We encounted an issue that our MIC supplier think the BCLK now we use is not very siuatable for the digital mic now we use.
The BCLK now we use is 4.8M Hz as default. Could this rate be 3.072Mhz or 2.4Mhz?
I check the code,and found the defination below,
but I think only modify the marco below can't change the speed as the function is in the lib.
Is there any way to change the I2S's BCLK?
BR
yaohongxuan
