Part Number: CC2640R2F
I am trying to run the pre-build command of simple_peripheral project from the bat script. The command is following:
"$XDCROOT$/xs" --xdcpath="$XDCPATH$" iar.tools.configuro -c "$TOOLKIT_DIR$" --cc "$COMPILER_PATH$" --device "$DEVICE$" --compileOptions $COMPILER_ARGS_ROOT_QUOTED$ --linkOptions $LINKER_ARGS_QUOTED$ --profile release --projFile "$PROJ_PATH$" --cfgArgs NO_ROM=1,OAD_IMG_B=1
When i run the command directly from the pre-build option of the IAR it works fine. I have attached the build log .
But when i try to run the command using bat script is following:
SET PROJECT_ROOT=%1
SET XDCROOT=%2
SET XDCPATH=%3
SET TOOLKIT_DIR=%4
SET COMPILER_PATH=%5
SET DEVICE=%6
SET COMPILER_ARGS_ROOT_QUOTED=%7
SET LINKER_ARGS_QUOTED=%8
SET PROJ_PATH=%9
%XDCROOT% --xdcpath=%XDCPATH% iar.tools.configuro -c %TOOLKIT_DIR% --cc %COMPILER_PATH% --device %DEVICE% --compileOptions %COMPILER_ARGS_ROOT_QUOTED% --linkOptions %LINKER_ARGS_QUOTED% --profile release --projFile %PROJ_PATH% --cfgArgs NO_ROM=1,OAD_IMG_B=1
I passed all the custom variables as argument to batch script. The command to run the script is following:
$PROJ_PATH$\pre-build.bat "$PROJECT_ROOT$" "$XDCROOT$" "$XDCPATH$" "$TOOLKIT_DIR$" "$COMPILER_PATH$" "$DEVICE$" $COMPILER_ARGS_ROOT_QUOTED$ $LINKER_ARGS_QUOTED$ "$PROJ_PATH$"
But command is not executing when i had a deep look into the problem i came to know that when XDC make the command it does not insert the --linkOptions. That makes it to fail.
I have attached the build logs while running directly from the pre-build and running from the script.
Can you please tell me how i can make script to recognize the --linkOptions?
