cc2500emk error
Other Parts Discussed in Thread: CC2500
I run one of the applications as outlined in Application Note N049 and receive and warnings when I rebuild all the files.
There are 23 but that all have a similar warning. Below is an example.
Warning[Pe1665]: concatenation with ";" in macro "MCU_IO_SET_PREP" does not create a valid token C:\Documents and Settings\deptadmin\My Documents\IAR Embedded Workbench\430\examples\swra141\source_rev_113\hal\common\hal_rf.c 29
What is causing this? I set up my paths in the preprocessor. When I tried following step 6c, when I selected "Debugger," there was no option to select "FET Debugger" from the "Driver" drop down list so I ignored it.
