CC2650STK: LCD firmware problem. Red led lit continuously
Part Number: CC2650STK
Hello everyone
I want to use Watch Devpack with my CC2650stk sensortag. My sensortag is PCB version 1.3. I have debug devpack. I tried several different scenarios for downloading LCD firmware to sensortag but can not make it work. So here is my scenarios:
1 flashing LCD firmware version 1.4x to sensortag with debug devpack through SmartRF Flash Programmer v2 and BLE Device Monitor softwares
2 flashing LCD firmware version 1.3x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
3 flashing Sensortag All firmware version 1.4x and after that flashing LCD firmware version 1.4x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
4 flashing Sensortag All firmware version 1.3x and after that flashing LCD firmware version 1.3x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
5 flashing Sensortag All firmware version 1.4x and after that flashing LCD firmware version 1.3x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
6 flashing Sensortag All firmware version 1.3x and after that flashing LCD firmware version 1.4x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
7 flashing Sensortag All firmware version 1.2x and after that flashing LCD firmware version 1.4x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
8 flashing Sensortag All firmware version 1.2x and after that flashing LCD firmware version 1.3x to sensortag with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares
9 flashing Sensortag All firmware version 1.2x with debug devpack through both SmartRF Flash Programmer v2 and BLE Device Monitor softwares and after that flashing LCD firmware version 1.2x to sensortag with OAD
All firmwares I said above are can be found in BLE Device Monitor Software folders
10 flashing sensortag firmware provided in BLE SDK with debug devpack and repeated all above process
11 doing forced mass erase function provided in SmartRF Flash Programmer v2 and repeated all above process
All process above I completely removed debug devpack after flashing done and mounted watch devpack
Also I have 23 all new cr2032 battery. While flashing process I know mounted battery is full.
All process above is same result. Red led lit flashing continuously and not advertising.
12 I installed CCS, BLE SDK, ti rtos, arm compiler and followed sensortag user guide. I debugged sensortag LCD projects with debug devpack (I can not found just Flash button in CCS. I must debug firmware. But I pressed debug button, after flashing done pressed run button and after that terminate button.). All three project (BIM extflash, sensortag LCD stack, sensortag LCD app) builded without error, just a couple warnings. But this time sensortag blink green led couple of times (I think it's self check or something like) and LEDs are gone. No advertising and watch devpack not showing anything while mounted.
Can anyone help me?
Note: Sorry for horrible grammar (English is not my native language) and too many repeated sentences. I'm not professional at this job. But I want to say I tried everything I can.
Edit: sensortag firmware all v1.4x, 1.3x and 1.2x hex files provided in BLE Device Monitor software folders works well. I'm using windows 10 machine and android 7.1 phone
Kind regards
