Other Parts Discussed in Thread: SEGGER, UNIFLASH
Hi Team,
My customer encountered some issue with the new board (CC26x2R)
It used to perform well but supposedly after some flash erase the only way to run the firmware is via debugger.
They turning on led at start of main and it indeed turned on when they run via code composer but it does not after power cycle.
They run release version with no breakpoints and no stops at start of main so imho it should be alright.
The steps they took prior to this behavior is:
Installing and working with J-link segger from ccs as plugin
Erasing flash and burning new image via Uniflsh utility (gave them warning about locked device??)
Did you familiar with such issue?
Shlomi
