Hi TI expert
For CC2652 simplelink_cc13x2_26x2_sdk_4_40_04_04, I am using Protocol stack RTLS slave code.
Could you tell me how to turn off the broadcast in this code?
Thomas
Hi Thomas,
Periodic advertising is used for connectionless-AoA. This functionality is enabled by default on rtls_slave example.
With that said you can disable periodic advertising on rtls_slave by removing the predefined symbol "USE_PERIODIC_ADV". To do so, in the CCS project, in Tools > Defines > rtls_slave_app.opt remove the line "-DUSE_PERIODIC_ADV".
I hope this will help,
Kind regards,
Hi Clement
Thank you for your replying.
I want to realize the function of connectionless AOA, but in order to save power, periodic is not allowed_ Adv works all the time, so we need to stop it and start peridic again after the movement_ Adv. How to modify the code ?
Thomas
Hi Thomas,
Did you manage to do what you wanted?
If yes, could you please close the thread (mark it as "Resolved")? Otherwise, please tell me how I can further help you. These are important to keep the forum easy to read for our customers.
Thanks and regards,
