x02, 0x06, 0x80, 0x21, 0x8D, 0x15, 0x70, 0x28, 0x46, 0x00, 0xF0, 0x20, 0xFE,
    		   0x06, 0xE0, 0x11, 0x20, 0x89, 0xF8, 0x03, 0x00, 0x00, 0x21, 0x01, 0x20, 0x01, 0xF0, 0x4F, 0xFA,
    		   0x03, 0xB0, 0xBD, 0xE8, 0xF0, 0x83, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x70, 0x47, 0x01, 0x05, 0xFF, 0x09, 0x7C, 0x24, 0x1B, 0x00, 0x04, 0x04, 0xF0, 0xE8,
    		   0xFD, 0x01, 0x05, 0xFF, 0x09, 0xD4, 0x26, 0x1B, 0x00, 0x04, 0x78, 0xB5, 0x02, 0xF0, 0x01, 0x05,
    		   0xFF, 0xCD, 0x14, 0x27, 0x1B, 0x00, 0xC8, 0x00, 0x28, 0x42, 0xD0, 0x0A, 0x20, 0x02, 0xF0, 0xF9,
    		   0xFF, 0x20, 0x68, 0x90, 0xF8, 0x3A, 0x00, 0x01, 0x28, 0x2C, 0xD1, 0x96, 0xF8, 0x47, 0x06, 0x4F,
    		   0xF0, 0x00, 0x01, 0xA9, 0x82, 0x80, 0xB9, 0x47, 0xF6, 0x48, 0x70, 0xC2, 0xF2, 0x32, 0x00, 0x05,
    		   0x21, 0x03, 0xF0, 0x72, 0xFF, 0x96, 0xF8, 0x47, 0x06, 0x30, 0xB9, 0x05, 0x21, 0x47, 0xF6, 0x4C,
    		   0x70, 0xC2, 0xF2, 0x32, 0x00, 0x03, 0xF0, 0x6F, 0xFF, 0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32,
    		   0x00, 0x09, 0x21, 0x03, 0xF0, 0x68, 0xFF, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32,
    		   0x00, 0x03, 0xF0, 0x61, 0xFF, 0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x03,
    		   0xF0, 0x5A, 0xFF, 0x0D, 0xE0, 0x09, 0x21, 0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0x03,
    		   0xF0, 0x52, 0xFF, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0x03, 0xF0, 0x4B,
    		   0xFF, 0x03, 0xF0, 0x80, 0xFB, 0x00, 0x20, 0x60, 0x72, 0x20, 0x68, 0x81, 0x1D, 0x91, 0xF8, 0x34,
    		   0x20, 0x01, 0x2A, 0x0C, 0xD1, 0x09, 0x78, 0x51, 0xB9, 0x61, 0x68, 0x4F, 0xF0, 0x01, 0x02, 0x81,
    		   0xF8, 0x5E, 0x20, 0x90, 0xF8, 0x37, 0x10, 0x11, 0xB9, 0x02, 0xF0, 0xE9, 0xFA, 0x20, 0x68, 0xC0,
    		   0x6E, 0x00, 0xF0, 0x03, 0x00, 0x03, 0x28, 0x29, 0xD1, 0x96, 0xF8, 0x0B, 0x16, 0x4F, 0xF2, 0x01,
    		   0x05, 0xFF, 0xCD, 0xDC, 0x27, 0x1B, 0x00, 0xC8, 0x04, 0x02, 0xC2, 0xF2, 0x32, 0x02, 0x10, 0x29,
    		   0x0B, 0xDA, 0x13, 0x88, 0x01, 0x20, 0x00, 0xFA, 0x01, 0xF1, 0x19, 0x43, 0x11, 0x80, 0x96, 0xF8,
    		   0x0B, 0x36, 0x11, 0x88, 0x98, 0x40, 0x81, 0x43, 0x11, 0x80, 0x94, 0xF8, 0x24, 0x30, 0xD9, 0x01,
    		   0x01, 0xEB, 0x83, 0x01, 0x60, 0x18, 0x09, 0x19, 0x28, 0x31, 0x28, 0x30, 0x82, 0x6C, 0x0C, 0x6F,
    		   0x45, 0x6C, 0x10, 0x06, 0x91, 0xF8, 0x35, 0x20, 0x21, 0x78, 0x40, 0xEA, 0x15, 0x20, 0x00, 0x90,
    		   0xA6, 0x20, 0x03, 0xF0, 0x46, 0xFD, 0x78, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0xB5, 0xAD, 0xF1, 0x08, 0x0D, 0x41, 0xF6, 0xBC, 0x24,
    		   0x41, 0xF6, 0x30, 0x45, 0xC2, 0xF2, 0x00, 0x04, 0x20, 0x88, 0xC2, 0xF2, 0x00, 0x05, 0x03, 0x21,
    		   0xA8, 0x82, 0x40, 0xF2, 0x0A, 0x50, 0xC2, 0xF2, 0x32, 0x00, 0x03, 0xF0, 0x1E, 0xFF, 0x38, 0xB9,
    		   0x40, 0xF2, 0x1E, 0x50, 0xC2, 0xF2, 0x32, 0x00, 0x03, 0x21, 0x03, 0xF0, 0x16, 0xFF, 0x10, 0xB1,
    		   0xA8, 0x8A, 0x00, 0x28, 0x7D, 0xD0, 0x40, 0xF6, 0x31, 0x31, 0xC2, 0xF2, 0x00, 0x01, 0x04, 0x22,
    		   0x01, 0xA8, 0x02, 0xF0, 0x02, 0xFE, 0x01, 0x98, 0x03, 0xF0, 0x1D, 0xFC, 0x41, 0xF6, 0x2C, 0x42,
    		   0x01, 0x05, 0xFF, 0xCD, 0xA4, 0x28, 0x1B, 0x00, 0xC8, 0xE0, 0x78, 0x01, 0x26, 0xC2, 0xF2, 0x00,
    		   0x02, 0xA0, 0x70, 0x20, 0x79, 0xA1, 0x78, 0xAE, 0x75, 0xE8, 0x75, 0x53, 0x5C, 0x00, 0x22, 0x04,
    		   0x21, 0xFD, 0xF7, 0x41, 0xFF, 0x20, 0x79, 0x00, 0x26, 0xE6, 0x62, 0x01, 0x28, 0x1B, 0xD0, 0x40,
    		   0xF6, 0x90, 0x42, 0xC2, 0xF2, 0x30, 0x02, 0x40, 0xF2, 0x00, 0x05, 0x91, 0x1C, 0xC2, 0xF2, 0x00,
    		   0x05, 0x02, 0x23, 0x04, 0xF1, 0x0F, 0x00, 0x62, 0x63, 0x85, 0xF8, 0x32, 0x30, 0x06, 0x22, 0x02,
    		   0xF0, 0xD8, 0xFD, 0x61, 0x6B, 0x06, 0x22, 0x04, 0xF1, 0x17, 0x00, 0x08, 0x31, 0x02, 0xF0, 0xD1,
    		   0xFD, 0x40, 0xF2, 0xF4, 0x53, 0x16, 0xE0, 0x40, 0xF2, 0x00, 0x01, 0xC2, 0xF2, 0x30, 0x01, 0x40,
    		   0xF2, 0x00, 0x05, 0xC2, 0xF2, 0x00, 0x05, 0x02, 0x23, 0x01, 0xF5, 0x48, 0x62, 0xE0, 0x1D, 0x01,
    		   0xF6, 0x82, 0x41, 0xAE, 0x77, 0x6E, 0x77, 0x2B, 0x77, 0x62, 0x63, 0x06, 0x22, 0x02, 0xF0, 0xB9,
    		   0xFD, 0x40, 0xF2, 0xF4, 0x53, 0x02, 0xF0, 0xD2, 0xFB, 0xE8, 0x5A, 0x80, 0x08, 0x0C, 0xD3, 0x41,
    		   0xF6, 0xAC, 0x30, 0xC2, 0xF2, 0x00, 0x00, 0x85, 0x89, 0x83, 0x68, 0x82, 0x88, 0x01, 0x68, 0x00,
    		   0x95, 0x40, 0xF2, 0xA5, 0x10, 0x03, 0xF0, 0xA0, 0xFC, 0x04, 0xF1, 0x4A, 0x00, 0x31, 0x46, 0x06,
    		   0x22, 0x03, 0xF0, 0x06, 0xF9, 0x84, 0xF8, 0x50, 0x60, 0x06, 0x22, 0x31, 0x46, 0x04, 0xF1, 0x1E,
    		   0x00, 0x01, 0x05, 0xFF, 0x41, 0x6C, 0x29, 0x1B, 0x00, 0x3C, 0x03, 0xF0, 0xFE, 0xF8, 0x43, 0xF2,
    		   0x20, 0x00, 0x03, 0x21, 0x84, 0xF8, 0x24, 0x60, 0xC2, 0xF2, 0x31, 0x00, 0x01, 0x80, 0x03, 0xF0,
    		   0x0C, 0xF8, 0x04, 0xE0, 0x11, 0x20, 0xE8, 0x75, 0x01, 0x20, 0x01, 0xF0, 0x85, 0xFD, 0x02, 0xB0,
    		   0x70, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF, 0xCD, 0x44, 0x2C, 0x1B, 0x00, 0xC8, 0xF0,
    		   0x83, 0x2D, 0xE9, 0xF0, 0x43, 0xAD, 0xF1, 0x08, 0x0D, 0x40, 0xF2, 0x4E, 0x68, 0xC2, 0xF2, 0x00,
    		   0x08, 0x06, 0x46, 0xB8, 0xF8, 0x00, 0x00, 0x41, 0xF6, 0x28, 0x44, 0xC2, 0xF2, 0x00, 0x04, 0x68,
    		   0xB1, 0x41, 0xF6, 0x34, 0x40, 0xC2, 0xF2, 0x00, 0x00, 0x03, 0x46, 0x41, 0xF6, 0x28, 0x44, 0x6F,
    		   0xF0, 0x01, 0x02, 0x00, 0x21, 0x02, 0xF0, 0x02, 0xFE, 0xC2, 0xF2, 0x00, 0x04, 0x20, 0x8A, 0xA1,
    		   0x89, 0x48, 0xF2, 0x00, 0x05, 0xCF, 0xF6, 0xFF, 0x75, 0x46, 0xF2, 0x0A, 0x07, 0xC2, 0xF2, 0x20,
    		   0x07, 0x28, 0x43, 0xA7, 0xF8, 0x4C, 0x10, 0xA7, 0xF8, 0x4A, 0x00, 0x32, 0x7B, 0x31, 0x68, 0x05,
    		   0x20, 0x02, 0xF0, 0x10, 0xFE, 0xB0, 0x7B, 0x04, 0xF1, 0x0C, 0x09, 0x14, 0x34, 0x00, 0x28, 0x1A,
    		   0xBF, 0x30, 0x89, 0x80, 0x1C, 0x30, 0x89, 0x71, 0x89, 0x4F, 0xF0, 0x64, 0x0E, 0x40, 0x18, 0x45,
    		   0xEA, 0xC0, 0x00, 0x78, 0x84, 0xA7, 0xF8, 0x00, 0xE0, 0x38, 0x88, 0xC0, 0x09, 0x02, 0xD3, 0x38,
    		   0x88, 0xC0, 0x09, 0xFC, 0xD2, 0x48, 0xF2, 0x18, 0x01, 0x4F, 0xF6, 0xFF, 0x70, 0xC2, 0xF2, 0x20,
    		   0x01, 0xC8, 0x81, 0xB8, 0xF8, 0x00, 0x00, 0x20, 0xB1, 0x41, 0xF6, 0xF8, 0x60, 0xC2, 0xF2, 0x00,
    		   0x00, 0x08, 0x80, 0xB0, 0x88, 0x08, 0x80, 0xB8, 0xF8, 0x00, 0x00, 0x31, 0x89, 0x23, 0x46, 0x00,
    		   0xEB, 0xC1, 0x00, 0x50, 0x30, 0x80, 0xB2, 0x01, 0x05, 0xFF, 0x75, 0x0C, 0x2D, 0x1B, 0x00, 0x70,
    		   0x00, 0x21, 0x02, 0xB2, 0xAD, 0xF8, 0x04, 0x00, 0x48, 0x46, 0x02, 0xF0, 0xB4, 0xFD, 0xBD, 0xF8,
    		   0x04, 0x00, 0x6B, 0x46, 0x00, 0x21, 0x40, 0x1C, 0x02, 0xB2, 0x48, 0x46, 0x02, 0xF0, 0xAB, 0xFD,
    		   0xBD, 0xF8, 0x04, 0x10, 0xBD, 0xF8, 0x00, 0x00, 0x02, 0xB0, 0x0D, 0x43, 0xA7, 0xF8, 0x48, 0x00,
    		   0xA7, 0xF8, 0x46, 0x50, 0xBD, 0xE8, 0xF0, 0x83, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xB5,
    		   0x01, 0x05, 0xFF, 0x09, 0xB4, 0x30, 0x1B, 0x00, 0x04, 0x5B, 0x5C, 0x02, 0x21, 0x01, 0x05, 0xFF,
    		   0x11, 0x38, 0x39, 0x1B, 0x00, 0x0C, 0x00, 0x21, 0xC2, 0xF2, 0x00, 0x04, 0x0A, 0x46, 0x20, 0x79,
    		   0x0B, 0x46, 0x01, 0x05, 0xFF, 0x15, 0x90, 0x41, 0x1B, 0x00, 0x10, 0x30, 0x40, 0x00, 0x21, 0xC2,
    		   0xF2, 0x00, 0x00, 0x0A, 0x46, 0xC0, 0x7D, 0x0B, 0x46, 0xFC, 0xF7, 0x01, 0x05, 0xFF, 0x09, 0x08,
    		   0x4A, 0x1B, 0x00, 0x04, 0x19, 0x46, 0x1A, 0x46, 0x01, 0x05, 0xFF, 0x71, 0x58, 0x4C, 0x1B, 0x00,
    		   0x6C, 0x10, 0xB5, 0x04, 0x46, 0x41, 0xF2, 0x24, 0x03, 0x46, 0xF2, 0x0E, 0x00, 0x4F, 0xF6, 0xFC,
    		   0x71, 0x1F, 0x22, 0xC2, 0xF2, 0x20, 0x00, 0xC2, 0xF2, 0x31, 0x03, 0xA0, 0xF8, 0x5A, 0x10, 0x06,
    		   0x21, 0x1A, 0x80, 0x4F, 0xF4, 0xB6, 0x42, 0x01, 0x83, 0x18, 0x21, 0xC2, 0x82, 0x4F, 0xF4, 0x08,
    		   0x52, 0x41, 0x83, 0x07, 0x21, 0x02, 0x80, 0x41, 0x80, 0x02, 0xF0, 0x44, 0xFA, 0x01, 0x2C, 0x0E,
    		   0xD1, 0x43, 0xF2, 0x00, 0x00, 0xC2, 0xF2, 0x31, 0x00, 0x00, 0x21, 0xC1, 0x83, 0x81, 0x83, 0x47,
    		   0xF6, 0x44, 0x70, 0xC2, 0xF2, 0x32, 0x00, 0x47, 0xF6, 0x60, 0x01, 0x01, 0xF0, 0xD4, 0xFC, 0x10,
    		   0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF,
    		   0x09, 0xD0, 0x4F, 0x1B, 0x00, 0x04, 0xE8, 0x7D, 0x02, 0x21, 0x01, 0x05, 0xFF, 0x69, 0x14, 0x50,
    		   0x1B, 0x00, 0x64, 0xAD, 0xF1, 0x14, 0x0D, 0x4F, 0xF0, 0x00, 0x04, 0x03, 0xB9, 0x01, 0x24, 0x41,
    		   0xF6, 0x28, 0x43, 0x45, 0xF2, 0x55, 0x5C, 0x41, 0xF6, 0x0C, 0x46, 0xC2, 0xF2, 0x00, 0x03, 0x02,
    		   0x90, 0xC0, 0xF2, 0x55, 0x0C, 0xC2, 0xF2, 0x00, 0x06, 0x00, 0x27, 0x9A, 0x18, 0x03, 0x91, 0x8D,
    		   0xF8, 0x11, 0x40, 0x15, 0x79, 0xCD, 0xF8, 0x00, 0xC0, 0x03, 0xF1, 0x14, 0x00, 0x01, 0x96, 0x40,
    		   0xF2, 0x4E, 0x62, 0xC2, 0xF2, 0x00, 0x02, 0x8D, 0xF8, 0x10, 0x50, 0x17, 0x80, 0x01, 0xF0, 0xD4,
    		   0xF9, 0x68, 0x46, 0xFD, 0xF7, 0x89, 0xFE, 0x05, 0xB0, 0xF0, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB5, 0x01, 0x05, 0xFF, 0x59, 0x58, 0x52, 0x1B, 0x00, 0x54,
    		   0xFC, 0x32, 0x41, 0xF6, 0x2C, 0x4C, 0xC2, 0xF2, 0x00, 0x02, 0xC2, 0xF2, 0x00, 0x0C, 0x40, 0xF2,
    		   0x4E, 0x63, 0x45, 0xF2, 0x55, 0x57, 0x00, 0x26, 0x91, 0x89, 0x01, 0x25, 0x1C, 0xF8, 0x00, 0x00,
    		   0x02, 0x24, 0xC2, 0xF2, 0x00, 0x03, 0xC0, 0xF2, 0x55, 0x07, 0x6F, 0xF3, 0x9F, 0x21, 0x8D, 0xF8,
    		   0x0C, 0x00, 0xAD, 0xF8, 0x0A, 0x60, 0x8D, 0xF8, 0x0E, 0x50, 0x01, 0x92, 0x1C, 0x80, 0x89, 0x1E,
    		   0x00, 0x97, 0x68, 0x46, 0xAD, 0xF8, 0x08, 0x10, 0xFD, 0xF7, 0xD1, 0xFC, 0x04, 0xB0, 0xF0, 0xBD,
    		   0x00, 0x00, 0x18, 0xB5, 0x01, 0x05, 0xFF, 0x15, 0x44, 0x55, 0x1B, 0x00, 0x10, 0x47, 0x40, 0x00,
    		   0x21, 0xC2, 0xF2, 0x00, 0x00, 0x0A, 0x46, 0x00, 0x78, 0x0B, 0x46, 0xFB, 0xF7, 0x01, 0x05, 0xFF,
    		   0x2D, 0xC4, 0x56, 0x1B, 0x00, 0x28, 0x10, 0xB5, 0x40, 0xF2, 0x00, 0x04, 0x02, 0x20, 0xC2, 0xF2,
    		   0x00, 0x04, 0x60, 0x77, 0xFF, 0xF7, 0x0D, 0xFF, 0x05, 0x20, 0x00, 0xF0, 0x1A, 0xF8, 0x41, 0xF6,
    		   0xC0, 0x20, 0x00, 0x21, 0x01, 0x22, 0xC2, 0xF2, 0x00, 0x00, 0x00, 0x78, 0x0B, 0x46, 0x01, 0x05,
    		   0xFF, 0x09, 0x0C, 0x57, 0x1B, 0x00, 0x04, 0x11, 0x80, 0x10, 0xBD, 0x01, 0x05, 0xFF, 0x49, 0xCC,
    		   0x58, 0x1B, 0x00, 0x44, 0x46, 0xF2, 0x28, 0x04, 0xC2, 0xF2, 0x20, 0x04, 0x4F, 0xF0, 0x18, 0x05,
    		   0x40, 0xF2, 0x4E, 0x63, 0x25, 0x80, 0xC2, 0xF2, 0x00, 0x03, 0x1B, 0x88, 0x41, 0xF6, 0x28, 0x45,
    		   0xC2, 0xF2, 0x00, 0x05, 0x03, 0xEB, 0xC0, 0x03, 0x63, 0x80, 0x2B, 0x78, 0x4F, 0xEA, 0x01, 0x66,
    		   0x4F, 0xEA, 0x11, 0x21, 0xA1, 0x81, 0x4F, 0xEA, 0x16, 0x45, 0x65, 0x81, 0x13, 0xB1, 0x11, 0x46,
    		   0x01, 0xF0, 0x1A, 0xFC, 0x70, 0xBD, 0x00, 0x00, 0x01, 0x05, 0xFF, 0x31, 0x2C, 0x59, 0x1B, 0x00,
    		   0x2C, 0x00, 0x94, 0xAD, 0xF8, 0x0A, 0x10, 0xAD, 0xF8, 0x08, 0x30, 0x38, 0x78, 0x00, 0x21, 0x8D,
    		   0xF8, 0x0E, 0x10, 0x8D, 0xF8, 0x0C, 0x00, 0x01, 0xF0, 0xE2, 0xFB, 0x68, 0x46, 0xFD, 0xF7, 0x7D,
    		   0xF9, 0x04, 0xB0, 0x90, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0xB5, 0x01, 0x05, 0xFF,
    		   0x3D, 0x34, 0x5B, 0x1B, 0x00, 0x38, 0x45, 0xF2, 0x55, 0x56, 0x40, 0xF2, 0x4E, 0x64, 0x01, 0x90,
    		   0x01, 0x27, 0x00, 0x25, 0xC0, 0xF2, 0x55, 0x06, 0xC2, 0xF2, 0x00, 0x04, 0x8D, 0xF8, 0x10, 0x30,
    		   0x03, 0x91, 0x02, 0x92, 0x68, 0x46, 0x8D, 0xF8, 0x11, 0x70, 0x00, 0x96, 0x25, 0x80, 0xFD, 0xF7,
    		   0x0D, 0xF9, 0x05, 0xB0, 0xF0, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05,
    		   0xFF, 0x75, 0x60, 0x5C, 0x1B, 0x00, 0x70, 0x01, 0x68, 0xB1, 0xF1, 0xFF, 0x3F, 0x1C, 0xBF, 0x49,
    		   0x1C, 0x01, 0x60, 0x13, 0xD1, 0x41, 0x68, 0x00, 0x23, 0x03, 0x60, 0x01, 0xF0, 0x7F, 0x02, 0x7F,
    		   0x2A, 0x04, 0xBF, 0x21, 0xF0, 0x7F, 0x01, 0x41, 0x60, 0x4F, 0xEA, 0x41, 0x62, 0x06, 0xD0, 0x02,
    		   0xF1, 0x00, 0x72, 0x21, 0xF0, 0x7F, 0x01, 0x41, 0xEA, 0x52, 0x61, 0x41, 0x60, 0x70, 0x47, 0x00,
    		   0x00, 0x70, 0xB5, 0xAD, 0xF1, 0x14, 0x0D, 0x41, 0xF6, 0xCC, 0x36, 0x40, 0xF2, 0x4E, 0x65, 0x03,
    		   0x90, 0x00, 0x24, 0xC2, 0xF2, 0x00, 0x06, 0xC2, 0xF2, 0x00, 0x05, 0x00, 0x93, 0x8D, 0xF8, 0x10,
    		   0x20, 0x02, 0x91, 0x68, 0x46, 0x8D, 0xF8, 0x11, 0x40, 0x01, 0x96, 0x2C, 0x80, 0xFD, 0xF7, 0x58,
    		   0xF8, 0x05, 0xB0, 0x70, 0xBD, 0x00, 0x00, 0x01, 0x05, 0xFF, 0xCD, 0x78, 0x6E, 0x1B, 0x00, 0xC8,
    		   0x1D, 0x1C, 0x1B, 0xFF, 0x15, 0x1E, 0x16, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0xB5, 0xFE, 0xF7, 0x31, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00,
    		   0xFF, 0xF7, 0xCC, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x09, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7,
    		   0xC5, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0xBE, 0xFB,
    		   0x00, 0xBD, 0x70, 0xB5, 0x41, 0xF6, 0x48, 0x44, 0xC2, 0xF2, 0x00, 0x04, 0xE0, 0x68, 0x81, 0x79,
    		   0x4F, 0xF4, 0xAF, 0x70, 0xA0, 0xEB, 0xC1, 0x00, 0x80, 0xB2, 0xFE, 0xF7, 0x1D, 0xFC, 0x40, 0xF6,
    		   0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0xA1, 0xFB, 0x40, 0xF6, 0x6A, 0x20,
    		   0x09, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0x9A, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21,
    		   0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0x9A, 0xFB, 0x14, 0x20, 0xFE, 0xF7, 0x05, 0xFC, 0x40, 0xF2,
    		   0x00, 0x01, 0xC2, 0xF2, 0x00, 0x01, 0x91, 0xF8, 0x96, 0x05, 0x63, 0x7A, 0x41, 0xF6, 0x44, 0x42,
    		   0xC2, 0xF2, 0x00, 0x02, 0x40, 0xEA, 0x03, 0x10, 0x43, 0xF2, 0x1C, 0x03, 0x12, 0x88, 0xC0, 0x00,
    		   0xC2, 0xF2, 0x31, 0x03, 0x00, 0x24, 0x40, 0xF2, 0x4E, 0x65, 0x42, 0xF2, 0x48, 0x46, 0x18, 0x80,
    		   0x4C, 0x53, 0xC2, 0xF2, 0x31, 0x06, 0x72, 0x80, 0x01, 0x05, 0xFF, 0xCD, 0x40, 0x6F, 0x1B, 0x00,
    		   0xC8, 0x15, 0x20, 0x30, 0x80, 0x30, 0x88, 0x15, 0x28, 0x02, 0xD0, 0x5E, 0x20, 0xFF, 0xF7, 0x8D,
    		   0xFB, 0x40, 0xF2, 0x00, 0x00, 0xC2, 0xF2, 0x00, 0x00, 0x90, 0xF8, 0x05, 0x36, 0x4F, 0xF2, 0x04,
    		   0x01, 0xC2, 0xF2, 0x32, 0x01, 0x10, 0x2B, 0x04, 0xDA, 0x0A, 0x88, 0x01, 0x20, 0x98, 0x40, 0x10,
    		   0x43, 0x08, 0x80, 0x41, 0xF6, 0x48, 0x40, 0xC2, 0xF2, 0x00, 0x00, 0xC1, 0x68, 0x42, 0x7A, 0x41,
    		   0xF6, 0x6C, 0x40, 0x89, 0x79, 0xC2, 0xF2, 0x00, 0x00, 0xFE, 0xF7, 0x2B, 0xFD, 0x70, 0xBD, 0x00,
    		   0xB5, 0x41, 0xF6, 0x48, 0x40, 0x07, 0x21, 0xC2, 0xF2, 0x00, 0x00, 0xFF, 0xF7, 0x9B, 0xFB, 0x40,
    		   0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0x3D, 0xFB, 0x14, 0x20, 0xFE,
    		   0xF7, 0xAF, 0xFB, 0x40, 0xF2, 0x97, 0x50, 0xC2, 0xF2, 0x00, 0x00, 0x00, 0x78, 0x43, 0xF2, 0x20,
    		   0x01, 0xC2, 0xF2, 0x31, 0x01, 0x08, 0x80, 0x00, 0xBD, 0x00, 0xB5, 0x41, 0xF6, 0x47, 0x40, 0x03,
    		   0x21, 0xC2, 0xF2, 0x00, 0x00, 0x01, 0x70, 0x40, 0xF6, 0x6A, 0x20, 0x07, 0x21, 0xC2, 0xF2, 0x32,
    		   0x00, 0xFF, 0xF7, 0x28, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x09, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF,
    		   0xF7, 0x21, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x32, 0x00, 0xFF, 0xF7, 0x1A,
    		   0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x02, 0x21, 0xC2, 0xF2, 0x01, 0x05, 0xFF, 0xCD, 0x08, 0x70, 0x1B,
    		   0x00, 0xC8, 0x32, 0x00, 0xFF, 0xF7, 0x13, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x08, 0x21, 0xC2, 0xF2,
    		   0x32, 0x00, 0xFF, 0xF7, 0x05, 0xFB, 0x40, 0xF6, 0x6A, 0x20, 0x06, 0x21, 0xC2, 0xF2, 0x32, 0x00,
    		   0xFF, 0xF7, 0xFE, 0xFA, 0x43, 0xF2, 0x5C, 0x10, 0x00, 0x21, 0xC2, 0xF2, 0x31, 0x00, 0xFF, 0xF7,
    		   0xF7, 0xFA, 0x41, 0xF6, 0x50, 0x40, 0xC2, 0xF2, 0x00, 0x00, 0x00, 0x78, 0x10, 0xB9, 0x00, 0xF0,
    		   0xBC, 0xFF, 0x00, 0xBD, 0x00, 0xF0, 0x22, 0xFF, 0x00, 0xBD, 0xF0, 0xB5, 0x40, 0xF2, 0x00, 0x02,
    		   0xC2, 0xF2, 0x00, 0x02, 0xD2, 0xF8, 0x8C, 0x35, 0x04, 0x78, 0x40, 0xF2, 0x00, 0x01, 0x6F, 0xF3,
    		   0x1F, 0x43, 0xC2, 0xF2, 0x30, 0x01, 0x19, 0x43, 0x42, 0xF2, 0x6C, 0x45, 0x0C, 0x80, 0x43, 0xF2,
    		   0x00, 0x01, 0x00, 0x23, 0xC4, 0xF2, 0x00, 0x05, 0x2B, 0x80, 0x4F, 0xF4, 0x20, 0x65, 0xC2, 0xF2,
    		   0x31, 0x01, 0x01, 0x24, 0x41, 0xF2, 0x08, 0x46, 0x40, 0x27, 0x4F, 0xF0, 0x78, 0x0C, 0x4D, 0x80,
    		   0x0E, 0x80, 0xCF, 0x83, 0xA1, 0xF8, 0x1C, 0xC0, 0x8C, 0x80, 0x0C, 0x84, 0x01, 0x78, 0x10, 0x29,
    		   0x29, 0xDA, 0x11, 0xB3, 0x49, 0x1E, 0x16, 0xD0, 0x49, 0x1E, 0x0A, 0xD0, 0x49, 0x1E, 0x22, 0xD1,
    		   0x42, 0xF2, 0x46, 0x40, 0xC2, 0xF2, 0x31, 0x00, 0x83, 0x80, 0x04, 0x80, 0x92, 0xF8, 0x49, 0x06,
    		   0x1B, 0xE0, 0x42, 0xF2, 0x46, 0x40, 0xC2, 0xF2, 0x31, 0x00, 0x01, 0x05, 0xFF, 0xCD, 0xD0, 0x70,
    		   0x1B, 0x00, 0xC8, 0x02, 0x21, 0x81, 0x80, 0x04, 0x80, 0x92, 0xF8, 0x49, 0x06, 0x11, 0xE0, 0x42,
    		   0xF2, 0x46, 0x40, 0xC2, 0xF2, 0x31, 0x00, 0x02, 0x21, 0x81, 0x80, 0x04, 0x80, 0x92, 0xF8, 0x49,
    		   0x06, 0x07, 0xE0, 0x42, 0xF2, 0x46, 0x40, 0xC2, 0xF2, 0x31, 0x00, 0x83, 0x80, 0x04, 0x80, 0x92,
    		   0xF8, 0x49, 0x06, 0x00, 0xF0, 0x7F, 0x00, 0x82, 0xF8, 0x49, 0x06, 0xF0, 0xBD, 0x40, 0xF2, 0x00,
    		   0x00, 0xC2, 0xF2, 0x00, 0x00, 0xB0, 0xF8, 0x50, 0x16, 0xA0, 0xF8, 0x4E, 0x16, 0x70, 0x47, 0x10,
    		   0xB5, 0x41, 0xF6, 0xF8, 0x60, 0x46, 0xF2, 0x01, 0x03, 0x42, 0xF2, 0x01, 0x02, 0xC2, 0xF2, 0x00,
    		   0x00, 0x4F, 0xF4, 0x00, 0x61, 0x4F, 0xF4, 0x33, 0x64, 0x43, 0x80, 0x82, 0x80, 0xC1, 0x80, 0x04,
    		   0x80, 0x10, 0xBD, 0x10, 0xB5, 0x40, 0xF2, 0x4E, 0x62, 0x46, 0xF6, 0x40, 0x63, 0xC2, 0xF2, 0x00,
    		   0x02, 0x46, 0xF2, 0x0C, 0x04, 0xC0, 0xF2, 0x00, 0x03, 0x12, 0x88, 0xC2, 0xF2, 0x20, 0x04, 0x59,
    		   0x5C, 0x02, 0xEB, 0xC0, 0x00, 0x20, 0x80, 0x48, 0xF2, 0xE0, 0x12, 0x08, 0x02, 0xE2, 0x80, 0x20,
    		   0x81, 0x10, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF, 0x25, 0x98,
    		   0x71, 0x1B, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF, 0xCD, 0xF4, 0x78, 0x1B, 0x00, 0xC8, 0xF0, 0x83, 0x70,
    		   0xB5, 0x41, 0xF6, 0x48, 0x44, 0x06, 0x46, 0xC2, 0xF2, 0x00, 0x04, 0xE0, 0x68, 0x07, 0x21, 0x45,
    		   0x78, 0x40, 0xF6, 0x6A, 0x20, 0xC2, 0xF2, 0x32, 0x00, 0xFE, 0xF7, 0x90, 0xFE, 0x01, 0x20, 0xFD,
    		   0xF7, 0xAE, 0xFB, 0x00, 0x2E, 0x40, 0xF2, 0x00, 0x01, 0x46, 0xD1, 0xC2, 0xF2, 0x00, 0x01, 0x91,
    		   0xF8, 0x98, 0x05, 0x01, 0xF2, 0xFC, 0x56, 0x90, 0xB9, 0xE0, 0x68, 0x2D, 0x18, 0x2A, 0x79, 0xE9,
    		   0x78, 0xA8, 0x78, 0xFB, 0xF7, 0x9C, 0xFE, 0x30, 0xB9, 0x61, 0x69, 0x49, 0x1C, 0x61, 0x61, 0x2C,
    		   0x20, 0xFE, 0xF7, 0xE2, 0xFD, 0x70, 0xBD, 0x30, 0x88, 0x40, 0x1C, 0x30, 0x80, 0x70, 0xBD, 0xFF,
    		   0xF7, 0x5E, 0xFE, 0xE0, 0x68, 0x28, 0x18, 0x02, 0x79, 0xC1, 0x78, 0x80, 0x78, 0xFF, 0xF7, 0x92,
    		   0xFD, 0x00, 0xF0, 0xD0, 0xF9, 0xB6, 0xF8, 0x42, 0x00, 0x80, 0x08, 0x2C, 0xBF, 0x01, 0x22, 0x00,
    		   0x22, 0x0E, 0x20, 0x00, 0x21, 0xFB, 0xF7, 0xE7, 0xFE, 0x06, 0x46, 0xE0, 0x68, 0x2D, 0x18, 0xA8,
    		   0x78, 0xE9, 0x78, 0x2A, 0x79, 0xFB, 0xF7, 0x73, 0xFE, 0x01, 0x2E, 0x04, 0xBF, 0xA1, 0x69, 0x00,
    		   0x28, 0x07, 0xD0, 0x4E, 0xB9, 0x01, 0x28, 0x07, 0xD1, 0xA1, 0x69, 0x88, 0x8F, 0x40, 0x1C, 0x88,
    		   0x87, 0x70, 0xBD, 0x48, 0x8F, 0x40, 0x1C, 0x48, 0x87, 0x70, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF, 0x75, 0xBC, 0x79, 0x1B, 0x00, 0x70, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05,
    		   0xFF, 0x09, 0x04, 0x7B, 0x1B, 0x00, 0x04, 0x28, 0xB9, 0x0F, 0x20, 0x01, 0x05, 0xFF, 0x55, 0x98,
    		   0x7E, 0x1B, 0x00, 0x50, 0x00, 0x20, 0xAD, 0xF8, 0x04, 0x00, 0x00, 0x90, 0xFF, 0xF7, 0x75, 0xF8,
    		   0x41, 0xF6, 0x48, 0x44, 0x41, 0xF6, 0x74, 0x40, 0xC2, 0xF2, 0x00, 0x04, 0x6A, 0x46, 0x69, 0x46,
    		   0x63, 0x7A, 0xC2, 0xF2, 0x00, 0x00, 0xFD, 0xF7, 0x38, 0xFE, 0x02, 0xB0, 0x02, 0x20, 0xE0, 0x61,
    		   0x10, 0xBD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0xB5,
    		   0x41, 0xF6, 0x48, 0x44, 0xC2, 0xF2, 0x00, 0x04, 0xE0, 0x69, 0x01, 0x28, 0x14, 0xD1, 0xFE, 0xF7,
    		   0xD1, 0xFF, 0x60, 0x69, 0x01, 0x05, 0xFF, 0x15, 0x0C, 0x7F, 0x1B, 0x00, 0x10, 0x10, 0xBD, 0x00,
    		   0xB5, 0x41, 0xF6, 0x50, 0x40, 0xC2, 0xF2, 0x00, 0x00, 0x00, 0x21, 0x02, 0x78, 0x01, 0x05, 0xFF,
    		   0x45, 0x30, 0x7F, 0x1B, 0x00, 0x40, 0xFF, 0xF7, 0x4A, 0xF8, 0x00, 0xBD, 0x00, 0x00, 0x00, 0x00,
    		   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x05, 0xFF, 0x0D, 0xD4, 0x7F, 0x1B, 0x00, 0x08, 0x56,
    		   0xFC, 0xFE, 0xF7, 0x70, 0xFF, 0x00, 0xBD, 0x01, 0x09, 0xFD, 0x08, 0x00, 0xC0, 0x1B, 0x00, 0x00,
    		   0x00, 0x01, 0x00, 0x01, 0xA8, 0xFD, 0x01, 0x00, 0x01, 0x5B, 0xFD, 0x02, 0x01, 0x00, 0x01, 0xDD,
    		   0xFD, 0x01, 0x01
    #endif
    /* NO CORTEX SLEEP NO BLE */
    #if(0)
    		0x01,0x5b,0xfd,0x02,0x01,0x01,
    		0x01,0xa8,0xfd,0x01,0x01,0x01,0x09,0xfd,0x08,0x00,0xc0,0x1b,0x00,0x01,0x00,0x01,0x00,
    		0x01,0x05,0xff,0x0d,0xac,0x4b,0x1b,0x00,0x08,0x91,0xff,0x47,0xf2,0x9b,0x35,0x47,
    		0xf2,
    		0x01,0x05,0xff,0x55,0x20,0x63,0x1b,0x00,0x50,0x30,0xbd,0x00,0x00,0x00,0x00,0x00,
    		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    		0x01,0x05,0xff,0x5d,0x98,0x73,0x1b,0x00,0x58,0x70,0x47,0x02,0x46,0x14,0x3a,0x1e,
    		0xd0,0x52,0x1e,0x24,0xd1,0x8a,0x78,0x02,0x2a,0x11,0xd9,0x12,0x1f,0x02,0x2a,0x0e,
    		0xd9,0x1d,0x3a,0x1c,0xd0,0x92,0x1f,0x02,0x2a,0x19,0xd9,0x09,0x3a,0x17,0xd0,0x89,
    		0x88,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x4b,0xbe,0x09,
    		0x89,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x43,0xbe,0x89,
    		0x88,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x3b,0xbe,0x70,
    		0x47,
    		0x01,0x09,0xfd,0x08,0x00,0xc0,0x1b,0x00,0x00,0x00,0x01,0x00
    #endif
    /* NO CORTEX SLEEP */
    #if(1)
    		0x01,0x5b,0xfd,0x02,0x01,0x01,0x01,0xa8,0xfd,0x01,0x01,
    		0x01,0x05,0xff,0x0d,0xac,0x4b,0x1b,0x00,0x08,0x91,0xff,0x47,0xf2,0x9b,0x35,0x47,0xf2,
    		0x88,0x40,0xf2,0x00,0x00,0xc2,0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x3b,0xbe,0x70,0x47,
    		0x01,0x09,0xfd,0x08,0x00,0xc0,0x1b,0x00,0x00,0x00,0x01,0x00,
    		0x01,0x5b,0xfd,0x02,0x01,0x00,
    		0x01,0xdd,0xfd,0x01,0x0
    #endif
    #if(0)
    		/* ORIGINAL SCRIPT FOR BLE ADD-ON */
    		0xf2,0x01,0x05,0xff,0x55,0x20,0x63,0x1b,0x00,0x50,0x30,0xbd,0x00,0x00,0x00,0x00,
    		0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x05,0xff,0x5d,0x98,0x73,
    		0x1b,0x00,0x58,0x70,0x47,0x02,0x46,0x14,0x3a,0x1e,0xd0,0x52,0x1e,0x24,0xd1,0x8a,
    		0x78,0x02,0x2a,0x11,0xd9,0x12,0x1f,0x02,0x2a,0x0e,0xd9,0x1d,0x3a,0x1c,0xd0,0x92,
    		0x1f,0x02,0x2a,0x19,0xd9,0x09,0x3a,0x17,0xd0,0x89,0x88,0x40,0xf2,0x00,0x00,0xc2,
    		0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x4b,0xbe,0x09,0x89,0x40,0xf2,0x00,0x00,0xc2,
    		0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x43,0xbe,0x89,0x88,0x40,0xf2,0x00,0x00,0xc2,
    		0xf2,0x30,0x00,0x08,0x43,0xfd,0xf7,0x3b,0xbe,0x70,0x47,0x01,0x09,0xfd,0x08,0x00,
    		0xc0,0x1b,0x00,0x00,0x00,0x01,0x00,0x01,0xa8,0xfd,0x01,0x00,0x01,0x5b,0xfd,0x02,
    		0x01,0x00,0x01,0xdd,0xfd,0x01,0x01
    #endif
    static BTPSCONST unsigned int LowEnergyPatchLength = sizeof(LowEnergyPatch);
    static unsigned long LowEnergyPatchPointer         = (unsigned long)LowEnergyPatch;
    #endif
    It doesn't open the stack when I'm debugging but always allows me to open the stack when it's programmed and not debugging.
    However, I don't think it is opening the stack, because when I ran the inquiry command, it didn't return anything. In this sense, I find it strange that the command prompt shows that the stack opens when it doesn't and that I'm able to run most of the commands.
    We didn't know about the Bluetooth SIG certification you just mentioned. But we will discuss this issue with our quality assurance manager. Thank you for pointing it out.
    We would like to know if you see it possible to really use the Buletopia stack for the CC2564MODA with the MSP430FR5994 microcontroller. Because we need to move forward with the project and we are evaluating to change the Bluetooth module if we cant start building our firmware for this one soon. Also, we would like to know if there is any communication channel where we could speak to you or another TI expert live to accelerate the testing/debugging process to find why the stack is not working for us.
    Many thanks,
    Diana
  • Hi Diana,
    I’ll try to respond tomorrow.
    Jacob
  • Hi Diana,
    I do not recommend using the CC2564MODA (CC2564B) with the MSP430 as your prototype. It is my understanding that you will not be able to certify this design according to the Bluetooth SIG requirements. I would definitely recommend bringing this up to your Q/A manager.
    TI's current Bluetooth recommendation is the CC2564C paired with the STM32F4.
    If you would like to continue with this project I will do my best to assist you.
    Jacob
  • Hi Jacob,
    Thanks a lot for all your help. Since we aren't allowed to change the microcontroller for this project and not being able to certify the design will be an issue, we will be using the RN4871 Microchip Bluetooth module with the MSP430FR5994 microcontroller.
    Thanks again for your support with this request.
    Best wished,
    Diana
  • Hi Diana,
    Happy to help. I wanted to clarify my previous message for anyone else watching this thread. The Bluetopia 4.0 stack for the MSP430 is withdrawn and can not be used for new designs. However the CC2564B can be used in new designs as long as the new design complies with a version of the specification that has not been deprecated or withdrawn until 2023-02-01.
    Best of luck with your design process,
    Jacob
