Other Parts Discussed in Thread: CC2564MODA
I'm currently using msp432 with cc2564MODA.
I wonder if I can change MAC address(BD_ADDR) in spp demo sample code.
If possible, could anyone tell me how?
Hi Park,
The hcitool command mentioned above sends the appropriate HCI command from a linux system.
But when using MCU releases of TI Dual-mode Bluetooth stack (like MSP430, MSP432, TIVA, STM32 etc,) you can use the VS_Set_Bluetooth_Address API from the BTVS.c file to change the BD_ADDR of the CC256x.
As mentioned above, it is not possible to overwrite the existing BD_ADDR. If you want to change the default BD_ADDR, you will be required to call this API (which issues the corresponding HCI command) every-time the system goes through a power cycle.
You can save your custom BD_ADDR in the BD_ADDR_t structure and call the VS_Set_Bluetooth_Address API with this custom BD_ADDR right after successfully calling OpenStack(HCI_DriverInformation, BTPS_Initialization).
Hope this helps.
Vihang
