CC2640R2F: 2.4GHz Antenna
Part Number: CC2640R2F
Dear TI team,
I am developing Bluetooth communication by using CC2640R2F
I have some question
1. I am starting design Bluetooth board and specify size of BT board around 35mm X 50 mm.I saw small size PCB antenna (size 15 x 6) as this link (http://www.ti.com/lit/an/swra117d/swra117d.pdf)
If my target of communication range is more than 100 m, Can I use this antenna ?
2. Could you please explain the direction of antenna to make the best signal performance ?
Thank you
