Hi Team,
We would like to ask your help regarding our customer's inquiry below.
My circuit has some peripherals that must communicate with the microcontroller through the I2C protocol.
Using the IDE environment I could create the pin definition.
However, when I try to run the firmware I don't see the I2C signals on my board.
Most of the definitions are in the config files and they are hidden somehow, because they must be generated by the IDE mechanism.
I would like to access this hidden files to understand how the routines are defined.
I2C_init()
I2C_open()
etc...
How can I find these routines in my code? What would be the steps to troubleshoot my I2C protocol?
Is there any example codes that could be provided in this case?
Is there any restrictions for the IO pins to be used as SDA and SCL?
I would like to discuss these issues with some deeper detail with someone more experienced in developing with this platform.
Danilo
