How to increase exchange rate i.e Ble throughput for Simple peripheral sys file. I want to change default parameters to Parameters which supports maximum speed data exchange rate. If possible list me the parameters need to be changed.
Hi Aria,
Under what condition do you want the data rate to be maximum?
I recommended you follow the following training: https://dev.ti.com/tirex/content/simplelink_academy_cc13xx_cc26xxsdk_6_30_00_00/overview.html
And especially the Bluetooth 5 PHY one: https://dev.ti.com/tirex/content/simplelink_academy_cc13xx_cc26xxsdk_6_30_00_00/modules/ble5stack/ble_phy/ble_phy.html
As it seems to be the one you are interested in.
Arthur
Thanks for response Arthur R,
Is it possible to use 2M mode in CC1352R1 chip based devices?
It is indeed possible to use the 2M on the CC1352R1, as seen in section 8.20 of the datasheet, where we show the performance data.
Arthur
Hi Aria,
What phone OS/model are you using? iPhones should support 2M BLE.
Arthur
Hi Titus,
I have tested with a Redmi 6A, and it supports the 2M PHY. So your Redmi 9A should support it.
Arthur
