Part Number: BOOSTXL-AOA
I observed the I and Q sample waveform on single antenna.
Why peak value of I and Q sample vary for different packet on a single antenna?
Here, i got 47 samples of one packet and took 3 packets and then plotted I waveform. Why peak value of I is varying?
If packets are sent by same slave to same slave and that too on one antenna, then ideally magnitude of Signal should be constant, but it is varying as shown below:
Magnitude of three packets on same antenna is plotted below:
Akansha
