Part Number: LAUNCHXL-CC2640R2
Other Parts Discussed in Thread: SIMPLELINK-CC2640R2-SDK
According to
, it mentions
- For RTLS Master and RTLS Slave projects, the configuration
-DRTLS_LOCATIONING_AOAinbuild_config.optfile that is located in the project directory, controls the build. - To build AoA, keep the option uncommented:
However, if we only uncommented "-DRTLS_LOCATIONING_AOA" in build_config.opt file, it will shows the following error and I need to put RTLS_LOCATIONING_AOA in predefined symbols to make it work. Can you confirm this is correct?
Also, I see the AOA results are erratic after I setup and run AOA. I only put rtls_slave 1 meter away from rtls_passive without moving and see the following results.
I also attach the event log for your reference.
What am I doing wrong?
By the way, do you have detail documents to explain what's the working theory between rtls_master, rtls_passive, and rtls_slave?
