Other Parts Discussed in Thread: CC1352P
Hi team
Hello, there is a technical need for 2.4G band, I hope to use CC2652P as a proprietary protocol, and transmit power needs 20dBm. The data rate needs to be around 1-2 kbps and the bandwidth is as narrow as possible to tens of kilohertz.
Ask:
(1) can the CC2652P modify its RF modulation and data rate to meet the data rate and bandwidth requirements mentioned above?
(2) the CC2652P sees a minimum receive bandwidth of 4KHz on the spec, but no application scenarios are seen for this minimum receive bandwidth. Can you explain this application scenario?
Best regards
Alex
