I am imaging an application of indoor localization composed by:
- Several slave devices
- Several master devices AoA booster pack installed
- Several passive devices with AoA booster pack installed
I am supposing passive and master devices are installed along a building. For AoA, a master device for pairing is required to be reachable from a slave device. While moving, if connection with master is lost, that means master cannot receive any more slave messages, but other passives are still receiving data, do you think system can still work?
In this way, just an initial pairing is required, then the slave can move through rooms with several passives installed. What do you about it? As you understa, I want to solve navigation problem.
Thank you
Luca
