Problem with simpleGATTProfile characteristics
Hello
I'm trying to use bluez's gatttool to write to SimpleBLEPeripheral's characteristics. Specifically I'm hoping to write to characteristic 1 and read the value back out. Here's what I'm doing (where 0x25 is the handle for CHAR1):
bluepy$ gatttool -b EC:24:B8:23:1C:39 -I
[   ][EC:24:B8:23:1C:39][LE]> connect
[CON][EC:24:B8:23:1C:39][LE]> char-read-hnd 0x0025
[CON][EC:24:B8:23:1C:39][LE]> Characteristic value/descriptor: 01
[CON][EC:24:B8:23:1C:39][LE]> char-write-cmd 0x25 0x02
[CON][EC:24:B8:23:1C:39][LE]> Characteristic value/descriptor: 00
Does anyone know why the characteristic value is 00 rather than 02?
Also, isn't it that SBLEP only implements the simpleGATTProfile, which encapsulates just 5 characteristics (as per Figure 5-9 of the SW doc)? If I run the "characteristics" command in GATTTool, I get the following
[CON][EC:24:B8:23:1C:39][LE]> characteristics
handle: 0x0002, char properties: 0x02, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, char properties: 0x0a, char value handle: 0x0007, uuid: 00002a02-0000-1000-8000-00805f9b34fb
handle: 0x0008, char properties: 0x08, char value handle: 0x0009, uuid: 00002a03-0000-1000-8000-00805f9b34fb
handle: 0x000a, char properties: 0x02, char value handle: 0x000b, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x20, char value handle: 0x000e, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x0011, char properties: 0x02, char value handle: 0x0012, uuid: 00002a23-0000-1000-8000-00805f9b34fb
handle: 0x0013, char properties: 0x02, char value handle: 0x0014, uuid: 00002a24-0000-1000-8000-00805f9b34fb
handle: 0x0015, char properties: 0x02, char value handle: 0x0016, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x0017, char properties: 0x02, char value handle: 0x0018, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x0019, char properties: 0x02, char value handle: 0x001a, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x001b, char properties: 0x02, char value handle: 0x001c, uuid: 00002a28-0000-1000-8000-00805f9b34fb
handle: 0x001d, char properties: 0x02, char value handle: 0x001e, uuid: 00002a29-0000-1000-8000-00805f9b34fb
handle: 0x001f, char properties: 0x02, char value handle: 0x0020, uuid: 00002a2a-0000-1000-8000-00805f9b34fb
handle: 0x0021, char properties: 0x02, char value handle: 0x0022, uuid: 00002a50-0000-1000-8000-00805f9b34fb
handle: 0x0024, char properties: 0x0a, char value handle: 0x0025, uuid: 0000fff1-0000-1000-8000-00805f9b34fb
handle: 0x0027, char properties: 0x02, char value handle: 0x0028, uuid: 0000fff2-0000-1000-8000-00805f9b34fb
handle: 0x002a, char properties: 0x08, char value handle: 0x002b, uuid: 0000fff3-0000-1000-8000-00805f9b34fb
handle: 0x002d, char properties: 0x10, char value handle: 0x002e, uuid: 0000fff4-0000-1000-8000-00805f9b34fb
handle: 0x0031, char properties: 0x02, char value handle: 0x0032, uuid: 0000fff5-0000-1000-8000-00805f9b34fb
which shows many more than 5 characteristics. With Characteristics Descriptor Discovery (char-desc), it gives
[CON][EC:24:B8:23:1C:39][LE]> char-desc
handle: 0x0001, uuid: 2800
handle: 0x0002, uuid: 2803
handle: 0x0003, uuid: 2a00
handle: 0x0004, uuid: 2803
handle: 0x0005, uuid: 2a01
rather than the 5 characteristics of simpleGATTProfile. Does anyone know why this is the case?
Thank you for the help in advance.
  • Hello Will,
    Given that your questions are quite academic in nature, I feel that you will benefit from taking the SimpleLink Academy training program, available on the BLE Wiki. Also, using the Linux cmd line gattool is not recommended for beginners to BLE, hence its use is not covered in our documentation.
    Best wishes
