Other Parts Discussed in Thread: UNIFLASH,
I am quite new to CCS, the use of the CC2650, and its Launchpad, so bear with me.
I have been working on some code and have been having success in making improvements and uploading it to the hardware. Recently, however, when trying to upload/debug I get an 'error connecting to the target'. The full description of the error message is below:
Error connecting to the target:
(Error -242 @ 0x0)
A router subpath could not be accessed.
The board configuration file is probably incorrect.
(Emulation package 8.0.27.9)
I used to get this error message before and was told it was because of a dodgy USB connection. Fiddling around with both the USB and JTAG connection fixed the issue before, but now it doesn't budge. I have tried several different USB cables and way's in which to connect my setup. Still, I get the error.
I have had a look at the board configuration file, but not sure how to approach the debugging process with it. From the 'test connection' button I receive the same -242 error.
Does anyone know what the issue might be? I might have missed something very fundamental since I am a beginner.
Thank you in advance.
