Other Parts Discussed in Thread: CC2640R2F, CC2650, BLE-STACK
I have created a project using simple peripheral project in cc2640r2f. I want to port it to cc2650MODA. Please guide me on this. Which SDK should i have to use?
Thanks for your inquiry. I notified a colleague and he will reply as soon as possible.
Any specific reason why moving to a previous generation device? We have migration guides on the reverse order - i.e., from CC2650 to CC2640R2F, which may help you.
https://dev.ti.com/tirex/explore/node?node=AAafBKylj8ra01461K-lnQ__krol.2c__LATEST
The SDK for CC2650 is available at:
https://www.ti.com/tool/BLE-STACK
Rafael
Hi!
I you just have a simple_peripheral out-of-the-box for the CC2640R2, then you should know that the BLE-STACK that Rafael mentioned also has a simple_peripheral example. So, you just need to go ahead and install that new stack, and use that simple peripheral example instead.
However, if you have made changes and have developed an application based on the CC2640R2 simple_peripheral, you would then need to do a little bit of work, using our porting guides (mentioned by Rafael, too) backwards, but they should be helpful.
I hope this helps.
Luis
Similar topic thread of interest: e2e.ti.com/.../945870
Hi Desouza,
Thanks for your reply, we have a customized PCB for the device and we faced a problem with the antenna. We don't have time to spare for modifying our design. so we decided to go with CC2650MODA.
CC2650MODA has an integrated antenna as we know, so we are trying to port our code written using simple peripheral of CC2640R2F SDK into cc2650.
