I am using a LAUNCHXL-CC1352R1 launch pad for a simple node mesh project under CC26X2R1_LAUNCHXL and facing issues . Is it because they are incompatible and does LAUNCHXL-CC1352R1 support ble mesh?
Hi William,
The CC1351R1 does supports Bluetooth Mesh. Please look at the following E2E thread:
Arthur
Hi Arthur ,
Thanks for your response. Having some issues though.
In the thread it says,
2. Right click on the simple_mesh_node.syscfg and open it as a text file. Change line 32 to your board type, as shown below.
// @cliArgs --board /ti/boards/CC1352R1_LAUNCHXL. Upon opening my sysconfig as a text file , line 32 reads different for me . It reads const TRNG = scripting.addModule("/ti/drivers/TRNG");
A screen shot
Looking forward to feedback!
Hi William,
Which sysconfig file did you open? I do see the correct line 32
After that, I downloaded the project to my CC1352R1 board and it seems to output something.
Arthur
Hi William, I did not manage to modify the files in step 1, but this step is actually not needed.
Indeed, the SysConfig generated files are generated for the chip with only the step 2:
I see that you are using Code Composer 10.40. Is it an option to upgrade to version 12, to see if this error is still present in the new SysConfig version?
Arthur
