Hi Team,
Good day. I am posting this inquiry on behalf of the customer.
I'm designing a board using the CC2651R3SIPA module. I'm trying to use the UART pins for bootloading. however, the reference design for the dev kit and the technical reference manual have conflicting information regarding the CC2651R UART pins.
In the technical reference manual, we have the following table where the relevant pins are labeled DIO2 and DIO3
However, in the reference design, they use different pins for the same chip
Some clarification would be much appreciated.
also, what is meant by input with pull-up? are they referring to an internal pull-up resistor or an external one I have to add to my schematic?
Thank you for your support.
Please help to advise. Thank you for extending your support.
Kind regards,
Marvin
