Other Parts Discussed in Thread: CC2652R
Ive implemented a working OAD solution using the simple peripheral project as a base. I actually ran into memory problems awhile ago. the easiest solution I had was to remove <display.h> from the project files. This gave me more than enough memory.
However, as noted in the referenced issue, there is a bug in the SDK for service changed. And implementing the fix fails to build because of not enough memory.
Does anyone have any ideas where I can strip down the code base to free more memory?
I would change chips or add off chip memory but, for this product its too late to make any major changes.
Thanks in advance for any suggestions.
