hi,
we are working on project based on cc2541, i want to know if it is possible to use two antenna : ceramic and IFA PCB on the same board with 0R separation resistor ?
the perfermance of antenna will be lost in this case ?
thanks,
hi,
thanks,
It should work fine, but the layout might be a critical factor here. Ideally you want to place the two antennas at different sides of the PCB and follow the design recommendation for each of the two antennas. You will most likely also need two different matching networks to the antennas.
