CC2640R2F: On-chip OAD not working. bTool reports OAD download not successful.
Part Number: CC2640R2F
Other Parts Discussed in Thread: BLE-STACK
Hi Team,
I have a similar setup as "simple_peripheral_oad_onchip" example project in order to perform On-chip over-the-air download with SimpleLink CC2640R2 SDK version 2_30_00_28 and CCS-8.2.0.0. I am following the "Performing a BLE OAD" section of "BLE-Stack User’s Guide" to use the bTool.
For our application needs, the following changes have been made:
a. Limited discoverable mode
b. Custom Advertisement and Scan response payload
c. Simple profile service is removed and only the OAD reset service is available
d. SimplePeripheral_performPeriodicTask is removed
With bTool used to perform OAD(unsecure mode), we see that the process stops in between and the control is not switching to OAD persistent application.
On debugging the code, it is found that the write cmd (start OAD) reaches "SimplePeripheral_processOadResetEvt" and the BIM variable "_bim_var" is set to trigger OAD.But the Connection event callback "SimplePeripheral_connEvtCB" is not received eventhough it is registered properly in the application. From bTool end, it waits for reset to happen and then reports "OAD download not successful".
As per the logic available in the application, it does not immediately perform a reset "HAL_SYSTEM_RESET" instead waits for a connection callback (as per the statement:   /* We cannot reboot the device immediately after receiving the enable command, we must allow the stack enough time to process and responsd to the OAD_EXT_CTRL_ENABLE_IMG command. The current implementation will wait one cxn evt */).
Please provide some insights on the need to wait for one connection event after receiving "OAD Start" command, OAD_EXT_CTRL_ENABLE_IMG and also the circumstances where there are issues in receiving the connection event.
[1] : <Tx> - 11:38:34.976
-Type           : 0x01 (Command)
-OpCode         : 0xFE09 (GAP_EstablishLinkRequest)
-Data Length    : 0x09 (9) byte(s)
 HighDutyCycle  : 0x00 (0) (Disable)
 WhiteList      : 0x00 (0) (Disable)
 AddrTypePeer   : 0x00 (0) (ADDRTYPE_PUBLIC)
 PeerAddr       : F0:F8:F2:CB:72:6D
Dump(Tx):
0000:01 09 FE 09 00 00 00 6D 72 CB F2 F8 F0          .......mr....
[2] : <Rx> - 11:38:35.007
-Type           : 0x04 (Event)
-EventCode      : 0x00FF (HCI_LE_ExtEvent)
-Data Length    : 0x06 (6) bytes(s)
 Event          : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus)
 Status         : 0x00 (0) (SUCCESS)
 DataLength     : 0x00 (0)
Dump(Rx):
0000:04 FF 06 7F 06 00 09 FE 00                      .........
[3] : <Rx> - 11:38:35.070
-Data Length    : 0x14 (20) bytes(s)
 Event          : 0x0605 (1541) (GAP_EstablishLink)
 DevAddrType    : 0x00 (0) (ADDRTYPE_PUBLIC)
 DevAddr        : F0:F8:F2:CB:72:6D
 ConnHandle     : 0x0000 (0)
 ConnRole       : 0x08 (8) (
                  Central)
 ConnInterval   : 0x0050 (80)
 ConnLatency    : 0x0000 (0)
 ConnTimeout    : 0x07D0 (2000)
 ClockAccuracy  : 0x00 (0)
Dump(Rx):
0000:04 FF 14 05 06 00 00 6D 72 CB F2 F8 F0 00 00 08 .......mr.......
0010:50 00 00 00 D0 07 00                            P......
[4] : <Tx> - 11:38:35.070
-OpCode         : 0x2022 (HCI_LE_SetDataLength)
-Data Length    : 0x06 (6) byte(s)
 Handle         : 0x0000 (0)
 TxOctets       : 0x00FB (251)
 TxTime         : 0x0848 (2120)
Dump(Tx):
0000:01 22 20 06 00 00 FB 00 48 08                   ." .....H.
[5] : <Rx> - 11:38:35.101
-EventCode      : 0x000E (HCI_CommandCompleteEvent)
 Packets        : 0x01 (1)
 Handle         : 0x0000 (0)
Dump(Rx):
0000:04 0E 06 01 22 20 00 00 00                      ...." ...
[6] : <Info> - 11:38:35.210
Device Connected
Handle = 0x0000
Addr Type = 0x00 (ADDRTYPE_PUBLIC)
BDAddr = F0:F8:F2:CB:72:6D
[7] : <Rx> - 11:38:35.210
-EventCode      : 0x003E (HCI_LE_GenericReportEvent)
-Data Length    : 0x0B (11) bytes(s)
 LE Event Code  : 0x07 (7) (HCI_LE_DataLengthChangeEvent)
 Handle         : 0x0000 (0)
 MaxTxOctets    : 0x00FB (251)
 MaxTxTime      : 0x0848 (2120)
 MaxRxOctets    : 0x001B (27)
 MaxRxTime      : 0x0148 (328)
Dump(Rx):
0000:04 3E 0B 07 00 00 FB 00 48 08 1B 00 48 01       .>......H...H.
[8] : <Info> - 11:39:20.860
OAD - Update Connection Settings
[9] : <Info> - 11:39:20.875
Start OAD Download
[10] : <Info> - 11:39:20.875
StartReset Service Discovery
[11] : <Info> - 11:39:20.891
OAD Send UUID Discovery
[12] : <Tx> - 11:39:20.875
-OpCode         : 0x2016 (HCI_LEReadRemoteUsedFeatures)
-Data Length    : 0x02 (2) byte(s)
 Handle         : 0x0000 (0)
Dump(Tx):
0000:01 16 20 02 00 00                               .. ...
[13] : <Tx> - 11:39:20.907
-OpCode         : 0xFD86 (GATT_DiscPrimaryServiceByUUID)
-Data Length    : 0x12 (18) byte(s)
 Value          : 00:00:00:00:00:00:00:B0:00:40:51:04:D0:FF:00:F0
Dump(Tx):
0000:01 86 FD 12 00 00 00 00 00 00 00 00 00 B0 00 40 ...............@
0010:51 04 D0 FF 00 F0                               Q.....
[14] : <Rx> - 11:39:20.938
Dump(Rx):
0000:04 FF 06 7F 06 00 86 FD 00                      .........
[15] : <Info> - 11:39:21.110
OAD Send UUID Info Discovery
[16] : <Rx> - 11:39:21.110
-Data Length    : 0x0A (10) bytes(s)
 Event          : 0x0507 (1287) (ATT_FindByTypeValueRsp)
 PduLen         : 0x04 (4)
 Handle         : 1C:00
 Handle         : FF:FF
Dump(Rx):
0000:04 FF 0A 07 05 00 00 00 04 1C 00 FF FF          .............
[17] : <Rx> - 11:39:21.219
-Data Length    : 0x0C (12) bytes(s)
 LE Event Code  : 0x04 (4) (HCI_LE_ReadRemoteUsedFeaturesCompleteEvent)
 ConnectionId   : 0x0000 (0)
 Features       : 0x00000000000000FD (253) (
                  Encryption
                  Reject_Extended_Indication
                  Slave_Features_Exchange
                  Ping
                  Data_Packet_Length_Extension
                  Privacy
                  Extended_Scanner_Filter_Policies)
Dump(Rx):
0000:04 3E 0C 04 00 00 00 FD 00 00 00 00 00 00 00    .>.............
[18] : <Rx> - 11:39:21.313
 Status         : 0x1A (26) (bleProcedureComplete)
 PduLen         : 0x00 (0)
Dump(Rx):
0000:04 FF 06 07 05 1A 00 00 00                      .........
[19] : <Tx> - 11:39:21.313
-OpCode         : 0xFD84 (GATT_DiscAllCharDescs)
 StartHandle    : 0x001C (28)
 EndHandle      : 0xFFFF (65535)
Dump(Tx):
0000:01 84 FD 06 00 00 1C 00 FF FF                   ..........
[20] : <Rx> - 11:39:21.360
Dump(Rx):
0000:04 FF 06 7F 06 00 84 FD 00                      .........
[21] : <Rx> - 11:39:21.516
-Data Length    : 0x0F (15) bytes(s)
 Event          : 0x0505 (1285) (ATT_FindInfoRsp)
 PduLen         : 0x09 (9)
 Format         : 0x01 (1) (HANDLE_BT_UUID_TYPE__handles_and_16_bit_Bluetooth_UUIDs)
 Handle         : 001C
 Uuid           : 00:28
 Handle         : 001D
 Uuid           : 03:28
Dump(Rx):
0000:04 FF 0F 05 05 00 00 00 09 01 1C 00 00 28 1D 00 .............(..
0010:03 28                                           .(
[22] : <Rx> - 11:39:21.719
-Data Length    : 0x19 (25) bytes(s)
 PduLen         : 0x13 (19)
 Format         : 0x02 (2) (HANDLE_UUID_TYPE__handles_and_128_bit_UUIDs)
 Handle         : 001E
 Uuid           : 00:00:00:00:00:00:00:B0:00:40:51:04:D1:FF:00:F0
Dump(Rx):
0000:04 FF 19 05 05 00 00 00 13 02 1E 00 00 00 00 00 ................
0010:00 00 00 B0 00 40 51 04 D1 FF 00 F0             .....@Q.....
[23] : <Rx> - 11:39:21.922
 PduLen         : 0x05 (5)
 Handle         : 001F
 Uuid           : 01:29
Dump(Rx):
0000:04 FF 0B 05 05 00 00 00 05 01 1F 00 01 29       .............)
[24] : <Rx> - 11:39:22.109
 PduLen         : 0x00 (0)
Dump(Rx):
0000:04 FF 06 05 05 1A 00 00 00                      .........
[25] : <Info> - 11:39:22.109
OAD Invalidate Image On StartReset
[26] : <Tx> - 11:39:22.109
-OpCode         : 0xFE11 (GAP_UpdateLinkParamReq)
-Data Length    : 0x0A (10) byte(s)
 IntervalMin    : 0x0006 (6)
 IntervalMax    : 0x0006 (6)
 ConnTimeout    : 0x0032 (50)
Dump(Tx):
0000:01 11 FE 0A 00 00 06 00 06 00 00 00 32 00       ............2.
[27] : <Tx> - 11:39:22.125
-OpCode         : 0xFD96 (GATT_WriteLongCharValue)
-Data Length    : 0x07 (7) byte(s)
 Handle         : 0x001E (30)
 Offset         : 0x0000 (0)
 Value          : 01
Dump(Tx):
0000:01 96 FD 07 00 00 1E 00 00 00 01                ...........
[28] : <Rx> - 11:39:22.156
Dump(Rx):
0000:04 FF 06 7F 06 00 11 FE 00                      .........
[29] : <Rx> - 11:39:22.188
Dump(Rx):
0000:04 FF 06 7F 06 00 96 FD 00                      .........
[30] : <Info> - 11:39:22.516
Waiting For Device Reset
[31] : <Rx> - 11:39:22.516
 Event          : 0x0519 (1305) (ATT_ExecuteWriteRsp)
 PduLen         : 0x00 (0)
Dump(Rx):
0000:04 FF 06 19 05 00 00 00 00                      .........
[32] : <Rx> - 11:39:22.812
 Event          : 0x0607 (1543) (GAP_LinkParamUpdate)
 ConnInterval   : 0x0006 (6)
Dump(Rx):
0000:04 FF 0B 07 06 00 00 00 06 00 00 00 32 00       ............2.
[33] : <Info> - 11:39:23.422
Device Disconnected
Handle = 0x0000
[34] : <Rx> - 11:39:23.422
 Event          : 0x0606 (1542) (GAP_TerminateLink)
 Reason         : 0x08 (8) (SUPERVISION_TIMEOUT_TERM)
Dump(Rx):
0000:04 FF 06 06 06 00 00 00 08                      .........
[35] : <Info> - 11:39:37.528
Establish Connection
[36] : <Tx> - 11:39:37.528
Dump(Tx):
[37] : <Rx> - 11:39:37.559
Dump(Rx):
[38] : <Rx> - 11:39:37.606
                  Central)
Dump(Rx):
[39] : <Tx> - 11:39:37.606
 Handle         : 0x0000 (0)
Dump(Tx):
[40] : <Rx> - 11:39:37.653
 Packets        : 0x01 (1)
 Handle         : 0x0000 (0)
Dump(Rx):
[41] : <Info> - 11:39:38.215
OAD - Restore Connection Settings
[42] : <Error> - 11:39:38.215
OAD Download Not Successful
[43] : <Rx> - 11:39:38.215
 Reason         : 0x3E (62) (FAILED_TO_ESTABLISH)
Dump(Rx):
0000:04 FF 06 06 06 00 00 00 3E                      ........>
Arul Christopher
  • Hi Arul,
    I've forwarded this to one of our experts on OAD. He should get back to you in a few days.
    If the "Simple profile service" is included in the application, i see that the OAD is happening without any issues.
    Is it mandatory that we need to have "Simple profile service"?
    Arul Christopher
  • Hi Arul Christopher,
    The simple profile service is not mandatory. However, it quite strange that the connection event callback isn't firing without the simple profile on the device. Can you run a test with the RF observables enabled to see if any connection events are happening after the enable is set
    dev.ti.com/.../
    Actually the current code is setup to wait N number of connection events where N is the number of buffers that are currently in use by the stack at the time that the enable image. The reason for waiting is that BTool expects a response from the device after the enable command.
    However, from a device perspective, the response isn't strictly needed. You can trigger the reset immediately if needed.
