CC2640R2F: CC2640R2F 5XD, 4XS footprint driver
Part Number: CC2640R2F
Other Parts Discussed in Thread: BLE-STACK, CC2640
Dear all,
Customer and I don't find 5XD, 4XS footprint driver do as sdk 2.xxx did.
do we have a guide how customer porting from simple peripheral project when they are using 4x4 or 5x5 footprint CC2640R2F ?
Thanks.
  • Hi Michael,
    This involves choosing the correct define in your board file so 5XD or 4XS configurations are chosen.
    We have a section on this in the SDG: http://software-dl.ti.com/lprf/simplelink_cc2640r2_sdk/1.00.00.22/exports/docs/blestack/html/ble-stack/index.html#configuring-rf-front-ends-and-antennas-for-custom-hardware
    Otherwise, the code is all the same between 4x4 or 5x5, follow the porting guide for instructions on how to port to simple_peripheral: http://software-dl.ti.com/lprf/simplelink_cc2640r2_sdk/1.00.00.22/exports/docs/blestack/html/cc2640/ble-sdg/cc2640-to-cc2640r2.html#porting-guide-from-cc2640-to-cc2640r2
    Rebel
  • Rebel,
    Thanks for your suggestion, i am porting old sdk cc2650DK_5XD.c file.
    But meet below issue, UART and display driver is not include on SDK 3.0 CC2640R2_LAUNCHXL project.
    I suggest R&D guys can do fully device level software driver support(do as CC2640 SDK2.0 did), because it will be hard and depressed for a new user to hand on CC2640R2F.
    Thanks for your help.
    You can't just use the old file. I would recommend you to use the original R2 board file and take out the pins/drivers you don't have/need on 5x5 or 4x4. Then recompile the project. That should be the quickest way.
  • Christin,
    Thanks for your recommendation.
    But hope BU can support the driver both with launchpad and CC2640DK different footprint as sdk2.x did.
    Launchpad can't veriy 5x5 and 4x4 application, many customer are doing development on CC2640DK with replaced CC2640R2F chipset on it.
  • Hi Michael,
    Thanks for the feedback, we will take this into consideration.
    For your convenience, you can use the attached files(for R2 5x5em, hacked version) to replace the board files with BLE core sdk(found here : C:\ti\simplelink_cc2640r2_sdk_1_00_00_22\examples\rtos\CC2640R2_LAUNCHXL\blestack\boards\CC2640R2_LAUNCHXL).
    On top of that you still need to change the content in ble_user_config.h
    from
    #if defined( CC2650EM_7ID )
      #define RF_FE_MODE_AND_BIAS           ( RF_FE_DIFFERENTIAL |                 \
                                              RF_FE_INT_BIAS)
    to
                                              RF_FE_EXT_BIAS)
    4478.Board.h
     * Copyright (c) 2016, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ====================== CC2640R2_LAUNCHXL.c ===================================
     *  This file is responsible for setting up the board specific items for the
     *  CC2640R2_LAUNCHXL board.
    #include <xdc/std.h>
    #include <xdc/runtime/System.h>
    #include <ti/sysbios/family/arm/m3/Hwi.h>
    #include <ti/drivers/Power.h>
    #include <ti/drivers/power/PowerCC26XX.h>
    #include <ti/devices/cc26x0r2/driverlib/ioc.h>
    #include <ti/devices/cc26x0r2/driverlib/udma.h>
    #include <ti/devices/cc26x0r2/inc/hw_ints.h>
    #include <ti/devices/cc26x0r2/inc/hw_memmap.h>
    #include "CC2640R2_LAUNCHXL.h"
     *  =============================== Crypto ===============================
    #include <ti/drivers/crypto/CryptoCC26XX.h>
    CryptoCC26XX_Object cryptoCC26XXObjects[CC2650DK_5XD_CRYPTOCOUNT];
    const CryptoCC26XX_HWAttrs cryptoCC26XXHWAttrs[CC2650DK_5XD_CRYPTOCOUNT] = {
            .baseAddr    = CRYPTO_BASE,
            .powerMngrId = PowerCC26XX_PERIPH_CRYPTO,
            .intNum      = INT_CRYPTO_RESULT_AVAIL_IRQ,
            .intPriority = ~0,
    const CryptoCC26XX_Config CryptoCC26XX_config[CC2650DK_5XD_CRYPTOCOUNT] = {
            .object  = &cryptoCC26XXObjects[CC2650DK_5XD_CRYPTO0],
            .hwAttrs = &cryptoCC26XXHWAttrs[CC2650DK_5XD_CRYPTO0]
     *  =============================== Display ===============================
    #include <ti/display/Display.h>
    #include <ti/display/DisplayUart.h>
    #ifndef CC2650DK_5XD_DISPLAY_UART_STRBUF_SIZE
    #define CC2650DK_5XD_DISPLAY_UART_STRBUF_SIZE    128
    #endif
    DisplayUart_Object        displayUartObject;
    static char uartStringBuf[CC2650DK_5XD_DISPLAY_UART_STRBUF_SIZE];
    const DisplayUart_HWAttrs displayUartHWAttrs = {
        .uartIdx      = CC2650DK_5XD_UART0,
        .baudRate     = 115200,
        .mutexTimeout = (unsigned int)(-1),
        .strBuf       = uartStringBuf,
        .strBufLen    = CC2650DK_5XD_DISPLAY_UART_STRBUF_SIZE,
    #ifndef BOARD_DISPLAY_USE_UART
    #define BOARD_DISPLAY_USE_UART 1
    #endif
    #ifndef BOARD_DISPLAY_USE_UART_ANSI
    #define BOARD_DISPLAY_USE_UART_ANSI 0
    #endif
    #ifndef BOARD_DISPLAY_USE_LCD
    #define BOARD_DISPLAY_USE_LCD 0
    #endif
     * This #if/#else is needed to workaround a problem with the
     * IAR compiler. The IAR compiler doesn't like the empty array
     * initialization. (IAR Error[Pe1345])
    #if (BOARD_DISPLAY_USE_UART)
    const Display_Config Display_config[] = {
    #  if (BOARD_DISPLAY_USE_UART_ANSI)
            .fxnTablePtr = &DisplayUartAnsi_fxnTable,
    #  else /* Default to minimal UART with no cursor placement */
            .fxnTablePtr = &DisplayUartMin_fxnTable,
    #  endif
            .object      = &displayUartObject,
            .hwAttrs     = &displayUartHWAttrs,
    #endif
    const uint_least8_t Display_count = sizeof(Display_config) / sizeof(Display_Config);
    #else
    const Display_Config *Display_config = NULL;
    const uint_least8_t Display_count = 0;
    #endif /* (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD) */
     *  =============================== GPIO ===============================
    #include <ti/drivers/GPIO.h>
    #include <ti/drivers/gpio/GPIOCC26XX.h>
     * Array of Pin configurations
     * NOTE: The order of the pin configurations must coincide with what was
     *       defined in CC2640R2_LAUNCHXL.h
     * NOTE: Pins not used for interrupts should be placed at the end of the
     *       array. Callback entries can be omitted from callbacks array to
     *       reduce memory usage.
    GPIO_PinConfig gpioPinConfigs[] = {
        /* Input pins */
        GPIOCC26XX_DIO_06 | GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_RISING,  /* Button 0 */
        GPIOCC26XX_DIO_04 | GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_RISING,  /* Button 1 */
        /* Output pins */
        GPIOCC26XX_DIO_03 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,  /* LED4 */
        GPIOCC26XX_DIO_02 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,  /* LED3 */
     * Array of callback function pointers
     *       defined in CC2640R2_LAUNCH.h
     * NOTE: Pins not used for interrupts can be omitted from callbacks array to
     *       reduce memory usage (if placed at end of gpioPinConfigs array).
    GPIO_CallbackFxn gpioCallbackFunctions[] = {
        NULL,  /* Button 0 */
        NULL,  /* Button 1 */
    const GPIOCC26XX_Config GPIOCC26XX_config = {
        .pinConfigs         = (GPIO_PinConfig *)gpioPinConfigs,
        .callbacks          = (GPIO_CallbackFxn *)gpioCallbackFunctions,
        .numberOfPinConfigs = CC2650DK_5XD_GPIOCOUNT,
        .numberOfCallbacks  = sizeof(gpioCallbackFunctions)/sizeof(GPIO_CallbackFxn),
        .intPriority        = (~0)
     *  =============================== GPTimer ===============================
     *  Remove unused entries to reduce flash usage both in Board.c and Board.h
    #include <ti/drivers/timer/GPTimerCC26XX.h>
    GPTimerCC26XX_Object gptimerCC26XXObjects[CC2650DK_5XD_GPTIMERCOUNT];
    const GPTimerCC26XX_HWAttrs gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMERPARTSCOUNT] = {
        { .baseAddr = GPT0_BASE, .intNum = INT_GPT0A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0A, },
        { .baseAddr = GPT0_BASE, .intNum = INT_GPT0B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0B, },
        { .baseAddr = GPT1_BASE, .intNum = INT_GPT1A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1A, },
        { .baseAddr = GPT1_BASE, .intNum = INT_GPT1B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1B, },
        { .baseAddr = GPT2_BASE, .intNum = INT_GPT2A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2A, },
        { .baseAddr = GPT2_BASE, .intNum = INT_GPT2B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2B, },
        { .baseAddr = GPT3_BASE, .intNum = INT_GPT3A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3A, },
        { .baseAddr = GPT3_BASE, .intNum = INT_GPT3B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3B, },
    const GPTimerCC26XX_Config GPTimerCC26XX_config[CC2650DK_5XD_GPTIMERPARTSCOUNT] = {
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER0], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER0A], GPT_A },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER0], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER0B], GPT_B },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER1], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER1A], GPT_A },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER1], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER1B], GPT_B },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER2], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER2A], GPT_A },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER2], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER2B], GPT_B },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER3], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER3A], GPT_A },
        { &gptimerCC26XXObjects[CC2650DK_5XD_GPTIMER3], &gptimerCC26xxHWAttrs[CC2650DK_5XD_GPTIMER3B], GPT_B },
     *  =============================== PIN ===============================
    #include <ti/drivers/PIN.h>
    #include <ti/drivers/pin/PINCC26XX.h>
    const PIN_Config BoardGpioInitTable[] = {
        CC2650DK_5XD_PIN_LED3 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,  /* LED initially off */
        CC2650DK_5XD_PIN_LED4 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,  /* LED initially off */
        CC2650DK_5XD_KEY_SELECT | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,                   /* Button is active low */
        CC2650DK_5XD_KEY_UP | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,                       /* Button is active low */
        CC2650DK_5XD_KEY_DOWN | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,                     /* Button is active low */
        CC2650DK_5XD_KEY_LEFT | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,                     /* Button is active low */
        CC2650DK_5XD_KEY_RIGHT | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,                    /* Button is active low  */
        CC2650DK_5XD_3V3_EN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL,                 /* 3V3 domain off initially */
        CC2650DK_5XD_UART_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL,               /* UART TX pin at inactive level */
        PIN_TERMINATE
    const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = {
        .intPriority = ~0,
        .swiPriority = 0
     *  =============================== Power ===============================
    const PowerCC26XX_Config PowerCC26XX_config = {
        .policyInitFxn      = NULL,
        .policyFxn          = &PowerCC26XX_standbyPolicy,
        .calibrateFxn       = &PowerCC26XX_calibrate,
        .enablePolicy       = TRUE,
    #ifdef USE_RCOSC
        .calibrateRCOSC_LF  = TRUE,
    #else
        .calibrateRCOSC_LF  = FALSE,
    #endif
        .calibrateRCOSC_HF  = TRUE,
     *  =============================== PWM ===============================
    #include <ti/drivers/PWM.h>
    #include <ti/drivers/pwm/PWMTimerCC26XX.h>
    PWMTimerCC26XX_Object pwmtimerCC26xxObjects[CC2650DK_5XD_PWMCOUNT];
    const PWMTimerCC26XX_HwAttrs pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWMCOUNT] = {
        { .pwmPin = CC2650DK_5XD_PWMPIN0, .gpTimerUnit = CC2650DK_5XD_GPTIMER0A },
        { .pwmPin = CC2650DK_5XD_PWMPIN1, .gpTimerUnit = CC2650DK_5XD_GPTIMER0B },
        { .pwmPin = CC2650DK_5XD_PWMPIN2, .gpTimerUnit = CC2650DK_5XD_GPTIMER1A },
        { .pwmPin = CC2650DK_5XD_PWMPIN3, .gpTimerUnit = CC2650DK_5XD_GPTIMER1B },
        { .pwmPin = CC2650DK_5XD_PWMPIN4, .gpTimerUnit = CC2650DK_5XD_GPTIMER2A },
        { .pwmPin = CC2650DK_5XD_PWMPIN5, .gpTimerUnit = CC2650DK_5XD_GPTIMER2B },
        { .pwmPin = CC2650DK_5XD_PWMPIN6, .gpTimerUnit = CC2650DK_5XD_GPTIMER3A },
        { .pwmPin = CC2650DK_5XD_PWMPIN7, .gpTimerUnit = CC2650DK_5XD_GPTIMER3B },
    const PWM_Config PWM_config[CC2650DK_5XD_PWMCOUNT] = {
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM0], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM0] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM1], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM1] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM2], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM2] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM3], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM3] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM4], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM4] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM5], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM5] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM6], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM6] },
        { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC2650DK_5XD_PWM7], &pwmtimerCC26xxHWAttrs[CC2650DK_5XD_PWM7] },
    const uint_least8_t PWM_count = CC2650DK_5XD_PWMCOUNT;
     *  =============================== RF Driver ===============================
    #include <ti/drivers/rf/RF.h>
    const RFCC26XX_HWAttrs RFCC26XX_hwAttrs = {
        .hwiCpe0Priority = ~0,
        .hwiHwPriority   = ~0,
        .swiCpe0Priority =  5,
        .swiHwPriority   =  5,
     *  =============================== SPI DMA ===============================
    #include <ti/drivers/SPI.h>
    #include <ti/drivers/spi/SPICC26XXDMA.h>
    SPICC26XXDMA_Object spiCC26XXDMAObjects[CC2650DK_5XD_SPICOUNT];
    const SPICC26XXDMA_HWAttrsV1 spiCC26XXDMAHWAttrs[CC2650DK_5XD_SPICOUNT] = {
            .baseAddr           = SSI0_BASE,
            .intNum             = INT_SSI0_COMB,
            .intPriority        = ~0,
            .swiPriority        = 0,
            .powerMngrId        = PowerCC26XX_PERIPH_SSI0,
            .defaultTxBufValue  = 0,
            .rxChannelBitMask   = 1<<UDMA_CHAN_SSI0_RX,
            .txChannelBitMask   = 1<<UDMA_CHAN_SSI0_TX,
            .mosiPin            = CC2650DK_5XD_SPI0_MOSI,
            .misoPin            = CC2650DK_5XD_SPI0_MISO,
            .clkPin             = CC2650DK_5XD_SPI0_CLK,
            .csnPin             = CC2650DK_5XD_SPI0_CSN
    const SPI_Config SPI_config[CC2650DK_5XD_SPICOUNT] = {
             .fxnTablePtr = &SPICC26XXDMA_fxnTable,
             .object      = &spiCC26XXDMAObjects[CC2650DK_5XD_SPI0],
             .hwAttrs     = &spiCC26XXDMAHWAttrs[CC2650DK_5XD_SPI0]
    const uint_least8_t SPI_count = CC2650DK_5XD_SPICOUNT;
     *  =============================== UART ===============================
    #include <ti/drivers/UART.h>
    #include <ti/drivers/uart/UARTCC26XX.h>
    UARTCC26XX_Object uartCC26XXObjects[CC2650DK_5XD_UARTCOUNT];
    const UARTCC26XX_HWAttrsV2 uartCC26XXHWAttrs[CC2650DK_5XD_UARTCOUNT] = {
            .baseAddr       = UART0_BASE,
            .powerMngrId    = PowerCC26XX_PERIPH_UART0,
            .intNum         = INT_UART0_COMB,
            .intPriority    = ~0,
            .swiPriority    = 0,
            .txPin          = CC2650DK_5XD_UART_TX,
            .rxPin          = CC2650DK_5XD_UART_RX,
            .ctsPin         = PIN_UNASSIGNED,
            .rtsPin         = PIN_UNASSIGNED
    const UART_Config UART_config[CC2650DK_5XD_UARTCOUNT] = {
            .fxnTablePtr = &UARTCC26XX_fxnTable,
            .object      = &uartCC26XXObjects[CC2650DK_5XD_UART0],
            .hwAttrs     = &uartCC26XXHWAttrs[CC2650DK_5XD_UART0]
    const uint_least8_t UART_count = CC2650DK_5XD_UARTCOUNT;
     *  =============================== UDMA ===============================
    #include <ti/drivers/dma/UDMACC26XX.h>
    UDMACC26XX_Object udmaObjects[CC2650DK_5XD_UDMACOUNT];
    const UDMACC26XX_HWAttrs udmaHWAttrs[CC2650DK_5XD_UDMACOUNT] = {
            .baseAddr    = UDMA0_BASE,
            .powerMngrId = PowerCC26XX_PERIPH_UDMA,
            .intNum      = INT_DMA_ERR,
            .intPriority = ~0
    const UDMACC26XX_Config UDMACC26XX_config[CC2650DK_5XD_UDMACOUNT] = {
             .object  = &udmaObjects[CC2650DK_5XD_UDMA0],
             .hwAttrs = &udmaHWAttrs[CC2650DK_5XD_UDMA0]
     *  =============================== Watchdog ===============================
    #include <ti/drivers/Watchdog.h>
    #include <ti/drivers/watchdog/WatchdogCC26XX.h>
    WatchdogCC26XX_Object watchdogCC26XXObjects[CC2650DK_5XD_WATCHDOGCOUNT];
    const WatchdogCC26XX_HWAttrs watchdogCC26XXHWAttrs[CC2650DK_5XD_WATCHDOGCOUNT] = {
            .baseAddr    = WDT_BASE,
            .reloadValue = 1000 /* Reload value in milliseconds */
    const Watchdog_Config Watchdog_config[CC2650DK_5XD_WATCHDOGCOUNT] = {
            .fxnTablePtr = &WatchdogCC26XX_fxnTable,
            .object      = &watchdogCC26XXObjects[CC2650DK_5XD_WATCHDOG0],
            .hwAttrs     = &watchdogCC26XXHWAttrs[CC2650DK_5XD_WATCHDOG0]
    const uint_least8_t Watchdog_count = CC2650DK_5XD_WATCHDOGCOUNT;
     *  ========================= TRNG begin ====================================
    #include <TRNGCC26XX.h>
    /* TRNG objects */
    TRNGCC26XX_Object trngCC26XXObjects[CC2640R2_LAUNCHXL_TRNGCOUNT];
    /* TRNG configuration structure, describing which pins are to be used */
    const TRNGCC26XX_HWAttrs TRNGCC26XXHWAttrs[CC2640R2_LAUNCHXL_TRNGCOUNT] = {
            .powerMngrId    = PowerCC26XX_PERIPH_TRNG,
    /* TRNG configuration structure */
    const TRNGCC26XX_Config TRNGCC26XX_config[] = {
             .object  = &trngCC26XXObjects[0],
             .hwAttrs = &TRNGCC26XXHWAttrs[0]
        {NULL, NULL}
     *  ========================= TRNG end ====================================
     *  ======== CC2640R2_LAUNCHXL_initGeneral ========
    void CC2640R2_LAUNCHXL_initGeneral(void)
        Power_init();
        if (PIN_init(BoardGpioInitTable) != PIN_SUCCESS) {
            System_abort("Error with PIN_init\n");
    CC2640R2_LAUNCHXL.h
  • Christin,
    I do follow your suggestion and can run the simple_peripheral on 5x5.
    Currently I know why sdk3.0 cc2640r2lp_simple_peripheral.hex under sdk hex folder can't be run on CC2650EM-5XD, because Launchpad is using internal BIAS, but CC2650EM-5XD using external BIAS? Am I correct?
