Other Parts Discussed in Thread: CC2652RSIP, SYSCONFIG
I have encountered a problem with the SPI driver.
I am using the LP-CC2652RSIP and simplelink_cc13xx_cc26xx_sdk_5_40_00_40.
SSIDataGet() will reliably get stuck if you increase the SSI bit rate to 12,000,000 and increase the minimum dma transfer size to greater than 10, and attempt to SPI transfer of 10 bytes.
I have also encountered this problem with a smaller minimum transfer size, but this is not as reproducible.
I have created a demonstration of this problem using the example simplelink_cc13xx_cc26xx_sdk_5_40_00_40/examples/rtos/LP_CC2652RSIP/drivers/nvsinternal/tirtos/ccs as a starting point.
The demonstration is accessible at https://github.com/tuckersteve/SSI_test.git
