Other Parts Discussed in Thread: CC-DEVPACK-DEBUG
Dear Ti engineer,
I posted a question
the engineer said I need to cut two wire. I refered to CC2650STK_Layout.pdf in SWRC304B(www.ti.com/.../swrc304), it shows I should cut these two wires on layer1.
but the first wire I mark on the picture seems be blocked by DevPack Connector.
I also try to cut the wire on the R28 side, but the wire there is too complicated on layer4 around R28, if I should cut this wire.
If someone has some good suggestion on cutting the wire. Or any other suggetion on letting battery continue powering the sensortag when I plug the CC-DEVPACK-DEBUG.
Thanks.
