The upgrade time is very slow 360 seconds, the upgrade mode is notify the safe mode upgrade, notify returns the number of blocks, the android device sends the block of this number
If the android device does not use the safe mode to consecutive send blocks regardless of the notify and set the delay of 10 ~ 60 milliseconds will not be upgraded successfully, I found the notify to check the 0th block each time by checking the log, so How to solve? Also, when the service was found, the connection control service uuid=f000ccc0-0451-4000-b000-000000000000 could not be found, so the connection interval could not be set. Does this affect the quick upgrade?
