Tool/software: TI-RTOS
Hi
I'm starting with ti_rtos, and I just created the task under the Task_construct() function.Is there any rule for setting the the value of taskParams.priority? Does larger number stand for higher priority or lower priority? Any range for number definition?
How task manager schedule different task process according to task priority setting? If there is a while(1) function in higher priority task A, will task B still be called or system will be blocked in task A while(1) ?
Is there any other way to switch between two tasks rather than using event_pend or event_post?
