Could you please provide guidance on configuring the TX power?
SDK : simplelink_lowpower_f3_sdk_7_10_00_35
Rahul K V
My apologies.
For the moment the power settings in sysconfig are not supported on CC2340R5, you'll need to change the Txpower value with an HCI command.
We have troubles with this HCI command. But the issue is in good hands and our R&D is working on this to provide a workaround ASAP.
From my side I'm searching for a patch, from your side is this a production-stop level issue?
regards,
Hi Guillaume,
Thank you for confirming that the workaround provided for the fixed TX power settings is effective. Regarding the runtime configuration, could you please clarify if you are referring to having a ready-to-use build for runtime configuration?
Rahul K V
