Other Parts Discussed in Thread: CC2650
I'm trying to see these user printed Log events but they aren't showing up. Other UIA tools work (Execution/Load Analysis display correctly) but Log_infoX() events do not. When the program is suspended, the "Live Modules" tab only shows events from other sources and not my Log events. I also don't see anything in ROV -> Viewable Modules -> LoggerStopMode -> MainLogger which I believe is supposed to show me these Log statements.
I'm I'm using a CC2650 LaunchPad and the TrainingTag application from the simplelink academy tutorials (Although I have tried this with SimpleBLEPeripheral and it doesn't work either). I wasn't sure if this is a problem specific to cc2650 or to rtos so I decided to post here.
Here is my .cfg file:
//var ROM = xdc.useModule('ti.sysbios.rom.ROM');
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
//ROM.romName = ROM.CC2650;
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Types = xdc.useModule('xdc.runtime.Types');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysCallback = xdc.useModule('xdc.runtime.SysCallback');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var Reset = xdc.useModule('xdc.runtime.Reset');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var M3Hwi = xdc.useModule('ti.sysbios.family.arm.m3.Hwi');
var Power = xdc.useModule('ti.sysbios.family.arm.cc26xx.Power');
/* Enable idle task (default). */
Task.enableIdleTask = true;
/* Idle CPU when threads blocked waiting for an interrupt */
Power.idle = true;
Power.policyFunc = Power.standbyPolicy;
/* compile out all Assert's */
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
/* Don't load string names of modules on the target */
Defaults.common$.namedModule = false;
/* Allow Mod_create() and Mod_construct() but not delete() or destruct() */
Defaults.common$.memoryPolicy = Types.CREATE_POLICY;
/* Don't load diagnostic/descriptive text strings on the target */
Text.isLoaded = false;
/* Use the minimal user-supplied callback provider */
System.SupportProxy = SysCallback;
/* no exit handlers needed */
System.maxAtexitHandlers = 0;
/* main() and Hwi, Swi stack size */
Program.stack = 1024;
/* no command-line arguments main(argc, argv) needed */
Program.argSize = 0;
/* build a custom, optimized version of SYS/BIOS */
BIOS.libType = BIOS.LibType_Custom;
/* no logging - all compiled out */
BIOS.logsEnabled = true;
/* disable Asserts in SYS/BIOS code */
BIOS.assertsEnabled = false;
/* Reduce number of Task priority levels to save RAM */
Task.numPriorities = 6;
/* Set the default Task stack size - used if one is not specified */
Task.defaultStackSize = 512;
/* Don't check stacks for overflow - saves cycles (and power) and Flash */
Task.checkStackFlag = false;
/* Disable exception handling to save Flash - undo during active development */
M3Hwi.enableException = true;
M3Hwi.excHandlerFunc = null; /* null = default while loop function. Use e.g. "&myFxn" to use your own function. */
M3Hwi.nvicCCR.UNALIGN_TRP = 0;
M3Hwi.nvicCCR.DIV_0_TRP = 0;
/* Don't check for interrupt stack overflow during Idle loop */
Hwi.checkStackFlag = false;
/* Minimize Flash and RAM usage of Error module */
Error.raiseHook = null; /* null = default while loop function. Use e.g. "&myFxn" to your own handler function. */
Error.maxDepth = 2;
/* Set the default CPU frequency */
BIOS.cpuFreq.lo = 48000000;
/* Put reset vector at start of Flash */
M3Hwi.resetVectorAddress = 0x0;
/* Put interrupt vector at start of RAM so interrupts can be configured at runtime */
M3Hwi.vectorTableAddress = 0x20000000;
/* CC2650 has 50 interrupts */
M3Hwi.NUM_INTERRUPTS = 50;
/* Set heap size */
BIOS.heapSize = 1668;
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
Swi.numPriorities = 6;
BIOS.swiEnabled = true;
BIOS.includeXdcRuntime = true;
/* Tasks cannot pend based on priority */
Semaphore.supportsPriority = false;
/* Change default error function -- just spin */
Error.policyFxn = Error.policySpin;
/* true: Allow runtime creation of e.g. semaphores
* false: Compile out reference to Memory in BIOS */
BIOS.runtimeCreatesEnabled = true;
/* Abort and exit functions -- just spin */
System.abortFxn = System.abortSpin;
System.exitFxn = System.exitSpin;
/* CC26xx Boot module */
var Boot = xdc.useModule('ti.sysbios.family.arm.cc26xx.Boot');
Boot.driverlibVersion = 2;
Boot.customerConfig = false;
//Boot.checkBackdoor = false;
/* Turn on RCOSC_HF calibration, thus enabling fast startup */
Power.calibrateRCOSC = true;
//Power.calibrateRCOSC = false;
/* 10 us tick period */
Clock.tickPeriod = 10;
LoggingSetup.sysbiosTaskLogging = true;
LoggingSetup.loadLogging = false;
From the original simpleBLEPeripheral/trainingTag .cfg file (they're both the same) I went to LoggingSetup -> Checked Add LoggingSetup to my Configuration -> made sure "Error, Warning, Info, and Print events" was checked, and went to BIOS -> Runtime -> Checked "Enable Logs". I believe the lines below were the only changes that resulted ( as well as commenting out the ROM lines ) :
Am I misunderstanding something? Any idea as to what I should do to get this working?
