Other Parts Discussed in Thread: CC2420, CC2650
I am using the CC2640 for a localization project, in which I need to have an accurate idea of the modulation/demodulation process; since I am interfacing it with BLE transceivers implemented in SDR/FPGAs and I would like to clarify some areas.
My question is mostly theoretical.
As the CC2640 uses GFSK, and this modulation has different BER vs. EB/N0 curves depending on the demodulation principle, I would like to know if the CC2640 can be considered as a coherent receiver (accurate frequency and phase recovery) or non-coherent (coarse frequency adjustment).
Is there some mechanism for frequency offset compensation, or the devices just "works fine" as long as the transmitter stays within the ppm tolerance specified by the BLE standard?
Thank you,
Antonio
